[GRASS-SVN] r32345 - in grass/trunk: . include include/Make
svn_grass at osgeo.org
Sun Jul 27 18:32:43 EDT 2008
Author: glynn
Date: 2008-07-27 18:32:43 -0400 (Sun, 27 Jul 2008)
New Revision: 32345
grass/trunk/aclocal.m4
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/Make/Platform.make.in
grass/trunk/include/config.h.in
Better support for OpenGL and Tcl/Tk frameworks on MacOSX
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2008-07-27 22:30:52 UTC (rev 32344)
+++ grass/trunk/aclocal.m4 2008-07-27 22:32:43 UTC (rev 32345)
@@ -169,6 +169,36 @@
LDFLAGS=${ac_save_ldflags}
+dnl $1 = function
+dnl $2 = descriptive name
+dnl $3 = result variable
+dnl $4 = LIBS initialiser (added to $3)
+dnl $5 = LDFLAGS initialiser (not added to $3)
+dnl $6 = LIBS initialiser (not added to $3)
+dnl $7 = ACTION-IF-FOUND
+dnl $8 = ACTION-IF-NOT-FOUND
+define(LOC_CHECK_FUNC,[
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS="$4 $6 $LIBS"
+LDFLAGS="$5 $LDFLAGS"
+AC_CHECK_FUNC($1,[
+ifelse($7,[],[
+ $3="$$3 $4"
+],$7)
+ifelse($8,[],[
+ifelse($2,[],
+ [AC_MSG_ERROR([*** Unable to locate $2.])],
+ [AC_MSG_ERROR([*** Unable to locate $1.])]
+],$8)
+LIBS=${ac_save_libs}
+LDFLAGS=${ac_save_ldflags}
AC_DEFUN([LOC_CHECK_VERSION_STRING],[
AC_MSG_CHECKING($3 version)
ac_save_cppflags="$CPPFLAGS"
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-07-27 22:30:52 UTC (rev 32344)
+++ grass/trunk/configure 2008-07-27 22:32:43 UTC (rev 32345)
@@ -8407,27 +8407,44 @@
# Enable TCLTK option
+TCLINCDIR=
+TCLTKLIBPATH=
+TCLTKLIBS=
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8413: checking whether to use Tcl/Tk" >&5
+echo "configure:8416: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
- "no") USE_TCLTK= ;;
- "yes") USE_TCLTK="1" ;;
- *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
+ n|no)
+ TCLTK_TYPE=none
+ y|yes|x|x11)
+ TCLTK_TYPE=X11
+ USE_TCLTK=1
+ TCLTK_X11=1
+ aqua|mac|osx|macosx)
+ TCLTK_TYPE=Aqua
+ USE_TCLTK=1
+ TCLTK_AQUA=1
+ win|windows|mswin)
+ TCLTK_TYPE=Windows
+ USE_TCLTK=1
+ TCLTK_WINDOWS=1
+ { echo "configure: error: *** Valid arguments for --with-tcltk= are yes,no,x11,aqua,windows." 1>&2; exit 1; }
esac
+if test -n "$USE_TCLTK"; then
+if test -n "$TCLTK_AQUA" ; then
-TCLINCDIR=
-TCLTKLIBPATH=
-TCLTKLIBS=
-if test -n "$USE_TCLTK"; then
echo $ac_n "checking for location of Tcl/Tk framework""... $ac_c" 1>&6
-echo "configure:8431: checking for location of Tcl/Tk framework" >&5
+echo "configure:8448: checking for location of Tcl/Tk framework" >&5
case "$with_tcltk_framework" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tcltk-framework." 1>&2; exit 1; }
@@ -8437,34 +8454,29 @@
if test -n "$with_tcltk_framework"; then
if test -d $with_tcltk_framework; then
- TCLTKLIBPATH="$TCLTKLIBPATH -F$with_tcltk_framework"
+ TCLTKPATH="$TCLTKPATH -F$with_tcltk_framework"
else
{ echo "configure: error: *** Tcl/Tk framework directory $dir does not exist." 1>&2; exit 1; }
fi
fi
-if test -n "$TCLTKLIBPATH" ; then
-dir="$with_tcltk_framework"
-TCLINCDIR="-I$dir/Tcl.framework/Headers -I$dir/Tk.framework/Headers -I$dir/Tk.framework/PrivateHeaders"
-CPPFLAGS="$TCLINCDIR $CPPFLAGS"
-for ac_hdr in tcl.h
+CPPFLAGS="$TCLTKPATH $CPPFLAGS"
+for ac_hdr in Tk/tk.h
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8460: checking for $ac_hdr" >&5
+echo "configure:8472: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 8463 "configure"
+#line 8475 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8468: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8486,7 +8498,7 @@
else
echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate Tcl includes." 1>&2; exit 1; }
+{ echo "configure: error: *** Unable to locate Tcl/Tk includes." 1>&2; exit 1; }
fi
done
@@ -8494,57 +8506,16 @@
CPPFLAGS=$ac_save_cppflags
-ac_save_cppflags="$CPPFLAGS"
-for ac_hdr in tk.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8504: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 8507 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=yes"
-else
- echo "$ac_err" >&5
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
- cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
- echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate Tk includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-LDFLAGS="$TCLTKLIBPATH -framework Tcl -framework Tk $LIBS"
+LIBS="-framework Tcl -framework Tk $LIBS"
+LDFLAGS="$TCLTKPATH $LDFLAGS"
echo $ac_n "checking for Tk_MainWindow""... $ac_c" 1>&6
-echo "configure:8545: checking for Tk_MainWindow" >&5
+echo "configure:8516: checking for Tk_MainWindow" >&5
-#line 8548 "configure"
+#line 8519 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char Tk_MainWindow(); below. */
@@ -8567,7 +8538,7 @@
; return 0; }
EOF
-if { (eval echo configure:8571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_Tk_MainWindow=yes"
else
@@ -8581,24 +8552,41 @@
if eval "test \"`echo '$ac_cv_func_'Tk_MainWindow`\" = yes"; then
-TCLTKLIBS="-framework Tcl -framework Tk"
+ TCLTKLIBS="$TCLTKLIBS -framework Tcl -framework Tk"
else
-{ echo "configure: error: *** Unable to locate Tcl/Tk libraries." 1>&2; exit 1; }
+{ echo "configure: error: *** Unable to locate Tk_MainWindow." 1>&2; exit 1; }
fi
-LDFLAGS=$ac_save_ldflags
-else
+TCLINCDIR="$TCLTKPATH"
+TCLTKLIBPATH="$TCLTKPATH"
+cat >> confdefs.h <<\EOF
+#define TCLTK_AQUA 1
+EOF
+fi # TCLTK_AQUA
+if test -n "$TCLTK_X11" -o -n "$TCLTK_WINDOWS" ; then
# With Tcl/Tk includes directory
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8602: checking for location of Tcl/Tk includes" >&5
+echo "configure:8590: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8624,15 +8612,15 @@
do
-echo "configure:8628: checking for $ac_hdr" >&5
+echo "configure:8616: checking for $ac_hdr" >&5
-#line 8631 "configure"
+#line 8619 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8636: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8624: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8669,15 +8657,15 @@
do
-echo "configure:8673: checking for $ac_hdr" >&5
+echo "configure:8661: checking for $ac_hdr" >&5
-#line 8676 "configure"
+#line 8664 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8711,7 +8699,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8715: checking Tcl version" >&5
+echo "configure:8703: checking Tcl version" >&5
if test "$cross_compiling" = yes; then
@@ -8719,7 +8707,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8723 "configure"
+#line 8711 "configure"
#include <stdio.h>
@@ -8731,7 +8719,7 @@
EOF
-if { (eval echo configure:8735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8749,7 +8737,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8753: checking Tk version" >&5
+echo "configure:8741: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8757,7 +8745,7 @@
else
-#line 8761 "configure"
+#line 8749 "configure"
#include <stdio.h>
@@ -8769,7 +8757,7 @@
EOF
-if { (eval echo configure:8773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8798,7 +8786,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8802: checking for location of Tcl/Tk library" >&5
+echo "configure:8790: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8828,13 +8816,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8832: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8820: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8838 "configure"
+#line 8826 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -8845,7 +8833,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -8864,13 +8852,13 @@
-echo "configure:8868: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8856: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8874 "configure"
+#line 8862 "configure"
@@ -8881,7 +8869,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8908,13 +8896,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8912: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8900: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8918 "configure"
+#line 8906 "configure"
@@ -8925,7 +8913,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8944,13 +8932,13 @@
-echo "configure:8948: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8936: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8954 "configure"
+#line 8942 "configure"
@@ -8961,7 +8949,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8988,13 +8976,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8992: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8980: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8998 "configure"
+#line 8986 "configure"
@@ -9005,7 +8993,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:9009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9024,13 +9012,13 @@
-echo "configure:9028: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9016: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9034 "configure"
+#line 9022 "configure"
@@ -9041,7 +9029,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:9045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9119,13 +9107,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9123: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9111: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9129 "configure"
+#line 9117 "configure"
@@ -9136,7 +9124,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9155,13 +9143,13 @@
-echo "configure:9159: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9147: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9165 "configure"
+#line 9153 "configure"
@@ -9172,7 +9160,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9199,13 +9187,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9203: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9191: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9209 "configure"
+#line 9197 "configure"
@@ -9216,7 +9204,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9220: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9235,13 +9223,13 @@
-echo "configure:9239: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9227: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9245 "configure"
+#line 9233 "configure"
@@ -9252,7 +9240,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9279,13 +9267,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9283: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9271: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9289 "configure"
+#line 9277 "configure"
@@ -9296,7 +9284,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9315,13 +9303,13 @@
-echo "configure:9319: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9307: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9325 "configure"
+#line 9313 "configure"
@@ -9332,7 +9320,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9402,11 +9390,23 @@
TCLTKLIBS="$TKLIB $TCLLIB"
+if test -n "$TCLTK_X11" ; then
+#define TCLTK_X11 1
+EOF
fi
+if test -n "$TCLTK_WINDOWS" ; then
+#define TCLTK_WINDOWS 1
+EOF
+fi
+fi # TCLTK_X11 || TCLTK_WINDOWS
#define HAVE_TCLTK 1
EOF
@@ -9414,20 +9414,25 @@
fi # $USE_TCLTK
-TKINCDIR=$TCLINCDIR
+TKINCDIR="$TCLINCDIR"
# Done checking Tcl/Tk
# Enable PostgreSQL option
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9431: checking whether to use PostgreSQL" >&5
+echo "configure:9436: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9454,7 +9459,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9458: checking for location of PostgreSQL includes" >&5
+echo "configure:9463: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9480,15 +9485,15 @@
do
-echo "configure:9484: checking for $ac_hdr" >&5
+echo "configure:9489: checking for $ac_hdr" >&5
-#line 9487 "configure"
+#line 9492 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9526,7 +9531,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9530: checking for location of PostgreSQL library" >&5
+echo "configure:9535: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9555,13 +9560,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9559: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9564: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9565 "configure"
+#line 9570 "configure"
@@ -9572,7 +9577,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9591,13 +9596,13 @@
-echo "configure:9595: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9600: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9601 "configure"
+#line 9606 "configure"
@@ -9608,7 +9613,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9627,13 +9632,13 @@
-echo "configure:9631: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9636: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9637 "configure"
+#line 9642 "configure"
@@ -9644,7 +9649,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9663,13 +9668,13 @@
-echo "configure:9667: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9672: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9673 "configure"
+#line 9678 "configure"
@@ -9680,7 +9685,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9737,13 +9742,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9741: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9746: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9747 "configure"
+#line 9752 "configure"
@@ -9754,7 +9759,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9776,13 +9781,13 @@
-echo "configure:9780: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9785: checking for PQcmdTuples in -lpq" >&5
-#line 9786 "configure"
+#line 9791 "configure"
@@ -9793,7 +9798,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9836,7 +9841,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9840: checking whether to use MySQL" >&5
+echo "configure:9845: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9856,7 +9861,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9860: checking for location of MySQL includes" >&5
+echo "configure:9865: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9882,15 +9887,15 @@
do
-echo "configure:9886: checking for $ac_hdr" >&5
+echo "configure:9891: checking for $ac_hdr" >&5
-#line 9889 "configure"
+#line 9894 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9927,7 +9932,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9931: checking for location of MySQL library" >&5
+echo "configure:9936: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9958,13 +9963,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9962: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9967: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9968 "configure"
+#line 9973 "configure"
@@ -9975,7 +9980,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9994,13 +9999,13 @@
-echo "configure:9998: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10003: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 10004 "configure"
+#line 10009 "configure"
@@ -10011,7 +10016,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10030,13 +10035,13 @@
-echo "configure:10034: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10039: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10040 "configure"
+#line 10045 "configure"
@@ -10047,7 +10052,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10066,13 +10071,13 @@
-echo "configure:10070: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10075: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10076 "configure"
+#line 10081 "configure"
@@ -10083,7 +10088,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10102,13 +10107,13 @@
-echo "configure:10106: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10111: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10112 "configure"
+#line 10117 "configure"
@@ -10119,7 +10124,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10138,13 +10143,13 @@
-echo "configure:10142: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10147: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10148 "configure"
+#line 10153 "configure"
@@ -10155,7 +10160,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10174,13 +10179,13 @@
-echo "configure:10178: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10183: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10184 "configure"
+#line 10189 "configure"
@@ -10191,7 +10196,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10210,13 +10215,13 @@
-echo "configure:10214: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10219: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10220 "configure"
+#line 10225 "configure"
@@ -10227,7 +10232,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10317,7 +10322,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10321: checking for $ac_word" >&5
+echo "configure:10326: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10358,10 +10363,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10362: checking for mysql_server_init" >&5
+echo "configure:10367: checking for mysql_server_init" >&5
-#line 10365 "configure"
+#line 10370 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -10384,7 +10389,7 @@
; return 0; }
EOF
-if { (eval echo configure:10388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10422,7 +10427,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10426: checking whether to use SQLite" >&5
+echo "configure:10431: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10442,7 +10447,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10446: checking for location of SQLite includes" >&5
+echo "configure:10451: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10468,15 +10473,15 @@
do
-echo "configure:10472: checking for $ac_hdr" >&5
+echo "configure:10477: checking for $ac_hdr" >&5
-#line 10475 "configure"
+#line 10480 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10485: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10519,7 +10524,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10523: checking for location of SQLite library" >&5
+echo "configure:10528: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10546,13 +10551,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10550: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10555: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10556 "configure"
+#line 10561 "configure"
@@ -10563,7 +10568,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10582,13 +10587,13 @@
-echo "configure:10586: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10591: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10592 "configure"
+#line 10597 "configure"
@@ -10599,7 +10604,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10652,7 +10657,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10656: checking whether to use FFMPEG" >&5
+echo "configure:10661: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10672,7 +10677,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10676: checking for location of FFMPEG includes" >&5
+echo "configure:10681: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10698,15 +10703,15 @@
do
-echo "configure:10702: checking for $ac_hdr" >&5
+echo "configure:10707: checking for $ac_hdr" >&5
-#line 10705 "configure"
+#line 10710 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10742,15 +10747,15 @@
do
-echo "configure:10746: checking for $ac_hdr" >&5
+echo "configure:10751: checking for $ac_hdr" >&5
-#line 10749 "configure"
+#line 10754 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10786,15 +10791,15 @@
do
-echo "configure:10790: checking for $ac_hdr" >&5
+echo "configure:10795: checking for $ac_hdr" >&5
-#line 10793 "configure"
+#line 10798 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10837,7 +10842,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10841: checking for location of FFMPEG library" >&5
+echo "configure:10846: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10864,13 +10869,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10868: checking for av_free in -lavutil" >&5
+echo "configure:10873: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10874 "configure"
+#line 10879 "configure"
@@ -10881,7 +10886,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10900,13 +10905,13 @@
-echo "configure:10904: checking for av_free in -lavutil" >&5
+echo "configure:10909: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10910 "configure"
+#line 10915 "configure"
@@ -10917,7 +10922,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10962,13 +10967,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10966: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10971: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10972 "configure"
+#line 10977 "configure"
@@ -10979,7 +10984,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10998,13 +11003,13 @@
-echo "configure:11002: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11007: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 11008 "configure"
+#line 11013 "configure"
@@ -11015,7 +11020,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:11019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11060,13 +11065,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11064: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11069: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 11070 "configure"
+#line 11075 "configure"
@@ -11077,7 +11082,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:11081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11096,13 +11101,13 @@
-echo "configure:11100: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11105: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11106 "configure"
+#line 11111 "configure"
@@ -11113,7 +11118,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11173,7 +11178,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11177: checking whether to use OpenGL" >&5
+echo "configure:11182: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -11207,7 +11212,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11211: checking for location of OpenGL includes" >&5
+echo "configure:11216: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11233,15 +11238,15 @@
do
-echo "configure:11237: checking for $ac_hdr" >&5
+echo "configure:11242: checking for $ac_hdr" >&5
-#line 11240 "configure"
+#line 11245 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11245: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11275,7 +11280,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11279: checking for location of OpenGL library" >&5
+echo "configure:11284: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11304,13 +11309,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11308: checking for glBegin in -lGL" >&5
+echo "configure:11313: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11314 "configure"
+#line 11319 "configure"
@@ -11321,7 +11326,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11340,13 +11345,13 @@
-echo "configure:11344: checking for glBegin in -lGL" >&5
+echo "configure:11349: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11350 "configure"
+#line 11355 "configure"
@@ -11357,7 +11362,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11376,13 +11381,13 @@
-echo "configure:11380: checking for glBegin in -lGL" >&5
+echo "configure:11385: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11386 "configure"
+#line 11391 "configure"
@@ -11393,7 +11398,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11412,13 +11417,13 @@
-echo "configure:11416: checking for glBegin in -lGL" >&5
+echo "configure:11421: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11422 "configure"
+#line 11427 "configure"
@@ -11429,7 +11434,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11491,13 +11496,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11495: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11500: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11501 "configure"
+#line 11506 "configure"
@@ -11508,7 +11513,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11527,13 +11532,13 @@
-echo "configure:11531: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11536: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11537 "configure"
+#line 11542 "configure"
@@ -11544,7 +11549,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11585,13 +11590,16 @@
OPENGLLIB="$OPENGL_LIB_PATH $OPENGLLIB"
OPENGLULIB="$OPENGL_LIB_PATH $OPENGLULIB"
-LDFLAGS="$LDFLAGS $OPENGLLIB"
+LIBS=" $OPENGLLIB $LIBS"
+LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11592: checking for glXCreatePbuffer" >&5
+echo "configure:11600: checking for glXCreatePbuffer" >&5
-#line 11595 "configure"
+#line 11603 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11614,7 +11622,7 @@
; return 0; }
EOF
-if { (eval echo configure:11618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11627,19 +11635,34 @@
if eval "test \"`echo '$ac_cv_func_'glXCreatePbuffer`\" = yes"; then
- cat >> confdefs.h <<\EOF
#define HAVE_PBUFFERS 1
EOF
else
+{ echo "configure: error: *** Unable to locate ." 1>&2; exit 1; }
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11640: checking for glXCreateGLXPixmap" >&5
+echo "configure:11663: checking for glXCreateGLXPixmap" >&5
-#line 11643 "configure"
+#line 11666 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11662,7 +11685,7 @@
; return 0; }
EOF
-if { (eval echo configure:11666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11675,16 +11698,25 @@
if eval "test \"`echo '$ac_cv_func_'glXCreateGLXPixmap`\" = yes"; then
#define HAVE_PIXMAPS 1
EOF
else
fi
#define OPENGL_X11 1
EOF
@@ -11694,48 +11726,41 @@
if test "$OPENGL_AQUA" = 1 ; then
-with_opengl_includes=/System/Library/Frameworks/OpenGL.framework/Headers
-with_opengl_libs="-framework OpenGL -framework AGL -framework ApplicationServices"
-# With OpenGL includes directory
-echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11705: checking for location of OpenGL includes" >&5
-case "$with_opengl_includes" in
+echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
+echo "configure:11732: checking for location of OpenGL framework" >&5
+case "$with_opengl_framework" in
- { echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
+ { echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
esac
-echo "$ac_t""$with_opengl_includes" 1>&6
+echo "$ac_t""$with_opengl_framework" 1>&6
-if test -n "$with_opengl_includes" ; then
- for dir in $with_opengl_includes; do
- if test -d "$dir"; then
- OPENGLINC="$OPENGLINC -I$dir"
- else
- { echo "configure: error: *** OpenGL includes directory $dir does not exist." 1>&2; exit 1; }
- fi
- done
+if test -n "$with_opengl_framework"; then
+ if test -d $with_opengl_framework; then
+ OPENGLPATH="$OPENGLPATH -F$with_opengl_framework"
+ else
+ { echo "configure: error: *** OpenGL framework directory $dir does not exist." 1>&2; exit 1; }
+ fi
fi
-CPPFLAGS="$OPENGLINC $CPPFLAGS"
+CPPFLAGS="$OPENGLPATH $CPPFLAGS"
for ac_hdr in OpenGL/gl.h OpenGL/glu.h
do
-echo "configure:11731: checking for $ac_hdr" >&5
+echo "configure:11756: checking for $ac_hdr" >&5
-#line 11734 "configure"
+#line 11759 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11764: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11765,15 +11790,16 @@
-# With OpenGL library directory
-LDFLAGS="$with_opengl_libs $LDFLAGS"
+LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
+LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11774: checking for glBegin" >&5
+echo "configure:11800: checking for glBegin" >&5
-#line 11777 "configure"
+#line 11803 "configure"
which can conflict with char glBegin(); below. */
@@ -11796,7 +11822,7 @@
; return 0; }
EOF
-if { (eval echo configure:11800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11810,11 +11836,33 @@
if eval "test \"`echo '$ac_cv_func_'glBegin`\" = yes"; then
+ OPENGLLIBS="$OPENGLLIBS -framework OpenGL -framework AGL -framework ApplicationServices"
+else
+ echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate glBegin." 1>&2; exit 1; }
+fi
+LIBS=" $OPENGLLIBS $LIBS"
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11815: checking for gluBeginCurve" >&5
+echo "configure:11863: checking for gluBeginCurve" >&5
-#line 11818 "configure"
+#line 11866 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11837,7 +11885,7 @@
; return 0; }
EOF
-if { (eval echo configure:11841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11851,23 +11899,27 @@
if eval "test \"`echo '$ac_cv_func_'gluBeginCurve`\" = yes"; then
-OPENGLLIB="$with_opengl_libs"
-USE_OPENGL=1
-OPENGL_AQUA=1
+ OPENGLLIBS="$OPENGLLIBS "
else
-{ echo "configure: error: *** Unable to locate GLU library." 1>&2; exit 1; }
-fi
-else
-{ echo "configure: error: *** Unable to locate OpenGL library." 1>&2; exit 1; }
+{ echo "configure: error: *** Unable to locate gluBeginCurve." 1>&2; exit 1; }
fi
+OPENGLINC="$OPENGLPATH"
+OPENGLLIBPATH="$OPENGLPATH"
#define OPENGL_AQUA 1
EOF
@@ -11881,7 +11933,7 @@
-echo "configure:11885: checking for location of OpenGL includes" >&5
+echo "configure:11937: checking for location of OpenGL includes" >&5
@@ -11907,15 +11959,15 @@
do
-echo "configure:11911: checking for $ac_hdr" >&5
+echo "configure:11963: checking for $ac_hdr" >&5
-#line 11914 "configure"
+#line 11966 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11949,7 +12001,7 @@
-echo "configure:11953: checking for location of OpenGL library" >&5
+echo "configure:12005: checking for location of OpenGL library" >&5
@@ -11974,18 +12026,18 @@
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11978: checking for OpenGL library" >&5
+echo "configure:12030: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11982 "configure"
+#line 12034 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -12009,18 +12061,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:12013: checking for GLU library" >&5
+echo "configure:12065: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 12017 "configure"
+#line 12069 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12069,7 +12121,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12073: checking whether to use ODBC" >&5
+echo "configure:12125: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12088,7 +12140,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12092: checking for location of ODBC includes" >&5
+echo "configure:12144: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12114,15 +12166,15 @@
do
-echo "configure:12118: checking for $ac_hdr" >&5
+echo "configure:12170: checking for $ac_hdr" >&5
-#line 12121 "configure"
+#line 12173 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12126: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12156,7 +12208,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12160: checking for location of ODBC library" >&5
+echo "configure:12212: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12181,13 +12233,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12185: checking for SQLConnect in -lodbc" >&5
+echo "configure:12237: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12191 "configure"
+#line 12243 "configure"
@@ -12198,7 +12250,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12223,13 +12275,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12227: checking for SQLConnect in -liodbc" >&5
+echo "configure:12279: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12233 "configure"
+#line 12285 "configure"
@@ -12240,7 +12292,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12265,11 +12317,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12269: checking for ODBC library" >&5
+echo "configure:12321: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12273 "configure"
+#line 12325 "configure"
#include <windows.h>
#include <sql.h>
@@ -12277,7 +12329,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12326,7 +12378,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12330: checking whether to use FFTW" >&5
+echo "configure:12382: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12345,7 +12397,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12349: checking for location of FFTW includes" >&5
+echo "configure:12401: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12371,15 +12423,15 @@
do
-echo "configure:12375: checking for $ac_hdr" >&5
+echo "configure:12427: checking for $ac_hdr" >&5
-#line 12378 "configure"
+#line 12430 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12383: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12407,15 +12459,15 @@
do
-echo "configure:12411: checking for $ac_hdr" >&5
+echo "configure:12463: checking for $ac_hdr" >&5
-#line 12414 "configure"
+#line 12466 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12471: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12443,15 +12495,15 @@
do
-echo "configure:12447: checking for $ac_hdr" >&5
+echo "configure:12499: checking for $ac_hdr" >&5
-#line 12450 "configure"
+#line 12502 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12455: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12497,7 +12549,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12501: checking for location of FFTW library" >&5
+echo "configure:12553: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12522,13 +12574,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12526: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12578: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12532 "configure"
+#line 12584 "configure"
@@ -12539,7 +12591,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12564,13 +12616,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12568: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12620: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12574 "configure"
+#line 12626 "configure"
@@ -12581,7 +12633,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12606,13 +12658,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12610: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12662: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12616 "configure"
+#line 12668 "configure"
@@ -12623,7 +12675,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12680,7 +12732,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12684: checking whether to use BLAS" >&5
+echo "configure:12736: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12701,7 +12753,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12705: checking for location of BLAS includes" >&5
+echo "configure:12757: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12721,7 +12773,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12725: checking for location of BLAS library" >&5
+echo "configure:12777: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12747,15 +12799,15 @@
do
-echo "configure:12751: checking for $ac_hdr" >&5
+echo "configure:12803: checking for $ac_hdr" >&5
-#line 12754 "configure"
+#line 12806 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12811: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12790,13 +12842,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12794: checking for dnrm2_ in -lblas" >&5
+echo "configure:12846: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12800 "configure"
+#line 12852 "configure"
@@ -12807,7 +12859,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12826,13 +12878,13 @@
-echo "configure:12830: checking for dnrm2_ in -lblas" >&5
+echo "configure:12882: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12836 "configure"
+#line 12888 "configure"
@@ -12843,7 +12895,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12887,13 +12939,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12891: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12943: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12897 "configure"
+#line 12949 "configure"
@@ -12904,7 +12956,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12919,13 +12971,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12923: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12975: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12929 "configure"
+#line 12981 "configure"
@@ -12936,7 +12988,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12951,13 +13003,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12955: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13007: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12961 "configure"
+#line 13013 "configure"
@@ -12968,7 +13020,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13013,16 +13065,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13017: checking for sgemm in $vlib_flags" >&5
+echo "configure:13069: checking for sgemm in $vlib_flags" >&5
-#line 13019 "configure"
+#line 13071 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13040,13 +13092,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13044: checking for sgemm_ in -lblas" >&5
+echo "configure:13096: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13050 "configure"
+#line 13102 "configure"
@@ -13057,7 +13109,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13072,13 +13124,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13076: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13128: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 13082 "configure"
+#line 13134 "configure"
#include "confdefs.h"
@@ -13089,7 +13141,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13104,13 +13156,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13108: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13160: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13114 "configure"
+#line 13166 "configure"
@@ -13121,7 +13173,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13155,13 +13207,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13159: checking for acosp in -lsunmath" >&5
+echo "configure:13211: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13165 "configure"
+#line 13217 "configure"
@@ -13172,7 +13224,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13187,13 +13239,13 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13191: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13243: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13197 "configure"
+#line 13249 "configure"
@@ -13204,7 +13256,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13234,13 +13286,13 @@
# Generic BLAS library
-echo "configure:13238: checking for sgemm_ in -lblas" >&5
+echo "configure:13290: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13244 "configure"
+#line 13296 "configure"
@@ -13251,7 +13303,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13290,7 +13342,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13294: checking whether to use LAPACK" >&5
+echo "configure:13346: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13315,7 +13367,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13319: checking for location of LAPACK includes" >&5
+echo "configure:13371: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13335,7 +13387,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13339: checking for location of LAPACK library" >&5
+echo "configure:13391: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13361,15 +13413,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13365: checking for $ac_hdr" >&5
+echo "configure:13417: checking for $ac_hdr" >&5
-#line 13368 "configure"
+#line 13420 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13373: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13425: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13401,10 +13453,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13405: checking for dsegv_" >&5
+echo "configure:13457: checking for dsegv_" >&5
-#line 13408 "configure"
+#line 13460 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char dsegv_(); below. */
@@ -13427,7 +13479,7 @@
; return 0; }
EOF
-if { (eval echo configure:13431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13454,13 +13506,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13458: checking for desgv_ in -llapack" >&5
+echo "configure:13510: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-llapack $FLIBS $LIBS"
-#line 13464 "configure"
+#line 13516 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13471,7 +13523,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13503,13 +13555,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13507: checking for dgesv_ in -llapack" >&5
+echo "configure:13559: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13513 "configure"
+#line 13565 "configure"
@@ -13520,7 +13572,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13539,13 +13591,13 @@
-echo "configure:13543: checking for dgesv_ in -llapack" >&5
+echo "configure:13595: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13549 "configure"
+#line 13601 "configure"
@@ -13556,7 +13608,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13612,7 +13664,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13616: checking whether to use Motif" >&5
+echo "configure:13668: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13631,7 +13683,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13635: checking for location of Motif includes" >&5
+echo "configure:13687: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13657,15 +13709,15 @@
do
-echo "configure:13661: checking for $ac_hdr" >&5
+echo "configure:13713: checking for $ac_hdr" >&5
-#line 13664 "configure"
+#line 13716 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13699,7 +13751,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13703: checking for location of Motif library" >&5
+echo "configure:13755: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13724,13 +13776,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13728: checking for XmStringCreate in -lXm" >&5
+echo "configure:13780: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13734 "configure"
+#line 13786 "configure"
@@ -13741,7 +13793,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13782,7 +13834,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13786: checking whether to use Cairo" >&5
+echo "configure:13838: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13808,15 +13860,15 @@
do
-echo "configure:13812: checking for $ac_hdr" >&5
+echo "configure:13864: checking for $ac_hdr" >&5
-#line 13815 "configure"
+#line 13867 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13820: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13850,13 +13902,16 @@
CAIROLIB=`pkg-config --libs cairo`
+ac_save_libs="$LIBS"
ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$LDFLAGS $CAIROLIB"
+LIBS=" $CAIROLIB $LIBS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13857: checking for cairo_create" >&5
+echo "configure:13912: checking for cairo_create" >&5
-#line 13860 "configure"
+#line 13915 "configure"
which can conflict with char cairo_create(); below. */
@@ -13879,7 +13934,7 @@
; return 0; }
EOF
-if { (eval echo configure:13883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13892,16 +13947,22 @@
if eval "test \"`echo '$ac_cv_func_'cairo_create`\" = yes"; then
else
-{ echo "configure: error: *** Unable to locate cairo_create() function." 1>&2; exit 1; }
fi
+LIBS=${ac_save_libs}
LDFLAGS=${ac_save_ldflags}
fi # $USE_CAIRO
@@ -13914,7 +13975,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13918: checking whether to use GLw" >&5
+echo "configure:13979: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13933,7 +13994,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13937: checking for location of GLw includes" >&5
+echo "configure:13998: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13959,15 +14020,15 @@
do
-echo "configure:13963: checking for $ac_hdr" >&5
+echo "configure:14024: checking for $ac_hdr" >&5
-#line 13966 "configure"
+#line 14027 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13995,15 +14056,15 @@
do
-echo "configure:13999: checking for $ac_hdr" >&5
+echo "configure:14060: checking for $ac_hdr" >&5
-#line 14002 "configure"
+#line 14063 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14043,7 +14104,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14047: checking for location of GLw library" >&5
+echo "configure:14108: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14068,13 +14129,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14072: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14133: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14078 "configure"
+#line 14139 "configure"
@@ -14085,7 +14146,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14110,13 +14171,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14114: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14175: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14120 "configure"
+#line 14181 "configure"
@@ -14127,7 +14188,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14152,13 +14213,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14156: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14217: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14162 "configure"
+#line 14223 "configure"
@@ -14169,7 +14230,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14194,13 +14255,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14198: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14259: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14204 "configure"
+#line 14265 "configure"
@@ -14211,7 +14272,7 @@
; return 0; }
EOF
-if { (eval echo configure:14215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14236,13 +14297,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14240: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14301: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14246 "configure"
+#line 14307 "configure"
@@ -14253,7 +14314,7 @@
; return 0; }
EOF
-if { (eval echo configure:14257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14278,13 +14339,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14282: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14343: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14288 "configure"
+#line 14349 "configure"
@@ -14295,7 +14356,7 @@
; return 0; }
EOF
-if { (eval echo configure:14299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14322,13 +14383,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14326: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14387: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14332 "configure"
+#line 14393 "configure"
@@ -14339,7 +14400,7 @@
; return 0; }
EOF
-if { (eval echo configure:14343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14358,13 +14419,13 @@
-echo "configure:14362: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14423: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14368 "configure"
+#line 14429 "configure"
@@ -14375,7 +14436,7 @@
; return 0; }
EOF
-if { (eval echo configure:14379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14402,13 +14463,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14406: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14467: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14412 "configure"
+#line 14473 "configure"
@@ -14419,7 +14480,7 @@
; return 0; }
EOF
-if { (eval echo configure:14423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14438,13 +14499,13 @@
-echo "configure:14442: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14503: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14448 "configure"
+#line 14509 "configure"
@@ -14455,7 +14516,7 @@
; return 0; }
EOF
-if { (eval echo configure:14459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14568,7 +14629,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14572: checking whether to use FreeType" >&5
+echo "configure:14633: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14587,7 +14648,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14591: checking for location of FreeType includes" >&5
+echo "configure:14652: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14613,15 +14674,15 @@
do
-echo "configure:14617: checking for $ac_hdr" >&5
+echo "configure:14678: checking for $ac_hdr" >&5
-#line 14620 "configure"
+#line 14681 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14655,7 +14716,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14659: checking for location of FreeType library" >&5
+echo "configure:14720: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14680,13 +14741,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14684: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14745: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14690 "configure"
+#line 14751 "configure"
@@ -14697,7 +14758,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14738,7 +14799,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14742: checking whether to use NLS" >&5
+echo "configure:14803: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14758,10 +14819,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14762: checking for gettext" >&5
+echo "configure:14823: checking for gettext" >&5
-#line 14765 "configure"
+#line 14826 "configure"
which can conflict with char gettext(); below. */
@@ -14784,7 +14845,7 @@
; return 0; }
EOF
-if { (eval echo configure:14788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14802,13 +14863,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14806: checking for gettext in -lintl" >&5
+echo "configure:14867: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14812 "configure"
+#line 14873 "configure"
@@ -14819,7 +14880,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14854,7 +14915,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14858: checking whether to use C++" >&5
+echo "configure:14919: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14870,7 +14931,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:14874: checking for $ac_word" >&5
+echo "configure:14935: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14899,7 +14960,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14903: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14964: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14910,12 +14971,12 @@
cat > conftest.$ac_ext << EOF
-#line 14914 "configure"
+#line 14975 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14941,19 +15002,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14945: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15006: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14950: checking whether we are using GNU C++" >&5
+echo "configure:15011: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14971,7 +15032,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14975: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15036: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15012,7 +15073,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15016: checking whether to use openDWG" >&5
+echo "configure:15077: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15032,7 +15093,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15036: checking for location of openDGW includes" >&5
+echo "configure:15097: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15058,15 +15119,15 @@
do
-echo "configure:15062: checking for $ac_hdr" >&5
+echo "configure:15123: checking for $ac_hdr" >&5
-#line 15065 "configure"
+#line 15126 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15131: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15100,7 +15161,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15104: checking for location of openDWG library" >&5
+echo "configure:15165: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15147,7 +15208,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15151: checking for special C compiler options needed for large files" >&5
+echo "configure:15212: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15155,7 +15216,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15159 "configure"
+#line 15220 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15171,7 +15232,7 @@
; return 0; }
EOF
-if { (eval echo configure:15175: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15236: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15180,7 +15241,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15184 "configure"
+#line 15245 "configure"
@@ -15196,7 +15257,7 @@
; return 0; }
EOF
-if { (eval echo configure:15200: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15261: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15216,11 +15277,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15220: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15281: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15224 "configure"
+#line 15285 "configure"
@@ -15236,14 +15297,14 @@
; return 0; }
EOF
-if { (eval echo configure:15240: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15301: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15247 "configure"
+#line 15308 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15261,7 +15322,7 @@
; return 0; }
EOF
-if { (eval echo configure:15265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15326: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15280,11 +15341,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15284: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15345: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15288 "configure"
+#line 15349 "configure"
@@ -15300,14 +15361,14 @@
; return 0; }
EOF
-if { (eval echo configure:15304: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15365: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15311 "configure"
+#line 15372 "configure"
#define _LARGE_FILES 1
@@ -15325,7 +15386,7 @@
; return 0; }
EOF
-if { (eval echo configure:15329: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15390: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15344,25 +15405,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15348: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15409: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15352 "configure"
+#line 15413 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15359: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15420: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15366 "configure"
+#line 15427 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15371,7 +15432,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15375: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15436: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15392,10 +15453,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15396: checking if system supports Large Files at all" >&5
+echo "configure:15457: checking if system supports Large Files at all" >&5
-#line 15399 "configure"
+#line 15460 "configure"
#include <stdio.h>
@@ -15427,7 +15488,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15492: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15456,7 +15517,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15460: checking whether to use Python" >&5
+echo "configure:15521: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15476,7 +15537,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15480: checking for $ac_word" >&5
+echo "configure:15541: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15521,15 +15582,15 @@
do
-echo "configure:15525: checking for $ac_hdr" >&5
+echo "configure:15586: checking for $ac_hdr" >&5
-#line 15528 "configure"
+#line 15589 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15594: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15569,7 +15630,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15573: checking for $ac_word" >&5
+echo "configure:15634: checking for $ac_word" >&5
case "$SWIG" in
@@ -15615,7 +15676,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15619: checking whether to use wxWidgets" >&5
+echo "configure:15680: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15635,7 +15696,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15639: checking for $ac_word" >&5
+echo "configure:15700: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15683,7 +15744,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15687: checking wxWidgets version" >&5
+echo "configure:15748: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15706,15 +15767,15 @@
do
-echo "configure:15710: checking for $ac_hdr" >&5
+echo "configure:15771: checking for $ac_hdr" >&5
-#line 15713 "configure"
+#line 15774 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15750,15 +15811,15 @@
do
-echo "configure:15754: checking for $ac_hdr" >&5
+echo "configure:15815: checking for $ac_hdr" >&5
-#line 15757 "configure"
+#line 15818 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15762: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15823: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16006,6 +16067,10 @@
s%@PNGINC@%$PNGINC%g
s%@PNGLIB@%$PNGLIB%g
s%@USE_PNG@%$USE_PNG%g
+s%@USE_TCLTK@%$USE_TCLTK%g
+s%@TCLTK_X11@%$TCLTK_X11%g
+s%@TCLTK_AQUA@%$TCLTK_AQUA%g
+s%@TCLTK_WINDOWS@%$TCLTK_WINDOWS%g
s%@TCLINCDIR@%$TCLINCDIR%g
s%@TKINCDIR@%$TKINCDIR%g
s%@TCLTKLIBPATH@%$TCLTKLIBPATH%g
@@ -16345,6 +16410,9 @@
echo " OpenGL platform: ${OPENGL_TYPE}"
+echo " Tcl/Tk platform: ${TCLTK_TYPE}"
echo " MacOSX application: `if test -n "${MACOSX_APP}" ; then echo yes ; else echo no ; fi`"
echo ""
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-07-27 22:30:52 UTC (rev 32344)
+++ grass/trunk/configure.in 2008-07-27 22:32:43 UTC (rev 32345)
@@ -791,35 +791,55 @@
# Enable TCLTK option
-LOC_CHECK_USE(tcltk,Tcl/Tk,USE_TCLTK)
TCLINCDIR=
TCLTKLIBPATH=
TCLTKLIBS=
+AC_MSG_CHECKING(whether to use Tcl/Tk)
+AC_MSG_RESULT("$with_tcltk")
+case "$with_tcltk" in
+ n|no)
+ TCLTK_TYPE=none
+ y|yes|x|x11)
+ TCLTK_TYPE=X11
+ USE_TCLTK=1
+ TCLTK_X11=1
+ aqua|mac|osx|macosx)
+ TCLTK_TYPE=Aqua
+ USE_TCLTK=1
+ TCLTK_AQUA=1
+ win|windows|mswin)
+ TCLTK_TYPE=Windows
+ USE_TCLTK=1
+ TCLTK_WINDOWS=1
+ AC_MSG_ERROR([*** Valid arguments for --with-tcltk= are yes,no,x11,aqua,windows.])
+esac
if test -n "$USE_TCLTK"; then
-LOC_CHECK_FRAMEWORK_PATH(tcltk,Tcl/Tk,TCLTKLIBPATH)
+if test -n "$TCLTK_AQUA" ; then
-if test -n "$TCLTKLIBPATH" ; then
+LOC_CHECK_FRAMEWORK_PATH(tcltk,Tcl/Tk,TCLTKPATH)
-dir="$with_tcltk_framework"
-TCLINCDIR="-I$dir/Tcl.framework/Headers -I$dir/Tk.framework/Headers -I$dir/Tk.framework/PrivateHeaders"
+LOC_CHECK_INCLUDES(Tk/tk.h,Tcl/Tk,$TCLTKPATH)
-LOC_CHECK_INCLUDES(tcl.h,Tcl,$TCLINCDIR)
-LOC_CHECK_INCLUDES(tk.h,Tk,$TCLINCDIR)
+LOC_CHECK_FUNC(Tk_MainWindow,Tcl/Tk framework,TCLTKLIBS,-framework Tcl -framework Tk,$TCLTKPATH)
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$TCLTKLIBPATH -framework Tcl -framework Tk $LIBS"
-AC_CHECK_FUNC(Tk_MainWindow,[
-TCLTKLIBS="-framework Tcl -framework Tk"
-AC_MSG_ERROR([*** Unable to locate Tcl/Tk libraries.])
-LDFLAGS=$ac_save_ldflags
+TCLINCDIR="$TCLTKPATH"
+TCLTKLIBPATH="$TCLTKPATH"
-else
+AC_DEFINE(TCLTK_AQUA)
+fi # TCLTK_AQUA
+if test -n "$TCLTK_X11" -o -n "$TCLTK_WINDOWS" ; then
# With Tcl/Tk includes directory
LOC_CHECK_INC_PATH(tcltk,Tcl/Tk,TCLINCDIR)
@@ -864,17 +884,28 @@
],$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS)
TCLTKLIBS="$TKLIB $TCLLIB"
+if test -n "$TCLTK_X11" ; then
+AC_DEFINE(TCLTK_X11)
fi
+if test -n "$TCLTK_WINDOWS" ; then
+AC_DEFINE(TCLTK_WINDOWS)
+fi
+fi # TCLTK_X11 || TCLTK_WINDOWS
AC_DEFINE(HAVE_TCLTK)
fi # $USE_TCLTK
-TKINCDIR=$TCLINCDIR
+TKINCDIR="$TCLINCDIR"
+AC_SUBST(USE_TCLTK)
+AC_SUBST(TCLTK_X11)
+AC_SUBST(TCLTK_AQUA)
+AC_SUBST(TCLTK_WINDOWS)
AC_SUBST(TCLINCDIR)
AC_SUBST(TKINCDIR)
AC_SUBST(TCLTKLIBPATH)
@@ -1122,11 +1153,8 @@
-AC_CHECK_FUNC(glXCreatePbuffer, [AC_DEFINE(HAVE_PBUFFERS)])
-AC_CHECK_FUNC(glXCreateGLXPixmap, [AC_DEFINE(HAVE_PIXMAPS)])
-LDFLAGS=${ac_save_ldflags}
+LOC_CHECK_FUNC(glXCreatePbuffer,,,,,$OPENGLLIB,[AC_DEFINE(HAVE_PBUFFERS)])
+LOC_CHECK_FUNC(glXCreateGLXPixmap,,,,,$OPENGLLIB,[AC_DEFINE(HAVE_PIXMAPS)])
AC_DEFINE(OPENGL_X11)
@@ -1134,28 +1162,16 @@
+LOC_CHECK_FRAMEWORK_PATH(opengl,OpenGL,OPENGLPATH)
+LOC_CHECK_INCLUDES(OpenGL/gl.h OpenGL/glu.h,OpenGL,$OPENGLPATH)
-LOC_CHECK_INC_PATH(opengl,OpenGL,OPENGLINC)
+LOC_CHECK_FUNC(glBegin,OpenGL library,OPENGLLIBS,-framework OpenGL -framework AGL -framework ApplicationServices,$OPENGLPATH)
+LOC_CHECK_FUNC(gluBeginCurve,GLU library,OPENGLLIBS,,$OPENGLPATH,$OPENGLLIBS)
-LOC_CHECK_INCLUDES(OpenGL/gl.h OpenGL/glu.h,OpenGL,$OPENGLINC)
-AC_CHECK_FUNC(glBegin,[
-AC_CHECK_FUNC(gluBeginCurve,[
-USE_OPENGL=1
-OPENGL_AQUA=1
-],[AC_MSG_ERROR([*** Unable to locate GLU library.])])
-],[AC_MSG_ERROR([*** Unable to locate OpenGL library.])])
AC_DEFINE(OPENGL_AQUA)
fi # $OPENGL_AQUA
@@ -1470,12 +1486,7 @@
-AC_CHECK_FUNC(cairo_create,,[
-AC_MSG_ERROR([*** Unable to locate cairo_create() function.])
+LOC_CHECK_FUNC(cairo_create,,,,,$CAIROLIB,[:])
fi # $USE_CAIRO
@@ -1805,6 +1816,7 @@
LOC_MSG([ Building shared libraries: ${shared_ok}])
LOC_MSG([ 64bit support: ${do64bit}])
LOC_MSG([ OpenGL platform: ${OPENGL_TYPE}])
+LOC_MSG([ Tcl/Tk platform: ${TCLTK_TYPE}])
LOC_MSG_USE(MacOSX application,MACOSX_APP)
LOC_MSG()
LOC_MSG_USE(NVIZ,USE_TOGL)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2008-07-27 22:30:52 UTC (rev 32344)
+++ grass/trunk/include/Make/Platform.make.in 2008-07-27 22:32:43 UTC (rev 32345)
@@ -160,16 +160,20 @@
OPENGLLIB = @OPENGLLIB@
OPENGLULIB = @OPENGLULIB@
OPENGLWM = @OPENGLWM@
-#USE_GLWM = @USE_GLWM@
OPENGL_X11 = @OPENGL_X11@
OPENGL_AQUA = @OPENGL_AQUA@
OPENGL_WINDOWS = @OPENGL_WINDOWS@
+USE_OPENGL = @USE_OPENGL@
#tcl/tk stuff
TCLINCDIR = @TCLINCDIR@
TKINCDIR = @TKINCDIR@
TCLTKLIBPATH = @TCLTKLIBPATH@
TCLTKLIBS = @TCLTKLIBS@
+TCLTK_X11 = @TCLTK_X11@
+TCLTK_AQUA = @TCLTK_AQUA@
+TCLTK_WINDOWS = @TCLTK_WINDOWS@
+USE_TCLTK = @USE_TCLTK@
#FFTW:
FFTWINC = @FFTWINC@
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in 2008-07-27 22:30:52 UTC (rev 32344)
+++ grass/trunk/include/config.h.in 2008-07-27 22:32:43 UTC (rev 32345)
@@ -245,6 +245,15 @@
/* define if OpenGL uses Windows */
#undef OPENGL_WINDOWS
+/* define if Tcl/Tk uses X11 */
+#undef TCLTK_X11
+/* define if Tcl/Tk uses Aqua (MacOS X) */
+#undef TCLTK_AQUA
+/* define if Tcl/Tk uses Windows */
+#undef TCLTK_WINDOWS
* configuration information solely dependent on the above
* nothing below this point should need changing
