[GRASS-SVN] r31685 - grass-addons/visualization/nviz2/cmd
Wed Jun 11 17:48:04 EDT 2008
Author: martinl
Date: 2008-06-11 17:48:03 -0400 (Wed, 11 Jun 2008)
New Revision: 31685
Added:
   grass-addons/visualization/nviz2/cmd/exag.c
   grass-addons/visualization/nviz2/cmd/args.c
   grass-addons/visualization/nviz2/cmd/draw.c
   grass-addons/visualization/nviz2/cmd/local_proto.h
   grass-addons/visualization/nviz2/cmd/main.c
   grass-addons/visualization/nviz2/cmd/map_obj.c
   grass-addons/visualization/nviz2/cmd/nviz.h
nviz_cmd: calculate viewpoint height, load vectors
Modified: grass-addons/visualization/nviz2/cmd/args.c
--- grass-addons/visualization/nviz2/cmd/args.c	2008-06-11 20:02:51 UTC (rev 31684)
+++ grass-addons/visualization/nviz2/cmd/args.c	2008-06-11 21:48:03 UTC (rev 31685)
@@ -32,8 +32,9 @@
 void parse_command(int argc, char* argv[], struct GParams *params)
+    /* raster */
     params->elev = G_define_standard_option(G_OPT_R_ELEV);
-    params->elev->required = YES;
+    params->elev->required = NO;
     params->elev->multiple = YES;
     params->elev->description = _("Name of raster map(s) for elevation");
     params->elev->guisection = _("Raster");
@@ -52,6 +53,15 @@
     params->color_const->key = "color_value";
     params->color_const->answer = NULL;
+    /* vector */
+    params->vector = G_define_standard_option(G_OPT_V_MAP);
+    params->vector->multiple = YES;
+    params->vector->required = NO;
+    params->vector->description = _("Name of vector overlay map(s)");
+    params->vector->guisection = _("Vector");
+    params->vector->key = "vector";
+    /* misc */
     params->exag = G_define_option();
     params->exag->key = "zexag";
     params->exag->key_desc = "value";
@@ -83,7 +93,6 @@
     params->height->multiple = NO;
     params->height->description = _("Viewpoint height (in map units)");
     params->height->guisection = _("Viewpoint");
-    params->height->answer = "10561";
     params->persp = G_define_option();
     params->persp->key = "perspective";
Modified: grass-addons/visualization/nviz2/cmd/draw.c
--- grass-addons/visualization/nviz2/cmd/draw.c	2008-06-11 20:02:51 UTC (rev 31684)
+++ grass-addons/visualization/nviz2/cmd/draw.c	2008-06-11 21:48:03 UTC (rev 31685)
@@ -25,6 +25,13 @@
 static int sort_surfs_max(int *, int *, int *, int);
 static int check_blank(int);
+  \brief Draw all loaded surfaces
+  \param dc nviz data
+  \return 1
 int draw_all_surf(nv_data *dc)
     int i, nsurfs;
@@ -137,7 +144,7 @@
     // const char* EMPTYSTRING = "";
     draw_surf = 1;
-    draw_vect = 0;
+    draw_vect = 1;
     draw_site = 0;
     draw_vol = 0;
     draw_north_arrow = 0;
@@ -173,10 +180,10 @@
     bar_x        = Tcl_GetVar(interp, "scalebar_x", TCL_GLOBAL_ONLY);
     if (draw_surf)
-	draw_all_surf (data);
+	draw_all_surf(data);
     if (draw_vect)
-	; // vect_draw_all_together(data, interp);
+	draw_all_vect (data);
     if (draw_site)
 	; // site_draw_all_together(data, interp);
@@ -323,3 +330,39 @@
     return 1;
+  \brief Draw all loaded vector sets
+  \return 1
+int draw_all_vect(nv_data *dc)
+    int i, nvects;
+    int *vect_list;
+    // GS_set_cancel(0);
+    vect_list = GV_get_vect_list(&nvects);
+    /* in case transparency is set */
+    GS_set_draw(GSD_BOTH);
+    GS_ready_draw();
+    for (i = 0; i < nvects; i++) {
+	if (!check_blank(vect_list[i])) {
+	    GV_draw_vect(vect_list[i]);
+    G_free (vect_list);
+    GS_done_draw();
+    GS_set_draw(GSD_BACK);
+    return 1;
Added: grass-addons/visualization/nviz2/cmd/exag.c
--- grass-addons/visualization/nviz2/cmd/exag.c	                        (rev 0)
+++ grass-addons/visualization/nviz2/cmd/exag.c	2008-06-11 21:48:03 UTC (rev 31685)
@@ -0,0 +1,72 @@
+  \file exag.c
+  \brief Exaggeration functions
+  COPYRIGHT: (C) 2008 by the GRASS Development Team
+  This program is free software under the GNU General Public
+  License (>=v2). Read the file COPYING that comes with GRASS
+  for details.
+  Based on visualization/nviz/src/exag.c
+  \author Updated/modified by Martin Landa <landa.martin gmail.com>
+  \date 2008
+#include <grass/gsurf.h>
+#include <grass/gstypes.h>
+#include "local_proto.h"
+  \brief Get viewpoint height
+  Call after initial data has been loaded
+  \param data nviz data
+  \param[out] val height value
+  \param[out] min min value (or NULL)
+  \param[out] max max value (or NULL)
+  \return 1
+int exag_get_height(float *val, float *min, float *max)
+    float longdim, exag, texag, hmin, hmax, fmin, fmax;
+    int nsurfs, i, *surf_list;
+    surf_list = GS_get_surf_list(&nsurfs);
+    if (nsurfs) {
+	GS_get_longdim(&longdim);
+	GS_get_zrange_nz(&hmin, &hmax);
+	exag = 0.0;
+	for (i = 0; i < nsurfs; i++) {
+	    if (GS_get_exag_guess(surf_list[i], &texag) > -1)
+		if (texag)
+		    exag = texag > exag ? texag : exag;
+	if (exag == 0.0)
+	    exag = 1.0;
+	fmin = hmin - (2. * longdim / exag);
+	fmax = hmin + (3 * longdim / exag);
+    else {
+	fmax = 10000.0;
+	fmin = 0.0;
+    *val = fmin + (fmax - fmin) / 2.0;
+    if (min)
+	*min = fmin;
+    if (max)
+	*max = fmax;
+    return 1;
Property changes on: grass-addons/visualization/nviz2/cmd/exag.c
___________________________________________________________________
   + text/x-csrc
   + Author Date Id
   + native
Modified: grass-addons/visualization/nviz2/cmd/local_proto.h
--- grass-addons/visualization/nviz2/cmd/local_proto.h	2008-06-11 20:02:51 UTC (rev 31684)
+++ grass-addons/visualization/nviz2/cmd/local_proto.h	2008-06-11 21:48:03 UTC (rev 31685)
@@ -6,7 +6,8 @@
 /* module flags and parameters */
 struct GParams {
-  struct Option *elev, *color_map, *color_const, /* data */
+  struct Option *elev, *color_map, *color_const, /* raster */
+    *vector, /* vector */
     *exag, *bgcolor, /* misc */
     *pos, *height, *persp, *twist; /* viewpoint */
@@ -35,7 +36,11 @@
 int draw_all_surf(nv_data *);
 int draw_all(nv_data *);
 int draw_quick(nv_data *);
+int draw_all_vect(nv_data *);
+/* exag.c */
+int exag_get_height(float *, float *, float *);
 /* map_obj.c */
 int new_map_obj(int, const char *,
 		nv_data *);
Modified: grass-addons/visualization/nviz2/cmd/main.c
--- grass-addons/visualization/nviz2/cmd/main.c	2008-06-11 20:02:51 UTC (rev 31684)
+++ grass-addons/visualization/nviz2/cmd/main.c	2008-06-11 21:48:03 UTC (rev 31685)
@@ -32,7 +32,8 @@
     char *mapset;
     unsigned int i;
     int id;
-    unsigned int nelev, ncolor_map, ncolor_const;
+    unsigned int nelev, ncolor_map, ncolor_const, nvect;
+    float vp_height; /* calculated viewpoint height */
     nv_data data;
     render_window offscreen;
@@ -77,7 +78,8 @@
     while(params->color_const->answer && params->color_const->answers[i++])
 	ncolor_const++;
-    if (params->elev->answers) {
+    /* load rasters */
+    if (params->elev->answer) {
 	for (i = 0; params->elev->answers[i]; i++) {
 	    mapset = G_find_cell2 (params->elev->answers[i], "");
 	    if (mapset == NULL) {
@@ -120,6 +122,29 @@
+    /* load vectors */
+    if (params->vector->answer) {
+	if (!params->elev->answer && GS_num_surfs() == 0) { /* load base surface if no loaded */
+	    int *surf_list, nsurf;
+	    new_map_obj(MAP_OBJ_SURF, NULL, &data);
+	    surf_list = GS_get_surf_list(&nsurf);
+	    GS_set_att_const(surf_list[0], ATT_TRANSP, 255);
+	for (i = 0; params->vector->answers[i]; i++) {
+	    mapset = G_find_vector2 (params->vector->answers[i], "");
+	    if (mapset == NULL) {
+		G_fatal_error(_("Vector map <%s> not found"),
+			      params->vector->answers[i]);
+	    new_map_obj(MAP_OBJ_VECT,
+			G_fully_qualified_name(params->vector->answers[i], mapset), &data);
+	nvect++;
     /* init view */
     init_view();
     focus_set_map(MAP_OBJ_UNDEFINED, -1);
@@ -156,8 +181,14 @@
 		      0.3, 0.3, 0.3);
     /* define view point */
+    if (params->height->answer) {
+	vp_height = atof(params->height->answer);
+    else {
+	exag_get_height(&vp_height, NULL, NULL);
     viewpoint_set_height(&data,
-			 atof(params->height->answer));
+			 vp_height);
     change_exag(&data,
 		atof(params->exag->answer));
     viewpoint_set_position(&data,
Modified: grass-addons/visualization/nviz2/cmd/map_obj.c
--- grass-addons/visualization/nviz2/cmd/map_obj.c	2008-06-11 20:02:51 UTC (rev 31684)
+++ grass-addons/visualization/nviz2/cmd/map_obj.c	2008-06-11 21:48:03 UTC (rev 31685)
@@ -54,7 +54,8 @@
 int new_map_obj(int type, const char *name,
 		nv_data *data)
-    int new_id;
+    int new_id, i;
+    int num_surfs, *surf_list;
     nv_clientdata *client_data;
@@ -68,6 +69,7 @@
  *      id number and link it to the Nmap_obj_cmd routine
  *      below.
+    /* raster -> surface */
     if (type == MAP_OBJ_SURF) {
 	if (GS_num_surfs() >= MAX_SURFS) {
 	    G_warning (_("Maximum surfaces loaded!"));
@@ -95,8 +97,36 @@
+    /* vector overlay */
+    else if (type == MAP_OBJ_VECT) {
+	if (GV_num_vects() >= MAX_VECTS) {
+	    G_warning (_("Maximum vectors loaded!"));
+	    return -1;
-    /* Initialize the client data filled for the new map object */
+	new_id = GV_new_vector();
+	if (name) {
+	    if (GV_load_vector(new_id, name) < 0) {
+		GV_delete_vector(new_id);
+		G_warning (_("Error loading vector <%s>"), name);
+		return -1;
+	/* initialize display parameters
+	   automatically select all surfaces to draw vector */
+	GV_set_vectmode(new_id, 1, 0xFF0000, 2, 0);
+	surf_list = GS_get_surf_list(&num_surfs);
+	if (num_surfs) {
+	    for (i = 0; i < num_surfs; i++) {
+		GV_select_surf(new_id, surf_list[i]);
+	G_free (surf_list);
+    /* initialize the client data filled for the new map object */
     client_data = (nv_clientdata *) G_malloc (sizeof(nv_clientdata));
     if (name) {
@@ -252,3 +282,4 @@
     return;
Modified: grass-addons/visualization/nviz2/cmd/nviz.h
--- grass-addons/visualization/nviz2/cmd/nviz.h	2008-06-11 20:02:51 UTC (rev 31684)
+++ grass-addons/visualization/nviz2/cmd/nviz.h	2008-06-11 21:48:03 UTC (rev 31685)
@@ -6,6 +6,7 @@
 #define MAP_OBJ_UNDEFINED 0
 #define MAP_OBJ_SURF 1
 #define MAP_OBJ_VOL 2
+#define MAP_OBJ_VECT 3
 #define RANGE (5 * GS_UNIT_SIZE)
 #define RANGE_OFFSET (2 * GS_UNIT_SIZE)
