[GRASS-SVN] r31612 - grass/trunk/lib/ogsf
svn_grass at osgeo.org
Mon Jun 2 15:23:33 EDT 2008
Author: martinl
Date: 2008-06-02 15:23:33 -0400 (Mon, 02 Jun 2008)
New Revision: 31612
grass/trunk/lib/ogsf/GS2.c
grass/trunk/lib/ogsf/GSX.c
grass/trunk/lib/ogsf/gs.c
grass/trunk/lib/ogsf/gs_bm.c
grass/trunk/lib/ogsf/gs_norms.c
grass/trunk/lib/ogsf/gsd_img_ppm.c
grass/trunk/lib/ogsf/gsd_prim.c
grass/trunk/lib/ogsf/gsd_surf.c
grass/trunk/lib/ogsf/gsd_views.c
grass/trunk/lib/ogsf/gsd_wire.c
ogsflib: doxygen strings & debug messages updated (merge devbr6, r31611)
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/GS2.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -132,6 +132,9 @@
int GS_get_longdim(float *dim)
*dim = Longdim;
+ G_debug(3, "GS_get_longdim(): dim=%g", *dim);
return (1);
@@ -153,7 +156,7 @@
- \brief Set attributes to default
+ \brief Set default attributes for map objects
\param defs attributes array (dim MAX_ATTS)
\param null_defs null attributes array (dim MAX_ATTS)
@@ -280,8 +283,8 @@
\bug I think lights array doesnt match sgi_light array
- \param num light id (starts with 1?)
- \param xpos,ypos,zpos coordinates
+ \param num light id (starts with 1)
+ \param xpos,ypos,zpos coordinates (model)
\param local ?
void GS_setlight_position(int num, float xpos, float ypos, float zpos,
@@ -1454,7 +1457,7 @@
\brief Set client data
\param id surface id
- \param clientd ?
+ \param clientd pointer to client data struct
\return 1 on success
\return -1 on error (invalid surface id)
@@ -1856,7 +1859,7 @@
geosurf *gs;
- G_debug(3, "GS_draw_surf");
+ G_debug(3, "GS_draw_surf(): id=%d", id);
gs = gs_get_surf(id);
if (gs) {
@@ -1881,7 +1884,7 @@
- \brief Draw wire
+ \brief Draw surface wire
Overrides draw_mode for fast display
@@ -1891,7 +1894,7 @@
geosurf *gs;
- G_debug(3, "GS_draw_wire");
+ G_debug(3, "GS_draw_wire(): id=%d", id);
@@ -1989,7 +1992,7 @@
float GS_global_exag(void)
- G_debug(3, "GS_global_exag");
+ G_debug(3, "GS_global_exag(): %g", Gv.vert_exag);
return (Gv.vert_exag);
@@ -2342,7 +2345,7 @@
- Get Z extents for all loaded surfaces
+ \brief Get Z extents for all loaded surfaces
Treating zeros as "no data"
@@ -2372,6 +2375,9 @@
+ G_debug (3, "GS_get_zrange_nz(): min=%g max=%g",
+ *min, *max);
return;
@@ -2490,7 +2496,7 @@
- \brief Draw done
+ \brief Draw done, swap buffers
void GS_done_draw(void)
@@ -2604,7 +2610,7 @@
- \brief Move position to
+ \brief Move to position
\param pt point model coordinates
@@ -2612,7 +2618,7 @@
float ft[3];
- G_debug(3, "GS_moveto");
+ G_debug(3, "GS_moveto(): %f,%f,%f", pt[0], pt[1], pt[2]);
if (Gv.infocus) {
GS_v3eq(Gv.from_to[FROM], pt);
@@ -2652,7 +2658,7 @@
\param[out] min min z-value
\param[out] max max z-value
- \param[out] mid middle z-value ?
+ \param[out] mid middle z-value
\return ?
@@ -2661,12 +2667,12 @@
geosurf *gs;
- G_debug(3, "GS_get_zextents");
if (NULL == (gs = gs_get_surf(id))) {
return (-1);
+ G_debug(3, "GS_get_zextents(): id=%d", id);
return (gs_get_zextents(gs, min, max, mid));
@@ -2675,7 +2681,7 @@
- \param doexag ?
+ \param doexag use z-exaggeration
\return -1 on error
@@ -2686,8 +2692,6 @@
float surf_min, surf_max;
float vol_min, vol_max;
- G_debug(3, "GS_get_zrange");
ret_surf = gs_get_zrange(&surf_min, &surf_max);
ret_vol = gvl_get_zrange(&vol_min, &vol_max);
@@ -2707,20 +2711,22 @@
*max *= Gv.vert_exag;
+ G_debug(3, "GS_get_zrange(): min=%g max=%g",
+ *min, *max);
return ((ret_surf > 0 || ret_vol > 0) ? (1) :(-1));
- \brief Get 'from' coordinates
+ \brief Get 'from' position
\param[out] fr from model coordinates
void GS_get_from(float *fr)
- G_debug(3, "GS_get_from");
GS_v3eq(fr, Gv.from_to[FROM]);
+ G_debug(3, "GS_get_from(): %f,%f,%f", fr[0], fr[1], fr[2]);
return;
@@ -2908,7 +2914,8 @@
void GS_set_viewport(int left, int right, int bottom, int top)
- G_debug(3, "GS_set_viewport");
+ G_debug(3, "GS_set_viewport(): left=%d, right=%d, "
+ "bottom=%d, top=%d", left, right, bottom, top);
gsd_viewport(left, right, bottom, top);
@@ -3162,7 +3169,7 @@
\brief Get scale
\param sx,sy,sz x/y/z scale values
- \param doexag ?
+ \param doexag use vertical exaggeration
void GS_get_scale(float *sx, float *sy, float *sz, int doexag)
@@ -3366,6 +3373,8 @@
\brief Get aspect value
+ \return aspect value
double GS_get_aspect(void)
Modified: grass/trunk/lib/ogsf/GSX.c
--- grass/trunk/lib/ogsf/GSX.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/GSX.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -24,7 +24,7 @@
static int Cxl = 0;
- \brief Check cancel
+ \brief Check for cancel
\return code
Modified: grass/trunk/lib/ogsf/gs.c
--- grass/trunk/lib/ogsf/gs.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gs.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -638,7 +638,7 @@
\brief Get attribute source
\param gs pointer to geosurf struct
- \param desc attribute id
+ \param desc attribute id (descriptor)
\return -1 on error
\return attribute source id
@@ -659,7 +659,7 @@
- \brief Get attribute typbuff
+ \brief Get attribute data buffer
Modified: grass/trunk/lib/ogsf/gs_bm.c
--- grass/trunk/lib/ogsf/gs_bm.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gs_bm.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -236,7 +236,7 @@
int row, col, offset, destroy_ok = 1;
gsurf_att *coloratt;
- G_debug (3, "gs_update_curmask():");
+ G_debug (4, "gs_update_curmask(): id=%d", surf->gsurf_id);
if (surf->mask_needupdate) {
surf->mask_needupdate = 0;
@@ -304,24 +304,24 @@
if (b_topo) {
- G_debug(3, " Update topo mask");
+ G_debug(4, "gs_update_curmask(): update topo mask");
gsbm_or_masks(surf->curmask, b_topo);
BM_destroy(b_topo);
if (b_color) {
- G_debug(3, " Update color mask");
+ G_debug(4, "gs_update_curmask(): update color mask");
gsbm_or_masks(surf->curmask, b_color);
BM_destroy(b_color);
if (t_topo->nm) {
- G_debug(3, " Update elev null mask");
+ G_debug(4, "gs_update_curmask(): update elev null mask");
gsbm_or_masks(surf->curmask, t_topo->nm);
if (b_mask) {
- G_debug(3, " Update mask mask");
+ G_debug(4, "gs_update_curmask(): update mask mask");
if (t_mask->bm) {
if (surf->att[ATT_MASK].constant) {
Modified: grass/trunk/lib/ogsf/gs_norms.c
--- grass/trunk/lib/ogsf/gs_norms.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gs_norms.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -141,7 +141,7 @@
init_vars(gs);
- G_debug (3, "recalculating normals...");
+ G_debug (4, "gs_calc_normals(): id=%d", gs->gsurf_id);
/* first row - just use single cell */
/* first col - use bottom & right neighbors */
@@ -158,7 +158,7 @@
/* now use four neighboring points for rows 1 - (n-1) */
for (row = 1; row < ycnt; row++) {
if (!(row % 100))
- G_debug (4, " row %d", row);
+ G_debug (4, "gs_calc_normals(): row=%d", row);
/* turn off left neighbor for first col */
calc_norm(gs, row * ymod, 0, ~NLFT);
@@ -195,9 +195,9 @@
and data row & col
\param gs surface (geosurf)
- \param drow
- \param dcol
- \param neighbors
+ \param drow data row
+ \param dcol data col
+ \param neighbors neighbors id
\return 0 no normals
Modified: grass/trunk/lib/ogsf/gsd_img_ppm.c
--- grass/trunk/lib/ogsf/gsd_img_ppm.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gsd_img_ppm.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -32,7 +32,7 @@
#include <grass/gstypes.h>
- \brief Write ppm file
+ \brief Save current GL screen to ppm file
\param name file name
@@ -49,7 +49,6 @@
gsd_getimage(&pixbuf, &xsize, &ysize);
if (NULL == (fp = fopen(name, "w"))) {
G_warning (_("Unable to open file <%s> for writing"),
name);
Modified: grass/trunk/lib/ogsf/gsd_prim.c
--- grass/trunk/lib/ogsf/gsd_prim.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gsd_prim.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -79,11 +79,11 @@
- \brief ADD
+ \brief Set color mode
Call glColorMaterial before enabling the GL_COLOR_MATERIAL
- \param cm
+ \param cm color mode value
void gsd_colormode(int cm)
@@ -221,7 +221,10 @@
\brief Write out z-mask
- \param n
+ Enable or disable writing into the depth buffer
+ \param n Specifies whether the depth buffer is enabled for
+ writing
void gsd_zwritemask(unsigned long n)
@@ -352,7 +355,7 @@
- \brief ADD
+ \brief Delimit the vertices of a primitive or a group of like primitives
void gsd_bgnpolygon(void)
@@ -367,7 +370,7 @@
- \brief ADD
void gsd_endpolygon(void)
@@ -397,9 +400,9 @@
- \brief Shaded model
+ \brief Set shaded model
- \param bool type
+ \param bool type non-zero for GL_SMOOTH otherwise GL_FLAT
void gsd_shademodel(int bool)
@@ -437,7 +440,10 @@
- \brief ADD
+ \brief Specify which color buffers are to be drawn
+ into
+ \param bool non-zero for enable otherwise disable front buffer
void gsd_frontbuffer(int bool)
@@ -448,9 +454,10 @@
- \brief ADD
+ into
- \param bool
+ \param bool non-zero for enable otherwise disable back buffer
void gsd_backbuffer(int bool)
@@ -460,7 +467,7 @@
- \brief ADD
+ \brief Swap buffers
void gsd_swapbuffers(void)
@@ -474,7 +481,7 @@
- \brief ADD
+ \brief Pop the current matrix stack
void gsd_popmatrix(void)
@@ -484,7 +491,7 @@
- \brief ADD
+ \brief Push the current matrix stack
void gsd_pushmatrix(void)
@@ -494,7 +501,11 @@
- \brief ADD
+ \brief Multiply the current matrix by a general scaling matrix
+ \param xs x scale value
+ \param ys y scale value
+ \param zs z scale value
void gsd_scale(float xs, float ys, float zs)
@@ -504,7 +515,11 @@
- \brief ADD
+ \brief Multiply the current matrix by a translation matrix
+ \param dx x translation value
+ \param dy y translation value
+ \param dz z translation value
void gsd_translate(float dx, float dy, float dz)
@@ -514,12 +529,12 @@
- \brief ADD
+ \brief Get viewport
- \param window
+ \param[out] window
\param viewport
- \param modelMatrix
- \param projMatrix
+ \param modelMatrix model matrix
+ \param projMatrix projection matrix
void gsd_getwindow(int *window, int *viewport, double *modelMatrix,
double *projMatrix)
@@ -623,11 +638,11 @@
- \brief ADD
+ \brief Set the current normal vector & specify vertex
- \param norm
- \param col
- \param pt
+ \param norm normal vector
+ \param col color value
+ \param pt point (model coordinates)
void gsd_litvert_func(float *norm, unsigned long col, float *pt)
@@ -666,9 +681,9 @@
- \brief ADD
+ \brief Set current color
- \param col
void gsd_color_func(unsigned int col)
@@ -866,7 +881,7 @@
- \brief Get image
+ \brief Get image of current GL screen
\param pixbuf data buffer
\param[out] xsize,ysize picture dimension
@@ -951,7 +966,7 @@
- \brief ADD
+ \brief Specify pixel arithmetic
\param yesno turn on/off
@@ -1026,12 +1041,17 @@
- \brief ADD
+ \brief Set the viewport
- \param l
- \param r
- \param b
- \param t
+ <i>l</i>, <i>b</i> specify the lower left corner of the viewport
+ rectangle, in pixels.
+ <i>r</i>, <i>t</i> specify the width and height of the viewport.
+ \param l left
+ \param r right
+ \param b bottom
+ \param t top
void gsd_viewport(int l, int r, int b, int t)
Modified: grass/trunk/lib/ogsf/gsd_surf.c
--- grass/trunk/lib/ogsf/gsd_surf.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gsd_surf.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -81,7 +81,7 @@
int desc, ret;
- G_debug (3, "gsd_surf");
+ G_debug (4, "gsd_surf(): id=%d", surf->gsurf_id);
desc = ATT_TOPO;
@@ -746,7 +746,7 @@
unsigned int ktrans = 255;
- G_debug(3, "gsd_surf_const");
+ G_debug(4, "gsd_surf_const(): id=%d", surf->gsurf_id);
if (GS_check_cancel()) {
return (-1);
@@ -2038,10 +2038,8 @@
- \brief ADD
+ \brief Draw surface using triangle fan instead of strip
- New (TEST) surface drawing routine using triangle fan instead of strip
Optimized by getting rid of BM_get mask check - GET_MAPPATT does same
and returns zero if masked
Modified: grass/trunk/lib/ogsf/gsd_views.c
--- grass/trunk/lib/ogsf/gsd_views.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gsd_views.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -276,9 +276,9 @@
- \brief ADD
+ \brief Set current scale
- \param doexag
void gsd_do_scale(int doexag)
Modified: grass/trunk/lib/ogsf/gsd_wire.c
--- grass/trunk/lib/ogsf/gsd_wire.c 2008-06-02 19:19:55 UTC (rev 31611)
+++ grass/trunk/lib/ogsf/gsd_wire.c 2008-06-02 19:23:33 UTC (rev 31612)
@@ -38,7 +38,7 @@
- \brief ADD
\param surf surface (geosurf)
@@ -48,7 +48,7 @@
int desc, ret;
- G_debug(3, "gsd_wire_surf");
+ G_debug(3, "gsd_wire_surf(): id=%d", surf->gsurf_id);
desc = ATT_TOPO;
@@ -552,7 +552,7 @@
- \brief ADD
+ \brief Draw coarse surface
New (TEST) wire routine that draws low res surface
Based on new Trinagle Fan routine
