[GRASS-SVN] r31671 - grass/branches/develbranch_6/general/g.proj
svn_grass at osgeo.org
Tue Jun 10 10:44:46 EDT 2008
Author: pkelly
Date: 2008-06-10 10:44:46 -0400 (Tue, 10 Jun 2008)
New Revision: 31671
grass/branches/develbranch_6/general/g.proj/description.html
grass/branches/develbranch_6/general/g.proj/input.c
grass/branches/develbranch_6/general/g.proj/local_proto.h
grass/branches/develbranch_6/general/g.proj/main.c
Update to support changed behaviour in GDAL wrt PROJ.4 +init=
parameters (merge from trunk)
Modified: grass/branches/develbranch_6/general/g.proj/description.html
--- grass/branches/develbranch_6/general/g.proj/description.html 2008-06-10 13:43:45 UTC (rev 31670)
+++ grass/branches/develbranch_6/general/g.proj/description.html 2008-06-10 14:44:46 UTC (rev 31671)
@@ -142,7 +142,7 @@
900913 (<a href="http://spatialreference.org/ref/user/6/">Google Mercator Projection</a>)<br>
<div class="code"><pre>
-g.proj -c proj4="+init=epsg:900913" loc=google
+g.proj -c epsg=900913 loc=google
</pre></div>
<p>
Modified: grass/branches/develbranch_6/general/g.proj/input.c
--- grass/branches/develbranch_6/general/g.proj/input.c 2008-06-10 13:43:45 UTC (rev 31670)
+++ grass/branches/develbranch_6/general/g.proj/input.c 2008-06-10 14:44:46 UTC (rev 31671)
@@ -143,8 +143,44 @@
return ret;
+ * \brief Read projection information corresponding to an EPSG co-ordinate
+ * system number
+ * Determines projection information corresponding to an EPSG co-ordinate
+ * system number and stores in global structs projinfo and projunits.
+ * Populates global cellhd with default region information.
+ * \param epsg_num EPSG number for co-ordinate system
+ * \return 2 if a projected or lat/long co-ordinate system has been
+ * defined; 1 if an unreferenced XY co-ordinate system has
+ * been defined
+int input_epsg(int epsg_num)
+ OGRSpatialReferenceH hSRS;
+ int ret = 0;
+ /* Set finder function for locating OGR csv co-ordinate system tables */
+ SetCSVFilenameHook( GPJ_set_csv_loc );
+ hSRS = OSRNewSpatialReference(NULL);
+ if (OSRImportFromEPSG(hSRS, epsg_num) != OGRERR_NONE)
+ G_fatal_error(_("Unable to translate EPSG code"));
+ ret = GPJ_osr_to_grass(&cellhd, &projinfo, &projunits, hSRS, 0);
+ OSRDestroySpatialReference(hSRS);
+ set_default_region();
+ return ret;
* \brief Read projection and region information associated with a
* georeferenced file
Modified: grass/branches/develbranch_6/general/g.proj/local_proto.h
--- grass/branches/develbranch_6/general/g.proj/local_proto.h 2008-06-10 13:43:45 UTC (rev 31670)
+++ grass/branches/develbranch_6/general/g.proj/local_proto.h 2008-06-10 14:44:46 UTC (rev 31671)
@@ -11,6 +11,7 @@
void input_currloc(void);
int input_wkt(char *);
int input_proj4(char *);
+int input_epsg(int);
int input_georef(char *);
/* output.c */
Modified: grass/branches/develbranch_6/general/g.proj/main.c
--- grass/branches/develbranch_6/general/g.proj/main.c 2008-06-10 13:43:45 UTC (rev 31670)
+++ grass/branches/develbranch_6/general/g.proj/main.c 2008-06-10 14:44:46 UTC (rev 31671)
@@ -195,12 +195,9 @@
else if (inproj4->answer)
/* Input in PROJ.4 format */
input_proj4(inproj4->answer);
- else if (inepsg->answer) {
+ else if (inepsg->answer)
/* Input from EPSG code */
- char buffer[64];
- sprintf(buffer, "+init=epsg:%s", inepsg->answer);
- input_proj4(buffer);
+ input_epsg(atoi(inepsg->answer));
else
/* Input from georeferenced file */
input_georef(ingeo->answer);
