[GRASS-SVN] r32426 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Jul 31 16:16:16 EDT 2008
Author: martinl
Date: 2008-07-31 16:16:15 -0400 (Thu, 31 Jul 2008)
New Revision: 32426
grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
wxGUI: suppress gettext warnings (merge from trunk, r32425)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-07-31 20:12:38 UTC (rev 32425)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py 2008-07-31 20:16:15 UTC (rev 32426)
@@ -229,10 +229,11 @@
cat = -1
wx.MessageBox(parent=self,
message=_("Error loading attribute data. "
- "Record number: %d. Unable to cast value '%s' in "
- "key column (%s) to integer.\n\n"
- "Details: %s") % \
- (i + 1, value, keyColumn, e),
+ "Record number: %(rec)d. Unable to cast value '%(val)s' in "
+ "key column (%(key)s) to integer.\n\n"
+ "Details: %(detail)s") % \
+ { 'rec' : i + 1, 'val' : value,
+ 'key' : keyColumn, 'detail' : e},
caption=_("Error"),
style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
j += 1
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2008-07-31 20:12:38 UTC (rev 32425)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py 2008-07-31 20:16:15 UTC (rev 32426)
@@ -1120,8 +1120,8 @@
self.bkw_rmserror = round((sumsq_bkw_err/i)**0.5,4)
self.list.ResizeColumns()
- self.SetStatusText(_('RMS error for selected points forward: %s backward: %s') % \
- (self.fwd_rmserror, self.bkw_rmserror))
+ self.SetStatusText(_('RMS error for selected points forward: %(fwd)s backward: %(bkw)s') % \
+ { 'fwd' : self.fwd_rmserror, 'bkw' : self.bkw_rmserror })
class GCPList(wx.ListCtrl,
CheckListCtrlMixin,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-07-31 20:12:38 UTC (rev 32425)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-07-31 20:16:15 UTC (rev 32426)
@@ -451,9 +451,11 @@
self.Append(settings, group, key, subkey, value)
idx += 2
except ValueError, e:
- print >> sys.stderr, _("Error: Reading settings from file <%s> failed.\n"
- " Details: %s\n"
- " Line: '%s'") % (filename, e, line)
+ print >> sys.stderr, _("Error: Reading settings from file <%(file)s> failed.\n"
+ " Details: %(detail)s\n"
+ " Line: '%(line)s'") % { 'file' : filename,
+ 'detail' : e,
+ 'line' : line }
file.close()
file.close()
@@ -510,8 +512,9 @@
except IOError, e:
raise gcmd.SettingsError(message=e)
except StandardError, e:
- raise gcmd.SettingsError(message=_('Writing settings to file <%s> failed.'
- '\n\nDetails: %s') % (filePath, e))
+ raise gcmd.SettingsError(message=_('Writing settings to file <%(file)s> failed.'
+ '\n\nDetails: %(detail)s') % { 'file' : filePath,
+ 'detail' : e })
file.close()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-07-31 20:12:38 UTC (rev 32425)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py 2008-07-31 20:16:15 UTC (rev 32426)
@@ -140,9 +140,9 @@
ret = self.driver.Reset(self.map)
raise gcmd.DigitError(parent=self.mapWindow.parent,
- message=_('Unable to initialize display driver, '
- 'see README file for more information.%s%s'
- 'Details: %s (%s)') % (os.linesep, os.linesep, e, digitErr))
+ message="%s %s (%s)" % (_('Unable to initialize display driver, '
+ 'see README file for more information.\n\n'
+ 'Details:'), e, digitErr))
if map and ret == -1:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2008-07-31 20:12:38 UTC (rev 32425)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py 2008-07-31 20:16:15 UTC (rev 32426)
@@ -340,9 +340,9 @@
if self.num_error > 0:
wx.MessageBox(parent=parent,
message=_("Some lines were skipped when reading settings "
- "from file <%s>.\nSee 'Command output' window for details.\n\n"
- "Number of skipped lines: %d" % \
- (self.filename, self.num_error)),
+ "from file <%(file)s>.\nSee 'Command output' window for details.\n\n"
+ "Number of skipped lines: %(line)d") % \
+ { 'file' : self.filename, 'line' : self.num_error },
caption=_("Warning"), style=wx.OK | wx.ICON_EXCLAMATION)
parent.goutput.WriteLog('Map layers loaded from GRC file <%s>' % self.filename)
parent.goutput.WriteLog('Skipped lines:\n%s' % self.error)
