[GRASS-SVN] r32176 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Jul 19 19:24:28 EDT 2008
Author: martinl
Date: 2008-07-19 19:24:28 -0400 (Sat, 19 Jul 2008)
New Revision: 32176
grass/trunk/gui/wxpython/gui_modules/dbm.py
wxGUI/dbm: fix trac #227 (column names uppercase, v.db.connect returns key column name lowercase)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-07-19 22:38:12 UTC (rev 32175)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-07-19 23:24:28 UTC (rev 32176)
@@ -2872,7 +2872,7 @@
type = columns[name]['type']
value = columns[name]['values'][idx]
id = columns[name]['ids'][idx]
- if name.lower() != key:
+ if name != key:
self.FindWindowById(id).SetValue(str(value))
def OnCancel(self, event):
@@ -2992,7 +2992,7 @@
else:
value = ''
- if name.lower() == key:
+ if name == key:
box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
label=" %s %s " % (_("Category"), value))
boxFont = self.GetFont()
@@ -3121,6 +3121,14 @@
else:
return False
+ # check for key column
+ # v.db.connect -g/p returns always key column name lowercase
+ if self.layers[layer]["key"] not in columns.keys():
+ for col in columns.keys():
+ if col.lower() == self.layers[layer]["key"]:
+ self.layers[layer]["key"] = col.upper()
+ break
self.tables[table] = columns
return True
