[GRASS-SVN] r32107 - grass/trunk/raster/r.random
svn_grass at osgeo.org
Mon Jul 14 16:25:54 EDT 2008
Author: martinl
Date: 2008-07-14 16:25:54 -0400 (Mon, 14 Jul 2008)
New Revision: 32107
grass/trunk/raster/r.random/count.c
grass/trunk/raster/r.random/description.html
grass/trunk/raster/r.random/main.c
grass/trunk/raster/r.random/random.c
Fixed crash when no cover map was specified;
Don't copy input raster map to raster_output if all cover map values are NULL;
Documentation cleanup and changes to match current module state.
[merged from develbranch_6, r32105, marisn]
Modified: grass/trunk/raster/r.random/count.c
--- grass/trunk/raster/r.random/count.c 2008-07-14 20:23:10 UTC (rev 32106)
+++ grass/trunk/raster/r.random/count.c 2008-07-14 20:25:54 UTC (rev 32107)
@@ -85,12 +85,14 @@
set_min(&theState->buf, col, &theState->min);
set_max(&theState->buf, col, &theState->max);
- if (is_null_value(theState->cover, col)) {
- theState->cnNulls++;
- } else {
- set_min(&theState->cover, col, &theState->cmin);
- set_max(&theState->cover, col, &theState->cmax);
+ if (theState->docover == 1) {
+ if (is_null_value(theState->cover, col)) {
+ theState->cnNulls++;
+ } else {
+ set_min(&theState->cover, col, &theState->cmin);
+ set_max(&theState->cover, col, &theState->cmax);
G_percent(row, nrows, 2);
Modified: grass/trunk/raster/r.random/description.html
--- grass/trunk/raster/r.random/description.html 2008-07-14 20:23:10 UTC (rev 32106)
+++ grass/trunk/raster/r.random/description.html 2008-07-14 20:25:54 UTC (rev 32107)
@@ -1,152 +1,66 @@
<h2>DESCRIPTION</h2>
+<p>
The program <em>r.random</em> allows the user to create a
-raster map layer and a vector points map containing
+raster map layer and/or a vector points map containing
coordinates of points whose locations have been randomly
determined. The program locates these randomly generated
-sites (vector points) within the current geographic region and mask (if
-any), on non-zero category value data areas within a
+vector points (sites) within the current geographic region and mask (if
+any), on non-NULL category value data areas within a
user-specified raster map layer. If the user sets the
-<b>-z</b> flag, sites will be randomly generated across all
+<b>-z</b> flag, points will be randomly generated across all
cells (even those with NULL values).
<p>
-The <em>raster_output</em> raster map layer is created in
-the user's current mapset. The category values and
+The category values and
corresponding category names already associated with the
-random vector point locations in the <em>input</em> map layer are
-assigned to these sites in the <em>raster_output</em> map
+random point locations in the <em>input</em> map layer are
+assigned to these points in the <em>raster_output</em> map
layer. If the <b>-z</b> is specified, then a unique entry
is made for the value used where the <em>input</em> was NULL.
This value is at least 1 less than the smallest value in the
<em>input</em> raster and is given a medium gray color.
+<h2>NOTES</h2>
<p>
+If a <em>cover</em> raster map is specified and the <em>cover</em> map
+contains NULL (no data) values, these points are suppressed in the
+resulting <em>vector_output</em> or <em>raster_output</em> map.
+<p>
The <em>vector_output</em> file created by <em>r.random</em>
-contains a listing of the sites' coordinates;
-these coordinates are the <em>center points</em> of the
-randomly selected cells. A double attribute contains the cell value
+contains vector points that represent the <em>center points</em> of the
+randomly generated cells. A <em>value</em> attribute contains the cell value
of the <em>input</em> raster (or the assigned value
-when <b>-z</b> is used. The values a stored in the <em>value</em>
-column in the attached attribute table. <br>
+when <b>-z</b> is used). <br>
If a <em>cover</em> map is additionally specified, a second
column <em>covervalue</em> is populated with raster values from
the <em>cover</em> map.
-<h2>OPTIONS</h2>
+<p>
The user may specify the quantity of random locations to be
generated either as a <em>positive integer</em> (e.g., 10),
or as a <em>percentage of the raster map layer's cells</em>
(e.g., 10%, or 3.05%). The number of cells considered for
the percentage reflects whether or not the <b>-z</b> flag
-was given. Options are 0-100; percentages less than
-one percent may be stated as decimals.
+was given. Options are 0-100; percentages less than
+one percent may be stated as decimals.
<p>
-<em>r.random</em> can be run interactively or
-non-interactively. The user may provide program arguments
-on the command line, specifying an input raster map layer name
-(<b>input=</b><em>name</em>), optionally a cover raster map layer name
-(<b>cover=</b><em>name</em>), output raster map layer name
-(<b>raster_output=</b><em>name</em>), output vector points map
-name (<b>vector_output=</b><em>name</em>), and
-the number of sites to be randomly generated as a
-total number of sites (<b>n=</b><em>number</em>) or as
-a percentage of the map's size
-(<b>n=</b><em>number</em><b>%</b>). The user can also
-direct that <em>r.random</em> run quietly (using the
-<b>-q</b>)</em> option, and/or direct <em>r.random</em> to
-also generate random vector point locations against cells
-containing NULL values (using the <b>-z</b> option). The
-<b>-i</b> can be used to get a count of the total cells and
-NULL cells given the current region settings.
-<h3>Flags:</h3>
-<dl>
-<dt><b>-z</b>
-<dd>Include NULL cells in the pool
-from which <em>r.random</em> will randomly generate vector point locations.
-<dt><b>-i</b>
-<dd>Print the raster map's name and location,
+Flag <b>-i</b> prints the raster map's name and location,
the total number of cells under the current region settings, and
the number of NULL valued cells under the current region settings.
-Then exit without doing anything. Useful for deciding on the number
+Then module exits without doing anything. Useful for deciding on the number
of sites to have <em>r.random</em> create.
+<b>WARNING:</b> this feature may be removed in future. Use
+<a href="g.region.html">g.region</a> and
+<a href="r.report.html">r.report</a>
+instead.
+<div class="code"><pre>
+g.region -p
+r.report map=inputmap units=c null=* nsteps=1
+</pre></div>
-<dt><b>-d</b>
-<dd>Generate vector points with 3D geometry instead of 2D geometry.
-The z values correspond to the raster map values.
-</dl>
<p>
-<h3>Parameters:</h3>
-<dl>
-<dt><b>input=</b><em>name</em>
-<dd>An existing raster map layer in the user's current mapset search path.
-<em>r.random</em> will randomly generate sites on a user-specified portion
-of the cells in this <em>input</em> raster map.
-<dt><b>cover=</b><em>name</em>
-<em>r.random</em> will extract raster values at the generates random sites
-from this <em>cover</em> raster map. The cover map only generates output
-for the <em>vector_output</em> map.
-<dt><b>n=</b><em>number</em>
-<dd>Specify the quantity of sites to be randomly generated as
-either a <em>positive</em> integer, or as a <em>percentage</em> value of
-the number of cells in the <em>input</em> map layer.
-If stated as a positive integer, <em>number</em> is
-the number of sites (i.e., number of cells) to appear
-in the <em>raster_output</em> layer and/or <em>vector_output</em> file.
-<br>
-Options: Non-percentage values should be given as positive integer values
-less than or equal to the number of cells in the input map layer.
-Percentage values given should be within the range 0.00 - 100.00
-(decimal values are allowed).
-<dt><b>raster_output=</b><em>name</em>
-<dd>The new raster map layer to hold program output. This map will contain
-the sites randomly generated by <em>r.random</em>. If the -z flag is not set,
-all sites will be assigned whatever category values were assigned these
-cell locations in the <em>input</em> raster map layer.
-If the -z flag is set, all sites except those falling on NULL cells
-in the <em>input</em> value will be assigned the category values
-assigned these cells in the input layer; sites falling on NULL cells
-in the <em>input</em> layer will be assigned to a newly created
-category in the <em>raster_output</em> layer with at least one integer
-value less than the minimum value in the <em>input</em> layer.
-<dt><b>vector_output=</b><em>name</em>
-<dd>The new GRASS <em>vector_output</em> file to hold program output.
-If no <em>vector_output</em> file name is given on the command line,
-no <em>vector_output</em> file will be created by <em>r.random</em>.
-(See <em>raster_output</em> parameter description, above.)
-Note. Although the user need not request that <em>r.random</em> output
-both a raster map layer (<em>raster_output</em>)
-and a vector points map (<em>vector_output</em>), the user must
-specify that at least one of these outputs be produced.
-</dl>
-<h2>NOTES</h2>
To create random vector point locations within some, but not all,
non-zero categories of the input raster map layer,
the user must first create a reclassified raster map layer
@@ -154,13 +68,9 @@
program <em><a href="r.reclass.html">r.reclass</a></em>)
that contains only the desired categories,
and then use the reclassed raster map layer as input to <em>r.random</em>.
-<p>
-If a <em>cover</em> raster map is specified and the <em>cover</em> map
-contains NULL (no data) values, these sites are suppressed in the
-resulting <em>vector_output</em> map.
<h2>EXAMPLES</h2>
+<p>
Random vector elevation points sampled from elevation map in the
Spearfish region, result stored in 2D vector map:
Modified: grass/trunk/raster/r.random/main.c
--- grass/trunk/raster/r.random/main.c 2008-07-14 20:23:10 UTC (rev 32106)
+++ grass/trunk/raster/r.random/main.c 2008-07-14 20:25:54 UTC (rev 32107)
@@ -73,7 +73,7 @@
flag.zero = G_define_flag() ;
flag.zero->key = 'z' ;
- flag.zero->description = _("Generate vector points for category zero also");
+ flag.zero->description = _("Generate vector points also for NULL category");
flag.info = G_define_flag() ;
flag.info->key = 'i' ;
@@ -116,7 +116,7 @@
if (flag.info->answer)
- fprintf (stderr,
+ G_message (
"Raster: %s@%s\n"
"Cover: %s@%s\n"
"Cell Count: %d\n"
@@ -173,7 +173,7 @@
G_fatal_error (_("There aren't [%ld] cells in the current region"),
targets);
else
- G_fatal_error (_("There aren't [%ld] non-zero cells in the current region"),
+ G_fatal_error (_("There aren't [%ld] non-NULL cells in the current region"),
targets);
Modified: grass/trunk/raster/r.random/random.c
--- grass/trunk/raster/r.random/random.c 2008-07-14 20:23:10 UTC (rev 32106)
+++ grass/trunk/raster/r.random/random.c 2008-07-14 20:25:54 UTC (rev 32107)
@@ -109,8 +109,9 @@
init_rand();
nc = (theState->use_nulls) ? theState->nCells :
theState->nCells - theState->nNulls ;
- nt = theState->nRand;
+ nt = theState->nRand; /* Number of points to generate */
cat = 1;
+ /* Execute for loop for every row if nt>1 */
for (row = 0; row < nrows && nt ; row++)
if (G_get_raster_row (infd, theState->buf.data.v, row, theState->buf.type) < 0)
@@ -126,8 +127,11 @@
if (!theState->use_nulls && is_null_value(theState->buf, col) )
continue;
if (theState->docover == 1) { /* skip no data cover points */
- if (!theState->use_nulls && is_null_value(theState->cover, col) )
- continue;
+ if (!theState->use_nulls && is_null_value(theState->cover, col) ) {
+ /* If cover is NULL, then output aso must be NULL */
+ set_to_null(&theState->buf, col);
+ continue;
if (make_rand() % nc < nt)
