[GRASS-SVN] r31639 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Jun 5 15:23:59 EDT 2008
Author: martinl
Date: 2008-06-05 15:23:59 -0400 (Thu, 05 Jun 2008)
New Revision: 31639
grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
wxGUI: statusbar mode for displays added to preferences
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2008-06-05 18:36:25 UTC (rev 31638)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py 2008-06-05 19:23:59 UTC (rev 31639)
@@ -83,6 +83,14 @@
MAP_WINDOW_SIZE = (680, 520)
HIST_WINDOW_SIZE = (500, 350)
+MAP_DISPLAY_STATUSBAR_MODE = [_("Coordinates"),
+ _("Extent"),
+ _("Comp. region"),
+ _("Show comp. extent"),
+ _("Display mode"),
+ _("Display geometry"),
+ _("Map scale")]
"""File name extension binaries/scripts"""
if subprocess.mswindows:
EXT_BIN = '.exe'
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-06-05 18:36:25 UTC (rev 31638)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-06-05 19:23:59 UTC (rev 31639)
@@ -2318,14 +2318,8 @@
self.statusbar = self.CreateStatusBar(number=3, style=0)
self.statusbar.SetStatusWidths([-5, -2, -1])
self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
- choices = [_("Coordinates"),
- _("Extent"),
- _("Comp. region"),
- _("Show comp. extent"),
- _("Display mode"),
- _("Display geometry"),
- _("Map scale")])
- self.toggleStatus.SetSelection(0)
+ choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+ self.toggleStatus.SetSelection(UserSettings.Get(group='display', key='statusbarMode', subkey='selection'))
self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.toggleStatus)
# auto-rendering checkbox
self.autoRender = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-06-05 18:36:25 UTC (rev 31638)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py 2008-06-05 19:23:59 UTC (rev 31639)
@@ -35,6 +35,7 @@
import gcmd
import grassenv
import utils
+import globalvar
from debug import Debug as Debug
class Settings:
@@ -73,6 +74,7 @@
'driver': { 'type': 'default' },
'compResolution' : { 'enabled' : False },
'autoRendering': { 'enabled' : False },
+ 'statusbarMode': { 'selection' : 0 },
# advanced
@@ -232,6 +234,7 @@
'verbose',
'quiet']
self.internalSettings['display']['driver']['choices'] = ['default']
+ self.internalSettings['display']['statusbarMode']['choices'] = globalvar.MAP_DISPLAY_STATUSBAR_MODE
def GetMapsetPath(self):
"""Store mapset search path"""
@@ -653,9 +656,29 @@
- # display mode (use computation resolution?)
+ # Statusbar mode
row += 1
+ gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Statusbar mode:")),
+ flag=wx.ALIGN_LEFT |
+ wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 0))
+ listOfModes = self.settings.Get(group='display', key='statusbarMode', subkey='choices', internal=True)
+ statusbarMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(150, -1),
+ choices=listOfModes,
+ name="GetSelection")
+ statusbarMode.SetSelection(self.settings.Get(group='display', key='statusbarMode', subkey='selection'))
+ self.winId['display:statusbarMode:selection'] = statusbarMode.GetId()
+ gridSizer.Add(item=statusbarMode,
+ flag=wx.ALIGN_RIGHT,
+ pos=(row, 1))
+ # Use computation resolution
+ row += 1
compResolution = wx.CheckBox(parent=panel, id=wx.ID_ANY,
label=_("Constrain display resolution to computational settings"),
name="IsChecked")
@@ -1078,6 +1101,7 @@
value = win.GetStringSelection()
else:
value = win.GetValue()
self.settings.Set(group, key, subkey, value)
