[GRASS-SVN] r32236 - grass/trunk/vector/v.class
svn_grass at osgeo.org
Wed Jul 23 17:28:04 EDT 2008
Author: mlennert
Date: 2008-07-23 17:28:04 -0400 (Wed, 23 Jul 2008)
New Revision: 32236
grass/trunk/vector/v.class/main.c
moved choice of algorithms to library
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c 2008-07-23 21:26:27 UTC (rev 32235)
+++ grass/trunk/vector/v.class/main.c 2008-07-23 21:28:04 UTC (rev 32236)
@@ -100,16 +100,18 @@
/* Read attributes */
db_CatValArray_init(&Cvarr);
Fi = Vect_get_field(&Map, ofield);
if (Fi == NULL) {
G_fatal_error(_("Unable to get layer info for vector map"));
+ Vect_close(&Map);
Driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (Driver == NULL)
G_fatal_error("Unable to open database <%s> by driver <%s>",
Fi->database, Fi->driver);
- /* Note do not check if the column exists in the table because it may be an expression */
+ /* Note: do not check if the column exists in the table because it may be an expression */
nrec =
db_select_CatValArray(Driver, Fi->table, Fi->key, col_opt->answer,
@@ -131,6 +133,9 @@
data = (double *)G_malloc((nrec) * sizeof(double));
+ for (i = 0; i < nrec; i++)
+ data[i] = 0.0;
if (ctype == DB_C_TYPE_INT) {
data[i] = Cvarr.value[i].val.i;
@@ -148,27 +153,19 @@
classbreaks = (double *)G_malloc((nbreaks) * sizeof(double));
for (i = 0; i < nbreaks; i++)
classbreaks[i] = 0;
- if (G_strcasecmp(algo_opt->answer, "int") == 0)
- finfo = class_interval(data, nrec, nbreaks, classbreaks);
- else if (G_strcasecmp(algo_opt->answer, "std") == 0)
- finfo = class_stdev(data, nrec, nbreaks, classbreaks);
- else if (G_strcasecmp(algo_opt->answer, "qua") == 0)
- finfo = class_quant(data, nrec, nbreaks, classbreaks);
- else if (G_strcasecmp(algo_opt->answer, "equ") == 0)
- finfo = class_equiprob(data, nrec, &nbreaks, classbreaks);
- else if (G_strcasecmp(algo_opt->answer, "dis") == 0)
- finfo = class_discont(data, nrec, nbreaks, classbreaks);
- else
- G_fatal_error("%s: Unknown algorithm", algo_opt->answer);
+ /* Get classbreaks for given algorithm and number of classbreaks.
+ * finfo takes any info coming from the classification algorithms
+ * equ algorithm can alter number of class breaks */
+ finfo =
+ class_apply_algorithm(algo_opt->answer, data, nrec, &nbreaks,
+ classbreaks);
- if (finfo == 0)
- G_fatal_error(_("%s: Error in classification algorithm"),
- algo_opt->answer);
+ if (G_strcasecmp(algo_opt->answer, "dis") == 0 && finfo < 3.84148)
+ G_warning(_
+ ("The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."));
/*output to be piped to other modules ? */
if (shell_flag->answer) {
@@ -190,17 +187,21 @@
min = data[0];
max = data[nrec - 1];
+ /* as equ algorithm can modify number of breaks we recalculate number of
+ * classes
fprintf(stdout, _("\nClassification of %s into %i classes\n"),
- col_opt->answer, nbclass);
+ col_opt->answer, nbreaks + 1);
fprintf(stdout, _("Using algorithm: *** %s ***\n"), algo_opt->answer);
fprintf(stdout, _("Mean: %f\tStandard deviation = %f\n"), stats.mean,
stats.stdev);
- if (G_strcasecmp(algo_opt->answer, "dis") == 0)
- fprintf(stdout, _("Last chi2 = %f\n"), finfo);
+ if (G_strcasecmp(algo_opt->answer, "dis") == 0) {
+ fprintf(stdout, _("Lowest chi2 = %f\n"), finfo);
- fprintf(stdout, _("Stdev multiplied by %.4f to define step\n"), finfo);
+ fprintf(stdout, _("Stdev multiplied by %.4f to define step\n"),
+ finfo);
fprintf(stdout, "\n");
fprintf(stdout, _("%15s%15s%15s\n\n"), "From (excl.)", "To (incl.)",
"Frequency");
@@ -218,9 +219,9 @@
fflush(stdout);
- Vect_close(&Map);
exit(EXIT_SUCCESS);
