Author: ychemin
Date: 2008-07-22 07:14:27 -0400 (Tue, 22 Jul 2008)
New Revision: 32207
grass-addons/gipe/i.dn2full.l5/main.c
Added possibility to correct any GRASS layers
Modified: grass-addons/gipe/i.dn2full.l5/main.c
--- grass-addons/gipe/i.dn2full.l5/main.c 2008-07-22 10:40:15 UTC (rev 32206)
+++ grass-addons/gipe/i.dn2full.l5/main.c 2008-07-22 11:14:27 UTC (rev 32207)
@@ -49,7 +49,7 @@
int row,col;
struct GModule *module;
- struct Option *input,*output;
+ struct Option *input, *input1, *output;
struct Flag *flag1;
struct History history; //metadata
@@ -111,6 +111,11 @@
input->gisprompt = _("old_file,file,file");
input->description= _("Landsat 5TM NLAPS processing report File (.txt)");
+ input1 = G_define_standard_option(G_OPT_R_INPUTS) ;
+ input1->key = _("input");
+ input1->required = NO;
+ input1->description= _("Names of all L5 DN layers (1,2,3,4,5,6,7)");
output = G_define_standard_option(G_OPT_R_OUTPUT) ;
output->key = _("output");
output->description= _("Base name of the output layers (will add .x)");
@@ -119,6 +124,10 @@
exit (-1);
metfName = input->answer;
+ if(input1->answers){
+ names = input1->answers;
+ ptr = input1->answers;
result = output->answer;
//Fetch parameters for DN2Rad2Ref correction
@@ -128,12 +137,33 @@
doy = date2doy(day,month,year);
//printf("doy=%i\n",doy);
- if(year<2000){
- temp = year - 1900;
+ int index=1;
+ for (; *ptr != NULL; ptr++){
+ name = *ptr;
+ if(index==1)
+ sprintf(b1,"%s",name);
+ if(index==2)
+ sprintf(b2,"%s",name);
+ if(index==3)
+ sprintf(b3,"%s",name);
+ if(index==4)
+ sprintf(b4,"%s",name);
+ if(index==5)
+ sprintf(b5,"%s",name);
+ if(index==6)
+ sprintf(b6,"%s",name);
+ if(index==7)
+ sprintf(b7,"%s",name);
+ index++;
} else {
- temp = year - 2000;
- if (temp >=10){
+ if(year<2000){
+ temp = year - 1900;
+ } else {
+ temp = year - 2000;
+ if (temp >=10){
sprintf(b1, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B1.tif");
sprintf(b2, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B2.tif");
sprintf(b3, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B3.tif");
@@ -141,7 +171,7 @@
sprintf(b5, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B5.tif");
sprintf(b6, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B6.tif");
sprintf(b7, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"00",temp,doy,"50_B7.tif");
- } else {
+ } else {
sprintf(b1, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B1.tif");
sprintf(b2, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B2.tif");
sprintf(b3, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B3.tif");
@@ -149,9 +179,11 @@
sprintf(b5, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B5.tif");
sprintf(b6, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B6.tif");
sprintf(b7, "%s%d%s%d%s%d%d%s","LT5",l5path,"0",l5row,"000",temp,doy,"50_B7.tif");
//printf("%f/%f/%i-%i-%i\n",sun_elevation,sun_azimuth,day,month,year);
-// exit(1);
+ // exit(1);
//Prepare the ouput file names
