[GRASS-SVN] r31614 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Tue Jun 3 07:34:30 EDT 2008
Author: neteler
Date: 2008-06-03 07:34:30 -0400 (Tue, 03 Jun 2008)
New Revision: 31614
grass/trunk/imagery/i.atcorr/main.cpp
mapset support fixed
Modified: grass/trunk/imagery/i.atcorr/main.cpp
--- grass/trunk/imagery/i.atcorr/main.cpp 2008-06-03 04:37:20 UTC (rev 31613)
+++ grass/trunk/imagery/i.atcorr/main.cpp 2008-06-03 11:34:30 UTC (rev 31614)
@@ -70,11 +70,11 @@
int mis = 0;
/* function prototypes */
-static void adjust_region (char *);
+static void adjust_region (char *, char *);
static CELL round_c (FCELL);
static void write_fp_to_cell (int, FCELL *);
static void process_raster (int, InputMask, ScaleRange, int, int, int, bool, ScaleRange, bool);
-static void copy_colors (char *, char *);
+static void copy_colors (char *, char *, char *);
static void define_module (void);
static struct Options define_options (void);
static void read_scale (Option *, ScaleRange *);
@@ -85,11 +85,11 @@
Atmospheric corrections should be done on the whole
satelite image, not just portions.
-static void adjust_region (char *name)
+static void adjust_region (char *name, char *mapset)
struct Cell_head iimg_head; /* the input image header file */
- if(G_get_cellhd(name, G_mapset(), &iimg_head) < 0)
+ if(G_get_cellhd(name, mapset, &iimg_head) < 0)
G_fatal_error ("Unable to retreive header dat for input image");
if(G_set_window(&iimg_head) < 0)
@@ -388,11 +388,11 @@
/* Copy the colors from map named iname to the map named oname */
-static void copy_colors (char *iname, char *oname)
+static void copy_colors (char *iname, char *imapset, char *oname)
struct Colors colors;
- G_read_colors(iname, G_mapset(), &colors);
+ G_read_colors(iname, imapset, &colors);
G_write_colors(oname, G_mapset(), &colors);
@@ -403,10 +403,10 @@
struct GModule *module;
module = G_define_module();
- module->label = "Performs atmospheric correction using the 6S algorithm.";
+ module->label = _("Performs atmospheric correction using the 6S algorithm.");
module->description =
- "6S - Second Simulation of Satellite Signal in the Solar Spectrum.";/*
+ _("6S - Second Simulation of Satellite Signal in the Solar Spectrum.");
" Incorporated into Grass by Christo A. Zietsman, January 2003.\n"
" Converted from Fortran to C by Christo A. Zietsman, November 2002.\n\n"
" Adapted by Mauro A. Homem Antunes for atmopheric corrections of\n"
@@ -538,7 +538,7 @@
int oimg_fd; /* output image's file descriptor */
int ialt_fd = -1; /* input elevation map's file descriptor */
int ivis_fd = -1; /* input visibility map's file descriptor */
+ char *iimg_mapset, *ialt_mapset, *iviz_mapset;
/* Define module */
define_module();
@@ -551,19 +551,27 @@
if (G_parser(argc, argv) < 0)
exit (EXIT_FAILURE);
- adjust_region(opts.iimg->answer);
/* open input raster */
- if((iimg_fd = G_open_cell_old(opts.iimg->answer, G_mapset())) < 0)
+ if ( (iimg_mapset = G_find_cell2 ( opts.iimg->answer, "") ) == NULL )
+ G_fatal_error ( _("Raster map <%s> not found"), opts.iimg->answer);
+ if((iimg_fd = G_open_cell_old(opts.iimg->answer, iimg_mapset)) < 0)
G_fatal_error ("Unable to open input raster");
+ adjust_region(opts.iimg->answer, iimg_mapset);
- if(opts.ialt->answer)
- if((ialt_fd = G_open_cell_old(opts.ialt->answer, G_mapset())) < 0)
+ if(opts.ialt->answer) {
+ if ( (ialt_mapset = G_find_cell2 ( opts.ialt->answer, "") ) == NULL )
+ G_fatal_error ( _("Raster map <%s> not found"), opts.ialt->answer);
+ if((ialt_fd = G_open_cell_old(opts.ialt->answer, ialt_mapset)) < 0)
G_warning ("Unable to open DEM raster");
- if(opts.ivis->answer)
- if((ivis_fd = G_open_cell_old(opts.ivis->answer, G_mapset())) < 0)
+ if(opts.ivis->answer) {
+ if ( (iviz_mapset = G_find_cell2 ( opts.ivis->answer, "") ) == NULL )
+ G_fatal_error ( _("Raster map <%s> not found"), opts.ivis->answer);
+ if((ivis_fd = G_open_cell_old(opts.ivis->answer, iviz_mapset)) < 0)
G_warning ("Unable to open visibility raster");
/* open a floating point raster or not? */
if(opts.oflt->answer)
@@ -604,7 +612,7 @@
/* Copy the colors of the input raster to the output raster.
Scaling is ignored and color ranges might not be correct. */
- copy_colors(opts.iimg->answer, opts.oimg->answer);
+ copy_colors(opts.iimg->answer, iimg_mapset, opts.oimg->answer);
exit (EXIT_SUCCESS);
