[GRASS-SVN] r32178 - grass/trunk/scripts/r.in.aster
Sun Jul 20 02:32:41 EDT 2008
Author: cmbarton
Date: 2008-07-20 02:32:41 -0400 (Sun, 20 Jul 2008)
New Revision: 32178
Added:
   grass/trunk/scripts/r.in.aster/r_in_aster.html
   grass/trunk/scripts/r.in.aster/r_in_aster.py
New Python version of r.in.aster bash script. Some improvements and bug fix for Mac over original script.
Added: grass/trunk/scripts/r.in.aster/r_in_aster.html
--- grass/trunk/scripts/r.in.aster/r_in_aster.html	                        (rev 0)
+++ grass/trunk/scripts/r.in.aster/r_in_aster.html	2008-07-20 06:32:41 UTC (rev 32178)
@@ -0,0 +1,28 @@
+<H2>DESCRIPTION</H2>
+<EM>r_in_aster.py</EM> uses GDALWARP and r.in.gdal to read, georectify, reproject, and import into GRASS Terra/ASTER imagery in HDF4 format. It will import Level 1A, Level 1B, and DEM imagery.
+<P>
+The user selects the *.hdf file to import, the type of imagery (Level 1B is the default), the bands to import, and the base name of the output file. Single or multiple bands can be imported by entering the band number or numbers separated by commas (1,2,3n,3b,4,5,6,7,8,9,10,11,12,13,14) in the input field. All bands can be imported by entering 'all' in the input field. The band number will be appended to the output file base name ('.DEM' will be appended to DEM files).
+<P>
+GDALWARP will attempt to reproject the Terra/ASTER imagery into the current location. For some Terra/ASTER files this may be unsuccesful. There will be an error message to that effect. The user will need to start GRASS in a location that matches the Terra/ASTER imagery--possibly a latlon location.
+<H2>NOTES</H2>
+<P>
+<h2>EXAMPLE</h2>
+<H2>SEE ALSO</H2>
+<EM><A HREF="r.in.aster">r.in.aster</A></EM>
+<H2>GDAL GDALWARP REQUIREMENT</H2>
+em>r.in.aster</em> requires <A HREF="http://www.gdal.org/gdalwarp.html">GDALWARP</a> (one of the Geographic Data Abstraction Library [GDAL] utilities) to be installed and to be in the user's path. GDAL must be compiled with HDF4 support.
+<H2>AUTHORS</H2>
+Michael Barton, Arizona State University<BR>
+Paul Kelley<BR>
+<p><i>Last changed: 2008-07-19</i></p>
Added: grass/trunk/scripts/r.in.aster/r_in_aster.py
--- grass/trunk/scripts/r.in.aster/r_in_aster.py	                        (rev 0)
+++ grass/trunk/scripts/r.in.aster/r_in_aster.py	2008-07-20 06:32:41 UTC (rev 32178)
@@ -0,0 +1,240 @@
+#!/usr/bin/python
+# MODULE:       r_in_aster.py
+# AUTHOR(S):    Michael Barton (michael.barton at asu.edu)
+#                   Based on r.in.aster bash script for GRASS
+#                   by Michael Barton and Paul Kelly
+# PURPOSE:      Rectifies, georeferences, & imports Terra-ASTER imagery
+#                   using gdalwarp
+# COPYRIGHT:    (C) 2008 by the GRASS Development Team
+#       This program is free software under the GNU General Public
+#       License (>=v2). Read the file COPYING that comes with GRASS
+#       for details.
+# Requires:
+#   gdalwarp
+#%Module
+#%  description: Georeference, rectify, and import Terra-ASTER imagery and relative DEM's using gdalwarp.
+#%  keywords: raster, imagery, import
+#%End
+#%option
+#%  key: input
+#%  type: string
+#%  gisprompt: old_file,file,input
+#%  description: Input ASTER image to be georeferenced & rectified
+#%  required: yes
+#%end
+#%option
+#%  key: proctype
+#%  type: string
+#%  description: ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)
+#%  options: L1A,L1B,DEM
+#%  answer: L1B
+#%  required: yes
+#%end
+#%option
+#%  key: band
+#%  type: string
+#%  description: List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands
+#%  answer: all
+#%  required: yes
+#%end
+#%option
+#%  key: output
+#%  type: string
+#%  description: Base name for output raster map (band number will be appended to base name)
+#%  gisprompt: old,cell,raster
+#%  required: yes
+#%end
+#%flag
+#%  key: o
+#%  description: Overwrite existing file
+#%END
+import sys
+import os
+import subprocess
+import platform
+def main():
+    #if ( os.getenv("GIS_FLAG_OVERWRITE") == "1" ):
+    #    print "Flag -f set"
+    #else:
+    #    print "Flag -f not set"
+    #check whether gdalwarp is in path and executable
+    p = None
+    try:
+        p = subprocess.call(['gdalwarp', '--version'])
+    except:
+        pass
+    if p == None or p != 0:
+        subprocess.call(["g.message", "-e", "gdalwarp is not in the path and executable"])
+        return
+    #initialize variables
+    dataset = ''
+    srcfile = ''
+    proj = ''
+    band = ''
+    outfile = ''
+    bandlist = []
+    #create temporary file to hold gdalwarp output before importing to GRASS
+    tempfileCmd = subprocess.Popen(["g.tempfile","pid=%d" % os.getpid()],stdout=subprocess.PIPE, stderr=subprocess.PIPE)
+    tempfile = tempfileCmd.stdout.read().strip()
+    tempfile=tempfile + '.tif'
+    #get projection information for current GRASS location
+    p = subprocess.Popen(['g.proj', '-jf'], stdout=subprocess.PIPE,
+            stderr=subprocess.PIPE)
+    proj = p.stdout.read()
+    #currently only runs in projected location
+    if "XY location" in proj:
+      subprocess.call(["g.message", "-e", "This module needs to be run in a projected location (found: %s)" % proj])
+      return
+    #process list of bands
+    if os.getenv("GIS_OPT_BAND").strip() == 'all':
+        bandlist = ['1','2','3n','3b','4','5','6','7','8','9','10','11','12','13','14']
+    else:
+        bandlist = os.getenv("GIS_OPT_BAND").split(',')
+    print 'bandlist =',bandlist
+    #initialize datasets for L1A and L1B
+    if os.getenv("GIS_OPT_PROCTYPE") == "L1A":
+        for band in bandlist:
+            if band == '1':
+                dataset="VNIR_Band1:ImageData"
+            elif band == '2':
+                dataset="VNIR_Band2:ImageData"
+            elif band == '3n':
+                dataset="VNIR_Band3N:ImageData"
+            elif band == '3b':
+                dataset="VNIR_Band3B:ImageData"
+            elif band == '4':
+                dataset="SWIR_Band4:ImageData"
+            elif band == '5':
+                dataset="SWIR_Band5:ImageData"
+            elif band == '6':
+                dataset="SWIR_Band6:ImageData"
+            elif band == '7':
+                dataset="SWIR_Band7:ImageData"
+            elif band == '8':
+                dataset="SWIR_Band8:ImageData"
+            elif band == '9':
+                dataset="SWIR_Band9:ImageData"
+            elif band == '10':
+                dataset="TIR_Band10:ImageData"
+            elif band == '11':
+                dataset="TIR_Band11:ImageData"
+            elif band == '12':
+                dataset="TIR_Band12:ImageData"
+            elif band == '13':
+                dataset="TIR_Band13:ImageData"
+            elif band == '14':
+                dataset="TIR_Band14:ImageData"
+            srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (os.getenv("GIS_OPT_INPUT"), dataset)
+            import_aster(proj, srcfile, tempfile, band)
+    elif os.getenv("GIS_OPT_PROCTYPE") == "L1B":
+            if band == '1':
+                dataset="VNIR_Swath:ImageData1"
+            elif band == '2':
+                dataset="VNIR_Swath:ImageData2"
+                dataset="VNIR_Swath:ImageData3N"
+                dataset="VNIR_Swath:ImageData3B"
+            elif band == '4':
+                dataset="SWIR_Swath:ImageData4"
+            elif band == '5':
+                dataset="SWIR_Swath:ImageData5"
+            elif band == '6':
+                dataset="SWIR_Swath:ImageData6"
+            elif band == '7':
+                dataset="SWIR_Swath:ImageData7"
+            elif band == '8':
+                dataset="SWIR_Swath:ImageData8"
+            elif band == '9':
+                dataset="SWIR_Swath:ImageData9"
+                dataset="TIR_Swath:ImageData10"
+                dataset="TIR_Swath:ImageData11"
+                dataset="TIR_Swath:ImageData12"
+                dataset="TIR_Swath:ImageData13"
+                dataset="TIR_Swath:ImageData14"
+    elif os.getenv("GIS_OPT_PROCTYPE") == "DEM":
+        srcfile=os.getenv("GIS_OPT_INPUT")
+        import_aster(proj, srcfile, tempfile, "DEM")
+    #for debugging
+    #print 'source file=',srcfile
+    #print 'tempfile=',tempfile
+    #print 'proj =',proj
+    # write cmd history: Not sure how to replicate this in Python yet
+    #r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
+    #cleanup
+    subprocess.call(["g.message", "Cleaning up ..."])
+    os.remove(tempfile)
+    subprocess.call(["g.message", "Done."])
+    return
+def import_aster(proj, srcfile, tempfile, band):
+    #run gdalwarp with selected options (must be in $PATH)
+    #to translate aster image to geotiff
+    subprocess.call(["g.message", "Georeferencing aster image ..."])
+    subprocess.call(["g.message", "-d", "message=gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile)])
+    if platform.system() == "Darwin":
+        cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile, tempfile ]
+    else:
+        cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile ]
+    p = subprocess.call(cmd)
+    if p != 0:
+        #check to see if gdalwarp executed properly
+        return
+    #p = subprocess.call(["gdal_translate", srcfile, tempfile])
+    #import geotiff to GRASS
+    subprocess.call(["g.message", "Importing into GRASS ..."])
+    outfile = os.getenv("GIS_OPT_OUTPUT").strip()+'.'+band
+    cmd = ["r.in.gdal", "input=%s" % tempfile, "output=%s" % outfile]
+    if ( os.getenv("GIS_FLAG_O") == "1" ):
+        cmd.append("--o")
+    #msgcmd = ['g.message']
+    #msgcmd = msgcmd.extend(cmd)
+    #subprocess.call(msgcmd)
+    subprocess.call(cmd)
+    return
+if __name__ == "__main__":
+    if ( len(sys.argv) <= 1 or sys.argv[1] != "@ARGS_PARSED@" ):
+        os.execvp("g.parser", [sys.argv[0]] + sys.argv)
+    else:
+        main();
