[GRASS-SVN] r32303 - grass/trunk/lib/python
svn_grass at osgeo.org
Fri Jul 25 14:39:54 EDT 2008
Author: glynn
Date: 2008-07-25 14:39:53 -0400 (Fri, 25 Jul 2008)
New Revision: 32303
grass/trunk/lib/python/README.txt
Add pipe_command, parse_color
Modified: grass/trunk/lib/python/README.txt
--- grass/trunk/lib/python/README.txt 2008-07-25 18:04:28 UTC (rev 32302)
+++ grass/trunk/lib/python/README.txt 2008-07-25 18:39:53 UTC (rev 32303)
@@ -23,6 +23,22 @@
GRASS_GUI='text';
MONITOR='x0';
+def pipe_command(*args, **kwargs):
+Passes all arguments to start_command, but also adds
+"stdout = subprocess.PIPE". Returns the Popen object. Example:
+>>> p = grass.pipe_command("g.gisenv")
+>>> print p
+<subprocess.Popen object at 0xb7c12f6c>
+>>> print p.communicate()[0]
+GISDBASE='/opt/grass-data';
+LOCATION_NAME='spearfish57';
+MAPSET='glynn';
+GRASS_DB_ENCODING='ascii';
+GRASS_GUI='text';
+MONITOR='x0';
def run_command(*args, **kwargs):
Passes all arguments to start_command, then waits for the process to
@@ -128,3 +144,16 @@
>>> grass.list_strings('rast')
['aspect at PERMANENT', 'erosion1 at PERMANENT', 'quads at PERMANENT', 'soils at PERMANENT', ...
+def parse_color(val, dflt = None):
+Parses the string "val" as a GRASS colour, which can be either one of
+the named colours or an R:G:B tuple e.g. 255:255:255. Returns an
+(r,g,b) triple whose components are floating point values between 0
+and 1. Example:
+>>> grass.parse_color("red")
+(1.0, 0.0, 0.0)
+>>> grass.parse_color("255:0:0")
+(1.0, 0.0, 0.0)
