[GRASS-SVN] r32286 - in grass/branches/develbranch_6/lib: .
vector/vedit
svn_grass at osgeo.org
Fri Jul 25 06:29:46 EDT 2008
Author: martinl
Date: 2008-07-25 06:29:46 -0400 (Fri, 25 Jul 2008)
New Revision: 32286
Added:
grass/branches/develbranch_6/lib/vector/vedit/veditlib.dox
grass/branches/develbranch_6/lib/grasslib.dox
grass/branches/develbranch_6/lib/vector/vedit/Makefile
grass/branches/develbranch_6/lib/vector/vedit/cats.c
grass/branches/develbranch_6/lib/vector/vedit/chtype.c
grass/branches/develbranch_6/lib/vector/vedit/copy.c
grass/branches/develbranch_6/lib/vector/vedit/delete.c
grass/branches/develbranch_6/lib/vector/vedit/distance.c
grass/branches/develbranch_6/lib/vector/vedit/flip.c
grass/branches/develbranch_6/lib/vector/vedit/merge.c
grass/branches/develbranch_6/lib/vector/vedit/move.c
grass/branches/develbranch_6/lib/vector/vedit/select.c
grass/branches/develbranch_6/lib/vector/vedit/snap.c
grass/branches/develbranch_6/lib/vector/vedit/vertex.c
grass/branches/develbranch_6/lib/vector/vedit/zbulk.c
veditlib: doxygen updates (merged from trunk, r32285)
Modified: grass/branches/develbranch_6/lib/grasslib.dox
--- grass/branches/develbranch_6/lib/grasslib.dox 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/grasslib.dox 2008-07-25 10:29:46 UTC (rev 32286)
@@ -92,7 +92,10 @@
<li>symbol: Drawing symbols for %point %vector data library - \ref symbol
<li>vask: Cursor management library - \ref vask
<li>%vector: \ref Vector_Library (GRASS Vector and Direct Graph Library)
+<ul>
+<li>vedit: \ref Vedit_Library - %vector editing
</ul>
+</ul>
<!--<li>image3: extra imagery library (mainly still unused) - \ref image3lib-->
<!--<li>D: display library - \ref d_displaylib-->
<!--<li>front.end: interface for interactive modules library - \ref frontend-->
Modified: grass/branches/develbranch_6/lib/vector/vedit/Makefile
--- grass/branches/develbranch_6/lib/vector/vedit/Makefile 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/Makefile 2008-07-25 10:29:46 UTC (rev 32286)
@@ -9,5 +9,9 @@
EXTRA_LIBS = $(VECTLIB) $(DBMILIB) $(GISLIB)
include $(MODULE_TOPDIR)/include/Make/Lib.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
default: lib
+# doxygen
+DOXNAME=vedit
Modified: grass/branches/develbranch_6/lib/vector/vedit/cats.c
--- grass/branches/develbranch_6/lib/vector/vedit/cats.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/cats.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,32 +1,31 @@
- \file cats.c
+ \file vector/vedit/cats.c
\brief Vedit library - category manipulation
- This program is free software under the
- GNU General Public License (>=v2).
- Read the file COPYING that comes with GRASS
- for details.
+ (C) 2006-2008 by the GRASS Development Team
- \author (C) 2006-2008 by the GRASS Development Team
- Jachym Cepicky <jachym.cepicky gmail.com>
- Martin Landa <landa.martin gmail.com>
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Jachym Cepicky <jachym.cepicky gmail.com>
+ \author Martin Landa <landa.martin gmail.com>
\date 2006-2008
#include <grass/vedit.h>
- \brief Add/remove categories of selected vector features
+ \brief Add / remove categories
- \param[in] Map vector map
- \param[in] List list of selected features
- \param[in] layer layer number
- \param[in] del action (non-zero for delete otherwise add)
- \param[in] cats_list list of category numbers
+ \param Map vector map
+ \param List list of selected primitives
+ \param layer layer number
+ \param del action (non-zero for delete otherwise add)
+ \param cats_list list of category numbers
- \return number of modified features
+ \return number of modified primitives
\return -1 on error
int Vedit_modify_cats (struct Map_info *Map, struct ilist *List,
Modified: grass/branches/develbranch_6/lib/vector/vedit/chtype.c
--- grass/branches/develbranch_6/lib/vector/vedit/chtype.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/chtype.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,25 +1,37 @@
- \file chtype.c
+ \file vector/vedit/chtype.c
- \brief Vedit library - change feature type
+ \brief Vedit library - change primitives type
- Supported conversions:
- - point<->centroid
- - line<->boundary
+ (C) 2008 by the GRASS Development Team
- for details.
- \author (C) 2008 by the GRASS Development Team
\date 2008
+ \brief Change primitive type
+ Supported conversions:
+ - point <-> centroid
+ - line <-> boundary
+ \param[out] npoints number of points after conversion
+ \param[out] ncentroids number of centroids after conversion
+ \param[out] nlines number of lines after conversion
+ \param[out] nboundaries number of boundaries after conversion
+ \return -1 on error
int Vedit_chtype_lines(struct Map_info *Map, struct ilist *List,
int *npoints, int *ncentroids,
int *nlines, int *nboundaries)
Modified: grass/branches/develbranch_6/lib/vector/vedit/copy.c
--- grass/branches/develbranch_6/lib/vector/vedit/copy.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/copy.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,30 +1,29 @@
- \file copy.c
+ \file vector/vedit/copy.c
- \brief Vedit library - copy features
+ \brief Vedit library - copy primitives
- for details.
+ (C) 2007-2008 by the GRASS Development Team
- \author (C) 2007-2008 by the GRASS Development Team
\date 2007-2008
- \brief Copy selected features
+ \brief Copy selected primitives
- \param[in] Map vector map copy to
- \param[in] FromMap vector map copy from (if not given use Map)
- \param[in] List list of selected features (to be copied)
+ \param Map vector map copy to
+ \param FromMap vector map copy from (if not given use Map)
+ \param List list of selected primitives (to be copied)
- \return number of copied features
+ \return number of copied primitives
\return -1 on error
int Vedit_copy_lines (struct Map_info *Map, struct Map_info *FromMap,
Modified: grass/branches/develbranch_6/lib/vector/vedit/delete.c
--- grass/branches/develbranch_6/lib/vector/vedit/delete.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/delete.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,28 +1,27 @@
- \file delete.c
+ \file vector/vedit/delete.c
- \brief Vedit library - delete features
+ \brief Vedit library - delete primitives
- for details.
\date 2007-2008
- \brief Delete selected features
+ \brief Delete selected primitives
- \param[in] List list of features to be deleted
+ \param List list of primitives to be deleted
- \return number of deleted features
+ \return number of deleted primitives
\return -1 on on error
int Vedit_delete_lines(struct Map_info *Map, struct ilist *List)
Modified: grass/branches/develbranch_6/lib/vector/vedit/distance.c
--- grass/branches/develbranch_6/lib/vector/vedit/distance.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/distance.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,15 +1,13 @@
- \file distance.c
+ \file vector/vedit/distance.c
\brief Vedit library - distance calculation
- for details.
\date 2007-2008
@@ -20,10 +18,10 @@
\brief Calculate distances between two lines
- TODO: LL projection
+ \todo LL projection
- \param[in] Points1 first line
- \param[in] Points2 second line
+ \param Points1 first line geometry
+ \param Points2 second line geometry
\param[out] index of minimal distance
\return minimal distance betwen two lines (their nodes)
Modified: grass/branches/develbranch_6/lib/vector/vedit/flip.c
--- grass/branches/develbranch_6/lib/vector/vedit/flip.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/flip.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,26 +1,25 @@
- \file flip.c
+ \file vector/vedit/flip.c
- \brief Vedit library - lines flipping
+ \brief Vedit library - flip lines
- for details.
\date 2007-2008
- \brief Flip direction of selected vector lines
+ \brief Flip direction of selected lines
- \param[in] List list of selected lines
+ \param List list of selected lines
\return number of modified lines
\return -1 on error
Modified: grass/branches/develbranch_6/lib/vector/vedit/merge.c
--- grass/branches/develbranch_6/lib/vector/vedit/merge.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/merge.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,17 +1,16 @@
- \file merge.c
+ \file vector/vedit/merge.c
\brief Vedit library - merge lines
- for details.
\date 2006-2008
@@ -24,9 +23,9 @@
b : Points2/Cats2
merged line : Points/Cats
- \param[in] Points1,Cats1 first line
- \param[in] Points2,Cats2 second line
- \param[in] thresh threshold value
+ \param Points1,Cats1 first line
+ \param Points2,Cats2 second line
+ \param thresh threshold value
\param[out] Points result line
\return 1 on success
@@ -41,8 +40,8 @@
At least two lines need to be given.
\return number of merged lines
\return -1 on error
Modified: grass/branches/develbranch_6/lib/vector/vedit/move.c
--- grass/branches/develbranch_6/lib/vector/vedit/move.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/move.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,32 +1,31 @@
- \file move.c
+ \file vector/vedit/move.c
- \brief Vedit library - snapping
+ \brief Vedit library - move primitives
- for details.
\date 2007-2008
- \brief Move selected features
+ \brief Move selected primitives
- \param[in] BgMap, nbgmaps list of background vector maps for snapping
- \param[in] List list of features to be moved
- \param[in] move_x,move_y,move_z direction (move_z used only if map is 3D)
- \param[in] snap enable snapping (see globals.h)
+ \param BgMap, nbgmaps list of background vector maps used for snapping
+ \param List list of primitives to be moved
+ \param move_x,move_y,move_z direction (move_z used only if map is 3D)
+ \param snap enable snapping (see globals.h)
\return -1 on error
int Vedit_move_lines(struct Map_info *Map, struct Map_info **BgMap, int nbgmaps,
Modified: grass/branches/develbranch_6/lib/vector/vedit/select.c
--- grass/branches/develbranch_6/lib/vector/vedit/select.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/select.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,14 +1,15 @@
- \brief Vedit library - select vector features (by query)
+ \file vector/vedit/select.c
- for details.
+ \brief Vedit library - select primitives by query
\date 2007-2008
@@ -20,23 +21,23 @@
static int merge_lists (struct ilist* alist, struct ilist* blist);
- \brief Select features by query (based on geometry properties)
+ \brief Select primitives by query (based on geometry properties)
Currently supported:
- - QUERY_LENGTH, select all features longer than threshold (or shorter if threshold is < 0)
+ - QUERY_LENGTH, select all lines longer than threshold (or shorter if threshold is < 0)
- QUERY_DANGLE, select all dangles longer than threshold (or shorter if threshold is < 0)
Perform global query if <i>List</i> is empty otherwise query only
selected vector objects.
- \param[in] type feature type
- \param[in] thresh threshold value (< 0 for 'shorter', > 0 for 'longer')
- \param[in] query query (length, dangle, ...)
+ \param type feature type
+ \param thresh threshold value (< 0 for 'shorter', > 0 for 'longer')
+ \param query query (length, dangle, ...)
\param[in,out] List list of selected features
- \return number of selected lines
+ \return number of selected primitives
int Vedit_select_by_query(struct Map_info *Map,
int type, int layer, double thresh, int query,
@@ -122,7 +123,7 @@
- \brief Query given feature
+ \brief Query selected primitive
\return 1 line test positive
\return 0 line test negative
@@ -237,7 +238,7 @@
\brief Merge two lists, i.e. store only duplicate items
\param[in,out] alist list to be merged
- \param[in] blist list used for merging
+ \param blist list used for merging
\return result number of items
Modified: grass/branches/develbranch_6/lib/vector/vedit/snap.c
--- grass/branches/develbranch_6/lib/vector/vedit/snap.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/snap.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,29 +1,28 @@
- \file snap.c
+ \file vector/vedit/snap.c
- for details.
\date 2007-2008
- \brief Snap given point to the nearest feature
+ \brief Snap given point to the nearest primitive
- \param[in] line line to be excluded (point on line)
- \param[in] x,y,z point on line to be snapped
- \param[in] thresh snapping threshold (>0)
- \param[in] vertex snap also to vertex
+ \param line line to be excluded (point on line)
+ \param x,y,z point on line to be snapped
+ \param thresh snapping threshold (>0)
+ \param vertex snap also to vertex (non-zero)
\return 1 snapped
\return 0 not snapped
@@ -86,18 +85,16 @@
- \brief Snap lines/boudaries to the nearest feature
+ \brief Snap selected primitive to its nearest primitive
- If 'line' > 0, given line is snapped and rewritten.
+ \param BgMap,nbgmaps list of background maps used for snapping
+ \param line line id to be snapped (if already written, otherwise -1)
+ \param Points line geometry
+ \param thresh threshold value used for snapping (>0)
+ \param to_vertex allow snapping also to vertex
- \param[in] Map pointer to vector map
- \param[in] BgMap,nbgmaps list of background maps used for snapping
- \param[in] line line to be snapped (if already written, otherwise -1)
- \param[in] Points line geometry
- \param[in] thresh threshold value used for snapping (>0)
- \param[in] to_vertex allow snapping also to vertex
\return 1 line snapped
\return 0 line not snapped
\return -1 line is dead (if 'line' is > 0)
@@ -165,14 +162,14 @@
+ \brief Snap lines/boundaries
- \param[in] BgMap,nbgmaps List of background maps
- \param[in] List list of lines to be snapped
+ \param List list of lines to be snapped
\return number of snapped lines
\return -1 on error
Copied: grass/branches/develbranch_6/lib/vector/vedit/veditlib.dox (from rev 32285, grass/trunk/lib/vector/vedit/veditlib.dox)
--- grass/branches/develbranch_6/lib/vector/vedit/veditlib.dox (rev 0)
+++ grass/branches/develbranch_6/lib/vector/vedit/veditlib.dox 2008-07-25 10:29:46 UTC (rev 32286)
@@ -0,0 +1,68 @@
+/*! \page Vedit_Library GRASS Vedit Library
+by GRASS Development Team
+http://grass.osgeo.org
+\section veditIntro Introduction to Vedit Library
+This library contains higher level functions to edit %vector primitives
+geometry (see \ref Vector_Library). Currently only 2D primitives are
+supported (points, lines, boundaries and centroids).
+<p>
+The library is currently used by v.edit module and wxGUI %vector digitizer.
+\section veditFn Functions
+\subsection veditModify Modify lines/boundaries
+ - int Vedit_split_lines()
+ - int Vedit_connect_lines()
+ - int Vedit_chtype_lines()
+ - int Vedit_delete_lines()
+ - int Vedit_flip_lines()
+ - int Vedit_merge_lines()
+ - int Vedit_move_lines()
+\subsection veditCats Manipulate feature categories
+ - int Vedit_modify_cats()
+\subsection veditCopy Copy primitives
+ - int Vedit_copy_lines()
+\subsection veditSelect Select primitives
+ - int Vedit_select_by_query()
+\subsection veditSnap Snapping
+ - int Vedit_snap_point()
+ - int Vedit_snap_line()
+ - int Vedit_snap_lines()
+\subsection veditVertex Vertex manipulation
+ - int Vedit_move_vertex()
+ - int Vedit_add_vertex()
+ - int Vedit_remove_vertex()
+\subsection veditMisc Miscellaneous
+ - double Vedit_get_min_distance()
+ - int Vedit_bulk_labeling()
Modified: grass/branches/develbranch_6/lib/vector/vedit/vertex.c
--- grass/branches/develbranch_6/lib/vector/vedit/vertex.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/vertex.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,17 +1,16 @@
- \file vertex.c
+ \file vector/vedit/vertex.c
\brief Vedit library - vertex manipulation
- for details.
\date 2006-2008
@@ -20,15 +19,15 @@
\brief Move all vertices in bounding box(es)
- \param[in] coord points location
- \param[in] thresh_coords threshold value for selecting vector feature
- \param[in] thresh_snap threshold value used for snapping
- \param[in] move_x,move_y,move_z direction (move_z is used when map is 3D)
- \param[in] move_first move only first vertex found in the bounding box
- \param[in] snap snapping mode (see vedit.h)
+ \param BgMap, nbgmaps list of background vector maps for snapping
+ \param coord points location
+ \param thresh_coords threshold value for selecting lines
+ \param thresh_snap threshold value used for snapping
+ \param move_x,move_y,move_z direction (move_z is used when map is 3D)
+ \param move_first move only first vertex found in the bounding box
+ \param snap snapping mode (see vedit.h)
\return number of moved verteces
\return -1 on error
@@ -172,16 +171,16 @@
- \brief Add new vertex to line.
+ \brief Add new vertex to line
Shape of line is not changed.
- TODO: 3D
+ \todo 3D
- \param[in] thresh find line in given threshold
+ \param thresh find line in given threshold
\return number of add verteces
\return -1 on error
@@ -262,12 +261,12 @@
\brief Remove vertex from line
- TODO: 3D
+ \todo 3D
- \param[in] thresh threshold value to find a line
+ \param thresh threshold value to find a line
\return number of removed vertices
\return -1 on error
Modified: grass/branches/develbranch_6/lib/vector/vedit/zbulk.c
--- grass/branches/develbranch_6/lib/vector/vedit/zbulk.c 2008-07-25 10:27:08 UTC (rev 32285)
+++ grass/branches/develbranch_6/lib/vector/vedit/zbulk.c 2008-07-25 10:29:46 UTC (rev 32286)
@@ -1,16 +1,16 @@
- \file zbulk.c
+ \file vector/vedit/zbulk.c
- \brief Vedit library - Bulk labeling (automated labeling of vector features)
+ \brief Vedit library - Bulk labeling (automated labeling of vector
+ features)
- for details.
\date 2007-2008
@@ -18,15 +18,15 @@
- \brief Z bulk-labeling.
+ \brief Lines z-bulk labeling
- Automated labeling (z coordinate assignment) of vector lines (contours).
+ Automated labeling (z coordinate assignment) of vector lines (iso-lines).
- \param[in] point_start_end staring and ending point
- \param[in] start starting value
- \param[in] step step
+ \param point_start_end staring and ending point
+ \param start starting value
+ \param step step value
\return -1 on error
