[GRASS-SVN] r31678 - grass/trunk/lib/ogsf
svn_grass at osgeo.org
Wed Jun 11 09:35:35 EDT 2008
Author: martinl
Date: 2008-06-11 09:35:34 -0400 (Wed, 11 Jun 2008)
New Revision: 31678
grass/trunk/lib/ogsf/gv.c
ogsflib: missing doxygen strings added (gv.c)
(merge devbr6, r31677)
Modified: grass/trunk/lib/ogsf/gv.c
--- grass/trunk/lib/ogsf/gv.c 2008-06-11 13:32:14 UTC (rev 31677)
+++ grass/trunk/lib/ogsf/gv.c 2008-06-11 13:35:34 UTC (rev 31678)
@@ -1,7 +1,7 @@
\file gv.c
- \brief OGSF library - loading and manipulating vector sets
+ \brief OGSF library - loading and manipulating vector sets (lower level functions)
GRASS OpenGL gsurf OGSF Library
@@ -13,6 +13,7 @@
for details.
\author Bill Brown USACERL (November 1993)
+ \author Doxygenized by Martin Landa (June 2008)
#include <stdio.h>
@@ -25,16 +26,19 @@
static geovect *Vect_top = NULL;
+ \brief Get vector set
+ \param id vector set id
+ \return pointer to geovect struct
+ \return NULL on failure
geovect *gv_get_vect(int id)
geovect *gv;
-#ifdef TRACE_FUNCS
- Gs_status("gv_get_vect");
-#endif
+ G_debug(4, "gv_get_vect() id=%d", id);
for (gv = Vect_top; gv; gv = gv->next) {
if (gv->gvect_id == id) {
@@ -45,16 +49,19 @@
return (NULL);
+ \brief Get previous vector set
geovect *gv_get_prev_vect(int id)
geovect *pv;
-#ifdef TRACE_FUNCS
- Gs_status("gv_get_prev_vect");
-#endif
+ G_debug(4, "gv_get_prev_vect(): id=%d", id);
for (pv = Vect_top; pv; pv = pv->next) {
if (pv->gvect_id == id - 1) {
@@ -65,63 +72,59 @@
return (NULL);
+ \brief Get number of loaded vector sets
+ \return number of vector sets
int gv_num_vects(void)
geovect *gv;
int i;
-#ifdef TRACE_FUNCS
- Gs_status("gv_num_vects");
-#endif
for (i = 0, gv = Vect_top; gv; gv = gv->next, i++);
+ G_debug(4, "gv_num_vects(): num=%d", i);
return (i);
+ \brief Get last loaded vector set
+ \return NULL on failure (no vector set available)
geovect *gv_get_last_vect(void)
geovect *lv;
-#ifdef TRACE_FUNCS
- Gs_status("gv_get_last_vect");
-#endif
if (!Vect_top) {
return (NULL);
for (lv = Vect_top; lv->next; lv = lv->next);
-#ifdef DEBUG
- fprintf(stderr, "last vect id: %d\n", lv->gvect_id);
-#endif
+ G_debug(4, "gv_get_last_vect(): id=%d", lv->gvect_id);
return (lv);
+ \brief Allocate memory for new vector set
geovect *gv_get_new_vect(void)
geovect *nv, *lv;
-#ifdef TRACE_FUNCS
- Gs_status("gv_get_new_vect");
-#endif
+ G_debug(4, "gv_get_new_vect()");
- if (NULL == (nv = (geovect *) malloc(sizeof(geovect)))) {
- gs_err("gv_get_new_vect");
+ nv = (geovect *) G_malloc(sizeof(geovect));
+ if (!nv) {
+ /* G_fatal_error */
return (NULL);
@@ -139,8 +142,11 @@
return (nv);
-/* call after surface is deleted */
+ \brief Update drape surfaces
+ Call after surface is deleted
void gv_update_drapesurfs(void)
geovect *gv;
@@ -163,16 +169,19 @@
+ \brief Set attributes of vector set to default values
+ \param gv pointer to geovect struct
+ \return -1 on error
+ \return 0 on success
int gv_set_defaults(geovect * gv)
int i;
-#ifdef TRACE_FUNCS
- Gs_status("gv_set_defaults");
-#endif
+ G_debug(4, "gv_set_defaults() id=%d", gv->gvect_id);
if (!gv) {
return (-1);
@@ -193,32 +202,35 @@
return (0);
+ \brief Initialize geovect struct
+ \return -1 on failure
+ \return 0 on succcess
int gv_init_vect(geovect * gv)
-#ifdef TRACE_FUNCS
- Gs_status("gv_init_vect");
-#endif
if (!gv) {
return (-1);
+ G_debug(4, "gv_init_vect() id=%d", gv->gvect_id);
return (0);
+ \brief Delete vector set (unload)
void gv_delete_vect(int id)
geovect *fv;
-#ifdef TRACE_FUNCS
- Gs_status("gv_delete_vect");
-#endif
+ G_debug(4, "gv_delete_vect(): id=%d", id);
fv = gv_get_vect(id);
@@ -229,18 +241,19 @@
return;
+ \brief Free allocated memory for geovect struct
+ \param fv pointer to geovect struct
+ \return 1 on success
int gv_free_vect(geovect * fv)
geovect *gv;
int found = 0;
-#ifdef TRACE_FUNCS
- Gs_status("gv_free_vect");
-#endif
if (Vect_top) {
if (fv == Vect_top) {
if (Vect_top->next) {
@@ -250,7 +263,7 @@
else {
gv_free_vectmem(fv);
- free(fv);
+ G_free(fv);
Vect_top = NULL;
@@ -267,8 +280,9 @@
if (found) {
+ G_debug(4, "gv_free_vect(): id=%d", fv->gvect_id);
- free(fv);
+ G_free(fv);
fv = NULL;
@@ -278,7 +292,11 @@
return (-1);
void gv_free_vectmem(geovect * fv)
geoline *gln, *tmpln;
@@ -287,17 +305,17 @@
for (gln = fv->lines; gln;) {
if (gln->dims == 2) {
sub_Vectmem(gln->npts * sizeof(Point2));
- free(gln->p2);
+ G_free(gln->p2);
if (gln->dims == 3) {
- free(gln->p3);
+ G_free(gln->p3);
tmpln = gln;
gln = gln->next;
sub_Vectmem(sizeof(geoline));
- free(tmpln);
+ G_free(tmpln);
fv->n_lines = 0;
@@ -309,7 +327,13 @@
return;
+ \brief Set drape surfaces for vector set
+ \param hsurfs array of surfaces (id)
+ \param nsurfs number of surfaces
void gv_set_drapesurfs(geovect * gv, int *hsurfs, int nsurfs)
int i;
