[GRASS-SVN] r32391 - grass-addons/vector/v.parallel2
Wed Jul 30 16:44:54 EDT 2008
Author: rmatev
Date: 2008-07-30 16:44:42 -0400 (Wed, 30 Jul 2008)
New Revision: 32391
   grass-addons/vector/v.parallel2/vlib_buffer.c
Fixed elliptical buffer lines
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c	2008-07-30 19:13:24 UTC (rev 32390)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c	2008-07-30 20:44:42 UTC (rev 32391)
@@ -47,6 +47,7 @@
 * (x,y) shoud be normalized vector for common transforms; This func transforms (x,y) to a vector corresponding to da, db, dalpha params
+* dalpha is in radians
 static void elliptic_transform(double x, double y, double da, double db, double dalpha, double *nx, double *ny) {
     double cosa = cos(dalpha);
@@ -70,6 +71,7 @@
 * vect(x,y) must be normalized
 * gives the tangent point of the tangent to ellpise(da,db,dalpha) parallel to vect(x,y)
 * ellipse center is in (0,0)
 static void elliptic_tangent(double x, double y, double da, double db, double dalpha, double *px, double *py) {
@@ -175,7 +177,7 @@
     if ((np == 0) || (np == 1))
         return;
-    if ((da == 0) && (db == 0)) {
+    if ((da == 0) || (db == 0)) {
         Vect_copy_xyz_to_pnts(nPoints, x, y, NULL, np);
         return;
@@ -319,7 +321,7 @@
     Vect_reset_line(nPoints);
         return;
@@ -613,8 +615,9 @@
 /* point_in_buf - test if point px,py is in d buffer of Points
+** dalpha is in degrees
 ** returns:  1 in buffer
-**           0 not  in buffer
+**           0 not in buffer
 int point_in_buf(struct line_pnts *Points, double px, double py, double da, double db, double dalpha) {
     int i, np;
@@ -622,7 +625,9 @@
     double delta, delta_k, k;
     double vx, vy, wx, wy, mx, my, nx, ny;
     double len, tx, ty, d, da2;
+    dalpha *= PI/180; /* convert dalpha from degrees to radians */
     np = Points->n_points;
     da2 = da*da;
     for (i = 0; i < np-1; i++) {
@@ -661,8 +666,10 @@
                 0, NULL, NULL, NULL, NULL, NULL);
 /*            G_debug(4, "sqrt(d)*da = %g, len' = %g, olen = %g", sqrt(d)*da, da*LENGTH(tx,ty), LENGTH((px-nx),(py-ny)));*/
-            if (d <= 1)
+            if (d <= 1) {
+                //G_debug(1, "d=%g", d);
                 return 1;
         else {
             d = dig_distance2_point_to_line(px, py, 0, vx, vy, 0, wx, wy, 0,
