[GRASS-SVN] r31649 - grass-addons/visualization/nviz2/cmd
Fri Jun 6 11:43:45 EDT 2008
Author: martinl
Date: 2008-06-06 11:43:45 -0400 (Fri, 06 Jun 2008)
New Revision: 31649
   grass-addons/visualization/nviz2/cmd/args.c
   grass-addons/visualization/nviz2/cmd/change_view.c
   grass-addons/visualization/nviz2/cmd/local_proto.h
   grass-addons/visualization/nviz2/cmd/main.c
nviz2/cmd: parameter for 'vertical exaggeration' added
Modified: grass-addons/visualization/nviz2/cmd/args.c
--- grass-addons/visualization/nviz2/cmd/args.c	2008-06-06 15:03:37 UTC (rev 31648)
+++ grass-addons/visualization/nviz2/cmd/args.c	2008-06-06 15:43:45 UTC (rev 31649)
@@ -38,6 +38,16 @@
     params->elev->description = _("Name of raster map(s) for elevation");
     params->elev->guisection = _("Raster");
+    params->exag = G_define_option();
+    params->exag->key = "exag";
+    params->exag->key_desc = "value";
+    params->exag->type = TYPE_DOUBLE;
+    params->exag->required = NO;
+    params->exag->multiple = NO;
+    params->exag->description = _("Vertical exaggeration");
+    params->exag->answer = "1.0";
+    params->exag->options = "0-10";
     params->pos = G_define_option();
     params->pos->key = "position";
     params->pos->key_desc = "x,y";
Modified: grass-addons/visualization/nviz2/cmd/change_view.c
--- grass-addons/visualization/nviz2/cmd/change_view.c	2008-06-06 15:03:37 UTC (rev 31648)
+++ grass-addons/visualization/nviz2/cmd/change_view.c	2008-06-06 15:43:45 UTC (rev 31649)
@@ -178,3 +178,27 @@
     GS_alldraw_wire();
     GS_done_draw();
+  \brief Change z-exag value
+  \param data nviz data
+  \param exag exag value
+  \return 1
+int change_exag(nv_data *data, float exag)
+    float temp;
+    temp = GS_global_exag();
+    if (exag != temp) {
+	GS_set_global_exag(exag);
+	update_ranges(data);
+	draw_quick(data);
+    return 1;
Modified: grass-addons/visualization/nviz2/cmd/local_proto.h
--- grass-addons/visualization/nviz2/cmd/local_proto.h	2008-06-06 15:03:37 UTC (rev 31648)
+++ grass-addons/visualization/nviz2/cmd/local_proto.h	2008-06-06 15:43:45 UTC (rev 31649)
@@ -7,6 +7,7 @@
 /* module flags and parameters */
 struct GParams {
   struct Option *elev, /* data */
+    *exag, /* misc */
     *pos, *height, *persp, *twist; /* viewpoint */
@@ -27,6 +28,7 @@
 int viewpoint_set_persp(nv_data *, int);
 int viewpoint_set_twist(nv_data *, int);
 void resize_window(int, int);
+int change_exag(nv_data *, float);
 /* draw.c */
 int draw_all_surf(nv_data *);
Modified: grass-addons/visualization/nviz2/cmd/main.c
--- grass-addons/visualization/nviz2/cmd/main.c	2008-06-06 15:03:37 UTC (rev 31648)
+++ grass-addons/visualization/nviz2/cmd/main.c	2008-06-06 15:43:45 UTC (rev 31649)
@@ -92,6 +92,8 @@
     GS_init_view();
     viewpoint_set_height(&data,
 			 atof(params->height->answer));
+    change_exag(&data,
+		atof(params->exag->answer));
     viewpoint_set_position(&data,
 			   atof(params->pos->answers[0]),
 			   atof(params->pos->answers[1]));
