[GRASS-SVN] r32381 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Jul 30 10:30:08 EDT 2008
Author: martinl
Date: 2008-07-30 10:30:08 -0400 (Wed, 30 Jul 2008)
New Revision: 32381
grass/trunk/lib/vector/Vlib/break_lines.c
vlib: cosmetics in build message (print number of primitives first)
[merged from trunk, r32380]
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2008-07-30 14:28:56 UTC (rev 32380)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2008-07-30 14:30:08 UTC (rev 32381)
@@ -36,7 +36,7 @@
void
Vect_break_lines ( struct Map_info *Map, int type, struct Map_info *Err, FILE *msgout )
- Vect_break_lines_list (Map, NULL, type, Err, msgout);
+ Vect_break_lines_list (Map, NULL, NULL, type, Err, msgout);
return;
@@ -52,7 +52,8 @@
0,0;1,0;0,0 is broken at 1,0.
\param Map input vector map
- \param List_break list of lines to be broken or NULL
+ \param List_break list of lines (NULL for all lines in vector map)
+ \param List_ref list of reference lines or NULL
\param type feature type
\param[out] Err vector map where points at intersections will be written or NULL
\param[out] msgout file pointer where messages will be written or NULL
@@ -61,7 +62,7 @@
int
-Vect_break_lines_list ( struct Map_info *Map, struct ilist *List_break,
+Vect_break_lines_list ( struct Map_info *Map, struct ilist *List_break, struct ilist *List_ref,
struct line_pnts *APoints, *BPoints, *Points;
@@ -122,6 +123,10 @@
else {
aline = iline + 1;
+ if (List_ref && !Vect_val_in_list(List_ref, aline))
+ continue;
G_debug (3, "aline = %d", aline);
if ( !Vect_line_alive ( Map, aline ) )
continue;
@@ -242,6 +247,7 @@
Vect_line_prune ( AXLines[k] );
if ( (atype & GV_POINTS) || AXLines[k]->n_points > 1 ) {
ret = Vect_write_line ( Map, atype, AXLines[k], ACats );
+ Vect_list_append(List_ref, ret);
G_debug (3, "Line %d written, npoints = %d", ret, AXLines[k]->n_points);
if (List_break) {
Vect_list_append(List_break, ret);
