[GRASS-SVN] r32084 - in grass/trunk: . include/Make lib lib/db lib/display lib/g3d lib/gmath lib/gpde lib/imagery lib/init lib/segment lib/vector lib/vector/dglib
Sat Jul 12 13:19:43 EDT 2008
Author: martinl
Date: 2008-07-12 13:19:42 -0400 (Sat, 12 Jul 2008)
New Revision: 32084
   grass/trunk/Makefile
   grass/trunk/README
   grass/trunk/include/Make/Doxyfile_arch_html
   grass/trunk/lib/db/dbmilib.dox
   grass/trunk/lib/display/displaylib.dox
   grass/trunk/lib/g3d/g3dlib.dox
   grass/trunk/lib/gmath/gmathlib.dox
   grass/trunk/lib/gpde/gpdelib.dox
   grass/trunk/lib/grasslib.dox
   grass/trunk/lib/imagery/imagerylib.dox
   grass/trunk/lib/init/README
   grass/trunk/lib/init/init.bat
   grass/trunk/lib/segment/segmentlib.dox
   grass/trunk/lib/vector/dglib/dglib.dox
   grass/trunk/lib/vector/vectorlib.dox
Doxygen cleanup: changed references from old itc.it web page/mailing lists to osgeo.org ones;
Removed unused <title> tags;
Doxygen now includes images in HTML from current folder.
[merged from devbr6, r32082, 32083]
Modified: grass/trunk/Makefile
--- grass/trunk/Makefile	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/Makefile	2008-07-12 17:19:42 UTC (rev 32084)
@@ -399,6 +399,21 @@
 	(cd swig/; $(MAKE) cleandocs ; $(MAKE) pdfdocs)
 	@echo "Written PDF docs in: lib/db/latex/, lib/g3d/latex/, lib/gis/latex/, lib/gmath/latex/ lib/gpde/latex/ lib/ogsf/latex/, lib/proj//latex/, lib/segment/latex/, lib/vector/latex/ lib/vector/dglib/latex/ rfc/latex/ swig/latex/"
+cleandocs:
+	(cd lib/db/ ; $(MAKE) cleandocs)
+	(cd lib/g3d/ ; $(MAKE) cleandocs)
+	(cd lib/gis/ ; $(MAKE) cleandocs)
+	(cd lib/gmath/ ; $(MAKE) cleandocs)
+	(cd lib/gpde/ ; $(MAKE) cleandocs)
+	(cd lib/ogsf/ ; $(MAKE) cleandocs)
+	(cd lib/proj/ ; $(MAKE) cleandocs)
+	(cd lib/segment/; $(MAKE) cleandocs)
+	(cd lib/vector/ ; $(MAKE) cleandocs)
+	(cd lib/vector/dglib/ ; $(MAKE) cleandocs)
+	(cd lib/ ; $(MAKE) cleandocs)
+	(cd rfc/ ; $(MAKE) cleandocs)
+	(cd swig/; $(MAKE) cleandocs)
 html2pdfdoc:
 	@ echo "Light PDF document from modules' HTML documentation"
 	@ # http://www.htmldoc.org
Modified: grass/trunk/README
--- grass/trunk/README	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/README	2008-07-12 17:19:42 UTC (rev 32084)
@@ -33,7 +33,9 @@
 To build the GRASS programmer's documentation, run
    make htmldocs
-here. This takes quite some time. The result is in doxygenhtml/index.html
+or to generate documentation as single html file (recommended for simple reading)
+   make htmldocs-single
+here. This takes quite some time. The result is in lib/html/index.html
 which refers to further document repositories in
    lib/vector/html/index.html
    lib/db/html/index.html
Modified: grass/trunk/include/Make/Doxyfile_arch_html
--- grass/trunk/include/Make/Doxyfile_arch_html	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/include/Make/Doxyfile_arch_html	2008-07-12 17:19:42 UTC (rev 32084)
@@ -485,7 +485,7 @@
 # directories that contain image that are included in the documentation (see
 # the \image command).
-IMAGE_PATH             =
+IMAGE_PATH             = .
 # The INPUT_FILTER tag can be used to specify a program that doxygen should
 # invoke to filter for each input file. Doxygen will invoke the filter program
Modified: grass/trunk/lib/db/dbmilib.dox
--- grass/trunk/lib/db/dbmilib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/db/dbmilib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -595,7 +595,7 @@
 \section contacts Contacts
- GRASS Development Team: http://grass.itc.it (preferably developers mailing list)
+ GRASS Development Team: http://grass.osgeo.org (preferably developers mailing list)
 \section references References
Modified: grass/trunk/lib/display/displaylib.dox
--- grass/trunk/lib/display/displaylib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/display/displaylib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -1,7 +1,5 @@
 /*! \page displaylib GRASS Display Library
-<title>GRASS Display Library</title>
 \section displayintro Display Library
 <P>
Modified: grass/trunk/lib/g3d/g3dlib.dox
--- grass/trunk/lib/g3d/g3dlib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/g3d/g3dlib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -2,7 +2,6 @@
 <!-- doxygenized from "GRASS 5 Programmer's Manual"
      by M. Neteler 5/2004, 8/2005
-<title>GRASS Grid3D raster volume Library</title>
 \section g3dintro Grid3D raster volume Library
Modified: grass/trunk/lib/gmath/gmathlib.dox
--- grass/trunk/lib/gmath/gmathlib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/gmath/gmathlib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -2,7 +2,6 @@
      by M. Neteler 8/2005
-<title>GRASS Numerical math interface</title>
 \section gmathintro Numerical math interface with optional support of LAPACK/BLAS
Modified: grass/trunk/lib/gpde/gpdelib.dox
--- grass/trunk/lib/gpde/gpdelib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/gpde/gpdelib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -223,7 +223,7 @@
 <P>
 <b>Example implementation:</b><br>
-The GRASS module <a href="http://grass.itc.it/grass63/manuals/html63_user/r.gwflow.html">r.gwflow</a>
+The GRASS module <a href="http://grass.osgeo.org/grass63/manuals/html63_user/r.gwflow.html">r.gwflow</a>
 implements numerical calculation program for transient,
 confined and unconfined groundwater flow in two dimensions.
Modified: grass/trunk/lib/grasslib.dox
--- grass/trunk/lib/grasslib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/grasslib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -104,7 +104,7 @@
 <h3>Interfaces</h3>
 <ul>
-<li> GRASS SWIG interface <a href=../../swig/html/>see here</a>.
+<li> GRASS SWIG interface <a href="../../swig/html/index.html">see here</a>.
 </ul>
 <h3>File structure of GRASS Location</h3>
@@ -155,6 +155,6 @@
   storage in database (DBMS).</li>
 </ul>
-<img src="http://grass.osgeo.org/images/loc_struct.png" alt="Diagram of GRASS file structure">
+\image html "loc_struct.png" "Diagram of GRASS file structure"
Modified: grass/trunk/lib/imagery/imagerylib.dox
--- grass/trunk/lib/imagery/imagerylib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/imagery/imagerylib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -2,7 +2,6 @@
      by M. Neteler 2/2004
-<title>GRASS Imagery Library</title>
 \section imageryintro Introduction to Imagery Library
Modified: grass/trunk/lib/init/README
--- grass/trunk/lib/init/README	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/init/README	2008-07-12 17:19:42 UTC (rev 32084)
@@ -78,5 +78,5 @@
 			# GISDBASE/loc2-1/map1-1 location
-  Any suggestionss to <grass-dev at grass.itc.it>
+  Any suggestionss to <grass-dev at lists.osgeo.org>
Modified: grass/trunk/lib/init/init.bat
--- grass/trunk/lib/init/init.bat	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/init/init.bat	2008-07-12 17:19:42 UTC (rev 32084)
@@ -118,7 +118,7 @@
 type "%WINGISBASE%\etc\welcome"
 "%WINGISBASE%\etc\echo" ""
-"%WINGISBASE%\etc\echo" "GRASS homepage:                          http://grass.itc.it/"
+"%WINGISBASE%\etc\echo" "GRASS homepage:                          http://grass.osgeo.org/"
 "%WINGISBASE%\etc\echo" "This version running thru:               Windows Command Shell (cmd.exe)"
 "%WINGISBASE%\etc\echo" "When ready to quit enter:                exit"
 "%WINGISBASE%\etc\echo" "Help is available with the command:      g.manual -i"
Modified: grass/trunk/lib/segment/segmentlib.dox
--- grass/trunk/lib/segment/segmentlib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/segment/segmentlib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -2,7 +2,6 @@
-<title>GRASS Segment Library</title>
 \section segmentintro Segment Library
Modified: grass/trunk/lib/vector/dglib/dglib.dox
--- grass/trunk/lib/vector/dglib/dglib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/vector/dglib/dglib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -2,7 +2,7 @@
 by GRASS Development Team
-http://grass.itc.it/dglib/
+http://grass.osgeo.org/dglib/
 \section intro Introduction
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox	2008-07-12 14:39:09 UTC (rev 32083)
+++ grass/trunk/lib/vector/vectorlib.dox	2008-07-12 17:19:42 UTC (rev 32084)
@@ -2,7 +2,7 @@
-http://www.grass-gis.org
 <h2>Table of contents</h2>
@@ -810,7 +810,7 @@
 \section grassdglib DGLib (Directed Graph Library)
 The Directed Graph Library or DGLib (Micarelli 2002, \ref dglib ,
-http://grass.itc.it/dglib/) provides functionality for vector network
+http://grass.osgeo.org/dglib/) provides functionality for vector network
 analysis. This library released under GPL is hosted by the GRASS
 project (within the GRASS source code). As a stand-alone library it
 may also be used by other software projects.
