[GRASS-SVN] r32398 - grass/trunk/vector/v.in.ascii
svn_grass at osgeo.org
Thu Jul 31 02:46:59 EDT 2008
Author: martinl
Date: 2008-07-31 02:46:58 -0400 (Thu, 31 Jul 2008)
New Revision: 32398
grass/trunk/vector/v.in.ascii/in.c
grass/trunk/vector/v.in.ascii/local_proto.h
grass/trunk/vector/v.in.ascii/points.c
Show progress information in points mode, trac #244
Modified: grass/trunk/vector/v.in.ascii/in.c
--- grass/trunk/vector/v.in.ascii/in.c 2008-07-31 05:59:03 UTC (rev 32397)
+++ grass/trunk/vector/v.in.ascii/in.c 2008-07-31 06:46:58 UTC (rev 32398)
@@ -228,7 +228,7 @@
if (format == FORMAT_POINT) {
- int i, rowlen, ncols, minncols, *coltype, *coltype2, *collen;
+ int i, rowlen, ncols, minncols, *coltype, *coltype2, *collen, nrows;
int n_int = 0, n_double = 0, n_string = 0;
char buf[1000];
struct field_info *Fi;
@@ -244,7 +244,7 @@
unlink(tmp);
- points_analyse(ascii, tmpascii, fs, &rowlen, &ncols, &minncols,
+ points_analyse(ascii, tmpascii, fs, &rowlen, &ncols, &minncols, &nrows,
&coltype, &collen, skip_lines, xcol, ycol,
region_flag->answer);
@@ -510,7 +510,7 @@
table = NULL;
- points_to_bin(tmpascii, rowlen, &Map, driver, table, fs, ncols,
+ points_to_bin(tmpascii, rowlen, &Map, driver, table, fs, nrows, ncols,
coltype2, xcol, ycol, zcol, catcol, skip_lines);
if (driver) {
Modified: grass/trunk/vector/v.in.ascii/local_proto.h
--- grass/trunk/vector/v.in.ascii/local_proto.h 2008-07-31 05:59:03 UTC (rev 32397)
+++ grass/trunk/vector/v.in.ascii/local_proto.h 2008-07-31 06:46:58 UTC (rev 32398)
@@ -11,11 +11,11 @@
#define FORMAT_ALL 1
-int points_analyse (FILE *, FILE *, char *, int *, int *, int *, int **,
+int points_analyse (FILE *, FILE *, char *, int *, int *, int *, int*, int **,
int **, int, int, int, int);
int points_to_bin (FILE *, int, struct Map_info *, dbDriver *,
- char *, char *, int, int *,
+ char *, char *, int, int, int *,
int, int, int, int, int);
int read_head (FILE *, struct Map_info *);
Modified: grass/trunk/vector/v.in.ascii/points.c
--- grass/trunk/vector/v.in.ascii/points.c 2008-07-31 05:59:03 UTC (rev 32397)
+++ grass/trunk/vector/v.in.ascii/points.c 2008-07-31 06:46:58 UTC (rev 32398)
@@ -48,12 +48,13 @@
* rowlength: maximum row length
* ncolumns: number of columns
* minncolumns: minimum number of columns
+ * nrows: number of rows
* column_type: column types
* column_length: column lengths (string only)
int points_analyse(FILE * ascii_in, FILE * ascii, char *fs,
- int *rowlength, int *ncolumns, int *minncolumns,
+ int *rowlength, int *ncolumns, int *minncolumns, int *nrows,
int **column_type, int **column_length, int skip_lines,
int xcol, int ycol, int region_flag)
@@ -242,6 +243,7 @@
*minncolumns = minncols;
*column_type = coltype;
*column_length = collen;
+ *nrows = row - 1; /* including skipped lines */
G_free(buf);
G_free(buf_raw);
@@ -265,7 +267,7 @@
* Note: column types (both in header or coldef) must be supported by driver
int points_to_bin(FILE * ascii, int rowlen, struct Map_info *Map,
- dbDriver * driver, char *table, char *fs, int ncols,
+ dbDriver * driver, char *table, char *fs, int nrows, int ncols,
int *coltype, int xcol, int ycol, int zcol, int catcol,
int skip_lines)
@@ -394,7 +396,11 @@
+ G_percent(row, nrows + 1, 2);
G_free_tokens(tokens);
+ row++;
return 0;
