[GRASS-SVN] r32438 - grass/trunk/vector/v.proj
svn_grass at osgeo.org
Thu Jul 31 18:06:37 EDT 2008
Author: martinl
Date: 2008-07-31 18:06:37 -0400 (Thu, 31 Jul 2008)
New Revision: 32438
grass/trunk/vector/v.proj/main.c
v.proj: progress info added, trac #243
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c 2008-07-31 21:40:50 UTC (rev 32437)
+++ grass/trunk/vector/v.proj/main.c 2008-07-31 22:06:37 UTC (rev 32438)
@@ -232,8 +232,12 @@
/* Cycle through all lines */
Vect_rewind ( &Map );
i = 0;
+ fprintf (stderr, _("Reprojecting primitives: "));
while(1) {
++i;
+ if (i % 1000 == 0) {
+ fprintf (stderr, "%7d\b\b\b\b\b\b\b", i);
type = Vect_read_next_line (&Map, Points, Cats); /* read line */
if ( type == 0 ) continue; /* Dead */
@@ -248,6 +252,7 @@
Vect_write_line (&Out_Map, type, Points, Cats); /* write line */
} /* end lines section */
+ fprintf (stderr, "\r");
/* Copy tables */
Vect_copy_tables ( &Map, &Out_Map, 0 );
