[GRASS-SVN] r31702 - grass/branches/develbranch_6/raster/r.stats
svn_grass at osgeo.org
Fri Jun 13 09:37:07 EDT 2008
Author: martinl
Date: 2008-06-13 09:37:07 -0400 (Fri, 13 Jun 2008)
New Revision: 31702
grass/branches/develbranch_6/raster/r.stats/main.c
r.stats: message cleaning, use standard options
Modified: grass/branches/develbranch_6/raster/r.stats/main.c
--- grass/branches/develbranch_6/raster/r.stats/main.c 2008-06-13 12:35:51 UTC (rev 31701)
+++ grass/branches/develbranch_6/raster/r.stats/main.c 2008-06-13 13:37:07 UTC (rev 31702)
@@ -16,15 +16,17 @@
#define GLOBAL
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
-#include "global.h"
#include <grass/glocale.h>
+#include "global.h"
int main (int argc, char *argv[])
- char *to_screen = " output to screen ";
int *fd;
char **names;
char **ptr;
@@ -46,7 +48,7 @@
struct Quant q;
CELL min, max, null_set=0;
DCELL dmin, dmax;
- struct GModule *module;
+ struct GModule *module;
struct
struct Flag *A ; /* print averaged values instead of intervals */
@@ -84,26 +86,20 @@
G_gisinit (argv[0]);
module = G_define_module();
- module->keywords = _("raster");
+ module->keywords = _("raster, statistics");
module->description =
_("Generates area statistics for raster map layers.");
-/* Define the different options */
+ /* Define the different options */
- option.cell = G_define_option() ;
- option.cell->key = "input";
- option.cell->type = TYPE_STRING;
- option.cell->required = YES;
- option.cell->multiple = YES;
- option.cell->gisprompt = "old,cell,raster" ;
- option.cell->description= _("Raster input maps(s)") ;
+ option.cell = G_define_standard_option(G_OPT_R_INPUTS);
- option.fs = G_define_option() ;
- option.fs->key = "fs";
+ option.output = G_define_standard_option(G_OPT_F_OUTPUT);
+ option.output->required = NO;
+ option.output->description = _("Name for output file (if omitted or \"-\" output to stdout)");
+ option.fs = G_define_standard_option(G_OPT_F_SEP) ;
option.fs->key_desc = "character|space|tab" ;
- option.fs->type = TYPE_STRING;
- option.fs->required = NO;
- option.fs->multiple = NO;
option.fs->answer = "space";
option.fs->description= _("Output field separator");
@@ -115,13 +111,6 @@
option.nv->answer = "*";
option.nv->description= _("String representing no data cell value");
- option.output = G_define_option();
- option.output->key = "output";
- option.output->type = TYPE_STRING;
- option.output->required = NO;
- option.output->multiple = NO;
- option.output->description= _("Output file name");
option.nsteps = G_define_option();
option.nsteps->key = "nsteps";
option.nsteps->type = TYPE_INTEGER;
@@ -129,9 +118,6 @@
option.nsteps->multiple = NO;
option.nsteps->answer = "255";
option.nsteps->description= _("Number of fp subranges to collect stats from");
- option.output->answer = to_screen;
/* Define the different flags */
@@ -142,23 +128,43 @@
flag.A = G_define_flag() ;
flag.A->key = 'A' ;
flag.A->description = _("Print averaged values instead of intervals") ;
+ flag.A->guisection = _("Print");
flag.a = G_define_flag() ;
flag.a->key = 'a' ;
flag.a->description = _("Print area totals") ;
+ flag.a->guisection = _("Print");
flag.c = G_define_flag() ;
flag.c->key = 'c' ;
flag.c->description = _("Print cell counts") ;
+ flag.c->guisection = _("Print");
flag.p = G_define_flag() ;
flag.p->key = 'p' ;
flag.p->description = _("Print APPROXIMATE percents (total percent may not be 100%)") ;
+ flag.p->guisection = _("Print");
flag.l = G_define_flag() ;
flag.l->key = 'l' ;
flag.l->description = _("Print category labels") ;
+ flag.l->guisection = _("Print");
+ flag.g = G_define_flag() ;
+ flag.g->key = 'g';
+ flag.g->description = _("Print grid coordinates (east and north)");
+ flag.g->guisection = _("Print");
+ flag.x = G_define_flag() ;
+ flag.x->key = 'x';
+ flag.x->description = _("Print x and y (column and row)");
+ flag.x->guisection = _("Print");
+ flag.r = G_define_flag() ;
+ flag.r->key = 'r';
+ flag.r->description = _("Print raw indexes of fp ranges (fp maps only)");
+ flag.r->guisection = _("Print");
flag.n = G_define_flag() ;
flag.n->key = 'n' ;
flag.n->description = _("Suppress reporting of any NULLs") ;
@@ -167,43 +173,32 @@
flag.N->key = 'N' ;
flag.N->description = _("Suppress reporting of NULLs when all values are NULL") ;
- flag.g = G_define_flag() ;
- flag.g->key = 'g';
- flag.g->description = _("Print grid coordinates (east and north)");
- flag.x = G_define_flag() ;
- flag.x->key = 'x';
- flag.x->description = _("Print x and y (column and row)");
flag.C = G_define_flag() ;
flag.C->key = 'C' ;
flag.C->description = _("Report for cats fp ranges (fp maps only)") ;
- flag.r = G_define_flag() ;
- flag.r->key = 'r';
- flag.r->description = _("Print raw indexes of fp ranges (fp maps only)");
flag.i = G_define_flag() ;
flag.i->key = 'i';
flag.i->description = _("Read fp map as integer (use map's quant rules)");
if (G_parser(argc, argv))
- exit (-1);
+ exit (EXIT_FAILURE);
name = option.output->answer;
- if (name != NULL && strcmp(name, to_screen) != 0)
+ if (name != NULL && strcmp(name, "-") != 0)
if(NULL == freopen (name, "w", stdout))
- perror (name);
- exit(EXIT_FAILURE);
+ G_fatal_error (_("Unable to open file <%s> for writing"), name);
sscanf(option.nsteps->answer, "%d", &nsteps);
if(nsteps <= 0)
- G_warning(_("nsteps must be greater than zero; using nsteps=255"));
- nsteps = 255;
+ G_warning(_("'%s' must be greater than zero; using %s=255"),
+ option.nsteps->key, option.nsteps->key);
+ nsteps = 255;
cat_ranges = flag.C->answer;
@@ -213,7 +208,6 @@
nrows = G_window_rows();
ncols = G_window_cols();
fd = NULL;
nfiles = 0;
dp = -1;
@@ -275,12 +269,14 @@
is_fp[nfiles] = 0;
if(cat_ranges || nsteps != 255)
- G_warning(_("%s: -i means read %s as integer! -C flag and/or nsteps option will be ignored"), G_program_name(),name);
+ G_warning(_("Raster map <%s> is reading as integer map! "
+ "Flag '-%c' and/or '%s' option will be ignored."),
+ G_fully_qualified_name(name, mapset), flag.C->key, option.nsteps->key);
if (with_labels || (cat_ranges && is_fp[nfiles]))
labels = (struct Categories *)
- G_realloc (labels, (nfiles+1) * sizeof(struct Categories));
+ G_realloc (labels, (nfiles+1) * sizeof(struct Categories));
if (G_read_cats (name, mapset, &labels[nfiles]) < 0)
G_init_cats((CELL) 0, "", &labels[nfiles]);
@@ -292,16 +288,21 @@
if(! G_quant_nof_rules (&labels[nfiles].q))
- G_warning(_("%s: cats for %s are either missing or have no explicit labels. Using nsteps=%d"), G_program_name(),name, nsteps);
+ G_warning(_("Cats for raster map <%s> are either missing or have no explicit labels. "
+ "Using %s=%d."),
+ G_fully_qualified_name(name, mapset), option.nsteps->key, nsteps);
cat_ranges = 0;
else if (nsteps != 255)
- G_warning(_("%s: -C flag was given, using cats fp ranges of %s, ignoring nsteps option"), G_program_name(),name);
+ G_warning(_("Flag '-%c' was given, using cats fp ranges of raster map <%s>, "
+ "ignoring '%s' option"),
+ flag.C->key, G_fully_qualified_name(name, mapset), option.nsteps->key);
if(!cat_ranges) /* DO NOT use else here, cat_ranges can change */
if(G_read_fp_range (name, mapset, &fp_range) < 0)
- G_fatal_error (_("%s: can't read fp range for [%s]"),G_program_name(),name);
+ G_fatal_error (_("Unable to read fp range of raster map <%s>"),
+ G_fully_qualified_name(name, mapset));
G_get_fp_range_min_max (&fp_range, &DMIN[nfiles], &DMAX[nfiles]);
G_quant_add_rule (&q, DMIN[nfiles], DMAX[nfiles], 1, nsteps);
/* set the quant rules for reading the map */
@@ -319,7 +320,8 @@
else
if(G_read_range (name, mapset, &range) < 0)
- G_fatal_error (_("Unable to read range for map <%s>"),name);
+ G_fatal_error (_("Unable to read range for map <%s>"),
G_get_range_min_max (&range, &min, &max);
if(!null_set)
@@ -340,8 +342,8 @@
raw_stats (fd, with_coordinates, with_xy, with_labels);
else
cell_stats (fd, with_percents, with_counts, with_areas, with_labels, fmt);
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
