[GRASS-SVN] r32160 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules vdigit
svn_grass at osgeo.org
Fri Jul 18 10:21:24 EDT 2008
Author: martinl
Date: 2008-07-18 10:21:24 -0400 (Fri, 18 Jul 2008)
New Revision: 32160
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
wxGUI/vdigit: isles filled in white
check for valid areas disabled by default
(merged from trunk, r32159)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-07-18 14:16:39 UTC (rev 32159)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-07-18 14:21:24 UTC (rev 32160)
@@ -207,7 +207,7 @@
'color' : (255, 20, 147, 255)
}, # deep pink
'symbolArea' : {
- 'enabled' : True,
+ 'enabled' : False,
'color' : (217, 255, 217, 255)
}, # green
'symbolDirection' : {
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2008-07-18 14:16:39 UTC (rev 32159)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp 2008-07-18 14:21:24 UTC (rev 32160)
@@ -122,27 +122,113 @@
if (settings.area.enabled) {
/* draw area fills first */
- int area;
+ int area, centroid, isle;
+ int num_isles;
+ bool draw;
struct ilist *listAreas, *listCentroids;
+ struct line_pnts *points, *ipoints, **isles;
BOUND_BOX areaBox;
+ wxBrush *fillArea, *fillIsle;
+ fillArea = new wxBrush(settings.area.color);
+ fillIsle = new wxBrush(*wxWHITE_BRUSH);
listAreas = Vect_new_list();
listCentroids = Vect_new_list();
+ points = Vect_new_line_struct();
+ ipoints = NULL;
- Vect_select_areas_by_box(mapInfo, &(region.box),
+ Vect_select_areas_by_box(mapInfo, ®ion.box,
listAreas);
for (int i = 0; i < listAreas->n_values; i++) {
area = listAreas->value[i];
+ if (!Vect_area_alive (mapInfo, area))
+ return -1;
/* check for other centroids -- only area with one centroid is valid */
- Vect_get_area_box(mapInfo, area, &areaBox);
- if(Vect_select_lines_by_box(mapInfo, &areaBox,
- GV_CENTROID, listCentroids) == 1) {
- DrawArea(area);
+ centroid = Vect_get_area_centroid(mapInfo, area);
+ if(centroid > 0) {
+ /* check for isles */
+ num_isles = Vect_get_area_num_isles(mapInfo, area); /* TODO */
+ if (num_isles < 1)
+ isles = NULL;
+ else
+ isles = (struct line_pnts **) G_malloc(num_isles * sizeof(struct line_pnts *));
+ for (int j = 0; j < num_isles; j++) {
+ ipoints = Vect_new_line_struct();
+ isle = Vect_get_area_isle(mapInfo, area, j);
+ if (!Vect_isle_alive (mapInfo, isle))
+ return -1;
+ Vect_get_isle_points(mapInfo, isle, ipoints);
+ isles[j] = ipoints;
+ Vect_get_area_points(mapInfo, area, points);
+ /* avoid processing areas with large number of polygon points (ugly) */
+ if (points->n_points < 5000) {
+ Vect_select_lines_by_polygon(mapInfo, points,
+ num_isles, isles, GV_CENTROID, listCentroids);
+ else {
+ Vect_reset_list(listCentroids);
+ Vect_get_area_box(mapInfo, area, &areaBox);
+ if (areaBox.E > region.box.E && areaBox.W < region.box.W &&
+ areaBox.S < region.box.S && areaBox.N > region.box.N) {
+ Vect_reset_line(points);
+ Vect_append_point(points, region.box.W, region.box.N, 0.0);
+ Vect_append_point(points, region.box.E, region.box.N, 0.0);
+ Vect_append_point(points, region.box.E, region.box.S, 0.0);
+ Vect_append_point(points, region.box.W, region.box.S, 0.0);
+ draw = true;
+ for (int c = 0; c < listCentroids->n_values; c++) {
+ if(Vect_get_centroid_area(mapInfo, listCentroids->value[c]) < 0) {
+ draw = false;
+ break;
+ if (draw) {
+ dc->SetBrush(*fillArea);
+ dc->SetPen(*wxTRANSPARENT_PEN);
+ DrawArea(points);
+ /* draw isles in white */
+ dc->SetBrush(*fillIsle);
+ DrawArea(isles[j]);
+ if(isles) {
+ Vect_destroy_line_struct(isles[j]);
+ isles[j] = NULL;
+ G_free((void *) isles);
+ delete fillArea;
+ delete fillIsle;
+ Vect_destroy_line_struct(points);
Vect_destroy_list(listAreas);
Vect_destroy_list(listCentroids);
@@ -153,7 +239,7 @@
dc->EndDrawing();
// PrintIds();
Vect_destroy_list(listLines);
return listLines->n_values;
@@ -162,24 +248,15 @@
\brief Draw area fill
- \param area area id
+ \param area boundary points
\return 1 on success
\return -1 on failure (vector object is dead, etc.)
-int DisplayDriver::DrawArea(int area)
+int DisplayDriver::DrawArea(const line_pnts* points)
double x, y, z;
- struct line_pnts *points;
- if (!dc || !Vect_area_alive (mapInfo, area))
- return -1;
- points = Vect_new_line_struct();
- // get boundary points
- Vect_get_area_points(mapInfo, area, points);
// convert EN -> xy
wxPoint wxPoints[points->n_points];
@@ -190,12 +267,8 @@
// draw polygon
- dc->SetBrush(wxBrush(settings.area.color));
- dc->SetPen(wxPen(settings.area.color));
dc->DrawPolygon(points->n_points, wxPoints);
- Vect_destroy_line_struct(points);
return 1;
@@ -796,7 +869,11 @@
settings.area.enabled = eArea;
settings.area.color.Set(cArea);
+ settings.area.color.Set(settings.area.color.Red(),
+ settings.area.color.Green(),
+ settings.area.color.Blue(),
+ 100); /* transparency */
settings.direction.enabled = eDirection;
settings.direction.color.Set(cDirection);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2008-07-18 14:16:39 UTC (rev 32159)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h 2008-07-18 14:21:24 UTC (rev 32160)
@@ -147,7 +147,7 @@
int DrawLineNodes(int);
int DrawDirectionArrow();
- int DrawArea(int);
+ int DrawArea(const line_pnts *);
/* debug */
void PrintIds();
