[GRASS-SVN] r32334 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Jul 27 12:17:53 EDT 2008
Author: martinl
Date: 2008-07-27 12:17:52 -0400 (Sun, 27 Jul 2008)
New Revision: 32334
grass/trunk/gui/wxpython/gui_modules/nviz.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/vdigit.py
wxGUI: use ';' as separator instead of ':', colors not saved as tuples but R:G:B strings -- it breaks previously saved settings
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-27 11:30:52 UTC (rev 32333)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-27 16:17:52 UTC (rev 32334)
@@ -2224,7 +2224,7 @@
if win.GetName() == "selection":
value = win.GetSelection()
elif win.GetName() == "color":
- value = win.GetColour()
+ value = tuple(win.GetColour())
else:
value = win.GetValue()
if subkey == 'pos':
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-07-27 11:30:52 UTC (rev 32333)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-07-27 16:17:52 UTC (rev 32334)
@@ -48,6 +48,11 @@
self.filePath = None
+ # key/value separator
+ self.sep = ';'
# default settings
self.defaultSettings = {
@@ -314,14 +319,14 @@
'legendSize' : 10,
'marker' : {
- 'color' : wx.Colour(0, 0, 0),
+ 'color' : (0, 0, 0, 255),
'fill' : 'transparent',
'size' : 2,
'type' : 'triangle',
'legend' : _('Segment break'),
'grid' : {
- 'color' : wx.Colour(200,200,200) ,
+ 'color' : (200, 200, 200, 255),
'enabled' : True,
'x-axis' : {
@@ -480,6 +485,7 @@
_("aster"),
_("gyro"),
_("histogram"))
def ReadSettingsFile(self, settings=None):
"""Reads settings file (mapset, location, gisdbase)"""
if settings is None:
@@ -519,8 +525,8 @@
file = open(filename, "r")
for line in file.readlines():
line = line.rstrip('%s' % os.linesep)
- group, key = line.split(':')[0:2]
- kv = line.split(':')[2:]
+ group, key = line.split(self.sep)[0:2]
+ kv = line.split(self.sep)[2:]
subkeyMaster = None
if len(kv) % 2 != 0: # multiple (e.g. nviz)
subkeyMaster = kv[0]
@@ -532,32 +538,8 @@
else:
subkey = kv[idx]
value = kv[idx+1]
- if len(value) == 0:
- self.Append(settings, group, key, subkey, '')
- else:
- # casting
- if value == 'True':
- value = True
- elif value == 'False':
- value = False
- elif value == 'None':
- value = None
- elif value[0] == '(':
- tmp = value.replace('(','').replace(')', '').split(',')
- try:
- value = tuple(map(int, tmp))
- except ValueError:
- value = tuple(tmp)
- else:
- try:
- value = int(value)
- try:
- value = float(value)
- pass
- self.Append(settings, group, key, subkey, value)
+ value = self.__parseValue(value, read=True)
+ self.Append(settings, group, key, subkey, value)
idx += 2
finally:
file.close()
@@ -589,35 +571,67 @@
file = open(filePath, "w")
for group in settings.keys():
for key in settings[group].keys():
- file.write('%s:%s:' % (group, key))
+ file.write('%s%s%s%s' % (group, self.sep, key, self.sep))
subkeys = settings[group][key].keys()
for idx in range(len(subkeys)):
value = settings[group][key][subkeys[idx]]
if type(value) == type({}):
if idx > 0:
- file.write('%s%s:%s:' % (os.linesep, group, key))
- file.write('%s:' % subkeys[idx])
+ file.write('%s%s%s%s%s' % (os.linesep, group, self.sep, key, self.sep))
+ file.write('%s%s' % (subkeys[idx], self.sep))
kvalues = settings[group][key][subkeys[idx]].keys()
srange = range(len(kvalues))
for sidx in srange:
- file.write('%s:%s' % (kvalues[sidx],
- settings[group][key][subkeys[idx]][kvalues[sidx]]))
+ svalue = self.__parseValue(settings[group][key][subkeys[idx]][kvalues[sidx]])
+ file.write('%s%s%s' % (kvalues[sidx], self.sep,
+ svalue))
if sidx < len(kvalues) - 1:
- file.write(':')
+ file.write('%s' % self.sep)
else:
- file.write('%s:%s' % (subkeys[idx], value))
+ value = self.__parseValue(settings[group][key][subkeys[idx]])
+ file.write('%s%s%s' % (subkeys[idx], self.sep, value))
if idx < len(subkeys) - 1:
- file.write(':')
file.write('%s' % os.linesep)
except IOError, e:
- raise gcmd.SettingsError(e)
- except:
- raise gcmd.SettingsError('Writing settings to file <%s> failed.' % filePath)
+ raise gcmd.SettingsError(message=e)
+ except StandardError, e:
+ raise gcmd.SettingsError(message=_('Writing settings to file <%s> failed.'
+ '\n\nDetails: %s') % (filePath, e))
file.close()
return filePath
+ def __parseValue(self, value, read=False):
+ """Parse value to be store in settings file"""
+ if read: # -> read settings (cast values)
+ if value == 'True':
+ value = True
+ elif value == 'False':
+ value = False
+ elif value == 'None':
+ value = None
+ elif ':' in value: # -> color
+ value = tuple(map(int, value.split(':')))
+ else:
+ try:
+ value = int(value)
+ except ValueError:
+ try:
+ value = float(value)
+ pass
+ else: # -> write settings
+ if type(value) == type(wx.Colour(0, 0, 0, 0)):
+ print value, type(value)
+ if type(value) == type(()): # -> color
+ value = str(value[0]) + ':' +\
+ str(value[1]) + ':' + \
+ str(value[2])
+ return value
def Get(self, group, key=None, subkey=None, internal=False):
"""Get value by key/subkey
@@ -1093,10 +1107,12 @@
flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
flexSizer.AddGrowableCol(0)
label = wx.StaticText(parent=panel, id=wx.ID_ANY, label="Color")
hlColor = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
colour=self.settings.Get(group='atm', key='highlight', subkey='color'),
size=(25, 25))
+ hlColor.SetName('GetColour')
self.winId['atm:highlight:color'] = hlColor.GetId()
flexSizer.Add(label, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
@@ -1391,6 +1407,8 @@
value = win.IsChecked()
elif win.GetName() == 'GetStringSelection':
value = win.GetStringSelection()
+ elif win.GetName() == 'GetColour':
+ value = tuple(win.GetValue())
else:
Modified: grass/trunk/gui/wxpython/gui_modules/vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-07-27 11:30:52 UTC (rev 32333)
+++ grass/trunk/gui/wxpython/gui_modules/vdigit.py 2008-07-27 16:17:52 UTC (rev 32334)
@@ -1652,7 +1652,8 @@
flexSizer.Add(textLabel, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(enabled, proportion=0, flag=wx.ALIGN_CENTER | wx.FIXED_MINSIZE)
flexSizer.Add(color, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ color.SetName("GetColour")
sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
panel.SetSizer(sizer)
@@ -2111,10 +2112,10 @@
UserSettings.Set(group='vdigit', key=key, subkey='enabled',
value=enabled.IsChecked())
UserSettings.Set(group='vdigit', key=key, subkey='color',
- value=color.GetColour())
+ value=tuple(color.GetColour()))
else:
# display
UserSettings.Set(group='vdigit', key="lineWidth", subkey='value',
value=int(self.lineWidthValue.GetValue()))
