[GRASS-SVN] r32200 - in grass/trunk: include lib/nviz lib/ogsf visualization/nviz2/cmd
Mon Jul 21 18:52:43 EDT 2008
Author: martinl
Date: 2008-07-21 18:52:43 -0400 (Mon, 21 Jul 2008)
New Revision: 32200
   grass/trunk/include/nviz.h
   grass/trunk/lib/nviz/map_obj.c
   grass/trunk/lib/ogsf/GP2.c
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/local_proto.h
   grass/trunk/visualization/nviz2/cmd/main.c
   grass/trunk/visualization/nviz2/cmd/surface.c
   grass/trunk/visualization/nviz2/cmd/vector.c
nviz2/cmd: module/nvizlib updated to support 2d points (in progress)
Modified: grass/trunk/include/nviz.h
--- grass/trunk/include/nviz.h	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/include/nviz.h	2008-07-21 22:52:43 UTC (rev 32200)
@@ -171,7 +171,7 @@
 		     nv_data *);
 int Nviz_set_attr(int, int, int, int, const char *, float,
 		  nv_data *);
-void Nviz_set_attr_default();
+void Nviz_set_surface_attr_default();
 int Nviz_unset_attr(int, int, int);
 /* nviz.c */
Modified: grass/trunk/lib/nviz/map_obj.c
--- grass/trunk/lib/nviz/map_obj.c	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/lib/nviz/map_obj.c	2008-07-21 22:52:43 UTC (rev 32200)
@@ -91,7 +91,7 @@
     /* vector overlay */
     else if (type == MAP_OBJ_VECT) {
 	if (GV_num_vects() >= MAX_VECTS) {
-	    G_warning (_("Maximum vectors loaded!"));
+	    G_warning (_("Maximum vector line maps loaded!"));
 	    return -1;
@@ -120,7 +120,7 @@
     else if (type == MAP_OBJ_SITE) {
 	geosite * gp;
 	if (GP_num_sites() >= MAX_SITES) {
-	    G_warning (_("Maximum point vectors loaded!"));
+	    G_warning (_("Maximum vector point maps loaded!"));
 	    return -1;
@@ -137,17 +137,15 @@
 	/* load vector points */
 	if (0 > GP_load_site(new_id, name)) {
 	    GP_delete_site(new_id);
-	    G_warning (_("Error loading point vector map <%s>"), name);
+	    G_warning (_("Error loading vector map <%s>"), name);
 	    return -1;
 	/* initialize display parameters */
 	GP_set_sitemode(new_id, ST_ATT_NONE, 0xFF0000, 2, 100, ST_X);
 	surf_list = GS_get_surf_list(&num_surfs);
-	if (num_surfs) {
-	    for (i = 0; i < num_surfs; i++) {
-		GP_select_surf(new_id, surf_list[i]);
+	for (i = 0; i < num_surfs; i++) {
+	    GP_select_surf(new_id, surf_list[i]);
 	G_free (surf_list);
@@ -291,9 +289,9 @@
-  \brief Set default map object attributes
+  \brief Set default surface attributes
     float defs[MAX_ATTS];
Modified: grass/trunk/lib/ogsf/GP2.c
--- grass/trunk/lib/ogsf/GP2.c	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/lib/ogsf/GP2.c	2008-07-21 22:52:43 UTC (rev 32200)
@@ -245,7 +245,7 @@
   \param id point set id
   \param atmod
   \param color icon color
-  \param width
+  \param width icon line width
   \param size icon size
   \param marker icon symbol
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2008-07-21 22:52:43 UTC (rev 32200)
@@ -9,7 +9,7 @@
   License (>=v2). Read the file COPYING that comes with GRASS
   for details.
-  \author Martin Landa <landa.martin gmail.com>
+  \author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
   \date 2008
@@ -26,6 +26,11 @@
 			const char *, const char *,
 			const char *, const char *);
+static void args_surface(struct GParams *);
+static void args_vline(struct GParams *);
+static void args_vpoint(struct GParams *);
+static void args_viewpoint(struct GParams *);
    \brief Parse command
@@ -44,6 +49,65 @@
       surface attributes
+    args_surface(params);
+      vector lines
+    args_vline(params);
+      vector points
+    args_vpoint(params);
+      misc
+    /* background color */
+    params->bgcolor = G_define_standard_option(G_OPT_C_BG);
+      viewpoint
+    args_viewpoint(params);
+      image
+    /* output */
+    params->output = G_define_standard_option(G_OPT_F_OUTPUT);
+    params->output->description = _("Name for output file (do not add extension)");
+    params->output->guisection = _("Image");
+    /* format */
+    params->format = G_define_option();
+    params->format->key = "format";
+    params->format->type = TYPE_STRING;
+    params->format->options = "ppm,tif"; /* TODO: png */
+    params->format->answer = "ppm";
+    params->format->description = _("Graphics file format");
+    params->format->required = YES;
+    params->format->guisection = _("Image");
+    /* size */
+    params->size = G_define_option();
+    params->size->key = "size";
+    params->size->type = TYPE_INTEGER;
+    params->size->key_desc = "width,height";
+    params->size->answer = "640,480";
+    params->size->description = _("Width and height of output image");
+    params->size->required = YES;
+    params->size->guisection = _("Image");
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    return;
+void args_surface(struct GParams *params)
     /* topography */
     params->elev_map = G_define_standard_option(G_OPT_R_ELEV);
     params->elev_map->key = "elevation_map";
@@ -220,70 +284,113 @@
     params->shade->answer = "gouraud";
     params->shade->guisection = _("Draw");
-      vector
-    params->vector = G_define_standard_option(G_OPT_V_MAP);
-    params->vector->multiple = YES;
-    params->vector->required = NO;
-    params->vector->description = _("Name of vector overlay map(s)");
-    params->vector->guisection = _("Vector");
-    params->vector->key = "vector";
+    return;
+void args_vline(struct GParams *params)
+    params->vlines = G_define_standard_option(G_OPT_V_MAP);
+    params->vlines->multiple = YES;
+    params->vlines->required = NO;
+    params->vlines->description = _("Name of line vector overlay map(s)");
+    params->vlines->guisection = _("Vector lines");
+    params->vlines->key = "vlines";
     /* line width */
-    params->line_width = G_define_option();
-    params->line_width->key = "line_width";
-    params->line_width->key_desc = "value";
-    params->line_width->type = TYPE_INTEGER;
-    params->line_width->required = NO;
-    params->line_width->multiple = YES;
-    params->line_width->description = _("Vector line width");
-    params->line_width->guisection = _("Vector");
-    params->line_width->options = "1-100";
-    params->line_width->answer = "2";
+    params->vline_width = G_define_option();
+    params->vline_width->key = "vline_width";
+    params->vline_width->key_desc = "value";
+    params->vline_width->type = TYPE_INTEGER;
+    params->vline_width->required = NO;
+    params->vline_width->multiple = YES;
+    params->vline_width->description = _("Vector line width");
+    params->vline_width->guisection = _("Vector lines");
+    params->vline_width->options = "1-100";
+    params->vline_width->answer = "2";
     /* line color */
-    params->line_color = G_define_standard_option(G_OPT_C_FG);
-    params->line_color->multiple = YES;
-    params->line_color->required = NO;
-    params->line_color->label = _("Vector line color");
-    params->line_color->key = "line_color";
-    params->line_color->answer = "blue";
-    params->line_color->guisection = _("Vector");
+    params->vline_color = G_define_standard_option(G_OPT_C_FG);
+    params->vline_color->multiple = YES;
+    params->vline_color->required = NO;
+    params->vline_color->label = _("Vector line color");
+    params->vline_color->key = "vline_color";
+    params->vline_color->answer = "blue";
+    params->vline_color->guisection = _("Vector lines");
     /* line mode */
-    params->line_mode = G_define_option();
-    params->line_mode->key = "line_mode";
-    params->line_mode->key_desc = "string";
-    params->line_mode->type = TYPE_STRING;
-    params->line_mode->required = YES;
-    params->line_mode->multiple = YES;
-    params->line_mode->description = _("Vector line display mode");
-    params->line_mode->options = "surface,flat";
-    params->line_mode->answer = "surface";
-    params->line_mode->guisection = _("Vector");
+    params->vline_mode = G_define_option();
+    params->vline_mode->key = "vline_mode";
+    params->vline_mode->key_desc = "string";
+    params->vline_mode->type = TYPE_STRING;
+    params->vline_mode->required = YES;
+    params->vline_mode->multiple = YES;
+    params->vline_mode->description = _("Vector line display mode");
+    params->vline_mode->options = "surface,flat";
+    params->vline_mode->answer = "surface";
+    params->vline_mode->guisection = _("Vector lines");
     /* line height */
-    params->line_height = G_define_option();
-    params->line_height->key = "line_height";
-    params->line_height->key_desc = "value";
-    params->line_height->type = TYPE_INTEGER;
-    params->line_height->required = NO;
-    params->line_height->multiple = YES;
-    params->line_height->description = _("Vector line height");
-    params->line_height->guisection = _("Vector");
-    params->line_height->options = "0-1000";
-    params->line_height->answer = "0";
+    params->vline_height = G_define_option();
+    params->vline_height->key = "vline_height";
+    params->vline_height->key_desc = "value";
+    params->vline_height->type = TYPE_INTEGER;
+    params->vline_height->required = NO;
+    params->vline_height->multiple = YES;
+    params->vline_height->description = _("Vector line height");
+    params->vline_height->guisection = _("Vector lines");
+    params->vline_height->options = "0-1000";
+    params->vline_height->answer = "0";
-      misc
-    /* background color */
-    params->bgcolor = G_define_standard_option(G_OPT_C_BG);
+    return;
-      viewpoint
+void args_vpoint(struct GParams *params)
+    params->vpoints = G_define_standard_option(G_OPT_V_MAP);
+    params->vpoints->multiple = YES;
+    params->vpoints->required = NO;
+    params->vpoints->description = _("Name of point vector overlay map(s)");
+    params->vpoints->guisection = _("Vector points");
+    params->vpoints->key = "vpoints";
+    /* point width */
+    params->vpoint_size = G_define_option();
+    params->vpoint_size->key = "vpoint_size";
+    params->vpoint_size->key_desc = "value";
+    params->vpoint_size->type = TYPE_INTEGER;
+    params->vpoint_size->required = NO;
+    params->vpoint_size->multiple = YES;
+    params->vpoint_size->description = _("Icon size");
+    params->vpoint_size->guisection = _("Vector points");
+    params->vpoint_size->options = "1-1000";
+    params->vpoint_size->answer = "100";
+    /* point color */
+    params->vpoint_color = G_define_standard_option(G_OPT_C_FG);
+    params->vpoint_color->multiple = YES;
+    params->vpoint_color->required = NO;
+    params->vpoint_color->label = _("Icon color");
+    params->vpoint_color->key = "vpoint_color";
+    params->vpoint_color->answer = "blue";
+    params->vpoint_color->guisection = _("Vector points");
+    /* point mode */
+    params->vpoint_symbol = G_define_option();
+    params->vpoint_symbol->key = "vpoint_symbol";
+    params->vpoint_symbol->key_desc = "string";
+    params->vpoint_symbol->type = TYPE_STRING;
+    params->vpoint_symbol->required = YES;
+    params->vpoint_symbol->multiple = YES;
+    params->vpoint_symbol->description = _("Icon symbol");
+    params->vpoint_symbol->options = "x,sphere,diamond,cube,box,gyro,aster,histogram";
+    params->vpoint_symbol->answer = "sphere";
+    params->vpoint_symbol->guisection = _("Vector points");
+    return;
+void args_viewpoint(struct GParams *params)
     /* position */
     params->pos = G_define_option();
     params->pos->key = "position";
@@ -338,38 +445,6 @@
     params->exag->multiple = NO;
     params->exag->description = _("Vertical exaggeration");
-      image
-    /* output */
-    params->output = G_define_standard_option(G_OPT_F_OUTPUT);
-    params->output->description = _("Name for output file (do not add extension)");
-    params->output->guisection = _("Image");
-    /* format */
-    params->format = G_define_option();
-    params->format->key = "format";
-    params->format->type = TYPE_STRING;
-    params->format->options = "ppm,tif"; /* TODO: png */
-    params->format->answer = "ppm";
-    params->format->description = _("Graphics file format");
-    params->format->required = YES;
-    params->format->guisection = _("Image");
-    /* size */
-    params->size = G_define_option();
-    params->size->key = "size";
-    params->size->type = TYPE_INTEGER;
-    params->size->key_desc = "width,height";
-    params->size->answer = "640,480";
-    params->size->description = _("Width and height of output image");
-    params->size->required = YES;
-    params->size->guisection = _("Image");
-    if (G_parser(argc, argv))
-        exit(EXIT_FAILURE);
     return;
@@ -377,34 +452,22 @@
   \brief Get number of answers of given option
   \param pointer to option
-  \param[out] number of non-zero length items (or NULL)
-  \param[out] number of all items (or NULL)
+  \return number of arguments
-void opt_get_num_answers(const struct Option *opt, int *non_zero, int *all)
+int opt_get_num_answers(const struct Option *opt)
     int i;
     i = 0;
-    if(non_zero)
-	*non_zero = 0;
-    if(all)
-	*all = 0;
     if (opt->answer) {
 	while (opt->answers[i]) {
-	    if (all)
-		(*all)++;
-	    if (strcmp(opt->answers[i], "")) {
-		if (non_zero)
-		    (*non_zero)++; /* skip empty values */
 	    i++;
-    return;
+    return i;
@@ -414,138 +477,128 @@
 void check_parameters(const struct GParams * params)
-    int nelev_map, nelev_const, nelev_map0, nelev_const0, nelevs0;
-    int nmaps0, nconsts0;
+    int nelev_map, nelev_const, nelevs;
+    int nmaps, nconsts;
     int nvects;
     /* topography */
-    opt_get_num_answers(params->elev_map, &nelev_map, &nelev_map0);
-    opt_get_num_answers(params->elev_const, &nelev_const, &nelev_const0);
-    if (nelev_map + nelev_const < 1)
+    nelev_map   = opt_get_num_answers(params->elev_map);
+    nelev_const = opt_get_num_answers(params->elev_const);
+    nelevs = nelev_map + nelev_const;
+    if (nelevs < 1)
 	G_fatal_error(_("At least one <%s> or <%s> required"),
 		      params->elev_map->key, params->elev_const->key);
-    if ((nelev_map > 0 && nelev_const > 0) &&
-	(nelev_map0 != nelev_const0))
-	G_fatal_error (_("Inconsistent number of attributes (<%s> %d, <%s> %d)"),
-		       params->elev_map->key, nelev_map0,
-		       params->elev_const->key, nelev_const0);
-    if (nelev_map0 > 0)
-	nelevs0 = nelev_map0;
-    else
-	nelevs0 = nelev_const0;
     /* color */
-    opt_get_num_answers(params->color_map, NULL, &nmaps0);
-    opt_get_num_answers(params->color_const, NULL, &nconsts0);
+    nmaps   = opt_get_num_answers(params->color_map);
+    nconsts = opt_get_num_answers(params->color_const);
-    print_error(nmaps0, nconsts0, nelevs0,
+    print_error(nmaps, nconsts, nelevs,
 		params->elev_map->key, params->elev_const->key,
 		params->color_map->key, params->color_const->key);
     /* mask */
-    opt_get_num_answers(params->mask_map, NULL, &nmaps0);
-    if (nmaps0 > 0 && nelevs0 != nmaps0)
+    nmaps = opt_get_num_answers(params->mask_map);
+    if (nmaps > 0 && nelevs != nmaps)
 	G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"),
-		      params->elev_map->key, params->elev_const->key, nelevs0,
-		      params->mask_map->key, nmaps0);
+		      params->elev_map->key, params->elev_const->key, nelevs,
+		      params->mask_map->key, nmaps);
     /* transparency */
-    opt_get_num_answers(params->transp_map, NULL, &nmaps0);
-    opt_get_num_answers(params->transp_const, NULL, &nconsts0);
+    nmaps   = opt_get_num_answers(params->transp_map);
+    nconsts = opt_get_num_answers(params->transp_const);
 		params->transp_map->key, params->transp_const->key);
     /* shininess */
-    opt_get_num_answers(params->shine_map, NULL, &nmaps0);
-    opt_get_num_answers(params->shine_const, NULL, &nconsts0);
+    nmaps   = opt_get_num_answers(params->shine_map);
+    nconsts = opt_get_num_answers(params->shine_const);
 		params->shine_map->key, params->shine_const->key);
     /* emit */
-    opt_get_num_answers(params->emit_map, NULL, &nmaps0);
-    opt_get_num_answers(params->emit_const, NULL, &nconsts0);
+    nmaps   = opt_get_num_answers(params->emit_map);
+    nconsts = opt_get_num_answers(params->emit_const);
 		params->emit_map->key, params->emit_const->key);
     /* draw mode */
     if (!params->mode_all->answer) { /* use one mode for all surfaces */
-	opt_get_num_answers(params->mode, NULL, &nconsts0);
-	if (nconsts0 > 0 && nconsts0 != nelevs0)
+	nconsts = opt_get_num_answers(params->mode);
+	if (nconsts > 0 && nconsts != nelevs)
-			  params->mode->key, nconsts0);
+			  params->mode->key, nconsts);
-	opt_get_num_answers(params->res_fine, NULL, &nconsts0);
+	nconsts = opt_get_num_answers(params->res_fine);
 	    G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d"),
-			  params->res_fine->key, nconsts0);
+			  params->res_fine->key, nconsts);
-	opt_get_num_answers(params->res_coarse, NULL, &nconsts0);
+	nconsts = opt_get_num_answers(params->res_coarse);
-			  params->res_coarse->key, nconsts0);
+			  params->res_coarse->key, nconsts);
-	opt_get_num_answers(params->style, NULL, &nconsts0);
+	nconsts = opt_get_num_answers(params->style);
-			  params->style->key, nconsts0);
+			  params->style->key, nconsts);
-	opt_get_num_answers(params->shade, NULL, &nconsts0);
+	nconsts = opt_get_num_answers(params->shade);
-			  params->shade->key, nconsts0);
+			  params->shade->key, nconsts);
-	opt_get_num_answers(params->wire_color, NULL, &nconsts0);
+	nconsts = opt_get_num_answers(params->wire_color);
-			  params->wire_color->key, nconsts0);
+			  params->wire_color->key, nconsts);
      * vector
-    opt_get_num_answers(params->vector, &nvects, NULL);
+    nvects = opt_get_num_answers(params->vlines);
     /* width */
-    opt_get_num_answers(params->line_width, NULL, &nconsts0);
-    if (nvects > 0 && nconsts0 != nvects)
+    nconsts = opt_get_num_answers(params->vline_width);
+    if (nvects > 0 && nconsts != nvects)
       G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
-		    params->vector->key, nvects,
-		    params->line_width->key, nconsts0);
+		    params->vlines->key, nvects,
+		    params->vline_width->key, nconsts);
     /* color */
-    opt_get_num_answers(params->line_color, NULL, &nconsts0);
+    nconsts = opt_get_num_answers(params->vline_color);
       G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d"),
-		    params->line_color->key, nconsts0);
+		    params->vline_color->key, nconsts);
     /* mode */
-    opt_get_num_answers(params->line_mode, NULL, &nconsts0);
+    nconsts = opt_get_num_answers(params->vline_mode);
-		    params->line_mode->key, nconsts0);
+		    params->vline_mode->key, nconsts);
     /* height */
-    opt_get_num_answers(params->line_height, NULL, &nconsts0);
+    nconsts = opt_get_num_answers(params->vline_height);
-		    params->line_height->key, nconsts0);
+		    params->vline_height->key, nconsts);
     return;
Modified: grass/trunk/visualization/nviz2/cmd/local_proto.h
--- grass/trunk/visualization/nviz2/cmd/local_proto.h	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/visualization/nviz2/cmd/local_proto.h	2008-07-21 22:52:43 UTC (rev 32200)
@@ -12,8 +12,10 @@
     *emit_map, *emit_const,
   /* draw */
     *mode, *res_fine, *res_coarse, *style, *shade, *wire_color,
-  /* vector */
-    *vector, *line_width, *line_color, *line_mode, *line_height,
+  /* vector lines */
+    *vlines, *vline_width, *vline_color, *vline_mode, *vline_height,
+  /* vector points */
+    *vpoints, *vpoint_size, *vpoint_symbol, *vpoint_color,
   /* misc */
     *exag, *bgcolor,
   /* viewpoint */
@@ -25,18 +27,21 @@
 /* args.c */
 void parse_command(int, char**, struct GParams *);
 int color_from_cmd(const char *);
-void opt_get_num_answers(const struct Option *, int *, int *);
+int opt_get_num_answers(const struct Option *);
 void check_parameters(const struct GParams *);
 /* surface.c */
 int load_rasters(const struct GParams *,
 		 nv_data *);
-void set_draw_mode(const struct GParams *);
+void surface_set_draw_mode(const struct GParams *);
 /* vector.c */
-int load_vectors(const struct GParams *,
-		 nv_data *);
-int set_lines_attrb(const struct GParams *);
+int load_vector_lines(const struct GParams *,
+		      nv_data *);
+int load_vector_points(const struct GParams *,
+		       nv_data *);
+int vlines_set_attrb(const struct GParams *);
+int vpoints_set_attrb(const struct GParams *);
 /* write_img.c */
 int write_img(const char *, int);
Modified: grass/trunk/visualization/nviz2/cmd/main.c
--- grass/trunk/visualization/nviz2/cmd/main.c	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/visualization/nviz2/cmd/main.c	2008-07-21 22:52:43 UTC (rev 32200)
@@ -2,10 +2,9 @@
  * MODULE:       nviz_cmd
- * AUTHOR(S):    Martin Landa <landa.martin gmail.com>
+ * AUTHOR(S):    Martin Landa <landa.martin gmail.com> (Google SoC 2008)
  * PURPOSE:      Experimental NVIZ CLI prototype
- *               Google SoC 2008
  * COPYRIGHT:    (C) 2008 by the GRASS Development Team
@@ -73,7 +72,7 @@
     Nviz_init_data(&data);
     /* define default attributes for map objects */
-    Nviz_set_attr_default();
+    Nviz_set_surface_attr_default();
     /* set background color */
     Nviz_set_bgcolor(&data, Nviz_color_from_str(params->bgcolor->answer));
@@ -102,13 +101,20 @@
     /* load raster maps (surface topography) & set attributes (map/constant) */
     load_rasters(params, &data);
     /* set draw mode of loaded surfaces */
-    set_draw_mode(params);
+    surface_set_draw_mode(params);
-    /* load vector maps & set line mode */
-    if (params->vector->answer) {
-	load_vectors(params, &data);
+    /* load line vector maps */
+    if (params->vlines->answer) {
+	load_vector_lines(params, &data);
+	/* set attributes of 2d lines */
+	vlines_set_attrb(params);
+    /* load point vector maps */
+    if (params->vpoints->answer) {
+	load_vector_points(params, &data);
 	/* set attributes for 2d lines */
-	set_lines_attrb(params);
+	vpoints_set_attrb(params);
     /* focus on loaded data */
Modified: grass/trunk/visualization/nviz2/cmd/surface.c
--- grass/trunk/visualization/nviz2/cmd/surface.c	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/visualization/nviz2/cmd/surface.c	2008-07-21 22:52:43 UTC (rev 32200)
@@ -32,24 +32,24 @@
     char *mapset;
     int i;
-    int nelevs, nelev_map0, nelev_const0, ncolor_map0, ncolor_const0, nmask_map0;
-    int ntransp_map0, ntransp_const0, nshine_map0, nshine_const0;
-    int nemit_map0, nemit_const0;
+    int nelevs, nelev_map, nelev_const, ncolor_map, ncolor_const, nmask_map;
+    int ntransp_map, ntransp_const, nshine_map, nshine_const;
+    int nemit_map, nemit_const;
     int *surf_list, nsurfs;
     int id;
-    opt_get_num_answers(params->elev_map, NULL, &nelev_map0);
-    opt_get_num_answers(params->elev_const, NULL, &nelev_const0);
-	nelevs = nelev_map0;
+    if (nelev_map > 0)
+	nelevs = nelev_map;
     else
-	nelevs = nelev_const0;
+	nelevs = nelev_const;
     /* topography (required) */
     for (i = 0; i < nelevs; i++) {
 	/* check maps */
-	if (i < nelev_map0 && strcmp(params->elev_map->answers[i], "")) {
+	if (i < nelev_map && strcmp(params->elev_map->answers[i], "")) {
 	    mapset = G_find_cell2 (params->elev_map->answers[i], "");
 	    if (mapset == NULL) {
 		G_fatal_error(_("Raster map <%s> not found"),
@@ -61,7 +61,7 @@
 				  data);
 	else {
-	    if (i < nelev_const0 && strcmp(params->elev_const->answers[i], "")) {
+	    if (i < nelev_const && strcmp(params->elev_const->answers[i], "")) {
 		id = Nviz_new_map_obj(MAP_OBJ_SURF,
 				      NULL, atof(params->elev_const->answers[i]),
 				      data);
@@ -76,21 +76,21 @@
     /* set surface attributes */
     surf_list = GS_get_surf_list(&nsurfs);
-    opt_get_num_answers(params->color_map, NULL, &ncolor_map0);
-    opt_get_num_answers(params->color_const, NULL, &ncolor_const0);
-    opt_get_num_answers(params->mask_map, NULL, &nmask_map0);
-    opt_get_num_answers(params->transp_map, NULL, &ntransp_map0);
-    opt_get_num_answers(params->transp_const, NULL, &ntransp_const0);
-    opt_get_num_answers(params->shine_map, NULL, &nshine_map0);
-    opt_get_num_answers(params->shine_const, NULL, &nshine_const0);
-    opt_get_num_answers(params->emit_map, NULL, &nemit_map0);
-    opt_get_num_answers(params->emit_const, NULL, &nemit_const0);
+    ncolor_map = opt_get_num_answers(params->color_map);
+    ncolor_const =opt_get_num_answers(params->color_const);
+    nmask_map = opt_get_num_answers(params->mask_map);
+    ntransp_map = opt_get_num_answers(params->transp_map);
+    ntransp_const = opt_get_num_answers(params->transp_const);
+    nshine_map = opt_get_num_answers(params->shine_map);
+    nshine_const = opt_get_num_answers(params->shine_const);
+    nemit_map = opt_get_num_answers(params->emit_map);
+    nemit_const = opt_get_num_answers(params->emit_const);
     for (i = 0; i < nsurfs; i++) {
 	id = surf_list[i];
 	/* color */
 	/* check for color map */
-	if (i < ncolor_map0 && strcmp(params->color_map->answers[i], "")) {
+	if (i < ncolor_map && strcmp(params->color_map->answers[i], "")) {
 	    mapset = G_find_cell2 (params->color_map->answers[i], "");
@@ -102,7 +102,7 @@
 			  data);
 	/* check for color value */
-	else if (i < ncolor_const0 && strcmp(params->color_const->answers[i], "")) {
+	else if (i < ncolor_const && strcmp(params->color_const->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, CONST_ATT,
 			  NULL, Nviz_color_from_str(params->color_const->answers[i]),
 			  data);
@@ -115,43 +115,43 @@
 			      G_fully_qualified_name(params->elev_map->answers[i], mapset));
 	/* mask */
-	if (i < nmask_map0 && strcmp(params->mask_map->answers[i], "")) {
+	if (i < nmask_map && strcmp(params->mask_map->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_MASK, MAP_ATT,
 			  G_fully_qualified_name(params->mask_map->answers[i], mapset), -1.0,
 			  data);
 	/* transparency */
-	if (i < ntransp_map0 && strcmp(params->transp_map->answers[i], "")) {
+	if (i < ntransp_map && strcmp(params->transp_map->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_TRANSP, MAP_ATT,
 			  G_fully_qualified_name(params->transp_map->answers[i], mapset), -1.0,
 			  data);
-	else if (i < ntransp_const0 && strcmp(params->transp_const->answers[i], "")) {
+	else if (i < ntransp_const && strcmp(params->transp_const->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_TRANSP, CONST_ATT,
 			  NULL, atof(params->transp_const->answers[i]),
 			  data);
 	/* shininess */
-	if (i < nshine_map0 && strcmp(params->shine_map->answers[i], "")) {
+	if (i < nshine_map && strcmp(params->shine_map->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_SHINE, MAP_ATT,
 			  G_fully_qualified_name(params->shine_map->answers[i], mapset), -1.0,
 			  data);
-	else if (i < nshine_const0 && strcmp(params->shine_const->answers[i], "")) {
+	else if (i < nshine_const && strcmp(params->shine_const->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_SHINE, CONST_ATT,
 			  NULL, atof(params->shine_const->answers[i]),
 			  data);
 	/* emission */
-	if (i < nemit_map0 && strcmp(params->emit_map->answers[i], "")) {
+	if (i < nemit_map && strcmp(params->emit_map->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_EMIT, MAP_ATT,
 			  G_fully_qualified_name(params->emit_map->answers[i], mapset), -1.0,
 			  data);
-	else if (i < nemit_const0 && strcmp(params->emit_const->answers[i], "")) {
+	else if (i < nemit_const && strcmp(params->emit_const->answers[i], "")) {
 	    Nviz_set_attr(id, MAP_OBJ_SURF, ATT_EMIT, CONST_ATT,
 			  NULL, atof(params->emit_const->answers[i]),
 			  data);
@@ -171,7 +171,7 @@
   \param params module parameters
-void set_draw_mode(const struct GParams *params)
+void surface_set_draw_mode(const struct GParams *params)
     int i, id, draw_mode;
Modified: grass/trunk/visualization/nviz2/cmd/vector.c
--- grass/trunk/visualization/nviz2/cmd/vector.c	2008-07-21 22:29:53 UTC (rev 32199)
+++ grass/trunk/visualization/nviz2/cmd/vector.c	2008-07-21 22:52:43 UTC (rev 32200)
@@ -21,23 +21,49 @@
 #include "local_proto.h"
+static int load_vectors(const struct Option *, const struct Option *,
+			const struct Option *, int, nv_data *);
-  \brief Load vector maps and set attributes
+  \brief Load vector maps (lines)
   \param data nviz data
   \return number of loaded vectors
-int load_vectors(const struct GParams *params,
-		 nv_data *data)
+int load_vector_lines(const struct GParams *params,
+		      nv_data *data)
+    return load_vectors(params->elev_map, params->elev_const,
+			params->vlines, MAP_OBJ_VECT, data);
+  \brief Load vector maps (points)
+  \param params module parameters
+  \param data nviz data
+  \return number of loaded vectors
+int load_vector_points(const struct GParams *params,
+		       nv_data *data)
+			params->vpoints, MAP_OBJ_SITE, data);
+int load_vectors(const struct Option *elev_map, const struct Option *elev_const,
+		 const struct Option *vect, int map_obj_type, nv_data *data)
     int i;
     int nvects;
     char *mapset;
-    if (!params->elev_map->answer && GS_num_surfs() == 0) { /* load base surface if no loaded */
+    if ((!elev_map->answer || elev_const->answer) &&
+	GS_num_surfs() == 0) { /* load base surface if no loaded */
 	int *surf_list, nsurf;
 	Nviz_new_map_obj(MAP_OBJ_SURF, NULL, 0.0, data);
@@ -48,14 +74,14 @@
     nvects = 0;
-    for (i = 0; params->vector->answers[i]; i++) {
-	mapset = G_find_vector2 (params->vector->answers[i], "");
+    for (i = 0; vect->answers[i]; i++) {
+	mapset = G_find_vector2 (vect->answers[i], "");
-	    G_fatal_error(_("Vector map <%s> not found"),
-			  params->vector->answers[i]);
+	  G_fatal_error(_("Vector map <%s> not found"),
+			vect->answers[i]);
-	Nviz_new_map_obj(MAP_OBJ_VECT,
-			 G_fully_qualified_name(params->vector->answers[i], mapset), 0.0,
+	Nviz_new_map_obj(map_obj_type,
+			 G_fully_qualified_name(vect->answers[i], mapset), 0.0,
 			 data);
 	nvects++;
@@ -65,14 +91,14 @@
-  \brief Set vector mode
+  \brief Set vector lines mode
   \param params parameters
   \return 1 on success
   \return 0 on failure
-int set_lines_attrb(const struct GParams *params)
+int vlines_set_attrb(const struct GParams *params)
     int i, color, width, flat, height;
     int *vect_list, nvects;
@@ -81,9 +107,9 @@
     for(i = 0; i < nvects; i++) {
 	/* mode -- use memory by default */
-	color =  Nviz_color_from_str(params->line_color->answers[i]);
-	width = atoi(params->line_width->answers[i]);
-	if (strcmp(params->line_mode->answers[i], "flat") == 0)
+	color =  Nviz_color_from_str(params->vline_color->answers[i]);
+	width = atoi(params->vline_width->answers[i]);
+	if (strcmp(params->vline_mode->answers[i], "flat") == 0)
 	    flat = 1;
 	else
 	    flat = 0;
@@ -91,10 +117,23 @@
 	    return 0;
 	/* height */
-	height = atoi(params->line_height->answers[i]);
+	height = atoi(params->vline_height->answers[i]);
 	if (height > 0)
 	    GV_set_trans(vect_list[i], 0.0, 0.0, height);
     return 1;
+  \brief Set vector points mode
+  \param params parameters
+  \return 1 on success
+  \return 0 on failure
+int vpoints_set_attrb(const struct GParams *params)
+    return 1;
