[GRASS-SVN] r32158 - grass/trunk/gui/wxpython/vdigit
svn_grass at osgeo.org
Fri Jul 18 05:35:48 EDT 2008
Author: martinl
Date: 2008-07-18 05:35:48 -0400 (Fri, 18 Jul 2008)
New Revision: 32158
grass/trunk/gui/wxpython/vdigit/driver.cpp
wxGUI/vdigit: better area fill support (TODO: draw isles)
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-07-18 08:00:21 UTC (rev 32157)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-07-18 09:35:48 UTC (rev 32158)
@@ -122,27 +122,72 @@
if (settings.area.enabled) {
/* draw area fills first */
- int area;
+ int area, centroid, isle;
+ int num_isles;
+ bool draw;
struct ilist *listAreas, *listCentroids;
- BOUND_BOX areaBox;
+ struct line_pnts *points, *ipoints, **isles;
listAreas = Vect_new_list();
listCentroids = Vect_new_list();
+ points = Vect_new_line_struct();
+ ipoints = NULL;
Vect_select_areas_by_box(mapInfo, &(region.box),
listAreas);
for (int i = 0; i < listAreas->n_values; i++) {
area = listAreas->value[i];
/* check for other centroids -- only area with one centroid is valid */
- Vect_get_area_box(mapInfo, area, &areaBox);
- if(Vect_select_lines_by_box(mapInfo, &areaBox,
- GV_CENTROID, listCentroids) == 1) {
- DrawArea(area);
+ centroid = Vect_get_area_centroid(mapInfo, area);
+ if(centroid > 0) {
+ Vect_get_area_points(mapInfo, area, points);
+ num_isles = Vect_get_area_num_isles(mapInfo, area);
+ if (num_isles < 1)
+ isles = NULL;
+ else
+ isles = (struct line_pnts **) G_malloc(num_isles * sizeof(struct line_pnts *));
+ for (int j = 0; j < num_isles; j++) {
+ ipoints = Vect_new_line_struct();
+ isle = Vect_get_area_isle(mapInfo, area, j);
+ Vect_get_isle_points(mapInfo, isle, ipoints);
+ isles[j] = ipoints;
+ Vect_select_lines_by_polygon(mapInfo, points,
+ num_isles, isles, GV_CENTROID, listCentroids);
+ draw = true;
+ for (int c = 0; c < listCentroids->n_values; c++) {
+ if(Vect_get_centroid_area(mapInfo, listCentroids->value[c]) < 0) {
+ draw = false;
+ break;
+ if (draw) {
+ DrawArea(area);
+ // DrawIsle(isle) -> TODO
+ if(isles) {
+ Vect_destroy_line_struct(isles[j]);
+ isles[j] = NULL;
+ G_free((void *) isles);
+ Vect_destroy_line_struct(points);
Vect_destroy_list(listAreas);
Vect_destroy_list(listCentroids);
