[GRASS-SVN] r32174 - grass/branches/develbranch_6
svn_grass at osgeo.org
Sat Jul 19 18:36:42 EDT 2008
Author: martinl
Date: 2008-07-19 18:36:42 -0400 (Sat, 19 Jul 2008)
New Revision: 32174
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
Use absolute path for aux directory so that install-sh works
[merged from trunk, r32168]
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2008-07-19 21:44:11 UTC (rev 32173)
+++ grass/branches/develbranch_6/configure 2008-07-19 22:36:42 UTC (rev 32174)
@@ -1213,6 +1213,28 @@
+# Use absolute path for aux directory so that install-sh works
+ac_aux_dir=
+for ac_dir in $SRCDIR $srcdir/$SRCDIR; do
+ if test -f $ac_dir/install-sh; then
+ ac_aux_dir=$ac_dir
+ ac_install_sh="$ac_aux_dir/install-sh -c"
+ break
+ elif test -f $ac_dir/install.sh; then
+ ac_install_sh="$ac_aux_dir/install.sh -c"
+ break
+ fi
+done
+if test -z "$ac_aux_dir"; then
+ { echo "configure: error: can not find install-sh or install.sh in $SRCDIR $srcdir/$SRCDIR" 1>&2; exit 1; }
+fi
+ac_config_guess=$ac_aux_dir/config.guess
+ac_config_sub=$ac_aux_dir/config.sub
+ac_configure=$ac_aux_dir/configure # This should be Cygnus configure.
# Set GISBASE and GRASS_BIN
GISBASE=${WINDSTDIR}/dist.${ARCH}
@@ -1255,7 +1277,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1259: checking for MacOSX App" >&5
+echo "configure:1281: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1278,7 +1300,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1282: checking how to build libraries" >&5
+echo "configure:1304: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1321,7 +1343,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1325: checking for $ac_word" >&5
+echo "configure:1347: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1346,7 +1368,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1350: checking how to run the C preprocessor" >&5
+echo "configure:1372: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1359,13 +1381,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
cat > conftest.$ac_ext <<EOF
-#line 1363 "configure"
+#line 1385 "configure"
#include "confdefs.h"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1376,13 +1398,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1380 "configure"
+#line 1402 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1386: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1408: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1393,13 +1415,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1397 "configure"
+#line 1419 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1425: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1427,7 +1449,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1431: checking if 64bit support is requested" >&5
+echo "configure:1453: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1447,7 +1469,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1451: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1473: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1471,7 +1493,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1475: checking system version (for dynamic loading)" >&5
+echo "configure:1497: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1497,13 +1519,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1501: checking for dlopen in -ldl" >&5
+echo "configure:1523: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1507 "configure"
+#line 1529 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1514,7 +1536,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1561,7 +1583,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1565: checking for $ac_word" >&5
+echo "configure:1587: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1690,13 +1712,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1694: checking for gettimeofday in -lbsd" >&5
+echo "configure:1716: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1700 "configure"
+#line 1722 "configure"
@@ -1707,7 +1729,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1748,13 +1770,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1752: checking for inet_ntoa in -lbind" >&5
+echo "configure:1774: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1758 "configure"
+#line 1780 "configure"
@@ -1765,7 +1787,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1826,13 +1848,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1830: checking for shl_load in -ldld" >&5
+echo "configure:1852: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1836 "configure"
+#line 1858 "configure"
@@ -1843,7 +1865,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1908,13 +1930,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1912: checking for shl_load in -ldld" >&5
+echo "configure:1934: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1918 "configure"
+#line 1940 "configure"
@@ -1925,7 +1947,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2047,15 +2069,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2051: checking for dld.h" >&5
+echo "configure:2073: checking for dld.h" >&5
-#line 2054 "configure"
+#line 2076 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2081: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2115,15 +2137,15 @@
else
-echo "configure:2119: checking for dld.h" >&5
+echo "configure:2141: checking for dld.h" >&5
-#line 2122 "configure"
+#line 2144 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2127: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2220,9 +2242,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2224: checking for ELF" >&5
+echo "configure:2246: checking for ELF" >&5
-#line 2226 "configure"
+#line 2248 "configure"
#ifdef __ELF__
@@ -2252,15 +2274,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2256: checking for dlfcn.h" >&5
+echo "configure:2278: checking for dlfcn.h" >&5
-#line 2259 "configure"
+#line 2281 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2286: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2284,9 +2306,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2288: checking for ELF" >&5
+echo "configure:2310: checking for ELF" >&5
-#line 2290 "configure"
+#line 2312 "configure"
#ifdef __ELF__
@@ -2610,17 +2632,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2614: checking for ld accepts -Bexport flag" >&5
+echo "configure:2636: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2617 "configure"
+#line 2639 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -3365,7 +3387,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3369: checking for additional include dirs" >&5
+echo "configure:3391: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3388,7 +3410,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3392: checking for additional library dirs" >&5
+echo "configure:3414: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3422,7 +3444,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3426: checking for a BSD compatible install" >&5
+echo "configure:3448: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3475,7 +3497,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3479: checking for $ac_word" >&5
+echo "configure:3501: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3506,13 +3528,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3510: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3532: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3516 "configure"
+#line 3538 "configure"
@@ -3523,7 +3545,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3548,7 +3570,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3552: checking for $ac_word" >&5
+echo "configure:3574: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3588,7 +3610,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3592: checking for $ac_word" >&5
+echo "configure:3614: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3619,7 +3641,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3623: checking for $ac_word" >&5
+echo "configure:3645: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3657,7 +3679,7 @@
-echo "configure:3661: checking for $ac_word" >&5
+echo "configure:3683: checking for $ac_word" >&5
@@ -3686,7 +3708,7 @@
-echo "configure:3690: checking for $ac_word" >&5
+echo "configure:3712: checking for $ac_word" >&5
@@ -3717,7 +3739,7 @@
-echo "configure:3721: checking for $ac_word" >&5
+echo "configure:3743: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3746,7 +3768,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3750: checking for $ac_word" >&5
+echo "configure:3772: checking for $ac_word" >&5
case "$PERL" in
@@ -3777,10 +3799,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3781: checking for ANSI C header files" >&5
+echo "configure:3803: checking for ANSI C header files" >&5
-#line 3784 "configure"
+#line 3806 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3788,7 +3810,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3805,7 +3827,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3809 "configure"
+#line 3831 "configure"
#include <string.h>
EOF
@@ -3823,7 +3845,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3827 "configure"
+#line 3849 "configure"
#include <stdlib.h>
EOF
@@ -3844,7 +3866,7 @@
else
-#line 3848 "configure"
+#line 3870 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3855,7 +3877,7 @@
exit (0); }
EOF
-if { (eval echo configure:3859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3882,15 +3904,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3886: checking for $ac_hdr" >&5
+echo "configure:3908: checking for $ac_hdr" >&5
-#line 3889 "configure"
+#line 3911 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3919,15 +3941,15 @@
do
-echo "configure:3923: checking for $ac_hdr" >&5
+echo "configure:3945: checking for $ac_hdr" >&5
-#line 3926 "configure"
+#line 3948 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3953: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3956,15 +3978,15 @@
do
-echo "configure:3960: checking for $ac_hdr" >&5
+echo "configure:3982: checking for $ac_hdr" >&5
-#line 3963 "configure"
+#line 3985 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3968: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3993,15 +4015,15 @@
do
-echo "configure:3997: checking for $ac_hdr" >&5
+echo "configure:4019: checking for $ac_hdr" >&5
-#line 4000 "configure"
+#line 4022 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4030,15 +4052,15 @@
do
-echo "configure:4034: checking for $ac_hdr" >&5
+echo "configure:4056: checking for $ac_hdr" >&5
-#line 4037 "configure"
+#line 4059 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4064,10 +4086,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4068: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4090: checking whether time.h and sys/time.h may both be included" >&5
-#line 4071 "configure"
+#line 4093 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4076,7 +4098,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4080: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4096,10 +4118,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4100: checking for off_t" >&5
+echo "configure:4122: checking for off_t" >&5
-#line 4103 "configure"
+#line 4125 "configure"
#if STDC_HEADERS
@@ -4126,10 +4148,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4130: checking for uid_t in sys/types.h" >&5
+echo "configure:4152: checking for uid_t in sys/types.h" >&5
-#line 4133 "configure"
+#line 4155 "configure"
EOF
@@ -4157,10 +4179,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4161: checking return type of signal handlers" >&5
+echo "configure:4183: checking return type of signal handlers" >&5
-#line 4164 "configure"
+#line 4186 "configure"
#include <signal.h>
@@ -4177,7 +4199,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4181: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4203: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4195,10 +4217,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4199: checking for Cygwin environment" >&5
+echo "configure:4221: checking for Cygwin environment" >&5
-#line 4202 "configure"
+#line 4224 "configure"
int main() {
@@ -4209,7 +4231,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4227,10 +4249,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4231: checking for $ac_func" >&5
+echo "configure:4253: checking for $ac_func" >&5
-#line 4234 "configure"
+#line 4256 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4253,7 +4275,7 @@
; return 0; }
EOF
-if { (eval echo configure:4257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4279,10 +4301,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4283: checking for $ac_func" >&5
+echo "configure:4305: checking for $ac_func" >&5
-#line 4286 "configure"
+#line 4308 "configure"
@@ -4305,7 +4327,7 @@
; return 0; }
EOF
-if { (eval echo configure:4309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4331,10 +4353,10 @@
for ac_func in drand48
do
-echo "configure:4335: checking for $ac_func" >&5
+echo "configure:4357: checking for $ac_func" >&5
-#line 4338 "configure"
+#line 4360 "configure"
@@ -4357,7 +4379,7 @@
; return 0; }
EOF
-if { (eval echo configure:4361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4383,10 +4405,10 @@
for ac_func in putenv setenv
do
-echo "configure:4387: checking for $ac_func" >&5
+echo "configure:4409: checking for $ac_func" >&5
-#line 4390 "configure"
+#line 4412 "configure"
@@ -4409,7 +4431,7 @@
; return 0; }
EOF
-if { (eval echo configure:4413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4435,10 +4457,10 @@
for ac_func in nanosleep
do
-echo "configure:4439: checking for $ac_func" >&5
+echo "configure:4461: checking for $ac_func" >&5
-#line 4442 "configure"
+#line 4464 "configure"
@@ -4461,7 +4483,7 @@
; return 0; }
EOF
-if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4486,13 +4508,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4490: checking whether setpgrp takes no argument" >&5
+echo "configure:4512: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4496 "configure"
+#line 4518 "configure"
#ifdef HAVE_UNISTD_H
@@ -4512,7 +4534,7 @@
EOF
-if { (eval echo configure:4516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4540,16 +4562,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4544: checking for long long int" >&5
+echo "configure:4566: checking for long long int" >&5
-#line 4546 "configure"
+#line 4568 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4553: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4575: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -4569,7 +4591,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4573: checking for W11" >&5
+echo "configure:4595: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4597,7 +4619,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4601: checking for X" >&5
+echo "configure:4623: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4657,12 +4679,12 @@
# First, try using that file with no special directory specified.
-#line 4661 "configure"
+#line 4683 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4731,14 +4753,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4735 "configure"
+#line 4757 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4843,17 +4865,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4847: checking whether -R must be followed by a space" >&5
+echo "configure:4869: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4850 "configure"
+#line 4872 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4869,14 +4891,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4873 "configure"
+#line 4895 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4908,13 +4930,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4912: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4934: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4918 "configure"
+#line 4940 "configure"
@@ -4925,7 +4947,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4946,13 +4968,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4950: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4972: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4956 "configure"
+#line 4978 "configure"
@@ -4963,7 +4985,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4991,10 +5013,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4995: checking for gethostbyname" >&5
+echo "configure:5017: checking for gethostbyname" >&5
-#line 4998 "configure"
+#line 5020 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5017,7 +5039,7 @@
; return 0; }
EOF
-if { (eval echo configure:5021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5037,13 +5059,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5041: checking for gethostbyname in -lnsl" >&5
+echo "configure:5063: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5047 "configure"
+#line 5069 "configure"
@@ -5054,7 +5076,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5083,10 +5105,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5087: checking for connect" >&5
+echo "configure:5109: checking for connect" >&5
-#line 5090 "configure"
+#line 5112 "configure"
which can conflict with char connect(); below. */
@@ -5109,7 +5131,7 @@
; return 0; }
EOF
-if { (eval echo configure:5113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5135: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5129,13 +5151,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5133: checking for connect in -lsocket" >&5
+echo "configure:5155: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5139 "configure"
+#line 5161 "configure"
@@ -5146,7 +5168,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5169,10 +5191,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5173: checking for remove" >&5
+echo "configure:5195: checking for remove" >&5
-#line 5176 "configure"
+#line 5198 "configure"
which can conflict with char remove(); below. */
@@ -5195,7 +5217,7 @@
; return 0; }
EOF
-if { (eval echo configure:5199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5215,13 +5237,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5219: checking for remove in -lposix" >&5
+echo "configure:5241: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5225 "configure"
+#line 5247 "configure"
@@ -5232,7 +5254,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5255,10 +5277,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5259: checking for shmat" >&5
+echo "configure:5281: checking for shmat" >&5
-#line 5262 "configure"
+#line 5284 "configure"
which can conflict with char shmat(); below. */
@@ -5281,7 +5303,7 @@
; return 0; }
EOF
-if { (eval echo configure:5285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5301,13 +5323,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5305: checking for shmat in -lipc" >&5
+echo "configure:5327: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5311 "configure"
+#line 5333 "configure"
@@ -5318,7 +5340,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5350,13 +5372,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5354: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5376: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5360 "configure"
+#line 5382 "configure"
@@ -5367,7 +5389,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5405,7 +5427,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5409: checking whether to use Curses" >&5
+echo "configure:5431: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5424,15 +5446,15 @@
do
-echo "configure:5428: checking for $ac_hdr" >&5
+echo "configure:5450: checking for $ac_hdr" >&5
-#line 5431 "configure"
+#line 5453 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5463,10 +5485,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5467: checking curses.h WINDOW structure component" >&5
+echo "configure:5489: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5470 "configure"
+#line 5492 "configure"
#include <curses.h>
@@ -5475,7 +5497,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5479: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5484,7 +5506,7 @@
fi
rm -f conftest*
-#line 5488 "configure"
+#line 5510 "configure"
#include <curses.h>
@@ -5493,7 +5515,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5497: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5519: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5509,13 +5531,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5513: checking for initscr in -lncurses" >&5
+echo "configure:5535: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5519 "configure"
+#line 5541 "configure"
@@ -5526,7 +5548,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5545,13 +5567,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5549: checking for initscr in -lcurses" >&5
+echo "configure:5571: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5555 "configure"
+#line 5577 "configure"
@@ -5562,7 +5584,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5591,13 +5613,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5595: checking for keypad in -lncurses" >&5
+echo "configure:5617: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5601 "configure"
+#line 5623 "configure"
@@ -5608,7 +5630,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5630,13 +5652,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5634: checking for keypad in -lcurses" >&5
+echo "configure:5656: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5640 "configure"
+#line 5662 "configure"
@@ -5647,7 +5669,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5677,13 +5699,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5681: checking for gtty in -lcompat" >&5
+echo "configure:5703: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5687 "configure"
+#line 5709 "configure"
@@ -5694,7 +5716,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5713,13 +5735,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5717: checking for gtty in -lbsd-compat" >&5
+echo "configure:5739: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5723 "configure"
+#line 5745 "configure"
@@ -5730,7 +5752,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5749,13 +5771,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5753: checking for gtty in -lbsd" >&5
+echo "configure:5775: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5759 "configure"
+#line 5781 "configure"
@@ -5766,7 +5788,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5800,12 +5822,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5804: checking for library containing cuserid" >&5
+echo "configure:5826: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5809 "configure"
+#line 5831 "configure"
@@ -5816,7 +5838,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5827,7 +5849,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5831 "configure"
+#line 5853 "configure"
@@ -5838,7 +5860,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5864,10 +5886,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5868: checking for xdrmem_create" >&5
+echo "configure:5890: checking for xdrmem_create" >&5
-#line 5871 "configure"
+#line 5893 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5890,7 +5912,7 @@
; return 0; }
EOF
-if { (eval echo configure:5894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5908,13 +5930,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5912: checking for xdrmem_create in -lsun" >&5
+echo "configure:5934: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5918 "configure"
+#line 5940 "configure"
@@ -5925,7 +5947,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5944,13 +5966,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5948: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5970: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5954 "configure"
+#line 5976 "configure"
@@ -5961,7 +5983,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5980,13 +6002,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5984: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6006: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 5990 "configure"
+#line 6012 "configure"
@@ -5997,7 +6019,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6016,13 +6038,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6020: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6042: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6026 "configure"
+#line 6048 "configure"
@@ -6033,7 +6055,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6067,10 +6089,10 @@
for ac_func in asprintf
do
-echo "configure:6071: checking for $ac_func" >&5
+echo "configure:6093: checking for $ac_func" >&5
-#line 6074 "configure"
+#line 6096 "configure"
@@ -6093,7 +6115,7 @@
; return 0; }
EOF
-if { (eval echo configure:6097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6120,10 +6142,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6124: checking for atan" >&5
+echo "configure:6146: checking for atan" >&5
-#line 6127 "configure"
+#line 6149 "configure"
which can conflict with char atan(); below. */
@@ -6146,7 +6168,7 @@
; return 0; }
EOF
-if { (eval echo configure:6150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6164,13 +6186,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6168: checking for atan in -lm" >&5
+echo "configure:6190: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6174 "configure"
+#line 6196 "configure"
@@ -6181,7 +6203,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6208,10 +6230,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6212: checking for dlsym" >&5
+echo "configure:6234: checking for dlsym" >&5
-#line 6215 "configure"
+#line 6237 "configure"
which can conflict with char dlsym(); below. */
@@ -6234,7 +6256,7 @@
; return 0; }
EOF
-if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6252,13 +6274,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6256: checking for dlsym in -ldl" >&5
+echo "configure:6278: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6262 "configure"
+#line 6284 "configure"
@@ -6269,7 +6291,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6296,10 +6318,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6300: checking for iconv" >&5
+echo "configure:6322: checking for iconv" >&5
-#line 6303 "configure"
+#line 6325 "configure"
which can conflict with char iconv(); below. */
@@ -6322,7 +6344,7 @@
; return 0; }
EOF
-if { (eval echo configure:6326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6340,13 +6362,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6344: checking for iconv in -liconv" >&5
+echo "configure:6366: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6350 "configure"
+#line 6372 "configure"
@@ -6357,7 +6379,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6376,13 +6398,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6380: checking for iconv in -lgiconv" >&5
+echo "configure:6402: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6386 "configure"
+#line 6408 "configure"
@@ -6393,7 +6415,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6412,10 +6434,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6416: checking for libiconv" >&5
+echo "configure:6438: checking for libiconv" >&5
-#line 6419 "configure"
+#line 6441 "configure"
which can conflict with char libiconv(); below. */
@@ -6438,7 +6460,7 @@
; return 0; }
EOF
-if { (eval echo configure:6442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6456,13 +6478,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6460: checking for libiconv in -liconv" >&5
+echo "configure:6482: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6466 "configure"
+#line 6488 "configure"
@@ -6473,7 +6495,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6492,13 +6514,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6496: checking for libiconv in -lgiconv" >&5
+echo "configure:6518: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6502 "configure"
+#line 6524 "configure"
@@ -6509,7 +6531,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6546,10 +6568,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6550: checking for socket" >&5
+echo "configure:6572: checking for socket" >&5
-#line 6553 "configure"
+#line 6575 "configure"
which can conflict with char socket(); below. */
@@ -6572,7 +6594,7 @@
; return 0; }
EOF
-if { (eval echo configure:6576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6590,13 +6612,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6594: checking for socket in -lsocket" >&5
+echo "configure:6616: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6600 "configure"
+#line 6622 "configure"
@@ -6607,7 +6629,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6655,7 +6677,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6659: checking for location of zlib includes" >&5
+echo "configure:6681: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6681,15 +6703,15 @@
do
-echo "configure:6685: checking for $ac_hdr" >&5
+echo "configure:6707: checking for $ac_hdr" >&5
-#line 6688 "configure"
+#line 6710 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6723,7 +6745,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6727: checking for location of zlib library" >&5
+echo "configure:6749: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6748,13 +6770,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6752: checking for deflate in -lz" >&5
+echo "configure:6774: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6758 "configure"
+#line 6780 "configure"
@@ -6765,7 +6787,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6813,7 +6835,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6817: checking for location of External PROJ.4 includes" >&5
+echo "configure:6839: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6839,15 +6861,15 @@
do
-echo "configure:6843: checking for $ac_hdr" >&5
+echo "configure:6865: checking for $ac_hdr" >&5
-#line 6846 "configure"
+#line 6868 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6884,7 +6906,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6888: checking External PROJ.4 version" >&5
+echo "configure:6910: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6892,7 +6914,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 6896 "configure"
+#line 6918 "configure"
#include <stdio.h>
@@ -6904,7 +6926,7 @@
EOF
-if { (eval echo configure:6908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6929,7 +6951,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6933: checking for location of External PROJ.4 library" >&5
+echo "configure:6955: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6954,13 +6976,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6958: checking for pj_get_def in -lproj" >&5
+echo "configure:6980: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 6964 "configure"
+#line 6986 "configure"
@@ -6971,7 +6993,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7005,7 +7027,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7009: checking for location of External PROJ.4 data files" >&5
+echo "configure:7031: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7029,14 +7051,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7033: checking for epsg" >&5
+echo "configure:7055: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7040: checking for $PROJSHARE/epsg" >&5
+echo "configure:7062: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7068,7 +7090,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:7072: checking for $ac_word" >&5
+echo "configure:7094: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7108,7 +7130,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7112: checking whether to use Readline" >&5
+echo "configure:7134: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7129,7 +7151,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7133: checking for location of Readline includes" >&5
+echo "configure:7155: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7155,15 +7177,15 @@
do
-echo "configure:7159: checking for $ac_hdr" >&5
+echo "configure:7181: checking for $ac_hdr" >&5
-#line 7162 "configure"
+#line 7184 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7167: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7189: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7199,15 +7221,15 @@
do
-echo "configure:7203: checking for $ac_hdr" >&5
+echo "configure:7225: checking for $ac_hdr" >&5
-#line 7206 "configure"
+#line 7228 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7233: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7241,7 +7263,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7245: checking for location of Readline library" >&5
+echo "configure:7267: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7266,13 +7288,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7270: checking for readline in -lreadline" >&5
+echo "configure:7292: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7276 "configure"
+#line 7298 "configure"
@@ -7283,7 +7305,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7318,13 +7340,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7322: checking for add_history in -lhistory" >&5
+echo "configure:7344: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7328 "configure"
+#line 7350 "configure"
@@ -7335,7 +7357,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7378,7 +7400,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7382: checking whether to use JPEG" >&5
+echo "configure:7404: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7398,7 +7420,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7402: checking for location of JPEG includes" >&5
+echo "configure:7424: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7424,15 +7446,15 @@
do
-echo "configure:7428: checking for $ac_hdr" >&5
+echo "configure:7450: checking for $ac_hdr" >&5
-#line 7431 "configure"
+#line 7453 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7458: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7466,7 +7488,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7470: checking for location of JPEG library" >&5
+echo "configure:7492: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7493,13 +7515,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7497: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7519: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7503 "configure"
+#line 7525 "configure"
#include "confdefs.h"
@@ -7510,7 +7532,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7529,13 +7551,13 @@
-echo "configure:7533: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7555: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7539 "configure"
+#line 7561 "configure"
@@ -7546,7 +7568,7 @@
; return 0; }
EOF
-if { (eval echo configure:7550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7595,7 +7617,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7599: checking whether to use GDAL" >&5
+echo "configure:7621: checking whether to use GDAL" >&5
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
@@ -7608,7 +7630,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7612: checking for $ac_word" >&5
+echo "configure:7634: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7668,14 +7690,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7672 "configure"
+#line 7694 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -7684,14 +7706,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7688 "configure"
+#line 7710 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7719,7 +7741,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7723: checking whether to use TIFF" >&5
+echo "configure:7745: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7739,7 +7761,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7743: checking for location of TIFF includes" >&5
+echo "configure:7765: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7765,15 +7787,15 @@
do
-echo "configure:7769: checking for $ac_hdr" >&5
+echo "configure:7791: checking for $ac_hdr" >&5
-#line 7772 "configure"
+#line 7794 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7777: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7799: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7807,7 +7829,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7811: checking for location of TIFF library" >&5
+echo "configure:7833: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7838,13 +7860,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7842: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7864: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltiff $LIBS"
-#line 7848 "configure"
+#line 7870 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7855,7 +7877,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7874,13 +7896,13 @@
-echo "configure:7878: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7900: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7884 "configure"
+#line 7906 "configure"
@@ -7891,7 +7913,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7910,13 +7932,13 @@
-echo "configure:7914: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7936: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7920 "configure"
+#line 7942 "configure"
@@ -7927,7 +7949,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7946,13 +7968,13 @@
-echo "configure:7950: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7972: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7956 "configure"
+#line 7978 "configure"
@@ -7963,7 +7985,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7982,13 +8004,13 @@
-echo "configure:7986: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8008: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7992 "configure"
+#line 8014 "configure"
@@ -7999,7 +8021,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8018,13 +8040,13 @@
-echo "configure:8022: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8044: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8028 "configure"
+#line 8050 "configure"
@@ -8035,7 +8057,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8054,13 +8076,13 @@
-echo "configure:8058: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8080: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8064 "configure"
+#line 8086 "configure"
@@ -8071,7 +8093,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8090,13 +8112,13 @@
-echo "configure:8094: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8116: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8100 "configure"
+#line 8122 "configure"
@@ -8107,7 +8129,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8205,7 +8227,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8209: checking whether to use PNG" >&5
+echo "configure:8231: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8224,7 +8246,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8228: checking for location of PNG includes" >&5
+echo "configure:8250: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8250,15 +8272,15 @@
do
-echo "configure:8254: checking for $ac_hdr" >&5
+echo "configure:8276: checking for $ac_hdr" >&5
-#line 8257 "configure"
+#line 8279 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8292,7 +8314,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8296: checking for location of PNG library" >&5
+echo "configure:8318: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8317,13 +8339,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8321: checking for png_read_image in -lpng" >&5
+echo "configure:8343: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8327 "configure"
+#line 8349 "configure"
@@ -8334,7 +8356,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8376,7 +8398,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8380: checking whether to use Tcl/Tk" >&5
+echo "configure:8402: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8396,7 +8418,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8400: checking for location of Tcl/Tk includes" >&5
+echo "configure:8422: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8422,15 +8444,15 @@
do
-echo "configure:8426: checking for $ac_hdr" >&5
+echo "configure:8448: checking for $ac_hdr" >&5
-#line 8429 "configure"
+#line 8451 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8456: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8467,15 +8489,15 @@
do
-echo "configure:8471: checking for $ac_hdr" >&5
+echo "configure:8493: checking for $ac_hdr" >&5
-#line 8474 "configure"
+#line 8496 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8479: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8501: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8509,7 +8531,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8513: checking Tcl version" >&5
+echo "configure:8535: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
@@ -8517,7 +8539,7 @@
else
-#line 8521 "configure"
+#line 8543 "configure"
#include <stdio.h>
@@ -8529,7 +8551,7 @@
EOF
-if { (eval echo configure:8533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8547,7 +8569,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8551: checking Tk version" >&5
+echo "configure:8573: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8555,7 +8577,7 @@
else
-#line 8559 "configure"
+#line 8581 "configure"
#include <stdio.h>
@@ -8567,7 +8589,7 @@
EOF
-if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8596,7 +8618,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8600: checking for location of Tcl/Tk library" >&5
+echo "configure:8622: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8626,13 +8648,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8630: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8652: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8636 "configure"
+#line 8658 "configure"
@@ -8643,7 +8665,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8662,13 +8684,13 @@
-echo "configure:8666: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8688: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8672 "configure"
+#line 8694 "configure"
@@ -8679,7 +8701,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8706,13 +8728,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8710: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8732: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8716 "configure"
+#line 8738 "configure"
@@ -8723,7 +8745,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8742,13 +8764,13 @@
-echo "configure:8746: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8768: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8752 "configure"
+#line 8774 "configure"
@@ -8759,7 +8781,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8786,13 +8808,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8790: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8812: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8796 "configure"
+#line 8818 "configure"
@@ -8803,7 +8825,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8822,13 +8844,13 @@
-echo "configure:8826: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8848: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8832 "configure"
+#line 8854 "configure"
@@ -8839,7 +8861,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8917,13 +8939,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8921: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8943: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8927 "configure"
+#line 8949 "configure"
@@ -8934,7 +8956,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8953,13 +8975,13 @@
-echo "configure:8957: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8979: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 8963 "configure"
+#line 8985 "configure"
@@ -8970,7 +8992,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8997,13 +9019,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9001: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9023: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9007 "configure"
+#line 9029 "configure"
@@ -9014,7 +9036,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9033,13 +9055,13 @@
-echo "configure:9037: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9059: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9043 "configure"
+#line 9065 "configure"
@@ -9050,7 +9072,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9077,13 +9099,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9081: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9103: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9087 "configure"
+#line 9109 "configure"
@@ -9094,7 +9116,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9113,13 +9135,13 @@
-echo "configure:9117: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9139: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9123 "configure"
+#line 9145 "configure"
@@ -9130,7 +9152,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9222,7 +9244,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9226: checking whether to use PostgreSQL" >&5
+echo "configure:9248: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9249,7 +9271,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9253: checking for location of PostgreSQL includes" >&5
+echo "configure:9275: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9275,15 +9297,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9279: checking for $ac_hdr" >&5
+echo "configure:9301: checking for $ac_hdr" >&5
-#line 9282 "configure"
+#line 9304 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9321,7 +9343,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9325: checking for location of PostgreSQL library" >&5
+echo "configure:9347: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9350,13 +9372,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9354: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9376: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9360 "configure"
+#line 9382 "configure"
@@ -9367,7 +9389,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9386,13 +9408,13 @@
-echo "configure:9390: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9412: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9396 "configure"
+#line 9418 "configure"
@@ -9403,7 +9425,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9422,13 +9444,13 @@
-echo "configure:9426: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9448: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9432 "configure"
+#line 9454 "configure"
@@ -9439,7 +9461,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9458,13 +9480,13 @@
-echo "configure:9462: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9484: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9468 "configure"
+#line 9490 "configure"
@@ -9475,7 +9497,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9532,13 +9554,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9536: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9558: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9542 "configure"
+#line 9564 "configure"
@@ -9549,7 +9571,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9571,13 +9593,13 @@
-echo "configure:9575: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9597: checking for PQcmdTuples in -lpq" >&5
-#line 9581 "configure"
+#line 9603 "configure"
@@ -9588,7 +9610,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9614: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9631,7 +9653,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9635: checking whether to use MySQL" >&5
+echo "configure:9657: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9651,7 +9673,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9655: checking for location of MySQL includes" >&5
+echo "configure:9677: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9677,15 +9699,15 @@
do
-echo "configure:9681: checking for $ac_hdr" >&5
+echo "configure:9703: checking for $ac_hdr" >&5
-#line 9684 "configure"
+#line 9706 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9689: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9711: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9722,7 +9744,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9726: checking for location of MySQL library" >&5
+echo "configure:9748: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9753,13 +9775,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9757: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9779: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9763 "configure"
+#line 9785 "configure"
@@ -9770,7 +9792,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9789,13 +9811,13 @@
-echo "configure:9793: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9815: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9799 "configure"
+#line 9821 "configure"
@@ -9806,7 +9828,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9825,13 +9847,13 @@
-echo "configure:9829: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9851: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9835 "configure"
+#line 9857 "configure"
@@ -9842,7 +9864,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9861,13 +9883,13 @@
-echo "configure:9865: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9887: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9871 "configure"
+#line 9893 "configure"
@@ -9878,7 +9900,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9897,13 +9919,13 @@
-echo "configure:9901: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9923: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9907 "configure"
+#line 9929 "configure"
@@ -9914,7 +9936,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9933,13 +9955,13 @@
-echo "configure:9937: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9959: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9943 "configure"
+#line 9965 "configure"
@@ -9950,7 +9972,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9969,13 +9991,13 @@
-echo "configure:9973: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9995: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9979 "configure"
+#line 10001 "configure"
@@ -9986,7 +10008,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10005,13 +10027,13 @@
-echo "configure:10009: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10031: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10015 "configure"
+#line 10037 "configure"
@@ -10022,7 +10044,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10112,7 +10134,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:10116: checking for $ac_word" >&5
+echo "configure:10138: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10153,10 +10175,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10157: checking for mysql_server_init" >&5
+echo "configure:10179: checking for mysql_server_init" >&5
-#line 10160 "configure"
+#line 10182 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10179,7 +10201,7 @@
; return 0; }
EOF
-if { (eval echo configure:10183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10217,7 +10239,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10221: checking whether to use SQLite" >&5
+echo "configure:10243: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10237,7 +10259,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10241: checking for location of SQLite includes" >&5
+echo "configure:10263: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10263,15 +10285,15 @@
do
-echo "configure:10267: checking for $ac_hdr" >&5
+echo "configure:10289: checking for $ac_hdr" >&5
-#line 10270 "configure"
+#line 10292 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10275: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10314,7 +10336,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10318: checking for location of SQLite library" >&5
+echo "configure:10340: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10341,13 +10363,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10345: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10367: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10351 "configure"
+#line 10373 "configure"
@@ -10358,7 +10380,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10377,13 +10399,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10381: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10403: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10387 "configure"
+#line 10409 "configure"
@@ -10394,7 +10416,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10447,7 +10469,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10451: checking whether to use FFMPEG" >&5
+echo "configure:10473: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10467,7 +10489,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10471: checking for location of FFMPEG includes" >&5
+echo "configure:10493: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10493,15 +10515,15 @@
do
-echo "configure:10497: checking for $ac_hdr" >&5
+echo "configure:10519: checking for $ac_hdr" >&5
-#line 10500 "configure"
+#line 10522 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10537,15 +10559,15 @@
do
-echo "configure:10541: checking for $ac_hdr" >&5
+echo "configure:10563: checking for $ac_hdr" >&5
-#line 10544 "configure"
+#line 10566 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10571: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10581,15 +10603,15 @@
do
-echo "configure:10585: checking for $ac_hdr" >&5
+echo "configure:10607: checking for $ac_hdr" >&5
-#line 10588 "configure"
+#line 10610 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10632,7 +10654,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10636: checking for location of FFMPEG library" >&5
+echo "configure:10658: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10659,13 +10681,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10663: checking for av_free in -lavutil" >&5
+echo "configure:10685: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10669 "configure"
+#line 10691 "configure"
@@ -10676,7 +10698,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10695,13 +10717,13 @@
-echo "configure:10699: checking for av_free in -lavutil" >&5
+echo "configure:10721: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10705 "configure"
+#line 10727 "configure"
@@ -10712,7 +10734,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10757,13 +10779,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10761: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10783: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10767 "configure"
+#line 10789 "configure"
@@ -10774,7 +10796,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10793,13 +10815,13 @@
-echo "configure:10797: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10819: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10803 "configure"
+#line 10825 "configure"
@@ -10810,7 +10832,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10855,13 +10877,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10859: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10881: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10865 "configure"
+#line 10887 "configure"
@@ -10872,7 +10894,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10891,13 +10913,13 @@
-echo "configure:10895: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10917: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10901 "configure"
+#line 10923 "configure"
@@ -10908,7 +10930,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10968,7 +10990,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10972: checking whether to use OpenGL" >&5
+echo "configure:10994: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -11002,7 +11024,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11006: checking for location of OpenGL includes" >&5
+echo "configure:11028: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11028,15 +11050,15 @@
do
-echo "configure:11032: checking for $ac_hdr" >&5
+echo "configure:11054: checking for $ac_hdr" >&5
-#line 11035 "configure"
+#line 11057 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11040: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11070,7 +11092,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11074: checking for location of OpenGL library" >&5
+echo "configure:11096: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11099,13 +11121,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11103: checking for glBegin in -lGL" >&5
+echo "configure:11125: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11109 "configure"
+#line 11131 "configure"
@@ -11116,7 +11138,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11135,13 +11157,13 @@
-echo "configure:11139: checking for glBegin in -lGL" >&5
+echo "configure:11161: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11145 "configure"
+#line 11167 "configure"
@@ -11152,7 +11174,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11171,13 +11193,13 @@
-echo "configure:11175: checking for glBegin in -lGL" >&5
+echo "configure:11197: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11181 "configure"
+#line 11203 "configure"
@@ -11188,7 +11210,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11207,13 +11229,13 @@
-echo "configure:11211: checking for glBegin in -lGL" >&5
+echo "configure:11233: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11217 "configure"
+#line 11239 "configure"
@@ -11224,7 +11246,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11286,13 +11308,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11290: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11312: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11296 "configure"
+#line 11318 "configure"
@@ -11303,7 +11325,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11322,13 +11344,13 @@
-echo "configure:11326: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11348: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11332 "configure"
+#line 11354 "configure"
@@ -11339,7 +11361,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11383,10 +11405,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11387: checking for glXCreatePbuffer" >&5
+echo "configure:11409: checking for glXCreatePbuffer" >&5
-#line 11390 "configure"
+#line 11412 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11409,7 +11431,7 @@
; return 0; }
EOF
-if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11431,10 +11453,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11435: checking for glXCreateGLXPixmap" >&5
+echo "configure:11457: checking for glXCreateGLXPixmap" >&5
-#line 11438 "configure"
+#line 11460 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11457,7 +11479,7 @@
; return 0; }
EOF
-if { (eval echo configure:11461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11496,7 +11518,7 @@
-echo "configure:11500: checking for location of OpenGL includes" >&5
+echo "configure:11522: checking for location of OpenGL includes" >&5
@@ -11522,15 +11544,15 @@
do
-echo "configure:11526: checking for $ac_hdr" >&5
+echo "configure:11548: checking for $ac_hdr" >&5
-#line 11529 "configure"
+#line 11551 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11565,10 +11587,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11569: checking for glBegin" >&5
+echo "configure:11591: checking for glBegin" >&5
-#line 11572 "configure"
+#line 11594 "configure"
which can conflict with char glBegin(); below. */
@@ -11591,7 +11613,7 @@
; return 0; }
EOF
-if { (eval echo configure:11595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11606,10 +11628,10 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11610: checking for gluBeginCurve" >&5
+echo "configure:11632: checking for gluBeginCurve" >&5
-#line 11613 "configure"
+#line 11635 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11632,7 +11654,7 @@
; return 0; }
EOF
-if { (eval echo configure:11636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11676,7 +11698,7 @@
-echo "configure:11680: checking for location of OpenGL includes" >&5
+echo "configure:11702: checking for location of OpenGL includes" >&5
@@ -11702,15 +11724,15 @@
do
-echo "configure:11706: checking for $ac_hdr" >&5
+echo "configure:11728: checking for $ac_hdr" >&5
-#line 11709 "configure"
+#line 11731 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11714: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11744,7 +11766,7 @@
-echo "configure:11748: checking for location of OpenGL library" >&5
+echo "configure:11770: checking for location of OpenGL library" >&5
@@ -11769,18 +11791,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11773: checking for OpenGL library" >&5
+echo "configure:11795: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11777 "configure"
+#line 11799 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11804,18 +11826,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11808: checking for GLU library" >&5
+echo "configure:11830: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11812 "configure"
+#line 11834 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11864,7 +11886,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11868: checking whether to use ODBC" >&5
+echo "configure:11890: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11883,7 +11905,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11887: checking for location of ODBC includes" >&5
+echo "configure:11909: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11909,15 +11931,15 @@
do
-echo "configure:11913: checking for $ac_hdr" >&5
+echo "configure:11935: checking for $ac_hdr" >&5
-#line 11916 "configure"
+#line 11938 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11921: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11951,7 +11973,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11955: checking for location of ODBC library" >&5
+echo "configure:11977: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11976,13 +11998,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11980: checking for SQLConnect in -lodbc" >&5
+echo "configure:12002: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11986 "configure"
+#line 12008 "configure"
@@ -11993,7 +12015,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12018,13 +12040,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12022: checking for SQLConnect in -liodbc" >&5
+echo "configure:12044: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12028 "configure"
+#line 12050 "configure"
@@ -12035,7 +12057,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12060,11 +12082,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12064: checking for ODBC library" >&5
+echo "configure:12086: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12068 "configure"
+#line 12090 "configure"
#include <windows.h>
#include <sql.h>
@@ -12072,7 +12094,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12121,7 +12143,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12125: checking whether to use FFTW" >&5
+echo "configure:12147: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12140,7 +12162,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12144: checking for location of FFTW includes" >&5
+echo "configure:12166: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12166,15 +12188,15 @@
do
-echo "configure:12170: checking for $ac_hdr" >&5
+echo "configure:12192: checking for $ac_hdr" >&5
-#line 12173 "configure"
+#line 12195 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12202,15 +12224,15 @@
do
-echo "configure:12206: checking for $ac_hdr" >&5
+echo "configure:12228: checking for $ac_hdr" >&5
-#line 12209 "configure"
+#line 12231 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12214: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12238,15 +12260,15 @@
do
-echo "configure:12242: checking for $ac_hdr" >&5
+echo "configure:12264: checking for $ac_hdr" >&5
-#line 12245 "configure"
+#line 12267 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12292,7 +12314,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12296: checking for location of FFTW library" >&5
+echo "configure:12318: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12317,13 +12339,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12321: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12343: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12327 "configure"
+#line 12349 "configure"
@@ -12334,7 +12356,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12359,13 +12381,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12363: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12385: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12369 "configure"
+#line 12391 "configure"
@@ -12376,7 +12398,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12380: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12401,13 +12423,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12405: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12427: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12411 "configure"
+#line 12433 "configure"
@@ -12418,7 +12440,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12475,7 +12497,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12479: checking whether to use BLAS" >&5
+echo "configure:12501: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12496,7 +12518,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12500: checking for location of BLAS includes" >&5
+echo "configure:12522: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12516,7 +12538,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12520: checking for location of BLAS library" >&5
+echo "configure:12542: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12542,15 +12564,15 @@
do
-echo "configure:12546: checking for $ac_hdr" >&5
+echo "configure:12568: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12549 "configure"
+#line 12571 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12585,13 +12607,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12589: checking for dnrm2_ in -lblas" >&5
+echo "configure:12611: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12595 "configure"
+#line 12617 "configure"
@@ -12602,7 +12624,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12621,13 +12643,13 @@
-echo "configure:12625: checking for dnrm2_ in -lblas" >&5
+echo "configure:12647: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12631 "configure"
+#line 12653 "configure"
@@ -12638,7 +12660,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12682,13 +12704,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12686: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12708: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12692 "configure"
+#line 12714 "configure"
@@ -12699,7 +12721,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12714,13 +12736,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12718: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12740: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12724 "configure"
+#line 12746 "configure"
@@ -12731,7 +12753,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12746,13 +12768,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12750: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12772: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12756 "configure"
+#line 12778 "configure"
@@ -12763,7 +12785,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12808,16 +12830,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12812: checking for sgemm in $vlib_flags" >&5
+echo "configure:12834: checking for sgemm in $vlib_flags" >&5
-#line 12814 "configure"
+#line 12836 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12835,13 +12857,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12839: checking for sgemm_ in -lblas" >&5
+echo "configure:12861: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $LIBS"
-#line 12845 "configure"
+#line 12867 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12852,7 +12874,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12867,13 +12889,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12871: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12893: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12877 "configure"
+#line 12899 "configure"
@@ -12884,7 +12906,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12899,13 +12921,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12903: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12925: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12909 "configure"
+#line 12931 "configure"
@@ -12916,7 +12938,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12950,13 +12972,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12954: checking for acosp in -lsunmath" >&5
+echo "configure:12976: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12960 "configure"
+#line 12982 "configure"
@@ -12967,7 +12989,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12982,13 +13004,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12986: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13008: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12992 "configure"
+#line 13014 "configure"
@@ -12999,7 +13021,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13029,13 +13051,13 @@
# Generic BLAS library
-echo "configure:13033: checking for sgemm_ in -lblas" >&5
+echo "configure:13055: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13039 "configure"
+#line 13061 "configure"
@@ -13046,7 +13068,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13085,7 +13107,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13089: checking whether to use LAPACK" >&5
+echo "configure:13111: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13110,7 +13132,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13114: checking for location of LAPACK includes" >&5
+echo "configure:13136: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13130,7 +13152,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13134: checking for location of LAPACK library" >&5
+echo "configure:13156: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13156,15 +13178,15 @@
do
-echo "configure:13160: checking for $ac_hdr" >&5
+echo "configure:13182: checking for $ac_hdr" >&5
-#line 13163 "configure"
+#line 13185 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13190: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13196,10 +13218,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13200: checking for dsegv_" >&5
+echo "configure:13222: checking for dsegv_" >&5
-#line 13203 "configure"
+#line 13225 "configure"
which can conflict with char dsegv_(); below. */
@@ -13222,7 +13244,7 @@
; return 0; }
EOF
-if { (eval echo configure:13226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13249,13 +13271,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13253: checking for desgv_ in -llapack" >&5
+echo "configure:13275: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13259 "configure"
+#line 13281 "configure"
@@ -13266,7 +13288,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13298,13 +13320,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13302: checking for dgesv_ in -llapack" >&5
+echo "configure:13324: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13308 "configure"
+#line 13330 "configure"
@@ -13315,7 +13337,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13334,13 +13356,13 @@
-echo "configure:13338: checking for dgesv_ in -llapack" >&5
+echo "configure:13360: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13344 "configure"
+#line 13366 "configure"
@@ -13351,7 +13373,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13407,7 +13429,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13411: checking whether to use Motif" >&5
+echo "configure:13433: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13426,7 +13448,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13430: checking for location of Motif includes" >&5
+echo "configure:13452: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13452,15 +13474,15 @@
do
-echo "configure:13456: checking for $ac_hdr" >&5
+echo "configure:13478: checking for $ac_hdr" >&5
-#line 13459 "configure"
+#line 13481 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13494,7 +13516,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13498: checking for location of Motif library" >&5
+echo "configure:13520: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13519,13 +13541,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13523: checking for XmStringCreate in -lXm" >&5
+echo "configure:13545: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13529 "configure"
+#line 13551 "configure"
@@ -13536,7 +13558,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13577,7 +13599,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13581: checking whether to use Cairo" >&5
+echo "configure:13603: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13603,15 +13625,15 @@
do
-echo "configure:13607: checking for $ac_hdr" >&5
+echo "configure:13629: checking for $ac_hdr" >&5
-#line 13610 "configure"
+#line 13632 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13648,10 +13670,10 @@
LDFLAGS="$LDFLAGS $CAIROLIB"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13652: checking for cairo_create" >&5
+echo "configure:13674: checking for cairo_create" >&5
-#line 13655 "configure"
+#line 13677 "configure"
which can conflict with char cairo_create(); below. */
@@ -13674,7 +13696,7 @@
; return 0; }
EOF
-if { (eval echo configure:13678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13709,7 +13731,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13713: checking whether to use GLw" >&5
+echo "configure:13735: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13728,7 +13750,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13732: checking for location of GLw includes" >&5
+echo "configure:13754: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13754,15 +13776,15 @@
do
-echo "configure:13758: checking for $ac_hdr" >&5
+echo "configure:13780: checking for $ac_hdr" >&5
-#line 13761 "configure"
+#line 13783 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13790,15 +13812,15 @@
do
-echo "configure:13794: checking for $ac_hdr" >&5
+echo "configure:13816: checking for $ac_hdr" >&5
-#line 13797 "configure"
+#line 13819 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13802: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13838,7 +13860,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13842: checking for location of GLw library" >&5
+echo "configure:13864: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13863,13 +13885,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13867: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13889: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13873 "configure"
+#line 13895 "configure"
@@ -13880,7 +13902,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13905,13 +13927,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13909: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13931: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13915 "configure"
+#line 13937 "configure"
@@ -13922,7 +13944,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13947,13 +13969,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13951: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13973: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13957 "configure"
+#line 13979 "configure"
@@ -13964,7 +13986,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13989,13 +14011,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13993: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14015: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13999 "configure"
+#line 14021 "configure"
@@ -14006,7 +14028,7 @@
; return 0; }
EOF
-if { (eval echo configure:14010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14031,13 +14053,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14035: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14057: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14041 "configure"
+#line 14063 "configure"
@@ -14048,7 +14070,7 @@
; return 0; }
EOF
-if { (eval echo configure:14052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14073,13 +14095,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14077: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14099: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14083 "configure"
+#line 14105 "configure"
@@ -14090,7 +14112,7 @@
; return 0; }
EOF
-if { (eval echo configure:14094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14117,13 +14139,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14121: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14143: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14127 "configure"
+#line 14149 "configure"
@@ -14134,7 +14156,7 @@
; return 0; }
EOF
-if { (eval echo configure:14138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14153,13 +14175,13 @@
-echo "configure:14157: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14179: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14163 "configure"
+#line 14185 "configure"
@@ -14170,7 +14192,7 @@
; return 0; }
EOF
-if { (eval echo configure:14174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14197,13 +14219,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14201: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14223: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14207 "configure"
+#line 14229 "configure"
@@ -14214,7 +14236,7 @@
; return 0; }
EOF
-if { (eval echo configure:14218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14233,13 +14255,13 @@
-echo "configure:14237: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14259: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14243 "configure"
+#line 14265 "configure"
@@ -14250,7 +14272,7 @@
; return 0; }
EOF
-if { (eval echo configure:14254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14363,7 +14385,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14367: checking whether to use FreeType" >&5
+echo "configure:14389: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14382,7 +14404,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14386: checking for location of FreeType includes" >&5
+echo "configure:14408: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14408,15 +14430,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14412: checking for $ac_hdr" >&5
+echo "configure:14434: checking for $ac_hdr" >&5
-#line 14415 "configure"
+#line 14437 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14450,7 +14472,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14454: checking for location of FreeType library" >&5
+echo "configure:14476: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14475,13 +14497,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14479: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14501: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14485 "configure"
+#line 14507 "configure"
@@ -14492,7 +14514,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14533,7 +14555,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14537: checking whether to use NLS" >&5
+echo "configure:14559: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14553,10 +14575,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14557: checking for gettext" >&5
+echo "configure:14579: checking for gettext" >&5
-#line 14560 "configure"
+#line 14582 "configure"
which can conflict with char gettext(); below. */
@@ -14579,7 +14601,7 @@
; return 0; }
EOF
-if { (eval echo configure:14583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14597,13 +14619,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14601: checking for gettext in -lintl" >&5
+echo "configure:14623: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14607 "configure"
+#line 14629 "configure"
@@ -14614,7 +14636,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14640: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14649,7 +14671,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14653: checking whether to use C++" >&5
+echo "configure:14675: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14665,7 +14687,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14669: checking for $ac_word" >&5
+echo "configure:14691: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14694,7 +14716,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14698: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14720: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14705,12 +14727,12 @@
cat > conftest.$ac_ext << EOF
-#line 14709 "configure"
+#line 14731 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14736,19 +14758,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14740: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14762: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14745: checking whether we are using GNU C++" >&5
+echo "configure:14767: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14752: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14774: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14766,7 +14788,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14770: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14792: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14807,7 +14829,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14811: checking whether to use openDWG" >&5
+echo "configure:14833: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14827,7 +14849,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14831: checking for location of openDGW includes" >&5
+echo "configure:14853: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14853,15 +14875,15 @@
do
-echo "configure:14857: checking for $ac_hdr" >&5
+echo "configure:14879: checking for $ac_hdr" >&5
-#line 14860 "configure"
+#line 14882 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14865: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14887: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14895,7 +14917,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14899: checking for location of openDWG library" >&5
+echo "configure:14921: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14942,7 +14964,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14946: checking for special C compiler options needed for large files" >&5
+echo "configure:14968: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14950,7 +14972,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14954 "configure"
+#line 14976 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14966,7 +14988,7 @@
; return 0; }
EOF
-if { (eval echo configure:14970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14975,7 +14997,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14979 "configure"
+#line 15001 "configure"
@@ -14991,7 +15013,7 @@
; return 0; }
EOF
-if { (eval echo configure:14995: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15017: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15011,11 +15033,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15015: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15037: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15019 "configure"
+#line 15041 "configure"
@@ -15031,14 +15053,14 @@
; return 0; }
EOF
-if { (eval echo configure:15035: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15057: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15042 "configure"
+#line 15064 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15056,7 +15078,7 @@
; return 0; }
EOF
-if { (eval echo configure:15060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15082: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15075,11 +15097,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15079: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15101: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15083 "configure"
+#line 15105 "configure"
@@ -15095,14 +15117,14 @@
; return 0; }
EOF
-if { (eval echo configure:15099: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15121: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15106 "configure"
+#line 15128 "configure"
#define _LARGE_FILES 1
@@ -15120,7 +15142,7 @@
; return 0; }
EOF
-if { (eval echo configure:15124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15146: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15139,25 +15161,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15143: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15165: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15147 "configure"
+#line 15169 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15154: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15176: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15161 "configure"
+#line 15183 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15166,7 +15188,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15170: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15192: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15187,10 +15209,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15191: checking if system supports Large Files at all" >&5
+echo "configure:15213: checking if system supports Large Files at all" >&5
-#line 15194 "configure"
+#line 15216 "configure"
#include <stdio.h>
@@ -15222,7 +15244,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15226: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15248: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15251,7 +15273,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15255: checking whether to use Python" >&5
+echo "configure:15277: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15271,7 +15293,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:15275: checking for $ac_word" >&5
+echo "configure:15297: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15316,15 +15338,15 @@
do
-echo "configure:15320: checking for $ac_hdr" >&5
+echo "configure:15342: checking for $ac_hdr" >&5
-#line 15323 "configure"
+#line 15345 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15350: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15364,7 +15386,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15368: checking for $ac_word" >&5
+echo "configure:15390: checking for $ac_word" >&5
case "$SWIG" in
@@ -15410,7 +15432,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15414: checking whether to use wxWidgets" >&5
+echo "configure:15436: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15430,7 +15452,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15434: checking for $ac_word" >&5
+echo "configure:15456: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15478,7 +15500,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15482: checking wxWidgets version" >&5
+echo "configure:15504: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15501,15 +15523,15 @@
do
-echo "configure:15505: checking for $ac_hdr" >&5
+echo "configure:15527: checking for $ac_hdr" >&5
-#line 15508 "configure"
+#line 15530 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15535: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15545,15 +15567,15 @@
do
-echo "configure:15549: checking for $ac_hdr" >&5
+echo "configure:15571: checking for $ac_hdr" >&5
-#line 15552 "configure"
+#line 15574 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15557: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15579: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2008-07-19 21:44:11 UTC (rev 32173)
+++ grass/branches/develbranch_6/configure.in 2008-07-19 22:36:42 UTC (rev 32174)
@@ -99,6 +99,10 @@
AC_SUBST(ARCH)
+# Use absolute path for aux directory so that install-sh works
+AC_CONFIG_AUX_DIR($SRCDIR)
# Set GISBASE and GRASS_BIN
GISBASE=${WINDSTDIR}/dist.${ARCH}
