[GRASS-SVN] r32325 - grass/trunk/visualization/nviz/scripts
Sat Jul 26 22:57:35 EDT 2008
Author: cmbarton
Date: 2008-07-26 22:57:35 -0400 (Sat, 26 Jul 2008)
New Revision: 32325
   grass/trunk/visualization/nviz/scripts/config.tcl
   grass/trunk/visualization/nviz/scripts/nviz2.2_script
   grass/trunk/visualization/nviz/scripts/panel_main.tcl
   grass/trunk/visualization/nviz/scripts/panel_surf.tcl
   grass/trunk/visualization/nviz/scripts/widgets.tcl
Fixed cosmetics for running nviz under TclTk 8.5 aqua in Mac. Should not adversely affect nviz in x11 or Windows.
Modified: grass/trunk/visualization/nviz/scripts/config.tcl
--- grass/trunk/visualization/nviz/scripts/config.tcl	2008-07-26 22:53:52 UTC (rev 32324)
+++ grass/trunk/visualization/nviz/scripts/config.tcl	2008-07-27 02:57:35 UTC (rev 32325)
@@ -31,7 +31,7 @@
 set nv_path "$gisbase/etc/nviz2.2"
 #Get ProcessName varaible set from nviz2.2_script
- set ProcessName $env(NV_processname)
+set ProcessName $env(NV_processname)
 if {[info exists env(MSYSCON)]} {
     set mingw "1"
@@ -78,6 +78,7 @@
 #  Resources
 option add *background gray90 widgetDefault
+option add *highlightBackground gray90 widgetDefault
 option add *activeBackground gray80 widgetDefault
 option add *font -*-helvetica-medium-r-normal-*-12-*-iso8859-1 widgetDefault
 option add *Label.font -*-helvetica-bold-r-normal-*-12-*-iso8859-1
Modified: grass/trunk/visualization/nviz/scripts/nviz2.2_script
--- grass/trunk/visualization/nviz/scripts/nviz2.2_script	2008-07-26 22:53:52 UTC (rev 32324)
+++ grass/trunk/visualization/nviz/scripts/nviz2.2_script	2008-07-27 02:57:35 UTC (rev 32325)
@@ -30,6 +30,7 @@
 global src_boot
 global env
 global BGColor
+set BGColor #FFFFFF
 #If set to 1 output debug statements
 global DEBUG
@@ -38,8 +39,6 @@
 #Initialize ProcessName variable
 set env(NV_processname) NVIZ
-set BGColor #FFFFFF
 source $src_boot/etc/nviz2.2/scripts/config.tcl
 #append bwidget for tooltip stuff
@@ -234,7 +233,7 @@
 if {$DEBUG} {puts "Build toplevel window"}
 	set Nv_(First) 1
-	wm geometry . +10+10
+	wm geometry . +100+50
 	wm minsize . 10 10
 	wm sizefrom . user
@@ -256,15 +255,15 @@
 	#panel area frame
 	frame $Nv_(PAREA) -relief flat -bd 0
-	pack $Nv_(PAREA) -side left -fill y -expand 0
+	pack $Nv_(PAREA) -side left -fill y -expand no
 	#togl canvas
 	frame .middle.draw -relief groove -bd 2
-	pack .middle.draw -side left -fill both -expand 1
+	pack .middle.draw -side left -fill both -expand yes
 	entry .bottom.entry -relief sunken -state disabled \
 		-background #FFFFFF -textvariable Nv_(text)
-	pack .bottom.entry -side left -fill both -expand 1
+	pack .bottom.entry -side left -fill both -expand yes
 	set cwidth [exec $src_boot/bin/g.gisenv X3D_WIDTH]
 	set cheight [exec $src_boot/bin/g.gisenv X3D_HEIGHT]
@@ -272,20 +271,20 @@
 	if {$cwidth > 0 && $cheight > 0} {
 		togl .middle.draw.canvas -rgba true -double true -depth true \
 				-width $cwidth -height $cheight
-		pack .middle.draw.canvas -side top -expand 0
+		pack .middle.draw.canvas -side top -expand no
 	} elseif {$cwidth == "" && $cheight > 0} {
 				-height $cheight
-		pack .middle.draw.canvas -side top -fill x -expand 1
+		pack .middle.draw.canvas -side top -fill x -expand yes
 	} elseif {$cheight == "" && $cwidth > 0} {
 				-width $cwidth
-		pack .middle.draw.canvas -side top -fill y -expand 1
+		pack .middle.draw.canvas -side top -fill y -expand yes
 	} else {
 	#nothing set
 	set constrained 1
-		pack .middle.draw.canvas -side top -fill both -expand 1
+		pack .middle.draw.canvas -side top -fill both -expand yes
 	bind .middle.draw.canvas <Expose> {Nv_expose %W}
@@ -301,11 +300,11 @@
 	#Moved the following packing here to satisfy some TCL versions
 	#Prevents minimized GUI
 	#top frame for menubar
-	pack .top -side top -fill x -expand 0
+	pack .top -side top -fill x -expand no
 	#middle frame for menus and togl canvas
-	pack .middle  -side top -fill both -expand 1
+	pack .middle  -side top -fill both -expand yes
 	#botom frame for statusbar
-	pack .bottom -side top -fill x -expand 0
+	pack .bottom -side top -fill x -expand no
 # DEBUG
@@ -330,12 +329,12 @@
 	# make	menubar
-	frame $Nv_(AREA).menu  -relief raised -borderwidth 1
-	pack $Nv_(AREA).menu -side top -fill x -expand 0
+	frame $Nv_(AREA).menu  -relief flat -borderwidth 1
+	pack $Nv_(AREA).menu -side top -fill x -expand no
 	pack $Nv_(PAREA).canvas -side top -fill both -expand yes
 	pack $Nv_(PAREA).f1 -side left -before $Nv_(PAREA).canvas -fill y
-	pack $Nv_(PAREA).f1.scrolly -side top -fill y -expand 1
+	pack $Nv_(PAREA).f1.scrolly -side top -fill y -expand yes
 	pack $Nv_(PAREA).f1.b1 -side bottom -fill x
 	pack $Nv_(P_AREA) -side top -fill y -expand yes
@@ -347,9 +346,20 @@
 	#Bind menu area to canvas and scrollbars
 	$Nv_(PAREA).canvas create window 0 0 -window $Nv_(P_AREA) -anchor nw
 	bind $Nv_(P_AREA) <Configure> "set_scrollsize"
+	pack [Nv_mkMenu $Nv_(AREA).menu.help Help \
+		{"NVIZ Help" "About NVIZ" "NVIZ - Bugs / ToDo"} \
+		{0 0 0} \
+		{"nviz_browse nviz_toc.html" "nviz_browse nviz_desc.html" "nviz_browse bugs_todo.html"} ] \
+		-side right -fill x -expand yes -anchor e
+	# DEBUG
+	if {$DEBUG} {puts "Help menu made"}
+	set leftmenu [frame $Nv_(AREA).menu.left -relief flat -bd 0]
 	# file menu
-	set filemenu [Nv_mkMenu $Nv_(AREA).menu.file File \
+	set filemenu [Nv_mkMenu $leftmenu.file File \
 			  {"Load State ..." "Save State ..." \
 				"Set Canvas Size ..."
@@ -370,21 +380,12 @@
 				"Separator" \
 				"reset_Nviz" "Nv_close_scripting ; exit ; puts"}]
-	pack $filemenu -side left -fill x -expand 0
+	pack $filemenu -side left -fill x -expand yes
 # DEBUG
 if {$DEBUG} {puts "file menu made"}
-	pack [Nv_mkMenu $Nv_(AREA).menu.help Help \
-		{"NVIZ Help" "About NVIZ" "NVIZ - Bugs / ToDo"} \
-		{0 0 0} \
-		{"nviz_browse nviz_toc.html" "nviz_browse nviz_desc.html" "nviz_browse bugs_todo.html"} ] \
-		-side right -fill x -expand 0
-# DEBUG
-if {$DEBUG} {puts "Help menu made"}
 	# Take these out later when these features are more reliable
 #	 $Nv_(AREA).menu.file.m entryconfigure 3 -state disabled
 #	 $Nv_(AREA).menu.file.m entryconfigure 4 -state disabled
@@ -392,52 +393,55 @@
 # DEBUG
 if {$DEBUG} {puts "disabled made"}
-	pack [Nv_mkConfigMenu $Nv_(AREA).menu.config] -side left -fill x -expand 0
+	pack [Nv_mkConfigMenu $leftmenu.config] -side left -fill x -expand yes
-	pack [Nv_mkPanelMenu $Nv_(AREA).menu.panel] -side left -fill x -expand 0
+	pack [Nv_mkPanelMenu $leftmenu.panel] -side left -fill x -expand yes
 # DEBUG
 if {$DEBUG} {puts "scripting menu 0 made"}
 	# Make a menu entry for scripting
-	menubutton $Nv_(AREA).menu.scripting -text Scripting \
-	-menu $Nv_(AREA).menu.scripting.m -underline 0
-	menu $Nv_(AREA).menu.scripting.m
+	menubutton $leftmenu.scripting -text Scripting \
+		-menu $leftmenu.scripting.m -underline 0
+	set scriptingmenu [menu $leftmenu.scripting.m]
-	$Nv_(AREA).menu.scripting.m add checkbutton -label "On" \
-	-onvalue 1 -offvalue 0 -variable ScriptState \
-	-command "script_handle_on"
+	$scriptingmenu add checkbutton -label "On" \
+		-onvalue 1 -offvalue 0 -variable ScriptState \
+		-command "script_handle_on"
-	$Nv_(AREA).menu.scripting.m add separator
+	$scriptingmenu add separator
-	$Nv_(AREA).menu.scripting.m add command -label "Create New Scriptfile" \
-	-underline 0 -command SetScriptFile
+	$scriptingmenu add command -label "Create New Scriptfile" \
+		-underline 0 -command SetScriptFile
-	$Nv_(AREA).menu.scripting.m add command -label "Open and Play Script" \
-	-underline 0 -command {set ScriptPlaying 1 ; exec nviz -f $default_panel_path/script_play &}
+	$scriptingmenu add command -label "Open and Play Script" \
+		-underline 0 -command {set ScriptPlaying 1 ; exec nviz -f $default_panel_path/script_play &}
-	$Nv_(AREA).menu.scripting.m add command -label "Close Script" \
-	-underline 1 -command Nv_close_scripting
+	$scriptingmenu add command -label "Close Script" \
+		-underline 1 -command Nv_close_scripting
-	$Nv_(AREA).menu.scripting.m add command -label "Add Script Line" \
-	-underline 0 -command AddScriptLine
+	$scriptingmenu add command -label "Add Script Line" \
+		-underline 0 -command AddScriptLine
-	$Nv_(AREA).menu.scripting.m add command -label "Add Script Command" \
-	-underline 1 -command AddScriptCmd
+	$scriptingmenu add command -label "Add Script Command" \
+		-underline 1 -command AddScriptCmd
-	$Nv_(AREA).menu.scripting.m add command -label "Script Tools" \
-	-underline 1 -command {exec nviz -f $default_panel_path/script_tools -q &}
+	$scriptingmenu add command -label "Script Tools" \
+		-underline 1 -command {exec nviz -f $default_panel_path/script_tools -q &}
-	pack $Nv_(AREA).menu.scripting -side left -fill x -expand 0
+	pack $leftmenu.scripting -side left -fill x -expand yes
 # DEBUG
 if {$DEBUG} {puts "scripting menu made"}
+	pack $leftmenu -side left -fill x -expand yes
 	tk_menuBar $Nv_(AREA).menu $Nv_(AREA).menu.file $Nv_(AREA).menu.panel \
@@ -778,10 +782,10 @@
 	frame .canvas_size.f2
 	frame .canvas_size.f3
 	pack .canvas_size.f3 .canvas_size.f1 .canvas_size.f2 -side top \
-			-fill both -expand 1
+			-fill both -expand yes
 	label .canvas_size.f3.l1 -text "Set Size of Display Canvas"
-	pack .canvas_size.f3.l1 -side top -fill both -expand 0
+	pack .canvas_size.f3.l1 -side top -fill both -expand no
 	label .canvas_size.f1.l1 -text "Width"
 	entry .canvas_size.f1.e1 -textvariable cwidth -width 6
@@ -804,10 +808,10 @@
 	button .canvas_size.f2.b1 -text "Close" \
 		-command {
 			if {$constrained} {
-					pack $Nv_(TOP).canvas -side top -fill both -expand 1
+					pack $Nv_(TOP).canvas -side top -fill both -expand yes
 			} else {
 					$Nv_(TOP).canvas configure -width $cwidth -height $cheight
-					pack $Nv_(TOP).canvas -side top -expand 0 -fill none
+					pack $Nv_(TOP).canvas -side top -expand no -fill none
 				#Need Nset_viewport to make sure reshape is called
 				Nset_viewport $cwidth $cheight
Modified: grass/trunk/visualization/nviz/scripts/panel_main.tcl
--- grass/trunk/visualization/nviz/scripts/panel_main.tcl	2008-07-26 22:53:52 UTC (rev 32324)
+++ grass/trunk/visualization/nviz/scripts/panel_main.tcl	2008-07-27 02:57:35 UTC (rev 32325)
@@ -32,11 +32,13 @@
 global arw_clr arw_text_clr
+global src_boot
+source $src_boot/etc/nviz2.2/scripts/config.tcl
 proc mkmainPanel { BASE } {
 	global Nv_
 	global XY
 	#Globals for draw features
 	global surface vector sites volume
 	global legend labels n_arrow scalebar
Modified: grass/trunk/visualization/nviz/scripts/panel_surf.tcl
--- grass/trunk/visualization/nviz/scripts/panel_surf.tcl	2008-07-26 22:53:52 UTC (rev 32324)
+++ grass/trunk/visualization/nviz/scripts/panel_surf.tcl	2008-07-27 02:57:35 UTC (rev 32325)
@@ -67,8 +67,8 @@
 	set tmp [frame $BASE.top.top]
 	Label $tmp.current -text "Current:" -anchor w
 	mkMapList $tmp.list surf set_display_from_curr
-	button $tmp.new -text New -anchor center -bd 1 -width 4 -command new_surf
-	button $tmp.delete -text Delete -anchor center -bd 1 -width 4 -command delete_surf
+	button $tmp.new -text New -anchor center -bd 1 -command new_surf
+	button $tmp.delete -text Delete -anchor center -bd 1 -command delete_surf
 	pack $tmp.current $tmp.list -side left
 	pack $tmp.delete $tmp.new -side right -expand 0
Modified: grass/trunk/visualization/nviz/scripts/widgets.tcl
--- grass/trunk/visualization/nviz/scripts/widgets.tcl	2008-07-26 22:53:52 UTC (rev 32324)
+++ grass/trunk/visualization/nviz/scripts/widgets.tcl	2008-07-27 02:57:35 UTC (rev 32325)
@@ -587,7 +587,7 @@
 		set name [Nget_map_name $name $type]
-	menubutton $P -text $name -menu $P.m -relief sunken -bg white
+	menubutton $P -text $name -menu $P.m -relief sunken
 	menu $P.m -tearoff 0
 	foreach i $list {
 		set map_name [Nget_map_name $i $type]
