[GRASS-SVN] r32091 - in grass/trunk: gui/wxpython/vdigit
lib/vector/vedit
svn_grass at osgeo.org
Mon Jul 14 05:30:25 EDT 2008
Author: martinl
Date: 2008-07-14 05:30:24 -0400 (Mon, 14 Jul 2008)
New Revision: 32091
grass/trunk/gui/wxpython/vdigit/line.cpp
grass/trunk/lib/vector/vedit/snap.c
veditlib: bugfix - snapping lines works now
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-07-14 07:41:51 UTC (rev 32090)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-07-14 09:30:24 UTC (rev 32091)
@@ -113,7 +113,7 @@
- if (snap != NO_SNAP) { /* apply snapping (node or vertex) */
+ if (snap != NO_SNAP && (type & GV_LINES)) { /* apply snapping (node or vertex) */
Vedit_snap_line(display->mapInfo, BgMap, nbgmaps,
-1, Points,
threshold, (snap == SNAP) ? 0 : 1);
Modified: grass/trunk/lib/vector/vedit/snap.c
--- grass/trunk/lib/vector/vedit/snap.c 2008-07-14 07:41:51 UTC (rev 32090)
+++ grass/trunk/lib/vector/vedit/snap.c 2008-07-14 09:30:24 UTC (rev 32091)
@@ -106,7 +106,7 @@
int line, struct line_pnts* Points,
double thresh, int to_vertex)
- int i, type, npoints, node, rewrite;
+ int i, npoints, node, rewrite;
double *x, *y, *z;
struct line_cats *Cats;
@@ -146,14 +146,14 @@
} /* for each line vertex */
/* close boundaries or lines */
- if (!rewrite && (type & GV_LINES) &&
+ if (!rewrite &&
Vect_points_distance(x[0], y[0], z[0],
x[npoints-1], y[npoints-1], z[npoints-1],
WITHOUT_Z) <= thresh) {
x[npoints-1] = x[0];
y[npoints-1] = y[0];
z[npoints-1] = z[0];
rewrite = 1;
@@ -193,9 +193,11 @@
for(i = 0; i < List -> n_values; i++) {
line = List -> value[i];
type = Vect_read_line(Map, Points, Cats, line);
- if (type < 0) {
- return -1;
+ if (!(type & GV_LINES)) {
+ continue;
if (Vedit_snap_line(Map, BgMap, nbgmaps,
line, Points, thresh, to_vertex) == 1) {
if (Vect_rewrite_line (Map, line, type, Points, Cats) < 0) {
