[GRASS-SVN] r32347 - grass/trunk
Sun Jul 27 19:59:02 EDT 2008
Author: glynn
Date: 2008-07-27 19:59:02 -0400 (Sun, 27 Jul 2008)
New Revision: 32347
   grass/trunk/configure
   grass/trunk/configure.in
Fix OpenGL library checks (broken from previous update)
Add --with-opengl-framework=
Modified: grass/trunk/configure
--- grass/trunk/configure	2008-07-27 23:10:29 UTC (rev 32346)
+++ grass/trunk/configure	2008-07-27 23:59:02 UTC (rev 32347)
@@ -140,6 +140,9 @@
 ac_help="$ac_help
   --with-opengl-libs=DIRS OpenGL library files are in DIRS"
 ac_help="$ac_help
+  --with-opengl-framework=DIR
+                          OpenGL framework is in DIR"
+ac_help="$ac_help
   --with-odbc-includes=DIRS
                           ODBC include files are in DIRS"
 ac_help="$ac_help
@@ -724,7 +727,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:728: checking host system type" >&5
+echo "configure:731: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -747,7 +750,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:751: checking for $ac_word" >&5
+echo "configure:754: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -774,7 +777,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:778: checking for $ac_word" >&5
+echo "configure:781: checking for $ac_word" >&5
@@ -822,7 +825,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:826: checking for $ac_word" >&5
+echo "configure:829: checking for $ac_word" >&5
@@ -851,7 +854,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:855: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:858: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -862,12 +865,12 @@
 cat > conftest.$ac_ext << EOF
-#line 866 "configure"
+#line 869 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -893,19 +896,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:897: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:900: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:902: checking whether we are using GNU C" >&5
+echo "configure:905: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -923,7 +926,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:927: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:930: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -952,10 +955,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:956: checking for Cygwin environment" >&5
+echo "configure:959: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 959 "configure"
+#line 962 "configure"
 int main() {
@@ -966,7 +969,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:970: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:973: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -982,17 +985,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:986: checking for mingw32 environment" >&5
+echo "configure:989: checking for mingw32 environment" >&5
-#line 989 "configure"
+#line 992 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:999: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1010,7 +1013,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1014: checking for executable suffix" >&5
+echo "configure:1017: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1029,23 +1032,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1033: checking for full floating-point support" >&5
+echo "configure:1036: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1038: checking whether "cc -mieee" works" >&5
+echo "configure:1041: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1042 "configure"
+#line 1045 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1049: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1061,7 +1064,7 @@
 else
-#line 1065 "configure"
+#line 1068 "configure"
 #include <float.h>
@@ -1075,7 +1078,7 @@
 EOF
-if { (eval echo configure:1079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1088,14 +1091,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1092: checking for full floating-point support with -mieee" >&5
+echo "configure:1095: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1099 "configure"
+#line 1102 "configure"
 #include <float.h>
@@ -1109,7 +1112,7 @@
 EOF
-if { (eval echo configure:1113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1146,7 +1149,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1150: checking for $ac_word" >&5
+echo "configure:1153: checking for $ac_word" >&5
 case "$pwd" in
@@ -1184,7 +1187,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1188: checking for source directory" >&5
+echo "configure:1191: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1195,7 +1198,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1199: checking for build directory" >&5
+echo "configure:1202: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1280,7 +1283,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1284: checking for MacOSX App" >&5
+echo "configure:1287: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1303,7 +1306,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1307: checking how to build libraries" >&5
+echo "configure:1310: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1346,7 +1349,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1350: checking for $ac_word" >&5
+echo "configure:1353: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1371,7 +1374,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1375: checking how to run the C preprocessor" >&5
+echo "configure:1378: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1384,13 +1387,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 1388 "configure"
+#line 1391 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1397: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1401,13 +1404,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1405 "configure"
+#line 1408 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1411: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1418,13 +1421,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1422 "configure"
+#line 1425 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1452,7 +1455,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1456: checking if 64bit support is requested" >&5
+echo "configure:1459: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1472,7 +1475,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1476: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1479: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1496,7 +1499,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1500: checking system version (for dynamic loading)" >&5
+echo "configure:1503: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1522,13 +1525,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1526: checking for dlopen in -ldl" >&5
+echo "configure:1529: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1532 "configure"
+#line 1535 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1539,7 +1542,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1586,7 +1589,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1590: checking for $ac_word" >&5
+echo "configure:1593: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1715,13 +1718,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1719: checking for gettimeofday in -lbsd" >&5
+echo "configure:1722: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1725 "configure"
+#line 1728 "configure"
@@ -1732,7 +1735,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1773,13 +1776,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1777: checking for inet_ntoa in -lbind" >&5
+echo "configure:1780: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1783 "configure"
+#line 1786 "configure"
@@ -1790,7 +1793,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1851,13 +1854,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1855: checking for shl_load in -ldld" >&5
+echo "configure:1858: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1861 "configure"
+#line 1864 "configure"
@@ -1868,7 +1871,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1933,13 +1936,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:1937: checking for shl_load in -ldld" >&5
+echo "configure:1940: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 1943 "configure"
+#line 1946 "configure"
@@ -1950,7 +1953,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:1954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2072,15 +2075,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2076: checking for dld.h" >&5
+echo "configure:2079: checking for dld.h" >&5
-#line 2079 "configure"
+#line 2082 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2084: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2087: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2140,15 +2143,15 @@
 	    else
-echo "configure:2144: checking for dld.h" >&5
+echo "configure:2147: checking for dld.h" >&5
-#line 2147 "configure"
+#line 2150 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2155: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2245,9 +2248,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2249: checking for ELF" >&5
+echo "configure:2252: checking for ELF" >&5
-#line 2251 "configure"
+#line 2254 "configure"
 #ifdef __ELF__
@@ -2277,15 +2280,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2281: checking for dlfcn.h" >&5
+echo "configure:2284: checking for dlfcn.h" >&5
-#line 2284 "configure"
+#line 2287 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2309,9 +2312,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2313: checking for ELF" >&5
+echo "configure:2316: checking for ELF" >&5
-#line 2315 "configure"
+#line 2318 "configure"
 #ifdef __ELF__
@@ -2635,17 +2638,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2639: checking for ld accepts -Bexport flag" >&5
+echo "configure:2642: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2642 "configure"
+#line 2645 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3228,7 +3231,15 @@
+# Check whether --with-opengl-framework or --without-opengl-framework was given.
+if test "${with_opengl_framework+set}" = set; then
+  withval="$with_opengl_framework"
+fi
 # Check whether --with-odbc-includes or --without-odbc-includes was given.
 if test "${with_odbc_includes+set}" = set; then
   withval="$with_odbc_includes"
@@ -3398,7 +3409,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3402: checking for additional include dirs" >&5
+echo "configure:3413: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3421,7 +3432,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3425: checking for additional library dirs" >&5
+echo "configure:3436: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3455,7 +3466,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3459: checking for a BSD compatible install" >&5
+echo "configure:3470: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3508,7 +3519,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3512: checking for $ac_word" >&5
+echo "configure:3523: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3539,13 +3550,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3543: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3554: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3549 "configure"
+#line 3560 "configure"
@@ -3556,7 +3567,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3581,7 +3592,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3585: checking for $ac_word" >&5
+echo "configure:3596: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3621,7 +3632,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3625: checking for $ac_word" >&5
+echo "configure:3636: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3652,7 +3663,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3656: checking for $ac_word" >&5
+echo "configure:3667: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3690,7 +3701,7 @@
-echo "configure:3694: checking for $ac_word" >&5
+echo "configure:3705: checking for $ac_word" >&5
@@ -3719,7 +3730,7 @@
-echo "configure:3723: checking for $ac_word" >&5
+echo "configure:3734: checking for $ac_word" >&5
@@ -3750,7 +3761,7 @@
-echo "configure:3754: checking for $ac_word" >&5
+echo "configure:3765: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3779,7 +3790,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3783: checking for $ac_word" >&5
+echo "configure:3794: checking for $ac_word" >&5
 case "$PERL" in
@@ -3810,10 +3821,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3814: checking for ANSI C header files" >&5
+echo "configure:3825: checking for ANSI C header files" >&5
-#line 3817 "configure"
+#line 3828 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3821,7 +3832,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:3825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3838,7 +3849,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3842 "configure"
+#line 3853 "configure"
 #include <string.h>
 EOF
@@ -3856,7 +3867,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3860 "configure"
+#line 3871 "configure"
 #include <stdlib.h>
 EOF
@@ -3877,7 +3888,7 @@
 else
-#line 3881 "configure"
+#line 3892 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3888,7 +3899,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:3892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -3915,15 +3926,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3919: checking for $ac_hdr" >&5
+echo "configure:3930: checking for $ac_hdr" >&5
-#line 3922 "configure"
+#line 3933 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3938: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3952,15 +3963,15 @@
 do
-echo "configure:3956: checking for $ac_hdr" >&5
+echo "configure:3967: checking for $ac_hdr" >&5
-#line 3959 "configure"
+#line 3970 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3975: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3989,15 +4000,15 @@
 do
-echo "configure:3993: checking for $ac_hdr" >&5
+echo "configure:4004: checking for $ac_hdr" >&5
-#line 3996 "configure"
+#line 4007 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4001: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4026,15 +4037,15 @@
 do
-echo "configure:4030: checking for $ac_hdr" >&5
+echo "configure:4041: checking for $ac_hdr" >&5
-#line 4033 "configure"
+#line 4044 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4049: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4063,15 +4074,15 @@
 do
-echo "configure:4067: checking for $ac_hdr" >&5
+echo "configure:4078: checking for $ac_hdr" >&5
-#line 4070 "configure"
+#line 4081 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4086: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4097,10 +4108,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4101: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4112: checking whether time.h and sys/time.h may both be included" >&5
-#line 4104 "configure"
+#line 4115 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4109,7 +4120,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4113: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4129,10 +4140,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4133: checking for off_t" >&5
+echo "configure:4144: checking for off_t" >&5
-#line 4136 "configure"
+#line 4147 "configure"
 #if STDC_HEADERS
@@ -4159,10 +4170,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4163: checking for uid_t in sys/types.h" >&5
+echo "configure:4174: checking for uid_t in sys/types.h" >&5
-#line 4166 "configure"
+#line 4177 "configure"
 EOF
@@ -4190,10 +4201,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4194: checking return type of signal handlers" >&5
+echo "configure:4205: checking return type of signal handlers" >&5
-#line 4197 "configure"
+#line 4208 "configure"
 #include <signal.h>
@@ -4210,7 +4221,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4214: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4225: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4228,10 +4239,10 @@
-echo "configure:4232: checking for Cygwin environment" >&5
+echo "configure:4243: checking for Cygwin environment" >&5
-#line 4235 "configure"
+#line 4246 "configure"
 int main() {
@@ -4242,7 +4253,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4246: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4257: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4260,10 +4271,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4264: checking for $ac_func" >&5
+echo "configure:4275: checking for $ac_func" >&5
-#line 4267 "configure"
+#line 4278 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4286,7 +4297,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4312,10 +4323,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4316: checking for $ac_func" >&5
+echo "configure:4327: checking for $ac_func" >&5
-#line 4319 "configure"
+#line 4330 "configure"
@@ -4338,7 +4349,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4364,10 +4375,10 @@
 for ac_func in drand48
 do
-echo "configure:4368: checking for $ac_func" >&5
+echo "configure:4379: checking for $ac_func" >&5
-#line 4371 "configure"
+#line 4382 "configure"
@@ -4390,7 +4401,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4416,10 +4427,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4420: checking for $ac_func" >&5
+echo "configure:4431: checking for $ac_func" >&5
-#line 4423 "configure"
+#line 4434 "configure"
@@ -4442,7 +4453,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4468,10 +4479,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4472: checking for $ac_func" >&5
+echo "configure:4483: checking for $ac_func" >&5
-#line 4475 "configure"
+#line 4486 "configure"
@@ -4494,7 +4505,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4519,13 +4530,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4523: checking whether setpgrp takes no argument" >&5
+echo "configure:4534: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4529 "configure"
+#line 4540 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4545,7 +4556,7 @@
 EOF
-if { (eval echo configure:4549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4573,16 +4584,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4577: checking for long long int" >&5
+echo "configure:4588: checking for long long int" >&5
-#line 4579 "configure"
+#line 4590 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4586: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4597: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -4602,7 +4613,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4606: checking for W11" >&5
+echo "configure:4617: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4630,7 +4641,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4634: checking for X" >&5
+echo "configure:4645: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4690,12 +4701,12 @@
   # First, try using that file with no special directory specified.
-#line 4694 "configure"
+#line 4705 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4764,14 +4775,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4768 "configure"
+#line 4779 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -4876,17 +4887,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4880: checking whether -R must be followed by a space" >&5
+echo "configure:4891: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4883 "configure"
+#line 4894 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -4902,14 +4913,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4906 "configure"
+#line 4917 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:4913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -4941,13 +4952,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4945: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4956: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 4951 "configure"
+#line 4962 "configure"
@@ -4958,7 +4969,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4979,13 +4990,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4983: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4994: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 4989 "configure"
+#line 5000 "configure"
@@ -4996,7 +5007,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5024,10 +5035,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5028: checking for gethostbyname" >&5
+echo "configure:5039: checking for gethostbyname" >&5
-#line 5031 "configure"
+#line 5042 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5050,7 +5061,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5070,13 +5081,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5074: checking for gethostbyname in -lnsl" >&5
+echo "configure:5085: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5080 "configure"
+#line 5091 "configure"
@@ -5087,7 +5098,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5116,10 +5127,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5120: checking for connect" >&5
+echo "configure:5131: checking for connect" >&5
-#line 5123 "configure"
+#line 5134 "configure"
     which can conflict with char connect(); below.  */
@@ -5142,7 +5153,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5162,13 +5173,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5166: checking for connect in -lsocket" >&5
+echo "configure:5177: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5172 "configure"
+#line 5183 "configure"
@@ -5179,7 +5190,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5202,10 +5213,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5206: checking for remove" >&5
+echo "configure:5217: checking for remove" >&5
-#line 5209 "configure"
+#line 5220 "configure"
     which can conflict with char remove(); below.  */
@@ -5228,7 +5239,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5248,13 +5259,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5252: checking for remove in -lposix" >&5
+echo "configure:5263: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5258 "configure"
+#line 5269 "configure"
@@ -5265,7 +5276,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5288,10 +5299,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5292: checking for shmat" >&5
+echo "configure:5303: checking for shmat" >&5
-#line 5295 "configure"
+#line 5306 "configure"
     which can conflict with char shmat(); below.  */
@@ -5314,7 +5325,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5334,13 +5345,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5338: checking for shmat in -lipc" >&5
+echo "configure:5349: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5344 "configure"
+#line 5355 "configure"
@@ -5351,7 +5362,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5383,13 +5394,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5387: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5398: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5393 "configure"
+#line 5404 "configure"
@@ -5400,7 +5411,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5438,7 +5449,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5442: checking whether to use Curses" >&5
+echo "configure:5453: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5457,15 +5468,15 @@
 do
-echo "configure:5461: checking for $ac_hdr" >&5
+echo "configure:5472: checking for $ac_hdr" >&5
-#line 5464 "configure"
+#line 5475 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5496,10 +5507,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5500: checking curses.h WINDOW structure component" >&5
+echo "configure:5511: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5503 "configure"
+#line 5514 "configure"
 #include <curses.h>
@@ -5508,7 +5519,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5512: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5523: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5517,7 +5528,7 @@
 fi
 rm -f conftest*
-#line 5521 "configure"
+#line 5532 "configure"
 #include <curses.h>
@@ -5526,7 +5537,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5530: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5541: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5542,13 +5553,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5546: checking for initscr in -lncurses" >&5
+echo "configure:5557: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5552 "configure"
+#line 5563 "configure"
@@ -5559,7 +5570,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5578,13 +5589,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5582: checking for initscr in -lcurses" >&5
+echo "configure:5593: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5588 "configure"
+#line 5599 "configure"
@@ -5595,7 +5606,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5624,13 +5635,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5628: checking for keypad in -lncurses" >&5
+echo "configure:5639: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5634 "configure"
+#line 5645 "configure"
@@ -5641,7 +5652,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5663,13 +5674,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5667: checking for keypad in -lcurses" >&5
+echo "configure:5678: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5673 "configure"
+#line 5684 "configure"
@@ -5680,7 +5691,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5710,13 +5721,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5714: checking for gtty in -lcompat" >&5
+echo "configure:5725: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5720 "configure"
+#line 5731 "configure"
@@ -5727,7 +5738,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5746,13 +5757,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5750: checking for gtty in -lbsd-compat" >&5
+echo "configure:5761: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5756 "configure"
+#line 5767 "configure"
@@ -5763,7 +5774,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5782,13 +5793,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5786: checking for gtty in -lbsd" >&5
+echo "configure:5797: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5792 "configure"
+#line 5803 "configure"
@@ -5799,7 +5810,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5833,12 +5844,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5837: checking for library containing cuserid" >&5
+echo "configure:5848: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 5842 "configure"
+#line 5853 "configure"
@@ -5849,7 +5860,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -5860,7 +5871,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 5864 "configure"
+#line 5875 "configure"
@@ -5871,7 +5882,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:5875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -5897,10 +5908,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5901: checking for xdrmem_create" >&5
+echo "configure:5912: checking for xdrmem_create" >&5
-#line 5904 "configure"
+#line 5915 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -5923,7 +5934,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -5941,13 +5952,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5945: checking for xdrmem_create in -lsun" >&5
+echo "configure:5956: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 5951 "configure"
+#line 5962 "configure"
@@ -5958,7 +5969,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5977,13 +5988,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5981: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5992: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5987 "configure"
+#line 5998 "configure"
@@ -5994,7 +6005,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:5998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6013,13 +6024,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6017: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6028: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6023 "configure"
+#line 6034 "configure"
@@ -6030,7 +6041,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6049,13 +6060,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6053: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6064: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6059 "configure"
+#line 6070 "configure"
@@ -6066,7 +6077,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6100,10 +6111,10 @@
 for ac_func in asprintf
 do
-echo "configure:6104: checking for $ac_func" >&5
+echo "configure:6115: checking for $ac_func" >&5
-#line 6107 "configure"
+#line 6118 "configure"
@@ -6126,7 +6137,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6153,10 +6164,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6157: checking for atan" >&5
+echo "configure:6168: checking for atan" >&5
-#line 6160 "configure"
+#line 6171 "configure"
     which can conflict with char atan(); below.  */
@@ -6179,7 +6190,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6197,13 +6208,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6201: checking for atan in -lm" >&5
+echo "configure:6212: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6207 "configure"
+#line 6218 "configure"
@@ -6214,7 +6225,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6241,10 +6252,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6245: checking for dlsym" >&5
+echo "configure:6256: checking for dlsym" >&5
-#line 6248 "configure"
+#line 6259 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6267,7 +6278,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6285,13 +6296,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6289: checking for dlsym in -ldl" >&5
+echo "configure:6300: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6295 "configure"
+#line 6306 "configure"
@@ -6302,7 +6313,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6329,10 +6340,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6333: checking for iconv" >&5
+echo "configure:6344: checking for iconv" >&5
-#line 6336 "configure"
+#line 6347 "configure"
     which can conflict with char iconv(); below.  */
@@ -6355,7 +6366,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6373,13 +6384,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6377: checking for iconv in -liconv" >&5
+echo "configure:6388: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6383 "configure"
+#line 6394 "configure"
@@ -6390,7 +6401,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6409,13 +6420,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6413: checking for iconv in -lgiconv" >&5
+echo "configure:6424: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6419 "configure"
+#line 6430 "configure"
@@ -6426,7 +6437,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6445,10 +6456,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6449: checking for libiconv" >&5
+echo "configure:6460: checking for libiconv" >&5
-#line 6452 "configure"
+#line 6463 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6471,7 +6482,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6489,13 +6500,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6493: checking for libiconv in -liconv" >&5
+echo "configure:6504: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6499 "configure"
+#line 6510 "configure"
@@ -6506,7 +6517,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6525,13 +6536,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6529: checking for libiconv in -lgiconv" >&5
+echo "configure:6540: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6535 "configure"
+#line 6546 "configure"
@@ -6542,7 +6553,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6579,10 +6590,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6583: checking for socket" >&5
+echo "configure:6594: checking for socket" >&5
-#line 6586 "configure"
+#line 6597 "configure"
     which can conflict with char socket(); below.  */
@@ -6605,7 +6616,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6623,13 +6634,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6627: checking for socket in -lsocket" >&5
+echo "configure:6638: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6633 "configure"
+#line 6644 "configure"
@@ -6640,7 +6651,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6688,7 +6699,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6692: checking for location of zlib includes" >&5
+echo "configure:6703: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6714,15 +6725,15 @@
 do
-echo "configure:6718: checking for $ac_hdr" >&5
+echo "configure:6729: checking for $ac_hdr" >&5
-#line 6721 "configure"
+#line 6732 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6726: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6756,7 +6767,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6760: checking for location of zlib library" >&5
+echo "configure:6771: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6781,13 +6792,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6785: checking for deflate in -lz" >&5
+echo "configure:6796: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6791 "configure"
+#line 6802 "configure"
@@ -6798,7 +6809,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6846,7 +6857,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6850: checking for location of External PROJ.4 includes" >&5
+echo "configure:6861: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6872,15 +6883,15 @@
 do
-echo "configure:6876: checking for $ac_hdr" >&5
+echo "configure:6887: checking for $ac_hdr" >&5
-#line 6879 "configure"
+#line 6890 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6895: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6917,7 +6928,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6921: checking External PROJ.4 version" >&5
+echo "configure:6932: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6925,7 +6936,7 @@
 else
-#line 6929 "configure"
+#line 6940 "configure"
 #include <stdio.h>
@@ -6937,7 +6948,7 @@
 EOF
-if { (eval echo configure:6941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -6962,7 +6973,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6966: checking for location of External PROJ.4 library" >&5
+echo "configure:6977: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6987,13 +6998,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6991: checking for pj_get_def in -lproj" >&5
+echo "configure:7002: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 6997 "configure"
+#line 7008 "configure"
@@ -7004,7 +7015,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7038,7 +7049,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7042: checking for location of External PROJ.4 data files" >&5
+echo "configure:7053: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7062,14 +7073,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7066: checking for epsg" >&5
+echo "configure:7077: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7073: checking for $PROJSHARE/epsg" >&5
+echo "configure:7084: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7101,7 +7112,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7105: checking for $ac_word" >&5
+echo "configure:7116: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7141,7 +7152,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7145: checking whether to use Readline" >&5
+echo "configure:7156: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7162,7 +7173,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7166: checking for location of Readline includes" >&5
+echo "configure:7177: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7188,15 +7199,15 @@
 do
-echo "configure:7192: checking for $ac_hdr" >&5
+echo "configure:7203: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 7195 "configure"
+#line 7206 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7232,15 +7243,15 @@
 do
-echo "configure:7236: checking for $ac_hdr" >&5
+echo "configure:7247: checking for $ac_hdr" >&5
-#line 7239 "configure"
+#line 7250 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7244: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7274,7 +7285,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7278: checking for location of Readline library" >&5
+echo "configure:7289: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7299,13 +7310,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7303: checking for readline in -lreadline" >&5
+echo "configure:7314: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7309 "configure"
+#line 7320 "configure"
@@ -7316,7 +7327,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7351,13 +7362,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7355: checking for add_history in -lhistory" >&5
+echo "configure:7366: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7361 "configure"
+#line 7372 "configure"
@@ -7368,7 +7379,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7411,7 +7422,7 @@
 echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7415: checking whether to use JPEG" >&5
+echo "configure:7426: checking whether to use JPEG" >&5
 echo "$ac_t"""$with_jpeg"" 1>&6
 case "$with_jpeg" in
 	"no")	USE_JPEG=	;;
@@ -7431,7 +7442,7 @@
 echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7435: checking for location of JPEG includes" >&5
+echo "configure:7446: checking for location of JPEG includes" >&5
 case "$with_jpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7457,15 +7468,15 @@
 do
-echo "configure:7461: checking for $ac_hdr" >&5
+echo "configure:7472: checking for $ac_hdr" >&5
-#line 7464 "configure"
+#line 7475 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7499,7 +7510,7 @@
 echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7503: checking for location of JPEG library" >&5
+echo "configure:7514: checking for location of JPEG library" >&5
 case "$with_jpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7526,13 +7537,13 @@
 echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7530: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7541: checking for jpeg_start_compress in -ljpeg" >&5
 ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
 LIBS="-ljpeg  $LIBS"
-#line 7536 "configure"
+#line 7547 "configure"
@@ -7543,7 +7554,7 @@
 jpeg_start_compress()
 ; return 0; }
 EOF
-if { (eval echo configure:7547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7562,13 +7573,13 @@
-echo "configure:7566: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7577: checking for jpeg_start_compress in -ljpeg" >&5
 LIBS="-ljpeg $ZLIB $LIBS"
-#line 7572 "configure"
+#line 7583 "configure"
@@ -7579,7 +7590,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7628,7 +7639,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7632: checking whether to use GDAL" >&5
+echo "configure:7643: checking whether to use GDAL" >&5
 if test "`basename xx/$with_gdal`" = "gdal-config" ; then
   GDAL_CONFIG="$with_gdal"
@@ -7641,7 +7652,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7645: checking for $ac_word" >&5
+echo "configure:7656: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7701,14 +7712,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7705 "configure"
+#line 7716 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7712: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7717,14 +7728,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7721 "configure"
+#line 7732 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7752,7 +7763,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7756: checking whether to use TIFF" >&5
+echo "configure:7767: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7772,7 +7783,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7776: checking for location of TIFF includes" >&5
+echo "configure:7787: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7798,15 +7809,15 @@
 do
-echo "configure:7802: checking for $ac_hdr" >&5
+echo "configure:7813: checking for $ac_hdr" >&5
-#line 7805 "configure"
+#line 7816 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7821: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7840,7 +7851,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7844: checking for location of TIFF library" >&5
+echo "configure:7855: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7871,13 +7882,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7875: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7886: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ltiff  $LIBS"
-#line 7881 "configure"
+#line 7892 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7888,7 +7899,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7907,13 +7918,13 @@
-echo "configure:7911: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7922: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7917 "configure"
+#line 7928 "configure"
@@ -7924,7 +7935,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7943,13 +7954,13 @@
-echo "configure:7947: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7958: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7953 "configure"
+#line 7964 "configure"
@@ -7960,7 +7971,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7979,13 +7990,13 @@
-echo "configure:7983: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7994: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7989 "configure"
+#line 8000 "configure"
@@ -7996,7 +8007,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8015,13 +8026,13 @@
-echo "configure:8019: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8030: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8025 "configure"
+#line 8036 "configure"
@@ -8032,7 +8043,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8051,13 +8062,13 @@
-echo "configure:8055: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8066: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8061 "configure"
+#line 8072 "configure"
@@ -8068,7 +8079,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8087,13 +8098,13 @@
-echo "configure:8091: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8102: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8097 "configure"
+#line 8108 "configure"
@@ -8104,7 +8115,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8123,13 +8134,13 @@
-echo "configure:8127: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8138: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8133 "configure"
+#line 8144 "configure"
@@ -8140,7 +8151,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8238,7 +8249,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8242: checking whether to use PNG" >&5
+echo "configure:8253: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8257,7 +8268,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8261: checking for location of PNG includes" >&5
+echo "configure:8272: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8283,15 +8294,15 @@
 do
-echo "configure:8287: checking for $ac_hdr" >&5
+echo "configure:8298: checking for $ac_hdr" >&5
-#line 8290 "configure"
+#line 8301 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8306: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8325,7 +8336,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8329: checking for location of PNG library" >&5
+echo "configure:8340: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8350,13 +8361,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8354: checking for png_read_image in -lpng" >&5
+echo "configure:8365: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8360 "configure"
+#line 8371 "configure"
@@ -8367,7 +8378,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8412,7 +8423,7 @@
 TCLTKLIBS=
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8416: checking whether to use Tcl/Tk" >&5
+echo "configure:8427: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	n|no)
@@ -8444,7 +8455,7 @@
 echo $ac_n "checking for location of Tcl/Tk framework""... $ac_c" 1>&6
-echo "configure:8448: checking for location of Tcl/Tk framework" >&5
+echo "configure:8459: checking for location of Tcl/Tk framework" >&5
 case "$with_tcltk_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-framework." 1>&2; exit 1; }
@@ -8468,15 +8479,15 @@
 do
-echo "configure:8472: checking for $ac_hdr" >&5
+echo "configure:8483: checking for $ac_hdr" >&5
-#line 8475 "configure"
+#line 8486 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8491: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8512,10 +8523,10 @@
 LIBS="-framework Tcl -framework Tk  $LIBS"
 LDFLAGS="$TCLTKPATH $LDFLAGS"
 echo $ac_n "checking for Tk_MainWindow""... $ac_c" 1>&6
-echo "configure:8516: checking for Tk_MainWindow" >&5
+echo "configure:8527: checking for Tk_MainWindow" >&5
-#line 8519 "configure"
+#line 8530 "configure"
     which can conflict with char Tk_MainWindow(); below.  */
@@ -8538,7 +8549,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_Tk_MainWindow=yes"
 else
@@ -8586,7 +8597,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8590: checking for location of Tcl/Tk includes" >&5
+echo "configure:8601: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8612,15 +8623,15 @@
 do
-echo "configure:8616: checking for $ac_hdr" >&5
+echo "configure:8627: checking for $ac_hdr" >&5
-#line 8619 "configure"
+#line 8630 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8624: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8657,15 +8668,15 @@
 do
-echo "configure:8661: checking for $ac_hdr" >&5
+echo "configure:8672: checking for $ac_hdr" >&5
-#line 8664 "configure"
+#line 8675 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8699,7 +8710,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8703: checking Tcl version" >&5
+echo "configure:8714: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -8707,7 +8718,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 8711 "configure"
+#line 8722 "configure"
 #include <stdio.h>
@@ -8719,7 +8730,7 @@
 EOF
-if { (eval echo configure:8723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -8737,7 +8748,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8741: checking Tk version" >&5
+echo "configure:8752: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8745,7 +8756,7 @@
 else
-#line 8749 "configure"
+#line 8760 "configure"
 #include <stdio.h>
@@ -8757,7 +8768,7 @@
 EOF
-if { (eval echo configure:8761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -8786,7 +8797,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8790: checking for location of Tcl/Tk library" >&5
+echo "configure:8801: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8816,13 +8827,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8820: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8831: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 8826 "configure"
+#line 8837 "configure"
@@ -8833,7 +8844,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8852,13 +8863,13 @@
-echo "configure:8856: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8867: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8862 "configure"
+#line 8873 "configure"
@@ -8869,7 +8880,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8896,13 +8907,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8900: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8911: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8906 "configure"
+#line 8917 "configure"
@@ -8913,7 +8924,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8932,13 +8943,13 @@
-echo "configure:8936: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8947: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8942 "configure"
+#line 8953 "configure"
@@ -8949,7 +8960,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8976,13 +8987,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8980: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8991: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8986 "configure"
+#line 8997 "configure"
@@ -8993,7 +9004,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:8997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9012,13 +9023,13 @@
-echo "configure:9016: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:9027: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 9022 "configure"
+#line 9033 "configure"
@@ -9029,7 +9040,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:9033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9107,13 +9118,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:9111: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9122: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 9117 "configure"
+#line 9128 "configure"
@@ -9124,7 +9135,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9143,13 +9154,13 @@
-echo "configure:9147: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9158: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9153 "configure"
+#line 9164 "configure"
@@ -9160,7 +9171,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9187,13 +9198,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9191: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9202: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9197 "configure"
+#line 9208 "configure"
@@ -9204,7 +9215,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9223,13 +9234,13 @@
-echo "configure:9227: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9238: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9233 "configure"
+#line 9244 "configure"
@@ -9240,7 +9251,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9267,13 +9278,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9271: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9282: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9277 "configure"
+#line 9288 "configure"
@@ -9284,7 +9295,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9303,13 +9314,13 @@
-echo "configure:9307: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9318: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9313 "configure"
+#line 9324 "configure"
@@ -9320,7 +9331,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:9324: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9432,7 +9443,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9436: checking whether to use PostgreSQL" >&5
+echo "configure:9447: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -9459,7 +9470,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9463: checking for location of PostgreSQL includes" >&5
+echo "configure:9474: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9485,15 +9496,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9489: checking for $ac_hdr" >&5
+echo "configure:9500: checking for $ac_hdr" >&5
-#line 9492 "configure"
+#line 9503 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9531,7 +9542,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9535: checking for location of PostgreSQL library" >&5
+echo "configure:9546: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9560,13 +9571,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9564: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9575: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9570 "configure"
+#line 9581 "configure"
@@ -9577,7 +9588,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9596,13 +9607,13 @@
-echo "configure:9600: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9611: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9606 "configure"
+#line 9617 "configure"
@@ -9613,7 +9624,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9632,13 +9643,13 @@
-echo "configure:9636: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9647: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9642 "configure"
+#line 9653 "configure"
@@ -9649,7 +9660,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9668,13 +9679,13 @@
-echo "configure:9672: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9683: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9678 "configure"
+#line 9689 "configure"
@@ -9685,7 +9696,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9742,13 +9753,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9746: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9757: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9752 "configure"
+#line 9763 "configure"
@@ -9759,7 +9770,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9781,13 +9792,13 @@
-echo "configure:9785: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9796: checking for PQcmdTuples in -lpq" >&5
-#line 9791 "configure"
+#line 9802 "configure"
@@ -9798,7 +9809,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9841,7 +9852,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9845: checking whether to use MySQL" >&5
+echo "configure:9856: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9861,7 +9872,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9865: checking for location of MySQL includes" >&5
+echo "configure:9876: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9887,15 +9898,15 @@
 do
-echo "configure:9891: checking for $ac_hdr" >&5
+echo "configure:9902: checking for $ac_hdr" >&5
-#line 9894 "configure"
+#line 9905 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9932,7 +9943,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9936: checking for location of MySQL library" >&5
+echo "configure:9947: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9963,13 +9974,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9967: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9978: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9973 "configure"
+#line 9984 "configure"
@@ -9980,7 +9991,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9999,13 +10010,13 @@
-echo "configure:10003: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10014: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 10009 "configure"
+#line 10020 "configure"
@@ -10016,7 +10027,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10035,13 +10046,13 @@
-echo "configure:10039: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10050: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 10045 "configure"
+#line 10056 "configure"
@@ -10052,7 +10063,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10071,13 +10082,13 @@
-echo "configure:10075: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10086: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 10081 "configure"
+#line 10092 "configure"
@@ -10088,7 +10099,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10107,13 +10118,13 @@
-echo "configure:10111: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10122: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 10117 "configure"
+#line 10128 "configure"
@@ -10124,7 +10135,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10143,13 +10154,13 @@
-echo "configure:10147: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10158: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 10153 "configure"
+#line 10164 "configure"
@@ -10160,7 +10171,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10179,13 +10190,13 @@
-echo "configure:10183: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10194: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10189 "configure"
+#line 10200 "configure"
@@ -10196,7 +10207,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10215,13 +10226,13 @@
-echo "configure:10219: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10230: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10225 "configure"
+#line 10236 "configure"
@@ -10232,7 +10243,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:10236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10322,7 +10333,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:10326: checking for $ac_word" >&5
+echo "configure:10337: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -10363,10 +10374,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10367: checking for mysql_server_init" >&5
+echo "configure:10378: checking for mysql_server_init" >&5
-#line 10370 "configure"
+#line 10381 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -10389,7 +10400,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -10427,7 +10438,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10431: checking whether to use SQLite" >&5
+echo "configure:10442: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -10447,7 +10458,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10451: checking for location of SQLite includes" >&5
+echo "configure:10462: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10473,15 +10484,15 @@
 do
-echo "configure:10477: checking for $ac_hdr" >&5
+echo "configure:10488: checking for $ac_hdr" >&5
-#line 10480 "configure"
+#line 10491 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10485: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10496: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10524,7 +10535,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10528: checking for location of SQLite library" >&5
+echo "configure:10539: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10551,13 +10562,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10555: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10566: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 10561 "configure"
+#line 10572 "configure"
@@ -10568,7 +10579,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10587,13 +10598,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10591: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10602: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10597 "configure"
+#line 10608 "configure"
@@ -10604,7 +10615,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10657,7 +10668,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10661: checking whether to use FFMPEG" >&5
+echo "configure:10672: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10677,7 +10688,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10681: checking for location of FFMPEG includes" >&5
+echo "configure:10692: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10703,15 +10714,15 @@
 do
-echo "configure:10707: checking for $ac_hdr" >&5
+echo "configure:10718: checking for $ac_hdr" >&5
-#line 10710 "configure"
+#line 10721 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10726: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10747,15 +10758,15 @@
 do
-echo "configure:10751: checking for $ac_hdr" >&5
+echo "configure:10762: checking for $ac_hdr" >&5
-#line 10754 "configure"
+#line 10765 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10791,15 +10802,15 @@
 do
-echo "configure:10795: checking for $ac_hdr" >&5
+echo "configure:10806: checking for $ac_hdr" >&5
-#line 10798 "configure"
+#line 10809 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10814: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10842,7 +10853,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10846: checking for location of FFMPEG library" >&5
+echo "configure:10857: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10869,13 +10880,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10873: checking for av_free in -lavutil" >&5
+echo "configure:10884: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10879 "configure"
+#line 10890 "configure"
@@ -10886,7 +10897,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10905,13 +10916,13 @@
-echo "configure:10909: checking for av_free in -lavutil" >&5
+echo "configure:10920: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10915 "configure"
+#line 10926 "configure"
@@ -10922,7 +10933,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10967,13 +10978,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10971: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10982: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10977 "configure"
+#line 10988 "configure"
@@ -10984,7 +10995,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11003,13 +11014,13 @@
-echo "configure:11007: checking for avcodec_init in -lavcodec" >&5
+echo "configure:11018: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 11013 "configure"
+#line 11024 "configure"
@@ -11020,7 +11031,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:11024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11065,13 +11076,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:11069: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11080: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 11075 "configure"
+#line 11086 "configure"
@@ -11082,7 +11093,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11101,13 +11112,13 @@
-echo "configure:11105: checking for av_set_parameters in -lavformat" >&5
+echo "configure:11116: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 11111 "configure"
+#line 11122 "configure"
@@ -11118,7 +11129,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:11122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11178,7 +11189,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11182: checking whether to use OpenGL" >&5
+echo "configure:11193: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -11212,7 +11223,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11216: checking for location of OpenGL includes" >&5
+echo "configure:11227: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11238,15 +11249,15 @@
 do
-echo "configure:11242: checking for $ac_hdr" >&5
+echo "configure:11253: checking for $ac_hdr" >&5
-#line 11245 "configure"
+#line 11256 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11250: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11261: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11280,7 +11291,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11284: checking for location of OpenGL library" >&5
+echo "configure:11295: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11309,13 +11320,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11313: checking for glBegin in -lGL" >&5
+echo "configure:11324: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11319 "configure"
+#line 11330 "configure"
@@ -11326,7 +11337,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11345,13 +11356,13 @@
-echo "configure:11349: checking for glBegin in -lGL" >&5
+echo "configure:11360: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11355 "configure"
+#line 11366 "configure"
@@ -11362,7 +11373,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11381,13 +11392,13 @@
-echo "configure:11385: checking for glBegin in -lGL" >&5
+echo "configure:11396: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11391 "configure"
+#line 11402 "configure"
@@ -11398,7 +11409,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11417,13 +11428,13 @@
-echo "configure:11421: checking for glBegin in -lGL" >&5
+echo "configure:11432: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11427 "configure"
+#line 11438 "configure"
@@ -11434,7 +11445,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:11438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11496,13 +11507,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11500: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11511: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11506 "configure"
+#line 11517 "configure"
@@ -11513,7 +11524,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11532,13 +11543,13 @@
-echo "configure:11536: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11547: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11542 "configure"
+#line 11553 "configure"
@@ -11549,7 +11560,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11596,10 +11607,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11600: checking for glXCreatePbuffer" >&5
+echo "configure:11611: checking for glXCreatePbuffer" >&5
-#line 11603 "configure"
+#line 11614 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11622,7 +11633,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11659,10 +11670,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11663: checking for glXCreateGLXPixmap" >&5
+echo "configure:11674: checking for glXCreateGLXPixmap" >&5
-#line 11666 "configure"
+#line 11677 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11685,7 +11696,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11728,7 +11739,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:11732: checking for location of OpenGL framework" >&5
+echo "configure:11743: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -11752,15 +11763,15 @@
 do
-echo "configure:11756: checking for $ac_hdr" >&5
+echo "configure:11767: checking for $ac_hdr" >&5
-#line 11759 "configure"
+#line 11770 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11764: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11796,10 +11807,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11800: checking for glBegin" >&5
+echo "configure:11811: checking for glBegin" >&5
-#line 11803 "configure"
+#line 11814 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11822,7 +11833,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11837,7 +11848,7 @@
   echo "$ac_t""yes" 1>&6
-    OPENGLLIBS="$OPENGLLIBS -framework OpenGL -framework AGL -framework ApplicationServices"
+    OPENGLLIB="$OPENGLLIB -framework OpenGL -framework AGL -framework ApplicationServices"
 else
@@ -11856,13 +11867,13 @@
 ac_save_libs="$LIBS"
-LIBS=" $OPENGLLIBS $LIBS"
+LIBS=" $OPENGLLIB $LIBS"
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11863: checking for gluBeginCurve" >&5
+echo "configure:11874: checking for gluBeginCurve" >&5
-#line 11866 "configure"
+#line 11877 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11885,7 +11896,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11900,7 +11911,7 @@
-    OPENGLLIBS="$OPENGLLIBS "
+    OPENGLLIB="$OPENGLLIB "
 else
@@ -11933,7 +11944,7 @@
-echo "configure:11937: checking for location of OpenGL includes" >&5
+echo "configure:11948: checking for location of OpenGL includes" >&5
@@ -11959,15 +11970,15 @@
 do
-echo "configure:11963: checking for $ac_hdr" >&5
+echo "configure:11974: checking for $ac_hdr" >&5
-#line 11966 "configure"
+#line 11977 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11982: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12001,7 +12012,7 @@
-echo "configure:12005: checking for location of OpenGL library" >&5
+echo "configure:12016: checking for location of OpenGL library" >&5
@@ -12026,18 +12037,18 @@
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:12030: checking for OpenGL library" >&5
+echo "configure:12041: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 12034 "configure"
+#line 12045 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:12041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -12061,18 +12072,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:12065: checking for GLU library" >&5
+echo "configure:12076: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 12069 "configure"
+#line 12080 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:12076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12121,7 +12132,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12125: checking whether to use ODBC" >&5
+echo "configure:12136: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12140,7 +12151,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12144: checking for location of ODBC includes" >&5
+echo "configure:12155: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12166,15 +12177,15 @@
 do
-echo "configure:12170: checking for $ac_hdr" >&5
+echo "configure:12181: checking for $ac_hdr" >&5
-#line 12173 "configure"
+#line 12184 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12189: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12208,7 +12219,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12212: checking for location of ODBC library" >&5
+echo "configure:12223: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12233,13 +12244,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12237: checking for SQLConnect in -lodbc" >&5
+echo "configure:12248: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12243 "configure"
+#line 12254 "configure"
@@ -12250,7 +12261,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12275,13 +12286,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12279: checking for SQLConnect in -liodbc" >&5
+echo "configure:12290: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 12285 "configure"
+#line 12296 "configure"
@@ -12292,7 +12303,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12317,11 +12328,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12321: checking for ODBC library" >&5
+echo "configure:12332: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12325 "configure"
+#line 12336 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12329,7 +12340,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12378,7 +12389,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12382: checking whether to use FFTW" >&5
+echo "configure:12393: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12397,7 +12408,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12401: checking for location of FFTW includes" >&5
+echo "configure:12412: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12423,15 +12434,15 @@
 do
-echo "configure:12427: checking for $ac_hdr" >&5
+echo "configure:12438: checking for $ac_hdr" >&5
-#line 12430 "configure"
+#line 12441 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12446: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12459,15 +12470,15 @@
 do
-echo "configure:12463: checking for $ac_hdr" >&5
+echo "configure:12474: checking for $ac_hdr" >&5
-#line 12466 "configure"
+#line 12477 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12471: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12482: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12495,15 +12506,15 @@
 do
-echo "configure:12499: checking for $ac_hdr" >&5
+echo "configure:12510: checking for $ac_hdr" >&5
-#line 12502 "configure"
+#line 12513 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12518: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12549,7 +12560,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12553: checking for location of FFTW library" >&5
+echo "configure:12564: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12574,13 +12585,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12578: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12589: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12584 "configure"
+#line 12595 "configure"
@@ -12591,7 +12602,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12616,13 +12627,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12620: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12631: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12626 "configure"
+#line 12637 "configure"
@@ -12633,7 +12644,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12658,13 +12669,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12662: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12673: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12668 "configure"
+#line 12679 "configure"
@@ -12675,7 +12686,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12679: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12732,7 +12743,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12736: checking whether to use BLAS" >&5
+echo "configure:12747: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12753,7 +12764,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12757: checking for location of BLAS includes" >&5
+echo "configure:12768: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12773,7 +12784,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12777: checking for location of BLAS library" >&5
+echo "configure:12788: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12799,15 +12810,15 @@
 do
-echo "configure:12803: checking for $ac_hdr" >&5
+echo "configure:12814: checking for $ac_hdr" >&5
-#line 12806 "configure"
+#line 12817 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12811: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12842,13 +12853,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12846: checking for dnrm2_ in -lblas" >&5
+echo "configure:12857: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 12852 "configure"
+#line 12863 "configure"
@@ -12859,7 +12870,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12878,13 +12889,13 @@
-echo "configure:12882: checking for dnrm2_ in -lblas" >&5
+echo "configure:12893: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12888 "configure"
+#line 12899 "configure"
@@ -12895,7 +12906,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:12899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12939,13 +12950,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12943: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12954: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 12949 "configure"
+#line 12960 "configure"
@@ -12956,7 +12967,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12971,13 +12982,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12975: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12986: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lf77blas -latlas $LIBS"
-#line 12981 "configure"
+#line 12992 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12988,7 +12999,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13003,13 +13014,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13007: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13018: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13013 "configure"
+#line 13024 "configure"
@@ -13020,7 +13031,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13065,16 +13076,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13069: checking for sgemm in $vlib_flags" >&5
+echo "configure:13080: checking for sgemm in $vlib_flags" >&5
-#line 13071 "configure"
+#line 13082 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13092,13 +13103,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13096: checking for sgemm_ in -lblas" >&5
+echo "configure:13107: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13102 "configure"
+#line 13113 "configure"
@@ -13109,7 +13120,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13124,13 +13135,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13128: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13139: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13134 "configure"
+#line 13145 "configure"
@@ -13141,7 +13152,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13156,13 +13167,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13160: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13171: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13166 "configure"
+#line 13177 "configure"
@@ -13173,7 +13184,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13207,13 +13218,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13211: checking for acosp in -lsunmath" >&5
+echo "configure:13222: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13217 "configure"
+#line 13228 "configure"
@@ -13224,7 +13235,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13239,13 +13250,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13243: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13254: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13249 "configure"
+#line 13260 "configure"
@@ -13256,7 +13267,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13286,13 +13297,13 @@
 # Generic BLAS library
-echo "configure:13290: checking for sgemm_ in -lblas" >&5
+echo "configure:13301: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13296 "configure"
+#line 13307 "configure"
@@ -13303,7 +13314,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13342,7 +13353,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13346: checking whether to use LAPACK" >&5
+echo "configure:13357: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13367,7 +13378,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13371: checking for location of LAPACK includes" >&5
+echo "configure:13382: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13387,7 +13398,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13391: checking for location of LAPACK library" >&5
+echo "configure:13402: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13413,15 +13424,15 @@
 do
-echo "configure:13417: checking for $ac_hdr" >&5
+echo "configure:13428: checking for $ac_hdr" >&5
-#line 13420 "configure"
+#line 13431 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13425: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13436: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13453,10 +13464,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13457: checking for dsegv_" >&5
+echo "configure:13468: checking for dsegv_" >&5
-#line 13460 "configure"
+#line 13471 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13479,7 +13490,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13506,13 +13517,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13510: checking for desgv_ in -llapack" >&5
+echo "configure:13521: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13516 "configure"
+#line 13527 "configure"
@@ -13523,7 +13534,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13555,13 +13566,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13559: checking for dgesv_ in -llapack" >&5
+echo "configure:13570: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13565 "configure"
+#line 13576 "configure"
@@ -13572,7 +13583,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13591,13 +13602,13 @@
-echo "configure:13595: checking for dgesv_ in -llapack" >&5
+echo "configure:13606: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13601 "configure"
+#line 13612 "configure"
@@ -13608,7 +13619,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13664,7 +13675,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13668: checking whether to use Motif" >&5
+echo "configure:13679: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13683,7 +13694,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13687: checking for location of Motif includes" >&5
+echo "configure:13698: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13709,15 +13720,15 @@
 do
-echo "configure:13713: checking for $ac_hdr" >&5
+echo "configure:13724: checking for $ac_hdr" >&5
-#line 13716 "configure"
+#line 13727 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13732: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13751,7 +13762,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13755: checking for location of Motif library" >&5
+echo "configure:13766: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13776,13 +13787,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13780: checking for XmStringCreate in -lXm" >&5
+echo "configure:13791: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 13786 "configure"
+#line 13797 "configure"
@@ -13793,7 +13804,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:13797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13834,7 +13845,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13838: checking whether to use Cairo" >&5
+echo "configure:13849: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -13860,15 +13871,15 @@
 do
-echo "configure:13864: checking for $ac_hdr" >&5
+echo "configure:13875: checking for $ac_hdr" >&5
-#line 13867 "configure"
+#line 13878 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13883: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13908,10 +13919,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13912: checking for cairo_create" >&5
+echo "configure:13923: checking for cairo_create" >&5
-#line 13915 "configure"
+#line 13926 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -13934,7 +13945,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -13975,7 +13986,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13979: checking whether to use GLw" >&5
+echo "configure:13990: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -13994,7 +14005,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13998: checking for location of GLw includes" >&5
+echo "configure:14009: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14020,15 +14031,15 @@
 do
-echo "configure:14024: checking for $ac_hdr" >&5
+echo "configure:14035: checking for $ac_hdr" >&5
-#line 14027 "configure"
+#line 14038 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14043: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14056,15 +14067,15 @@
 do
-echo "configure:14060: checking for $ac_hdr" >&5
+echo "configure:14071: checking for $ac_hdr" >&5
-#line 14063 "configure"
+#line 14074 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14068: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14079: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14104,7 +14115,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14108: checking for location of GLw library" >&5
+echo "configure:14119: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14129,13 +14140,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14133: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14144: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14139 "configure"
+#line 14150 "configure"
@@ -14146,7 +14157,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14171,13 +14182,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14175: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14186: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14181 "configure"
+#line 14192 "configure"
@@ -14188,7 +14199,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14213,13 +14224,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14217: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14228: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14223 "configure"
+#line 14234 "configure"
@@ -14230,7 +14241,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14234: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14255,13 +14266,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14259: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14270: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14265 "configure"
+#line 14276 "configure"
@@ -14272,7 +14283,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14297,13 +14308,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14301: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14312: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14307 "configure"
+#line 14318 "configure"
@@ -14314,7 +14325,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14339,13 +14350,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14343: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14354: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14349 "configure"
+#line 14360 "configure"
@@ -14356,7 +14367,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14383,13 +14394,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14387: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14398: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14393 "configure"
+#line 14404 "configure"
@@ -14400,7 +14411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14419,13 +14430,13 @@
-echo "configure:14423: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14434: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14429 "configure"
+#line 14440 "configure"
@@ -14436,7 +14447,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14463,13 +14474,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14467: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14478: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14473 "configure"
+#line 14484 "configure"
@@ -14480,7 +14491,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14499,13 +14510,13 @@
-echo "configure:14503: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14514: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14509 "configure"
+#line 14520 "configure"
@@ -14516,7 +14527,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14629,7 +14640,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14633: checking whether to use FreeType" >&5
+echo "configure:14644: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14648,7 +14659,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14652: checking for location of FreeType includes" >&5
+echo "configure:14663: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14674,15 +14685,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14678: checking for $ac_hdr" >&5
+echo "configure:14689: checking for $ac_hdr" >&5
-#line 14681 "configure"
+#line 14692 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14716,7 +14727,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14720: checking for location of FreeType library" >&5
+echo "configure:14731: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14741,13 +14752,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14745: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14756: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 14751 "configure"
+#line 14762 "configure"
@@ -14758,7 +14769,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:14762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14799,7 +14810,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14803: checking whether to use NLS" >&5
+echo "configure:14814: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -14819,10 +14830,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14823: checking for gettext" >&5
+echo "configure:14834: checking for gettext" >&5
-#line 14826 "configure"
+#line 14837 "configure"
     which can conflict with char gettext(); below.  */
@@ -14845,7 +14856,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14863,13 +14874,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14867: checking for gettext in -lintl" >&5
+echo "configure:14878: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14873 "configure"
+#line 14884 "configure"
@@ -14880,7 +14891,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14915,7 +14926,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14919: checking whether to use C++" >&5
+echo "configure:14930: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14931,7 +14942,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14935: checking for $ac_word" >&5
+echo "configure:14946: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14960,7 +14971,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14964: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14975: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14971,12 +14982,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14975 "configure"
+#line 14986 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15002,19 +15013,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15006: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15017: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15011: checking whether we are using GNU C++" >&5
+echo "configure:15022: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15032,7 +15043,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15036: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15047: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15073,7 +15084,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15077: checking whether to use openDWG" >&5
+echo "configure:15088: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15093,7 +15104,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15097: checking for location of openDGW includes" >&5
+echo "configure:15108: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15119,15 +15130,15 @@
 do
-echo "configure:15123: checking for $ac_hdr" >&5
+echo "configure:15134: checking for $ac_hdr" >&5
-#line 15126 "configure"
+#line 15137 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15131: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15161,7 +15172,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15165: checking for location of openDWG library" >&5
+echo "configure:15176: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15208,7 +15219,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15212: checking for special C compiler options needed for large files" >&5
+echo "configure:15223: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15216,7 +15227,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15220 "configure"
+#line 15231 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15232,7 +15243,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15236: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15247: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -15241,7 +15252,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15245 "configure"
+#line 15256 "configure"
@@ -15257,7 +15268,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15261: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15272: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15277,11 +15288,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15281: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15292: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15285 "configure"
+#line 15296 "configure"
@@ -15297,14 +15308,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15301: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15312: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15308 "configure"
+#line 15319 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15322,7 +15333,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15326: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15337: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15341,11 +15352,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15345: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15356: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15349 "configure"
+#line 15360 "configure"
@@ -15361,14 +15372,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15365: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15376: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15372 "configure"
+#line 15383 "configure"
 #define _LARGE_FILES 1
@@ -15386,7 +15397,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15390: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15401: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15405,25 +15416,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15409: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15420: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15413 "configure"
+#line 15424 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15420: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15427 "configure"
+#line 15438 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15432,7 +15443,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15436: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15447: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15453,10 +15464,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15457: checking if system supports Large Files at all" >&5
+echo "configure:15468: checking if system supports Large Files at all" >&5
-#line 15460 "configure"
+#line 15471 "configure"
 #include <stdio.h>
@@ -15488,7 +15499,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15492: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15503: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15517,7 +15528,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15521: checking whether to use Python" >&5
+echo "configure:15532: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15537,7 +15548,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15541: checking for $ac_word" >&5
+echo "configure:15552: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15582,15 +15593,15 @@
 do
-echo "configure:15586: checking for $ac_hdr" >&5
+echo "configure:15597: checking for $ac_hdr" >&5
-#line 15589 "configure"
+#line 15600 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15594: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15630,7 +15641,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15634: checking for $ac_word" >&5
+echo "configure:15645: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15676,7 +15687,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15680: checking whether to use wxWidgets" >&5
+echo "configure:15691: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15696,7 +15707,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15700: checking for $ac_word" >&5
+echo "configure:15711: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15744,7 +15755,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15748: checking wxWidgets version" >&5
+echo "configure:15759: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15767,15 +15778,15 @@
 do
-echo "configure:15771: checking for $ac_hdr" >&5
+echo "configure:15782: checking for $ac_hdr" >&5
-#line 15774 "configure"
+#line 15785 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15790: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15811,15 +15822,15 @@
 do
-echo "configure:15815: checking for $ac_hdr" >&5
+echo "configure:15826: checking for $ac_hdr" >&5
-#line 15818 "configure"
+#line 15829 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15823: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15834: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2008-07-27 23:10:29 UTC (rev 32346)
+++ grass/trunk/configure.in	2008-07-27 23:59:02 UTC (rev 32347)
@@ -249,6 +249,7 @@
 LOC_ARG_WITH_INC(opengl, OpenGL)
 LOC_ARG_WITH_LIB(opengl, OpenGL)
+LOC_ARG_WITH_FRAMEWORK(opengl, OpenGL)
 LOC_ARG_WITH_INC(odbc, ODBC)
 LOC_ARG_WITH_LIB(odbc, ODBC)
@@ -1166,8 +1167,8 @@
 LOC_CHECK_INCLUDES(OpenGL/gl.h OpenGL/glu.h,OpenGL,$OPENGLPATH)
-LOC_CHECK_FUNC(glBegin,OpenGL library,OPENGLLIBS,-framework OpenGL -framework AGL -framework ApplicationServices,$OPENGLPATH)
-LOC_CHECK_FUNC(gluBeginCurve,GLU library,OPENGLLIBS,,$OPENGLPATH,$OPENGLLIBS)
+LOC_CHECK_FUNC(glBegin,OpenGL library,OPENGLLIB,-framework OpenGL -framework AGL -framework ApplicationServices,$OPENGLPATH)
+LOC_CHECK_FUNC(gluBeginCurve,GLU library,OPENGLLIB,,$OPENGLPATH,$OPENGLLIB)
 OPENGLINC="$OPENGLPATH"
 OPENGLLIBPATH="$OPENGLPATH"
