[GRASS-SVN] r31636 - grass/branches/develbranch_6/raster
svn_grass at osgeo.org
Thu Jun 5 07:41:23 EDT 2008
Author: neteler
Date: 2008-06-05 07:41:23 -0400 (Thu, 05 Jun 2008)
New Revision: 31636
grass/branches/develbranch_6/raster/rasterintro.html
notes on export and resampling (merge from trunk)
Modified: grass/branches/develbranch_6/raster/rasterintro.html
--- grass/branches/develbranch_6/raster/rasterintro.html 2008-06-05 11:40:47 UTC (rev 31635)
+++ grass/branches/develbranch_6/raster/rasterintro.html 2008-06-05 11:41:23 UTC (rev 31636)
@@ -63,8 +63,19 @@
<P>
Raster maps are exported with <a href="r.out.gdal.html">r.out.gdal</a>
into common formats. Also <a href="r.out.bin.html">r.out.bin</a>,
-<a href="r.out.vtk.html">r.out.vtk</a> and other export modules are
-available.
+<a href="r.out.vtk.html">r.out.vtk</a>, <a href="r.out.ascii.html">r.out.ascii</a>
+and other export modules are available. They export the data according
+to the current region settings. If those differ from the original map,
+the map is resampled on the fly (nearest neighbor algorithm). In other
+words, the output will have as many rows and columns as the current region.
+To export maps with various grid spacings(e.g, 500x500 or 200x500), you
+can just change the region resolution with <a href="g.region.html">g.region</a>
+and then export the map. The resampling is done with nearest neighbor
+algorithm in this case. If you want some other form of resampling,
+first change the region, then explicitly resample the map with e.g.
+<a href="r.resamp.interp.html">r.resamp.interp</a> or
+<a href="r.resamp.stats.html">r.resamp.stats</a>, then export the
+resampled map.
<h3>Metadata</h3>
