[GRASS-SVN] r31668 - grass-addons/visualization/nviz2/cmd
svn_grass at osgeo.org
Tue Jun 10 09:39:02 EDT 2008
Author: martinl
Date: 2008-06-10 09:39:02 -0400 (Tue, 10 Jun 2008)
New Revision: 31668
Added:
grass-addons/visualization/nviz2/cmd/description.html
grass-addons/visualization/nviz2/cmd/position.c
grass-addons/visualization/nviz2/cmd/args.c
grass-addons/visualization/nviz2/cmd/local_proto.h
grass-addons/visualization/nviz2/cmd/main.c
grass-addons/visualization/nviz2/cmd/map_obj.c
grass-addons/visualization/nviz2/cmd/nviz.c
grass-addons/visualization/nviz2/cmd/nviz.h
nviz_cmd: color_map/value option added
template for manual page created
Modified: grass-addons/visualization/nviz2/cmd/args.c
--- grass-addons/visualization/nviz2/cmd/args.c 2008-06-10 11:52:51 UTC (rev 31667)
+++ grass-addons/visualization/nviz2/cmd/args.c 2008-06-10 13:39:02 UTC (rev 31668)
@@ -38,8 +38,22 @@
params->elev->description = _("Name of raster map(s) for elevation");
params->elev->guisection = _("Raster");
+ params->color_map = G_define_standard_option(G_OPT_R_MAP);
+ params->color_map->multiple = YES;
+ params->color_map->required = NO;
+ params->color_map->description = _("Name of raster map(s) for color");
+ params->color_map->guisection = _("Raster");
+ params->color_map->key = "color_map";
+ params->color_const = G_define_standard_option(G_OPT_C_FG);
+ params->color_const->multiple = YES;
+ params->color_const->label = _("Color value");
+ params->color_const->guisection = _("Raster");
+ params->color_const->key = "color_value";
+ params->color_const->answer = NULL;
params->exag = G_define_option();
- params->exag->key = "exag";
+ params->exag->key = "zexag";
params->exag->key_desc = "value";
params->exag->type = TYPE_DOUBLE;
params->exag->required = NO;
@@ -48,6 +62,9 @@
params->exag->answer = "1.0";
params->exag->options = "0-10";
+ params->bgcolor = G_define_standard_option(G_OPT_C_BG);
+ /* viewpoint */
params->pos = G_define_option();
params->pos->key = "position";
params->pos->key_desc = "x,y";
@@ -95,3 +112,23 @@
return;
+ \brief Get color value from color string (name or RGB triplet)
+ \param color_str color string
+ \return color value
+int color_from_cmd(const char *color_str)
+ int red, grn, blu;
+ if (G_str_to_color(color_str, &red, &grn, &blu) != 1) {
+ G_warning (_("Invalid color (%s), using \"white\" as default"),
+ color_str);
+ red = grn = blu = 255;
+ return (red & RED_MASK) + ((int)((grn) << 8) & GRN_MASK) + ((int)((blu) << 16) & BLU_MASK);
Added: grass-addons/visualization/nviz2/cmd/description.html
--- grass-addons/visualization/nviz2/cmd/description.html (rev 0)
+++ grass-addons/visualization/nviz2/cmd/description.html 2008-06-10 13:39:02 UTC (rev 31668)
@@ -0,0 +1,19 @@
+<h2>DESCRIPTION</h2>
+Experimental CLI prototype of NVIZ.
+<p>
+TODO
+<h2>SEE ALSO</h2>
+<em>
+<a HREF="nviz.html">TCL/TK-based NVIZ</a>
+</em>
+<h2>AUTHOR</h2>
+Martin Landa (Google Summer of Code 2008)
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/visualization/nviz2/cmd/description.html
___________________________________________________________________
+ text/html
+ Author Date Id
+ native
Modified: grass-addons/visualization/nviz2/cmd/local_proto.h
--- grass-addons/visualization/nviz2/cmd/local_proto.h 2008-06-10 11:52:51 UTC (rev 31667)
+++ grass-addons/visualization/nviz2/cmd/local_proto.h 2008-06-10 13:39:02 UTC (rev 31668)
@@ -6,13 +6,14 @@
/* module flags and parameters */
struct GParams {
- struct Option *elev, /* data */
- *exag, /* misc */
+ struct Option *elev, *color_map, *color_const, /* data */
+ *exag, *bgcolor, /* misc */
*pos, *height, *persp, *twist; /* viewpoint */
/* args.c */
void parse_command(int, char**, struct GParams *);
+int color_from_cmd(const char *);
/* cplanes_obj.c */
int cplane_new(nv_data *, int);
@@ -38,12 +39,13 @@
/* map_obj.c */
int new_map_obj(int, const char *,
nv_data *);
-int set_attr(int, int, int, int, const char *,
+int set_attr(int, int, int, int, const char *, float,
nv_data *);
void set_att_default();
/* nviz.c */
void nv_data_init(nv_data *);
+void nv_data_set_bgcolor(nv_data *, int);
/* lights.c */
int light_set_position(nv_data *, int,
@@ -56,6 +58,11 @@
int light_init(nv_data *, int);
int light_new(nv_data *);
+/* position.c */
+void init_view();
+int focus_set_state(int);
+int focus_set_map(int, int);
/* render.c */
void render_window_init(render_window *);
int render_window_create(render_window *, int, int);
Modified: grass-addons/visualization/nviz2/cmd/main.c
--- grass-addons/visualization/nviz2/cmd/main.c 2008-06-10 11:52:51 UTC (rev 31667)
+++ grass-addons/visualization/nviz2/cmd/main.c 2008-06-10 13:39:02 UTC (rev 31668)
@@ -5,6 +5,7 @@
* AUTHOR(S): Martin Landa <landa.martin gmail.com>
* PURPOSE: Experimental NVIZ CLI prototype
+ * Google SoC 2008
* COPYRIGHT: (C) 2008 by the GRASS Development Team
@@ -31,6 +32,7 @@
char *mapset;
unsigned int i;
int id;
+ unsigned int nelev, ncolor_map, ncolor_const;
nv_data data;
render_window offscreen;
@@ -61,8 +63,20 @@
nv_data_init(&data);
/* define default attributes for map objects */
set_att_default();
+ /* set background color */
+ nv_data_set_bgcolor(&data, color_from_cmd(params->bgcolor->answer));
/* load data */
+ nelev = ncolor_map = ncolor_const = 0;
+ i = 0;
+ while(params->color_map->answer && params->color_map->answers[i++])
+ ncolor_map++;
+ i = 0;
+ while(params->color_const->answer && params->color_const->answers[i++])
+ ncolor_const++;
if (params->elev->answers) {
for (i = 0; params->elev->answers[i]; i++) {
mapset = G_find_cell2 (params->elev->answers[i], "");
@@ -76,20 +90,72 @@
G_fully_qualified_name(params->elev->answers[i], mapset),
&data);
- /* color TODO: option */
- set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
- G_fully_qualified_name(params->elev->answers[i], mapset),
- &data);
+ if (i < ncolor_map) { /* check for color map */
+ mapset = G_find_cell2 (params->color_map->answers[i], "");
+ if (mapset == NULL) {
+ G_fatal_error(_("Raster map <%s> not found"),
+ params->color_map->answers[i]);
+ set_attr(id, MAP_OBJ_SURF, ATT_COLOR, MAP_ATT,
+ G_fully_qualified_name(params->color_map->answers[i], mapset), -1.0,
+ &data);
+ else if (i < ncolor_const) { /* check for color value */
+ set_attr(id, MAP_OBJ_SURF, ATT_COLOR, CONST_ATT,
+ NULL, color_from_cmd(params->color_const->answers[i]),
+ &data);
+ else { /* use by default elevation map for coloring */
+ G_fully_qualified_name(params->elev->answers[i], mapset), -1.0,
+ &data);
if (i > 1)
set_default_wirecolors(data, i);
+ nelev++;
+ /* init view */
+ init_view();
+ focus_set_map(MAP_OBJ_UNDEFINED, -1);
+ /* set lights */
+ /* TODO: add options */
+ light_set_position(&data, 0,
+ 0.68, -0.68, 0.80, 0.0);
+ light_set_bright(&data, 0,
+ 0.8);
+ light_set_color(&data, 0,
+ 1.0, 1.0, 1.0);
+ light_set_ambient(&data, 0,
+ 0.2, 0.2, 0.2);
+ light_set_position(&data, 1,
+ light_set_bright(&data, 1,
+ 0.8);
+ light_set_color(&data, 1,
+ 1.0, 1.0, 1.0);
+ light_set_ambient(&data, 1,
+ 0.2, 0.2, 0.2);
+ 0.0, 0.0, 1.0, 0.0);
+ 0.5);
+ 1.0, 1.0, 1.0);
+ 0.3, 0.3, 0.3);
/* define view point */
- GS_init_view();
viewpoint_set_height(&data,
atof(params->height->answer));
change_exag(&data,
@@ -103,42 +169,15 @@
atoi(params->persp->answer));
- /* resize_window(400, 400); */
+ // resize_window(600, 480);
- light_set_position(&data, 0,
- 0.68, -0.68, 0.80, 0.0);
- light_set_position(&data, 1,
- light_set_position(&data, 2,
- 0.0, 0.0, 1.0, 0.0);
- light_set_bright(&data, 0,
- 0.8);
- light_set_bright(&data, 1,
- 0.8);
- light_set_bright(&data, 2,
- 0.5);
- light_set_color(&data, 0,
- 1.0, 1.0, 1.0);
- light_set_color(&data, 1,
- 1.0, 1.0, 1.0);
- light_set_color(&data, 2,
- 1.0, 1.0, 1.0);
- light_set_ambient(&data, 0,
- 0.2, 0.2, 0.2);
- light_set_ambient(&data, 1,
- 0.2, 0.2, 0.2);
- light_set_ambient(&data, 2,
- 0.3, 0.3, 0.3);
GS_clear(data.bgcolor);
+ /* draw */
cplane_draw(&data, -1, -1);
draw_all (&data);
- write_ppm("test.ppm");
+ write_ppm("test.ppm"); /* TODO: option 'format' */
render_window_destroy(&offscreen);
Modified: grass-addons/visualization/nviz2/cmd/map_obj.c
--- grass-addons/visualization/nviz2/cmd/map_obj.c 2008-06-10 11:52:51 UTC (rev 31667)
+++ grass-addons/visualization/nviz2/cmd/map_obj.c 2008-06-10 13:39:02 UTC (rev 31668)
@@ -82,14 +82,14 @@
if (name) {
/* map */
- if (!set_attr(new_id, MAP_OBJ_SURF, ATT_TOPO, MAP_ATT, name,
+ if (!set_attr(new_id, MAP_OBJ_SURF, ATT_TOPO, MAP_ATT, name, -1.0,
data)) {
return -1;
else {
/* constant */
- if (!set_attr(new_id, MAP_OBJ_SURF, ATT_TOPO, CONST_ATT, "0",
+ if (!set_attr(new_id, MAP_OBJ_SURF, ATT_TOPO, CONST_ATT, NULL, 0.0,
data)) {
return -1;
@@ -136,12 +136,14 @@
\param type map object type (MAP_OBJ_SURF, MAP_OBJ_VECT, ...)
\param desc attribute descriptors
\param src attribute sources
- \param str_value attribute value as string
+ \param str_value attribute value as string (if NULL, check for <i>num_value</i>)
+ \param num_value attribute value as float
\return 1 on success
\return 0 on failure
-int set_attr(int id, int type, int desc, int src, const char *str_value,
+int set_attr(int id, int type, int desc, int src,
+ const char *str_value, float num_value,
nv_data *data)
int ret;
@@ -157,7 +159,10 @@
/* Get the value for the constant
* Note that we require the constant to be an integer
- value = (float) atof(str_value);
+ if (str_value)
+ value = (float) atof(str_value);
+ else
+ value = num_value;
/* Only special case is setting constant color.
* In this case we have to decode the constant Tcl
@@ -165,13 +170,14 @@
if (desc == ATT_COLOR) {
/* TODO check this - sometimes gets reversed when save state
- saves a surface with constant color */
- /* Tcl code and C code reverse RGB to BGR (sigh) */
+ saves a surface with constant color
int r, g, b;
- r = (((int) value) & 0xff0000) >> 16;
- g = (((int) value) & 0x00ff00) >> 8;
- b = (((int) value) & 0x0000ff);
+ r = (((int) value) & RED_MASK) >> 16;
+ g = (((int) value) & GRN_MASK) >> 8;
+ b = (((int) value) & BLU_MASK);
value = r + (g << 8) + (b << 16);
/* Once the value is parsed, set it */
Modified: grass-addons/visualization/nviz2/cmd/nviz.c
--- grass-addons/visualization/nviz2/cmd/nviz.c 2008-06-10 11:52:51 UTC (rev 31667)
+++ grass-addons/visualization/nviz2/cmd/nviz.c 2008-06-10 13:39:02 UTC (rev 31668)
@@ -37,8 +37,6 @@
cplane_off(data, i);
- data->bgcolor = 16777215; /* TODO: option bgcolor */
/* lights */
for (i = 0; i < MAX_LIGHTS; i++) {
light_new(data);
@@ -46,3 +44,15 @@
return;
+ \brief Set background color
+ \param color color value
+void nv_data_set_bgcolor(nv_data *data, int color)
+ data->bgcolor = color;
+ return;
Modified: grass-addons/visualization/nviz2/cmd/nviz.h
--- grass-addons/visualization/nviz2/cmd/nviz.h 2008-06-10 11:52:51 UTC (rev 31667)
+++ grass-addons/visualization/nviz2/cmd/nviz.h 2008-06-10 13:39:02 UTC (rev 31668)
@@ -3,7 +3,9 @@
#include <grass/gsurf.h>
+#define MAP_OBJ_UNDEFINED 0
#define MAP_OBJ_SURF 1
+#define MAP_OBJ_VOL 2
#define RANGE (5 * GS_UNIT_SIZE)
#define RANGE_OFFSET (2 * GS_UNIT_SIZE)
@@ -12,6 +14,10 @@
#define DEFAULT_SURF_COLOR 0x33BBFF
+#define RED_MASK 0x000000FF
+#define GRN_MASK 0x0000FF00
+#define BLU_MASK 0x00FF0000
/* data structures */
typedef struct{
int id;
Added: grass-addons/visualization/nviz2/cmd/position.c
--- grass-addons/visualization/nviz2/cmd/position.c (rev 0)
+++ grass-addons/visualization/nviz2/cmd/position.c 2008-06-10 13:39:02 UTC (rev 31668)
@@ -0,0 +1,108 @@
+ \file position.c
+ \brief Position, focus settings
+ COPYRIGHT: (C) 2008 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ Based on visualization/nviz/src/position.c
+ \author Updated/modified by Martin Landa <landa.martin gmail.com>
+ \date 2008
+#include <grass/gsurf.h>
+#include <grass/gstypes.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+ Initialize view and position settings (focus)
+ Set position to center of view
+void init_view()
+ GS_init_view();
+ focus_set_state(1); /* center of view */
+ return;
+ \brief Set focus state
+ \param state_flag 1 for center view, 0 use viewdir
+ \return 1 on success
+ \return 0 on failure
+int focus_set_state(int state_flag)
+ if (state_flag == 1)
+ GS_set_infocus(); /* return center of view */
+ else if (state_flag == 0)
+ GS_set_nofocus(); /* no center of view -- use viewdir */
+ else {
+ G_warning (_("Unable to set focus"));
+ return 0;
+ return 1;
+ \brief Set focus based on loaded map
+ If <i>map</i> is MAP_OBJ_UNDEFINED, set focus from first
+ surface/volume in the list.
+ \param type map object type
+ \param id map object id
+ \return 0 on no focus
+ \return id id of map object used for setting focus
+int focus_set_map(int type, int id)
+ if (GS_num_surfs() < 0 && GVL_num_vols() < 0) {
+ GS_set_nofocus();
+ return 0;
+ if (type == MAP_OBJ_UNDEFINED) {
+ int *surf_list, num_surfs, *vol_list;
+ if (GS_num_surfs() > 0) {
+ surf_list = GS_get_surf_list(&num_surfs);
+ id = surf_list[0];
+ G_free (surf_list);
+ GS_set_focus_center_map(id);
+ if (GVL_num_vols() > 0) {
+ vol_list = GVL_get_vol_list(&num_surfs);
+ id = vol_list[0];
+ G_free (vol_list);
+ GVL_set_focus_center_map(id);
+ return id;
+ if (type == MAP_OBJ_SURF) {
+ else if (type == MAP_OBJ_VOL) {
+ return id;
Property changes on: grass-addons/visualization/nviz2/cmd/position.c
+ text/x-csrc
+ Author Date Id
+ native
