[GRASS-SVN] r32373 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 30 09:05:12 EDT 2008
Author: martinl
Date: 2008-07-30 09:05:12 -0400 (Wed, 30 Jul 2008)
New Revision: 32373
grass/trunk/gui/wxpython/gui_modules/gcmd.py
wxGUI: do not run command twice, redirect stdout properly, update r32364
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-07-30 12:52:58 UTC (rev 32372)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-07-30 13:05:12 UTC (rev 32373)
@@ -221,6 +221,7 @@
return ''
r = conn.read(maxsize)
if not r:
return self._close(which)
@@ -319,12 +320,6 @@
os.environ["GRASS_VERBOSE"] = str(verbose)
- # set message formatting
- message_format = os.getenv("GRASS_MESSAGE_FORMAT")
- os.environ["GRASS_MESSAGE_FORMAT"] = "gui"
# create command thread
self.cmdThread = CommandThread(cmd, stdin,
@@ -366,11 +361,6 @@
Debug.msg (3, "Command(): cmd='%s', wait=%s, returncode=?, alive=%s" % \
(' '.join(cmd), wait, self.cmdThread.isAlive()))
- if message_format:
- os.environ["GRASS_MESSAGE_FORMAT"] = message_format
- else:
- os.unsetenv("GRASS_MESSAGE_FORMAT")
if verbose_orig:
os.environ["GRASS_VERBOSE"] = verbose_orig
else:
@@ -492,7 +482,17 @@
self.aborted = False
self.setDaemon(True)
+ # set message formatting
+ self.message_format = os.getenv("GRASS_MESSAGE_FORMAT")
+ os.environ["GRASS_MESSAGE_FORMAT"] = "gui"
+ def __del__(self):
+ if self.message_format:
+ os.environ["GRASS_MESSAGE_FORMAT"] = self.message_format
+ else:
+ os.unsetenv("GRASS_MESSAGE_FORMAT")
def run(self):
if len(self.cmd) == 0:
return
@@ -531,7 +531,7 @@
if not subprocess.mswindows:
flags = fcntl.fcntl(out_fileno, fcntl.F_GETFL)
fcntl.fcntl(out_fileno, fcntl.F_SETFL, flags| os.O_NONBLOCK)
# wait for the process to end, sucking in stuff until it does end
while self.module.poll() is None:
if self._want_abort: # abort running process
