[GRASS-SVN] r32278 - grass-addons/gipe/i.eb.h_SEBAL95
Fri Jul 25 05:21:01 EDT 2008
Author: ychemin
Date: 2008-07-25 05:21:01 -0400 (Fri, 25 Jul 2008)
New Revision: 32278
   grass-addons/gipe/i.eb.h_SEBAL95/U_0.c
   grass-addons/gipe/i.eb.h_SEBAL95/functions.h
   grass-addons/gipe/i.eb.h_SEBAL95/main.c
   grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
   grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c
   grass-addons/gipe/i.eb.h_SEBAL95/u_star.c
Added more parameterization
Modified: grass-addons/gipe/i.eb.h_SEBAL95/U_0.c
--- grass-addons/gipe/i.eb.h_SEBAL95/U_0.c	2008-07-25 07:53:50 UTC (rev 32277)
+++ grass-addons/gipe/i.eb.h_SEBAL95/U_0.c	2008-07-25 09:21:01 UTC (rev 32278)
@@ -1,15 +1,16 @@
 #include<stdio.h>
 #include<math.h>
-#include"functions.h"
-double U_0(double zom_0, double u2m)
+// hu = height of measurement of wind speed
+// u_hu = wind speed at hu height
+double U_0(double zom_0, double u_hu, double hu)
 	double u_0;
-	u_0 = u2m*0.41*log10(200/(0.15/7))/(log10(2/(0.15/7))*log10(200/zom_0));
+	double grass_height=0.15; /* in meters */
+	double hblend=200.0; /* blending height */
+	u_0 = u_hu*0.41*log(hblend/(grass_height/7))/(log(hu/(grass_height/7))*log(hblend/zom_0));
 //	printf("u_0 = %5.3f\n", u_0);
-	return (u_0);
+	return u_0;
Modified: grass-addons/gipe/i.eb.h_SEBAL95/functions.h
--- grass-addons/gipe/i.eb.h_SEBAL95/functions.h	2008-07-25 07:53:50 UTC (rev 32277)
+++ grass-addons/gipe/i.eb.h_SEBAL95/functions.h	2008-07-25 09:21:01 UTC (rev 32278)
@@ -29,7 +29,7 @@
 double sensi_h( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u2m, double dem_desert);
 double roh_air_0(double tempk);
 double zom_0(double ndvi, double ndvi_max);
-double U_0(double zom_0, double u2m);
+double U_0(double zom_0, double u_hu, double hu);
 double rah_0(double zom_0, double u_0);
 double h_0(double roh_air, double rah, double dtair);
 double dt_air_approx( double temp_k );
@@ -38,7 +38,7 @@
 double dt_air(double t0_dem, double tempk_water, double tempk_desert, double dtair_desert);
 double rohair(double dem, double tempk, double dtair);
 double h1(double roh_air, double rah, double dtair);
-double u_star(double t0_dem, double h, double ustar, double roh_air, double zom, double u2m);
+double u_star(double t0_dem,double h,double ustar,double roh_air,double zom,double u_hu,double hu);
 double psi_h(double t0_dem, double h, double U_0, double roh_air);
 double rah1(double psih, double u_star);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/main.c
--- grass-addons/gipe/i.eb.h_SEBAL95/main.c	2008-07-25 07:53:50 UTC (rev 32277)
+++ grass-addons/gipe/i.eb.h_SEBAL95/main.c	2008-07-25 09:21:01 UTC (rev 32278)
@@ -26,8 +26,8 @@
 /*#include <omp.h>*/
-double sensi_h_z0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double zom0, double dtair0, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u2m, double dem_desert);
-double sensi_h_noz0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double dtair0, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u2m, double dem_desert);
+double sensi_h_z0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double zom0, double dtair0, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u_hu, double hu, double dem_desert);
+double sensi_h_noz0m( int iteration, double tempk_water, double tempk_desert, double t0_dem, double tempk, double dtair0, double ndvi, double ndvi_max, double dem, double rnet_desert, double g0_desert, double t0_dem_desert, double u_hu, double hu, double dem_desert);
 int main(int argc, char *argv[])
@@ -35,9 +35,9 @@
 	char *mapset; // mapset name
 	/* buffer for in out raster */
-	void *inrast_T,*inrast_ndvi,*inrast_u2,*inrast_dem;
+	void *inrast_T,*inrast_ndvi,*inrast_u_hu,*inrast_dem;
 	void *inrast_Rn,*inrast_g0,*inrast_albedo,*inrast_dT;
-	void *inrast_z0m;
+	void *inrast_z0m, *inrast_hu;
 	DCELL *outrast;
 	int nrows, ncols;
@@ -46,22 +46,22 @@
 	int row_dry, col_dry;
 	double m_row_wet, m_col_wet;
 	double m_row_dry, m_col_dry;
-	int infd_T,infd_ndvi,infd_u2,infd_dem;
+	int infd_T,infd_ndvi,infd_u_hu,infd_dem;
 	int infd_Rn,infd_g0,infd_albedo,infd_dT;
-	int infd_z0m;
+	int infd_z0m, infd_hu;
 	int outfd;
-	char *mapset_T,*mapset_ndvi,*mapset_u2,*mapset_dem;
+	char *mapset_T,*mapset_ndvi,*mapset_u_hu,*mapset_dem;
 	char *mapset_Rn,*mapset_g0,*mapset_albedo,*mapset_dT;
-	char *mapset_z0m;
-	char *T, *ndvi, *u2, *dem, *Rn, *g0, *albedo, *dT, *z0m;
+	char *mapset_z0m, *mapset_hu;
+	char *T, *ndvi, *u_hu, *dem, *Rn, *g0, *albedo, *dT, *z0m, *hu;
 	char *h0;
         struct History history;
 	struct GModule *module;
-	struct Option *input_T, *input_ndvi, *input_u2, *input_dem;
+	struct Option *input_T, *input_ndvi, *input_u_hu, *input_dem;
 	struct Option *input_Rn, *input_g0, *input_albedo, *input_dT;
-	struct Option *input_z0m, *output;
+	struct Option *input_z0m, *input_hu, *output;
 	struct Option *input_row_wet, *input_col_wet;
 	struct Option *input_row_dry, *input_col_dry;
 	struct Option *input_iter;
@@ -69,13 +69,14 @@
 	RASTER_MAP_TYPE data_type_T;
 	RASTER_MAP_TYPE data_type_ndvi;
-	RASTER_MAP_TYPE data_type_u2;
+	RASTER_MAP_TYPE data_type_u_hu;
 	RASTER_MAP_TYPE data_type_dem;
 	RASTER_MAP_TYPE data_type_Rn;
 	RASTER_MAP_TYPE data_type_g0;
 	RASTER_MAP_TYPE data_type_albedo;
 	RASTER_MAP_TYPE data_type_dT;
 	RASTER_MAP_TYPE data_type_z0m;
+	RASTER_MAP_TYPE data_type_hu;
 	RASTER_MAP_TYPE data_type_output=DCELL_TYPE;
 	int iteration = 10; /*SEBAL95 loop number*/
@@ -112,9 +113,13 @@
 	input_z0m->description = _("Name of aerodynamic resistance to heat momentum [s/m]");
 	input_z0m->guisection	= _("Optional");
-	input_u2 = G_define_standard_option(G_OPT_R_INPUT);
-	input_u2->key	= "u2m";
-	input_u2->description = _("Name of Wind Speed input map [m/s]");
+	input_u_hu = G_define_standard_option(G_OPT_R_INPUT);
+	input_u_hu->key	= "u_hu";
+	input_u_hu->description = _("Name of Wind Speed (at hu height) input map [m/s]");
+	input_hu = G_define_standard_option(G_OPT_R_INPUT);
+	input_hu->key	= "hu";
+	input_hu->description = _("Name of Height of measurement of Wind Speed input map [m]");
 	input_dem = G_define_standard_option(G_OPT_R_INPUT);
 	input_dem->key	= "dem";
@@ -206,7 +211,8 @@
 		dT	= input_dT->answer;
 	if(input_z0m->answer)
 		z0m	= input_z0m->answer;
-	u2	= input_u2->answer;
+	u_hu	= input_u_hu->answer;
+	hu	= input_hu->answer;
 	dem	= input_dem->answer;
 	ndvi	= input_ndvi->answer;
 	Rn	= input_Rn->answer;
@@ -247,9 +253,12 @@
 		if (mapset_z0m == NULL)
 	        	G_fatal_error (_("cell file [%s] not found"), z0m);
-	mapset_u2 = G_find_cell2 (u2, "");
-	if (mapset_u2 == NULL)
-	        G_fatal_error (_("cell file [%s] not found"), u2);
+	mapset_u_hu = G_find_cell2 (u_hu, "");
+	if (mapset_u_hu == NULL)
+	        G_fatal_error (_("cell file [%s] not found"), u_hu);
+	mapset_hu = G_find_cell2 (hu, "");
+	if (mapset_hu == NULL)
+	        G_fatal_error (_("cell file [%s] not found"), hu);
 	mapset_dem = G_find_cell2 (dem, "");
 	if (mapset_dem == NULL)
 	        G_fatal_error (_("cell file [%s] not found"), dem);
@@ -278,7 +287,8 @@
 	if(input_z0m->answer){
 		data_type_z0m 	= G_raster_map_type(z0m, mapset_z0m);
-	data_type_u2 	= G_raster_map_type(u2, mapset_u2);
+	data_type_u_hu 	= G_raster_map_type(u_hu, mapset_u_hu);
+	data_type_hu 	= G_raster_map_type(hu, mapset_hu);
 	data_type_dem 	= G_raster_map_type(dem, mapset_dem);
 	data_type_ndvi 	= G_raster_map_type(ndvi, mapset_ndvi);
 	data_type_Rn 	= G_raster_map_type(Rn, mapset_Rn);
@@ -295,8 +305,10 @@
 		if ( (infd_z0m = G_open_cell_old (z0m, mapset_z0m)) < 0)
 			G_fatal_error (_("Cannot open cell file [%s]"), z0m);
-	if ( (infd_u2 = G_open_cell_old (u2, mapset_u2)) < 0)
-		G_fatal_error (_("Cannot open cell file [%s]"),u2);
+	if ( (infd_u_hu = G_open_cell_old (u_hu, mapset_u_hu)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"),u_hu);
+	if ( (infd_hu = G_open_cell_old (hu, mapset_hu)) < 0)
+		G_fatal_error (_("Cannot open cell file [%s]"),hu);
 	if ( (infd_dem = G_open_cell_old (dem, mapset_dem)) < 0)
 		G_fatal_error (_("Cannot open cell file [%s]"),dem);
 	if ( (infd_ndvi = G_open_cell_old (ndvi, mapset_ndvi)) < 0)
@@ -318,8 +330,10 @@
 		if (G_get_cellhd (z0m, mapset_z0m, &cellhd) < 0)
 			G_fatal_error (_("Cannot read file header of [%s]"), z0m);
-	if (G_get_cellhd (u2, mapset_u2, &cellhd) < 0)
-		G_fatal_error (_("Cannot read file header of [%s]"), u2);
+	if (G_get_cellhd (u_hu, mapset_u_hu, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s]"), u_hu);
+	if (G_get_cellhd (hu, mapset_hu, &cellhd) < 0)
+		G_fatal_error (_("Cannot read file header of [%s]"), hu);
 	if (G_get_cellhd (dem, mapset_dem, &cellhd) < 0)
 		G_fatal_error (_("Cannot read file header of [%s]"), dem);
 	if (G_get_cellhd (ndvi, mapset_ndvi, &cellhd) < 0)
@@ -339,7 +353,8 @@
 		inrast_z0m  	= G_allocate_raster_buf(data_type_z0m);
-	inrast_u2 	= G_allocate_raster_buf(data_type_u2);
+	inrast_u_hu 	= G_allocate_raster_buf(data_type_u_hu);
+	inrast_hu 	= G_allocate_raster_buf(data_type_hu);
 	inrast_dem 	= G_allocate_raster_buf(data_type_dem);
 	inrast_ndvi 	= G_allocate_raster_buf(data_type_ndvi);
 	inrast_Rn 	= G_allocate_raster_buf(data_type_Rn);
@@ -861,7 +876,8 @@
 		DCELL d_tempk;
 		DCELL d_dem;
 		DCELL d_t0dem;
-		DCELL d_u2m; 	/* Input raster */
+		DCELL d_u_hu; 	/* Input raster */
+		DCELL d_hu; 	/* Input raster */
 		DCELL d_dT; 	/* Optional Input raster */
 		DCELL d_z0m; 	/* Optional Input raster */
 		DCELL d;	/* Output pixel */
@@ -879,8 +895,10 @@
 			if(G_get_raster_row(infd_z0m,inrast_z0m,row,data_type_z0m)<0)
 				G_fatal_error(_("Could not read from <%s>"),z0m);
-		if(G_get_raster_row(infd_u2,inrast_u2,row,data_type_u2) < 0)
-			G_fatal_error(_("Could not read from <%s>"),u2);
+		if(G_get_raster_row(infd_u_hu,inrast_u_hu,row,data_type_u_hu) < 0)
+			G_fatal_error(_("Could not read from <%s>"),u_hu);
+		if(G_get_raster_row(infd_hu,inrast_hu,row,data_type_hu) < 0)
+			G_fatal_error(_("Could not read from <%s>"),hu);
 		if(G_get_raster_row(infd_dem,inrast_dem,row,data_type_dem)<0)
 			G_fatal_error(_("Could not read from <%s>"),dem);
 		if(G_get_raster_row(infd_ndvi,inrast_ndvi,row,data_type_ndvi) < 0)
@@ -939,17 +957,28 @@
 					d_tempk = (double) ((DCELL *) inrast_T)[col];
 					break;
-			switch(data_type_u2){
+			switch(data_type_u_hu){
 				case CELL_TYPE:
-					d_u2m = (double) ((CELL *) inrast_u2)[col];
+					d_u_hu = (double) ((CELL *) inrast_u_hu)[col];
 					break;
 				case FCELL_TYPE:
-					d_u2m = (double) ((FCELL *) inrast_u2)[col];
+					d_u_hu = (double) ((FCELL *) inrast_u_hu)[col];
 					break;
 				case DCELL_TYPE:
-					d_u2m = (double) ((DCELL *) inrast_u2)[col];
+					d_u_hu = (double) ((DCELL *) inrast_u_hu)[col];
 					break;
+			switch(data_type_hu){
+				case CELL_TYPE:
+					d_hu = (double) ((CELL *) inrast_hu)[col];
+					break;
+				case FCELL_TYPE:
+					d_hu = (double) ((FCELL *) inrast_hu)[col];
+					break;
+				case DCELL_TYPE:
+					d_hu = (double) ((DCELL *) inrast_hu)[col];
+					break;
 			switch(data_type_dem){
 				case CELL_TYPE:
 					d_dem = (double) ((CELL *) inrast_dem)[col];
@@ -995,7 +1024,8 @@
 					break;
 			if(G_is_d_null_value(&d_tempk) ||
-			G_is_d_null_value(&d_u2m) ||
+			G_is_d_null_value(&d_u_hu) ||
+			G_is_d_null_value(&d_hu) ||
 			G_is_d_null_value(&d_dem) ||
 			G_is_d_null_value(&d_ndvi) ||
 			G_is_d_null_value(&d_Rn) ||
@@ -1020,9 +1050,8 @@
 				G_message(" d_Rn=%5.3f",d_Rn);
 				G_message(" d_g0=%5.3f",d_g0);
 				G_message(" d_ndvi=%5.3f",d_ndvi);
-				G_message(" d_u2m=%5.3f",d_u2m);
+				G_message(" d_u_hu=%5.3f",d_u_hu);
 			*/	/* Calculate sensible heat flux */
-				//d = sensi_h(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
 					if(input_dT->answer){
 						/* do nothing */
@@ -1030,7 +1059,7 @@
 						/* let the internal constant take over */
 						d_dT = -1.0;
-					d = sensi_h_z0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_z0m,d_dT,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
+					d = sensi_h_z0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_z0m,d_dT,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry);
 				} else {
 						/* do nothing */
@@ -1038,7 +1067,7 @@
 						d_dT = -1.0;
-					d = sensi_h_noz0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_dT,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u2m,d_dem_dry);
+					d = sensi_h_noz0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_dT,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry);
 		//		G_message(" d_h0=%5.3f",d);
 				if (zero->answer && d<0.0){
@@ -1060,8 +1089,10 @@
 		G_free(inrast_z0m);
 		G_close_cell (infd_z0m);
-	G_free(inrast_u2);
-	G_close_cell (infd_u2);
+	G_free(inrast_u_hu);
+	G_close_cell (infd_u_hu);
+	G_free(inrast_hu);
+	G_close_cell (infd_hu);
 	G_free(inrast_dem);
 	G_close_cell (infd_dem);
 	G_free(inrast_ndvi);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c	2008-07-25 07:53:50 UTC (rev 32277)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c	2008-07-25 09:21:01 UTC (rev 32278)
@@ -6,7 +6,7 @@
 /* Arrays Declarations */
 #define ITER_MAX 10
 	double dtair[ITER_MAX], roh_air[ITER_MAX], rah[ITER_MAX];
@@ -46,7 +46,7 @@
 // 	printf("**rohairdesert = %5.3f\n",roh_air_desert);
 	zom0 		= zom_0(ndvi, ndvi_max);
 // 	printf("*****************************zom = %5.3f\n",zom0);
-	u_0 		= U_0(zom0, u2m);
+	u_0 		= U_0(zom0, u_hu, hu);
 // 	printf("*****************************u0\n");
 	rah[0] 		= rah_0(zom0, u_0);
 // 	printf("*****************************rah = %5.3f\n",rah[0]);
@@ -71,20 +71,20 @@
 		/* Where is roh_air[i]? */
 		psih = psi_h(t0_dem,h[ic-1],u_0,roh_air[ic-1]);
-		ustar[ic] = u_star(t0_dem,h[ic-1],u_0,roh_air[ic-1],zom[0],u2m);
+		ustar[ic] = u_star(t0_dem,h[ic-1],u_0,roh_air[ic-1],zom[0],u_hu,hu);
 		rah[ic] = rah1(psih, ustar[ic]);
 		/* get desert point values from maps */
 		if(ic==1){
 			h_desert	= rnet_desert - g0_desert;
 			zom_desert	= 0.002;
 			psih_desert 	= psi_h(t0_dem_desert,h_desert,u_0,roh_air_desert);
-			ustar_desert	= u_star(t0_dem_desert,h_desert,u_0,roh_air_desert,zom_desert,u2m);
+			ustar_desert	= u_star(t0_dem_desert,h_desert,u_0,roh_air_desert,zom_desert,u_hu,hu);
 		} else {
 			roh_air_desert	= rohair(dem_desert,tempk_desert,dtair_desert);
 			h_desert	= h1(roh_air_desert,rah_desert,dtair_desert);
 			ustar_desertold = ustar_desert;
 			psih_desert 	= psi_h(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert);
-			ustar_desert	= u_star(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,zom_desert,u2m);
+			ustar_desert	= u_star(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,zom_desert,u_hu,hu);
 		rah_desert	= rah1(psih_desert,ustar_desert);
 		dtair_desert 	= dt_air_desert(h_desert, roh_air_desert, rah_desert);
Modified: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c	2008-07-25 07:53:50 UTC (rev 32277)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_z0m.c	2008-07-25 09:21:01 UTC (rev 32278)
@@ -6,7 +6,7 @@
 #define ITER_MAX 10
@@ -44,7 +44,7 @@
 // 	printf("*****************************rohair=%5.3f\n",roh_air[0]);
 	roh_air_desert 	= roh_air_0(tempk_desert);
@@ -69,20 +69,20 @@
 		if(ic==1){
 			zom_desert	= 0.002;
 		} else {
Modified: grass-addons/gipe/i.eb.h_SEBAL95/u_star.c
--- grass-addons/gipe/i.eb.h_SEBAL95/u_star.c	2008-07-25 07:53:50 UTC (rev 32277)
+++ grass-addons/gipe/i.eb.h_SEBAL95/u_star.c	2008-07-25 09:21:01 UTC (rev 32278)
@@ -4,42 +4,33 @@
 #define PI 3.1415927
 	double result;
-	double n5_temp; /* Monin-Obukov Length 		*/
-        double n10_mem; /* psi m 			*/
-	double n31_mem; /* x for U200 (that is bh...) 	*/
-	double hv=0.15;	/* crop height (m) 		*/
+	double n5; 	/* Monin-Obukov Length 		*/
+        double n10; 	/* psi m 			*/
+	double n31; 	/* x for U200 (that is bh...) 	*/
+	double hv=0.15;	/* grass height (m) 		*/
 	double bh=200;	/* blending height (m) 		*/
 //	printf("t0dem = %5.3f\n", t0_dem);
 //	printf("h = %5.3f\n", h);
 //	printf("U_0 = %5.3f\n", U_0);
 //	printf("roh_air = %5.3f\n", roh_air);
 //	printf("zom = %5.3f\n", zom);
-//	printf("u2m = %5.3f\n", u2m);
+//	printf("u_hu = %5.3f\n", u_hu);
 	if(h != 0.0){
-		n5_temp = (-1004* roh_air*pow(ustar,3)* t0_dem)/(0.41*9.81* h);
+		n5 = (-1004* roh_air*pow(ustar,3)* t0_dem)/(0.41*9.81* h);
 	} else {
-		n5_temp = -1000.0;
+		n5 = -1000.0;
-	if(n5_temp < 0.0){
-		n31_mem = pow((1-16*(200/n5_temp)),0.25);
-		n10_mem = (2*log10((1+n31_mem)/2)+log10((1+pow(n31_mem,2))/2)-2*atan(n31_mem)+0.5*PI);
+	if(n5 < 0.0){
+		n31 = pow((1-16*(hu/n5)),0.25);
+		n10 = (2*log((1+n31)/2)+log((1+pow(n31,2))/2)-2*atan(n31)+0.5*PI);
 	} else {
-//		n31_mem = 1.0;
-		n10_mem = -5*2/n5_temp;
+//		n31 = 1.0;
+		n10 = -5*2/n5;
-	result = ((u2m*0.41/log10(2/(hv/7)))/0.41*log10(bh /(hv/7)*0.41))/(log10(bh / zom)-n10_mem);
-	return (result);
+	result = ((u_hu*0.41/log(hu/(hv/7)))/0.41*log(bh/(hv/7)*0.41))/(log(bh/zom)-n10);
+	return result;
