[GRASS-SVN] r31719 - grass-addons/raster/r.sun_horizon/r.horizon
Mon Jun 16 10:15:33 EDT 2008
Author: hamish
Date: 2008-06-16 10:15:33 -0400 (Mon, 16 Jun 2008)
New Revision: 31719
   grass-addons/raster/r.sun_horizon/r.horizon/main.c
dos2unix newlines
Modified: grass-addons/raster/r.sun_horizon/r.horizon/main.c
--- grass-addons/raster/r.sun_horizon/r.horizon/main.c	2008-06-16 11:15:05 UTC (rev 31718)
+++ grass-addons/raster/r.sun_horizon/r.horizon/main.c	2008-06-16 14:15:33 UTC (rev 31719)
@@ -1,1274 +1,1274 @@
-r.horizon: This module does one of two things:
-1) Using a map of the terrain elevation it calculates for a set of points
-the angle height of the horizon for each point, using an angle interval given
-by the user.
-2) For a given minimum angle it calculates one or more raster map giving the mazimum
-distance to a point on the horizon.
-This program was written in 2006 by Tfomas Huld and Tomas Cebecauer,
-Joint Research Centre of the European Commission, based on bits of the r.sun module by Jaro Hofierka
- * This program is free software; you can redistribute it and/or
- * modify it under the terms of the GNU General Public License
- * as published by the Free Software Foundation; either version 2
- * of the License, or (at your option) any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program; if not, write to the
- *   Free Software Foundation, Inc.,
- *   59 Temple Place - Suite 330,
- *   Boston, MA  02111-1307, USA.
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <math.h>
-#include <malloc.h>
-#include <grass/gis.h>
-#include <grass/gprojects.h>
-#include <grass/glocale.h>
-#define WHOLE_RASTER 1
-#define SINGLE_POINT 0
-#define RAD      (180. / M_PI)
-#define DEG      ((M_PI)/180.)
-#define EARTHRADIUS 6371000.
-#define UNDEF    0.            /* undefined value for terrain aspect*/
-#define UNDEFZ   -9999.        /* undefined value for elevation */
-#define BIG      1.e20
-#define SMALL    1.e-20
-#define EPS      1.e-4
-#define DIST     "1.0"
-#define DEGREEINMETERS 111120.
-#define TANMINANGLE 0.008727		/* tan of minimum horizon angle (0.5 deg) */
-#define AMAX1(arg1, arg2) ((arg1) >= (arg2) ? (arg1) : (arg2))
-#define DISTANCE1(x1, x2, y1, y2) (sqrt((x1 - x2)*(x1 - x2) + (y1 - y2)*(y1 - y2)))
-FILE *fw;
-const double rad2deg = 180./M_PI;
-const double deg2rad = M_PI/180.;
-const double pihalf=M_PI*0.5;
-const double twopi=2.*M_PI;
-const double invEarth=1./EARTHRADIUS;
-const double minAngle=DEG;
-char *elevin;
-char *latin = NULL;
-char *horizon = NULL;
-char *mapset = NULL;
-char *per;
-char shad_filename[256];
-struct Cell_head cellhd;
-struct Key_value *in_proj_info, *in_unit_info;
-struct pj_info iproj;
-struct pj_info oproj;
-struct Cell_head new_cellhd;
-double bufferZone=0., ebufferZone=0., wbufferZone=0., nbufferZone=0., sbufferZone=0.;
-int INPUT(void);
-int OUTGR(int numrows, int numcols);
-double amax1(double, double);
-double amin1(double, double);
-int min(int, int);
-int max(int, int);
-void com_par(double angle);
-int is_shadow(void);
-double  horizon_height(void);
-void calculate_shadow();
-double calculate_shadow_onedirection(double shadow_angle);
-int new_point();
-double searching();
-int test_low_res();
-/*void where_is_point();
-void cube(int, int);
-void calculate(double xcoord, double ycoord, int buffer_e, int buffer_w, int buffer_s, int buffer_n);
-int     ip, jp,  ip100, jp100;
-int     n, m,  m100, n100;
-int degreeOutput=0;
-float     **z, **z100, **horizon_raster;
-double  stepx, stepy, stepxhalf, stepyhalf, stepxy, xp, yp, op, dp, xg0, xx0, yg0, yy0,deltx,delty;
-double  invstepx, invstepy, distxy;
-double offsetx, offsety;
-double single_direction;
-/*int arrayNumInt;*/
-double  xmin, xmax, ymin, ymax,zmax=0.;
-int     d, day, tien=0;
-double  length, maxlength=BIG, zmult=1.0, step=0.0,dist;
-double fixedMaxLength=BIG;
-char *tt,*lt;
-double z_orig,zp;
-double h0, tanh0, angle;
-double stepsinangle, stepcosangle, sinangle, cosangle, distsinangle, distcosangle;
-double TOLER;
-int mode;
-int isMode()
-	return mode;
-void setMode(int val)
-	mode = val;
-int ll_correction=0;
-double coslatsq;
-double distance(double x1, double x2, double y1, double y2)
-	if(ll_correction)
-		return DEGREEINMETERS*sqrt(coslatsq*(x1-x2)*(x1-x2)
-				+(y1-y2)*(y1-y2));
-	else
-		return sqrt((x1 - x2)*(x1 - x2) + (y1 - y2)*(y1 - y2));
-int main(int argc, char *argv[])
-	double xcoord, ycoord;
-	struct GModule *module;
- 	struct
-		struct Option *elevin,*dist,*coord,*direction,*horizon,*step,*bufferzone,*e_buff,*w_buff,*n_buff,*s_buff, *maxdistance;
-	} parm;
-	struct
-		struct Flag   *degreeOutput;
-	flag;
-	  G_gisinit (argv[0]);
-          module = G_define_module();
-	module->keywords = _("raster");
-	module->label = _("Horizon angle computation from a digital elevation model.");
-	module->description =
-          _("Computes horizon angle height from a digital elevation model. The module has two"
-		  " different modes of operation:  "
-		  "1. Computes the entire horizon around a single point whose coordinates are"
-		  " given on withe the 'coord' option. The horizon height (in radians). "
-		  "2. Computes one or more raster maps of the horizon height in a single direction. "
-		  " The input for this is the angle (in degrees), which is measured "
-		  " counterclockwise with east=0, north=90 etc. The output is the horizon height in radians.");
-	if(G_get_set_window(&cellhd)==-1) G_fatal_error("G_get_set_window() failed");
-	stepx = cellhd.ew_res;
-	stepy = cellhd.ns_res;
-	stepxhalf = stepx/2.;
-	stepyhalf = stepy/2.;
-	invstepx = 1./stepx;
-	invstepy = 1./stepy;
-	offsetx = 2. *  invstepx;
-    	offsety = 2. * invstepy;
-	offsetx = 0.5*stepx;
-    	offsety = 0.5*stepy;
-	offsetx = 0.5;
-    	offsety = 0.5;
-	n/*n_cols*/ = cellhd.cols;
-	m/*n_rows*/ = cellhd.rows;
-	n100=ceil(n/100.);
-	m100=ceil(m/100.);
-	xmin = cellhd.west;
-	ymin = cellhd.south;
-	xmax = cellhd.east;
-	ymax = cellhd.north;
-        deltx = fabs(cellhd.east - cellhd.west);
-        delty = fabs(cellhd.north - cellhd.south);
-	  parm.elevin = G_define_option();
-	  parm.elevin->key = "elevin";
-	  parm.elevin->type = TYPE_STRING;
-	  parm.elevin->required = YES;
-	  parm.elevin->gisprompt = "old,cell,raster";
-	  parm.elevin->description = _("Name of the input elevation raster map [meters]");
-  	  parm.elevin->guisection  = _("Input_options");
-	  parm.direction = G_define_option();
-	  parm.direction->key = "direction";
-	  parm.direction->type = TYPE_DOUBLE;
-	  parm.direction->required = NO;
-	  parm.direction->description = _("Direction in which you want to know the horizon height");
-	  parm.direction->guisection = _("Input_options");
-	  parm.step = G_define_option();
-	  parm.step->key = "step";
-	  parm.step->type = TYPE_DOUBLE;
-	  parm.step->required = NO;
-	  parm.step->description = _("For multidirectional horizon: the step size in degrees");
-	  parm.step->guisection = _("Input_options");
-	  parm.bufferzone = G_define_option();
-	  parm.bufferzone->key = "bufferzone";
-	  parm.bufferzone->type = TYPE_DOUBLE;
-	  parm.bufferzone->required = NO;
-	  parm.bufferzone->description = _("For horizon rasters, read from the DEM an extra buffer around the present region");
-	  parm.bufferzone->guisection = _("Input_options");
-	  parm.e_buff = G_define_option();
-	  parm.e_buff->key = "e_buff";
-	  parm.e_buff->type = TYPE_DOUBLE;
-	  parm.e_buff->required = NO;
-	  parm.e_buff->description = _("For horizon rasters, read from the DEM an extra buffer eastward the present region");
-	  parm.e_buff->guisection = _("Input_options");
-	  parm.w_buff = G_define_option();
-	  parm.w_buff->key = "w_buff";
-	  parm.w_buff->type = TYPE_DOUBLE;
-	  parm.w_buff->required = NO;
-	  parm.w_buff->description = _("For horizon rasters, read from the DEM an extra buffer westward the present region");
-	  parm.w_buff->guisection = _("Input_options");
-	  parm.n_buff = G_define_option();
-	  parm.n_buff->key = "n_buff";
-	  parm.n_buff->type = TYPE_DOUBLE;
-	  parm.n_buff->required = NO;
-	  parm.n_buff->description = _("For horizon rasters, read from the DEM an extra buffer northward the present region");
-	  parm.n_buff->guisection = _("Input_options");
-	  parm.s_buff = G_define_option();
-	  parm.s_buff->key = "s_buff";
-	  parm.s_buff->type = TYPE_DOUBLE;
-	  parm.s_buff->required = NO;
-	  parm.s_buff->description = _("For horizon rasters, read from the DEM an extra buffer southward the present region");
-	  parm.s_buff->guisection = _("Input_options");
-	  parm.maxdistance = G_define_option();
-	  parm.maxdistance->key = "maxdistance";
-	  parm.maxdistance->type = TYPE_DOUBLE;
-	  parm.maxdistance->required = NO;
-	  parm.maxdistance->description = _("The maximum distance to consider when finding the horizon height");
-	  parm.maxdistance->guisection = _("Input_options");
-	  parm.horizon = G_define_option();
-	  parm.horizon->key = "horizon";
-	  parm.horizon->type = TYPE_STRING;
-	  parm.horizon->required = NO;
-	  parm.horizon->gisprompt = "old,cell,raster";
-	  parm.horizon->description = _("Name of the horizon raster output");
-	  parm.horizon->guisection = _("Output_options");
-          parm.coord = G_define_option();
-          parm.coord->key = "coord";
-          parm.coord->type = TYPE_STRING;
-          parm.coord->required = NO;
-          parm.coord->description = _("Coordinate for which you want to calculate the horizon");
-          parm.coord->guisection = _("Output_options");
-          parm.dist = G_define_option();
-          parm.dist->key = "dist";
-          parm.dist->type = TYPE_DOUBLE;
-          parm.dist->answer = DIST;
-          parm.dist->required = NO;
-          parm.dist->description = _("Sampling distance step coefficient (0.5-1.5)");
-          parm.dist->guisection = _("Output_options");
-	  flag.degreeOutput = G_define_flag();
-	  flag.degreeOutput->key = 'd';
-	  flag.degreeOutput->description =
-			  _("Write output in degrees (default is radians)");
- 	if (G_parser(argc, argv))
-	   exit(EXIT_FAILURE);
-	degreeOutput = flag.degreeOutput->answer;
-	elevin = parm.elevin->answer;
-	if(parm.coord->answer==NULL)
-		setMode(WHOLE_RASTER);
-	else
-		setMode(SINGLE_POINT);
-		if(sscanf(parm.coord->answer,"%lf,%lf", &xcoord, &ycoord)!=2)
-		    G_fatal_error
-			("Can't read the coordinates from the \"coord\" option.");
-		/* Transform the coordinates to row/column */
-		xcoord = (int) ((xcoord-xmin)/stepx);
-		ycoord = (int) ((ycoord-ymin)/stepy);
-	if(parm.direction->answer!=NULL) sscanf(parm.direction->answer, "%lf", &single_direction);
-	if(isMode(WHOLE_RASTER))
-		if((parm.direction->answer==NULL) && (parm.step->answer==NULL))
-			G_fatal_error
-			(_("You didn't specify a direction value or step size. Aborting."));
-		if(parm.horizon->answer==NULL)
-			G_fatal_error
-			(_("You didn't specify a horizon raster name. Aborting."));
-		horizon = parm.horizon->answer;
-		if(parm.step->answer!=NULL) sscanf(parm.step->answer, "%lf", &step);
-	else
-		if(parm.step->answer==NULL)
-			G_fatal_error
-			(_("You didn't specify an angle step size. Aborting."));
-	        sscanf(parm.step->answer, "%lf", &step);
-	if(step==0.0)
-		step=360.;
-	if(parm.bufferzone->answer!=NULL)
-		if(sscanf(parm.bufferzone->answer, "%lf", &bufferZone)!=1)
-			G_fatal_error
-			(_("Could not read bufferzone size. Aborting."));
-	if(parm.e_buff->answer!=NULL)
-		if(sscanf(parm.e_buff->answer, "%lf", &ebufferZone)!=1)
-			G_fatal_error
-			(_("Could not read east bufferzone size. Aborting."));
-	if(parm.w_buff->answer!=NULL)
-		if(sscanf(parm.w_buff->answer, "%lf", &wbufferZone)!=1)
-			G_fatal_error
-			(_("Could not read west bufferzone size. Aborting."));
-	if(parm.s_buff->answer!=NULL)
-		if(sscanf(parm.s_buff->answer, "%lf", &sbufferZone)!=1)
-			G_fatal_error
-			(_("Could not read south bufferzone size. Aborting."));
-	if(parm.n_buff->answer!=NULL)
-		if(sscanf(parm.n_buff->answer, "%lf", &nbufferZone)!=1)
-			G_fatal_error
-			(_("Could not read north bufferzone size. Aborting."));
-	if(parm.maxdistance->answer!=NULL)
-		if(sscanf(parm.maxdistance->answer, "%lf", &fixedMaxLength)!=1)
-			G_fatal_error
-			(_("Could not read maximum distance. Aborting."));
-        sscanf(parm.dist->answer, "%lf", &dist);
-                stepxy = dist * 0.5 * (stepx + stepy);
-		distxy = dist;
-                TOLER = stepxy * EPS;
-	if(bufferZone>0. || ebufferZone>0. || wbufferZone>0. || sbufferZone>0. || nbufferZone>0.)
-		new_cellhd=cellhd;
-		if (ebufferZone==0.) ebufferZone=bufferZone;
-		if (wbufferZone==0.) wbufferZone=bufferZone;
-		if (sbufferZone==0.) sbufferZone=bufferZone;
-		if (nbufferZone==0.) nbufferZone=bufferZone;
-		new_cellhd.rows+=(int) ((nbufferZone+sbufferZone)/stepy);
-		new_cellhd.cols+=(int) ((ebufferZone+wbufferZone)/stepx);
-		new_cellhd.north+=nbufferZone;
-		new_cellhd.south-=sbufferZone;
-		new_cellhd.east+=ebufferZone;
-		new_cellhd.west-=wbufferZone;
-		xmin = new_cellhd.west;
-		ymin = new_cellhd.south;
-		xmax = new_cellhd.east;
-		ymax = new_cellhd.north;
-        	deltx = fabs(new_cellhd.east - new_cellhd.west);
-        	delty = fabs(new_cellhd.north - new_cellhd.south);
-		n/*n_cols*/ = new_cellhd.cols;
-		m/*n_rows*/ = new_cellhd.rows;
-/*printf("%lf %lf %lf %lf \n",ymax, ymin, xmin,xmax);
-		if(G_set_window(&new_cellhd)==-1) exit(EXIT_FAILURE);
-	struct Key_Value *in_proj_info, *in_unit_info;
-	if ((in_proj_info = G_get_projinfo()) == NULL)
-	    G_fatal_error
-		(_("Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"));
-	if ((in_unit_info = G_get_projunits()) == NULL)
-	    G_fatal_error(_("Can't get projection units of current location"));
-	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
-	    G_fatal_error
-		(_("Can't get projection key values of current location"));
-	G_free_key_value(in_proj_info);
-	G_free_key_value(in_unit_info);
-	/* Set output projection to latlong w/ same ellipsoid */
-	oproj.zone = 0;
-	oproj.meters = 1.;
-	sprintf(oproj.proj, "ll");
-	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
-	    G_fatal_error(_("Unable to set up lat/long projection parameters"));
-/**********end of parser - ******************************/
-	   INPUT();
-	   calculate(xcoord, ycoord, (int) (ebufferZone/stepx), (int) (wbufferZone/stepx),  (int) (sbufferZone/stepy), (int) (nbufferZone/stepy));
-	if(bufferZone>0.)
-		/* Set the region window back to the original */
-		if(G_set_window(&cellhd)==-1) exit(EXIT_FAILURE);
-/*sorry, I've moved OUTGR to calculate() - into the loop*/
-/*	if(isMode(WHOLE_RASTER))
-		OUTGR(cellhd.rows,cellhd.cols);
-	exit(EXIT_SUCCESS);
-/**********************end of main.c*****************/
-int INPUT(void)
-	FCELL    *cell1;
-	int     fd1, row, row_rev;
-	int     l,i,j,k;
-	int     lmax,kmax;
-	cell1=G_allocate_f_raster_buf();
-	z = (float **)malloc(sizeof(float *)*(m));
-	z100 = (float **)malloc(sizeof(float *)*(m100));
-  for(l=0;l<m;l++)
-	z[l]   = (float*)malloc(sizeof(float)*(n));
-  for(l=0;l<m100;l++)
-	z100[l]   = (float*)malloc(sizeof(float)*(n100));
-/*read Z raster*/
-  if((mapset=G_find_cell(elevin,""))==NULL)
-  	G_fatal_error(_("Elevation raster file not found"));
-  fd1 = G_open_cell_old(elevin,mapset);
-  for (row=0; row<m; row++)
-	  G_get_f_raster_row(fd1,cell1,row);
-	for (j=0; j<n; j++)
-	   row_rev = m - row - 1;
-	    if (!G_is_f_null_value(cell1 + j))
-                z[row_rev][j] = (float)cell1[j];
-            else
-                z[row_rev][j] = UNDEFZ;
-  G_close_cell(fd1);
-/*create low resolution array 100*/
-  for (i=0; i<m100; i++)
-	lmax=(i+1)*100;
-	if (lmax>m) lmax=m;
-	for (j=0; j<n100; j++)
-		zmax=SMALL;
-		kmax=(j+1)*100;
-		if (kmax>n) kmax=n;
-	 	for (l=(i*100); l<lmax; l++)
-		 	for (k=(j*100); k<kmax; k++)
-				zmax=amax1(zmax,z[l][k]);
-		z100[i][j]=zmax;
-//printf("%d %d %lf\n", i, j, z100[i][j]);
-/*find max Z*/
-  for (i = 0; i < m; i++)
-	  for (j = 0; j < n; j++)
-		zmax = amax1(zmax,z[i][j]);
-	return 1;
-	FCELL *cell1=NULL;
-   int 	 	fd1=0;
-   int      i,iarc,j;
-   if(G_set_window (&cellhd) < 0) exit(EXIT_FAILURE);
-    if (horizon != NULL) {
-	cell1 = G_allocate_f_raster_buf();
-	fd1 = G_open_fp_cell_new(shad_filename);
-	if (fd1 < 0)
-	    G_fatal_error(_("Unable to create raster map %s"), shad_filename);
-   if (numrows != G_window_rows())
-	  G_fatal_error(_("OOPS: rows changed from %d to %d"), numrows, G_window_rows());
-   if (numcols != G_window_cols())
-	  G_fatal_error(_("OOPS: cols changed from %d to %d"), numcols, G_window_cols());
-	  for(iarc=0;iarc<numrows;iarc++)
-	  i=numrows-iarc-1;
-		    for (j = 0; j < numcols; j++) {
-			if (horizon_raster[i][j] == UNDEFZ)
-			    G_set_f_null_value(cell1 + j, 1);
-			else
-			    cell1[j] = (FCELL) horizon_raster[i][j];
-		    G_put_f_raster_row(fd1, cell1);
-	  } /* End loop over rows. */
-	G_close_cell (fd1);
-		return 1;
-double amax1(arg1,arg2)
- double arg1;
- double arg2;
-	double res;
-	if (arg1>=arg2) {
-	res = arg1;
-	else  {
-	res = arg2;
-	return res;
-double amin1(arg1,arg2)
- double arg1;
- double arg2;
-	double res;
-	if (arg1<=arg2) {
-	res = arg1;
-	else  {
-	res = arg2;
-	return res;
-int min(arg1,arg2)
- int arg1;
- int arg2;
-	int res;
-	if (arg1 <= arg2)
-	res = arg1;
-	else
-	res = arg2;
-	return res;
-int max(arg1,arg2)
- int arg1;
- int arg2;
-	int res;
-	if (arg1>=arg2) {
-	res = arg1;
-	else  {
-	res = arg2;
-	return res;
-	sinangle=sin(angle);
-	if (fabs(sinangle)<0.0000001) {sinangle=0.;}
-	cosangle=cos(angle);
-	if (fabs(cosangle)<0.0000001) {cosangle=0.;}
-	distsinangle=32000;
-	distcosangle=32000;
-	if (sinangle != 0.)
-	{	distsinangle = 100./(distxy*sinangle);}
-	if (cosangle != 0.)
-	{	distcosangle = 100./(distxy*cosangle);}
-	stepsinangle = stepxy*sinangle;
-	stepcosangle = stepxy*cosangle;
-	double height;
-	tanh0 = 0.;
-	length = 0;
-	height = searching();
-        xx0 = xg0; yy0 = yg0;
-	return height;
-	shadow_angle = horizon_height();
-	return shadow_angle;
-	  double dfr_rad;
-	int i;
-	int printCount;
-	double shadow_angle;
-	double printangle;
-        double sx, sy;
-	double xp, yp;
-	double latitude, longitude;
-   	double delt_lat, delt_lon;
-   	double delt_east, delt_nor;
-	double delt_dist;
-	double angle;
-	printCount=360./fabs(step);
-	if(printCount<1)
-		printCount=1;
-	dfr_rad = step*deg2rad ;
-	xp = xmin + xx0;
-	yp = ymin + yy0;
-	angle = (single_direction*deg2rad)+pihalf;
-	maxlength=fixedMaxLength;
-	for(i=0;i<printCount;i++)
-		ip=jp=0;
-		sx = xx0 * invstepx;
-		sy = yy0 * invstepy;
-		ip100=floor(sx/100.); jp100=floor(sy/100.);
-		if ((G_projection() != PROJECTION_LL))
-            		longitude = xp;
-            		latitude = yp;
-		        if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) <0)
-                		G_fatal_error(_("Error in pj_do_proj"));
-		else
-			{ /* ll projection */
-			latitude = yp;
-			longitude=xp;
-		latitude *= deg2rad;
-		longitude *= deg2rad;
-		delt_lat = -0.0001*cos(angle);
-		delt_lon = 0.0001*sin(angle)/cos(latitude);
-		latitude = (latitude+delt_lat)*rad2deg;
-		longitude = (longitude+delt_lon)*rad2deg;
-		if (pj_do_proj(&longitude, &latitude, &oproj, &iproj) <0)
-		delt_east=longitude-xp;
-		delt_nor=latitude-yp;
-		delt_dist=sqrt(delt_east*delt_east+delt_nor*delt_nor);
-		stepsinangle = stepxy*delt_nor/delt_dist;
-		stepcosangle = stepxy*delt_east/delt_dist;
-		if(degreeOutput)
-			shadow_angle *= rad2deg;
-		printangle=angle*rad2deg-90.;
-		if(printangle<0.)
-			printangle+=360;
-		else if(printangle>=360.)
-			printangle-=360;
-		printf("%lf, %lf\n", printangle, shadow_angle);
-		angle += dfr_rad;
-		if(angle<0.)
-			angle+=twopi;
-		else if(angle>twopi)
-			angle-=twopi;
-		} /* end of for loop over angles */
-int new_point()
-	int iold, jold;
-        int succes = 1, succes2 = 1;
-        double sx, sy;
-        double dx, dy;
-	iold=ip; jold=jp;
-	while (succes)
-          yy0 += stepsinangle;
-          xx0 += stepcosangle;
-    /* offset 0.5 cell size to get the right cell i, j */
-	sx = xx0 * invstepx  + offsetx;
-	sy = yy0 * invstepy  + offsety;
-	ip = (int)sx; jp = (int)sy;
-    /* test outside of raster*/
-	if ((ip < 0) || (ip >= n) || (jp < 0) || (jp >= m)) return (3);
-	if ((ip!=iold) || (jp!=jold))
-		dx = (double)ip *stepx;
-		dy = (double)jp *stepy;
-		length = distance(xg0, dx, yg0, dy); /* dist from orig. grid point to the current grid point */
-		succes2=test_low_res();
-		if (succes2 ==1)
-			zp = z[jp][ip];
-			return(1);
-	return -1;
-int test_low_res()
-	int iold100, jold100;
-        double sx, sy;
-	int delx, dely, mindel;
-	double zp100, z2, curvature_diff;
-	iold100=ip100; jold100=jp100;
-	ip100 = floor(ip/100.); jp100 = floor(jp/100.);
-	/*test the new position with low resolution*/
-	if ((ip100!=iold100) || (jp100!=jold100))
-//printf("%d %d %d %d\n",ip,jp, iold100,jold100);
-/*  replace with approximate version
-			curvature_diff = EARTHRADIUS*(1.-cos(length/EARTHRADIUS));
-			curvature_diff = 0.5*length*length*invEarth;
-			z2 = z_orig + curvature_diff + length * tanh0;
-		zp100=z100[jp100][ip100];
-//printf("%d %d %lf %lf \n",ip,jp,z2,zp100);
-		if (zp100 <= z2)
-			/*skip to the next lowres cell*/
-			delx=32000;
-			dely=32000;
-			if (cosangle>0.) {
-				delx=floor(fabs((ceil(sx/100.) - (sx/100.))*distcosangle));
-			if (cosangle<0.) {
-				delx=floor(fabs((floor(sx/100.) - (sx/100.))*distcosangle));
-			if (sinangle>0.) {
-				dely=floor(fabs((ceil(sy/100.) - (sy/100.))*distsinangle));
-			else if (sinangle<0.) {
-				dely=floor(fabs((floor(jp/100.) - (sy/100.))*distsinangle));
-			mindel=min(delx,dely);
-//printf("%d %d %d %lf %lf\n",ip, jp, mindel,xg0, yg0);
-			yy0 = yy0 + (mindel*stepsinangle);
-			xx0 = xx0 + (mindel*stepcosangle);
-//printf("  %lf %lf\n",xx0,yy0);
-			return(3);
-			else
-			return(1); /*change of low res array - new cell is reaching limit for high resolution processing*/
-	else
-	return(1); /*no change of low res array*/
-double searching()
-	double z2;
-	double curvature_diff;
-        int succes = 1;
-	if(zp==UNDEFZ)
-		return 0;
-	while(1)
-		succes = new_point();
-		if(succes!=1)
-			break;
-		if (z2 < zp)
-			tanh0 = (zp-z_orig-curvature_diff)/length;
-        	if( z2 >= zmax)
-			break;
-        	if( length >= maxlength)
-			break;
-       return atan(tanh0);
-	int i, j, l, k=0;
-	int numDigits;
-	int xindex, yindex;
-	double coslat;
-	double latitude,longitude;
-	double xp, yp;
-	double inputAngle;
-	double delt_dist;
-	char formatString[10];
-	int hor_row_start=buffer_s;
-	int hor_row_end= m - buffer_n;
-	int hor_col_start= buffer_w;
-	int hor_col_end= n - buffer_e;
-	int hor_numrows = m - (buffer_s+buffer_n);
-	int hor_numcols = n - (buffer_e+buffer_w);
-/*	char shad_filename[256];*/
-	int arrayNumInt;
-	double dfr_rad;
-	fprintf(stderr,"\n\n");
-	xindex = (int) ((xcoord-xmin)/stepx);
-	yindex = (int) ((ycoord-ymin)/stepy);
-	if ((G_projection() == PROJECTION_LL))
-		ll_correction=1;
-	if(isMode()==SINGLE_POINT)
-		/* Calculate the horizon for one single point */
-		xg0 = xx0 = (double)xcoord * stepx;
-		yg0 = yy0 = (double)ycoord * stepy;
-		xg0 = xx0 = xcoord -0.5*stepx -xmin;
-		yg0 = yy0 = ycoord -0.5*stepy-ymin;
-			xg0 = xx0 = xindex*stepx -0.5*stepx;
-			yg0 = yy0 = yindex*stepy -0.5*stepy;
-		xg0 = xx0 = xindex*stepx;
-		yg0 = yy0 = yindex*stepy;
-		if(ll_correction)
-			coslat=cos(deg2rad*(ymin + yy0));
-			coslatsq = coslat*coslat;
-		z_orig= zp = z[yindex][xindex];
-		calculate_shadow();
-	else
-		/*  The loop over raster points starts here!                    */
-                        horizon_raster = (float **)malloc(sizeof(float *)*(hor_numrows));
-                        for( l=0; l<hor_numrows; l++)
-                          horizon_raster[l] = (float*)malloc(sizeof(float)*(hor_numcols));
-                        for (j = 0; j < hor_numrows; j++)
-                          for (i = 0; i < hor_numcols; i++)
-                          	horizon_raster[j][i] = 0.;
-definition of horizon angle in loop
-	if (step==0.0)  {
-		dfr_rad = 0;
-		arrayNumInt=1;
-		sprintf(shad_filename, "%s", horizon);
-	else {
-		dfr_rad = step*deg2rad;
-		arrayNumInt = (int)(360. / fabs(step));
-	numDigits = (int)(log10(1.*arrayNumInt))+1;
-	sprintf(formatString, "%%s_%%0%dd", numDigits);
-	for (k = 0; k < arrayNumInt; k++) {
-		if (step!=0.0)  sprintf(shad_filename, formatString, horizon,k);
-		angle = (single_direction*deg2rad)+(dfr_rad*k);
-		com_par(angle);
-		printf("%01d from %01d  angle %lf  %s\n", (k+1),arrayNumInt,angle*rad2deg,shad_filename);
-		for (j = hor_row_start; j < hor_row_end; j++) {
-			G_percent(j-hor_row_start,hor_numrows-1,2);
-			shadow_angle = 15*deg2rad;
-			for (i = hor_col_start; i < hor_col_end; i++) {
-				ip100=floor(i/100.); jp100=floor(j/100.);
-				ip=jp=0;
-				xg0 = xx0 = (double)i * stepx;
-				xp = xmin + xx0;
-				yg0 = yy0 = (double)j * stepy;
-				yp = ymin + yy0;
-				length=0;
-				if(ll_correction)
-					coslat=cos(deg2rad*yp);
-				longitude=xp;
-				latitude = yp;
-                				G_fatal_error("Error in pj_do_proj");
-				inputAngle=angle+pihalf;
-				inputAngle=(inputAngle>=twopi)?inputAngle-twopi:inputAngle;
-				delt_lat = -0.0001*cos(inputAngle); /* Arbitrary small distance in latitude */
-				delt_lon = 0.0001*sin(inputAngle)/cos(latitude);
-				sinangle=delt_nor/delt_dist;
-				cosangle=delt_east/delt_dist;
-				z_orig= zp = z[j][i];
-				maxlength=(zmax-z_orig)/TANMINANGLE;
-				maxlength=(maxlength<fixedMaxLength)?maxlength:fixedMaxLength;
-                          if (z_orig != UNDEFZ) {
-/*printf("**************new line %d %d\n", i, j);
-				if(degreeOutput)
-				if((j==1400)&&(i==1400))
-					printf("coordinates=%f,%f, raster no. %d, horizon=%f\n",
-					       xp, yp, k, shadow_angle);
-				horizon_raster[j-buffer_s][i-buffer_w] = shadow_angle;
-				} /* undefs*/
-		/* empty array*/
-  		/*return back the buffered region*/
-		if(bufferZone>0.)
-			if(G_set_window(&new_cellhd)==-1) exit(0);
+r.horizon: This module does one of two things:
+1) Using a map of the terrain elevation it calculates for a set of points
+the angle height of the horizon for each point, using an angle interval given
+by the user.
+2) For a given minimum angle it calculates one or more raster map giving the mazimum
+distance to a point on the horizon.
+This program was written in 2006 by Tfomas Huld and Tomas Cebecauer,
+Joint Research Centre of the European Commission, based on bits of the r.sun module by Jaro Hofierka
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License
+ * as published by the Free Software Foundation; either version 2
+ * of the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the
+ *   Free Software Foundation, Inc.,
+ *   59 Temple Place - Suite 330,
+ *   Boston, MA  02111-1307, USA.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <malloc.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+#define WHOLE_RASTER 1
+#define SINGLE_POINT 0
+#define RAD      (180. / M_PI)
+#define DEG      ((M_PI)/180.)
+#define EARTHRADIUS 6371000.
+#define UNDEF    0.            /* undefined value for terrain aspect*/
+#define UNDEFZ   -9999.        /* undefined value for elevation */
+#define BIG      1.e20
+#define SMALL    1.e-20
+#define EPS      1.e-4
+#define DIST     "1.0"
+#define DEGREEINMETERS 111120.
+#define TANMINANGLE 0.008727		/* tan of minimum horizon angle (0.5 deg) */
+#define AMAX1(arg1, arg2) ((arg1) >= (arg2) ? (arg1) : (arg2))
+#define DISTANCE1(x1, x2, y1, y2) (sqrt((x1 - x2)*(x1 - x2) + (y1 - y2)*(y1 - y2)))
+FILE *fw;
+const double rad2deg = 180./M_PI;
+const double deg2rad = M_PI/180.;
+const double pihalf=M_PI*0.5;
+const double twopi=2.*M_PI;
+const double invEarth=1./EARTHRADIUS;
+const double minAngle=DEG;
+char *elevin;
+char *latin = NULL;
+char *horizon = NULL;
+char *mapset = NULL;
+char *per;
+char shad_filename[256];
+struct Cell_head cellhd;
+struct Key_value *in_proj_info, *in_unit_info;
+struct pj_info iproj;
+struct pj_info oproj;
+struct Cell_head new_cellhd;
+double bufferZone=0., ebufferZone=0., wbufferZone=0., nbufferZone=0., sbufferZone=0.;
+int INPUT(void);
+int OUTGR(int numrows, int numcols);
+double amax1(double, double);
+double amin1(double, double);
+int min(int, int);
+int max(int, int);
+void com_par(double angle);
+int is_shadow(void);
+double  horizon_height(void);
+void calculate_shadow();
+double calculate_shadow_onedirection(double shadow_angle);
+int new_point();
+double searching();
+int test_low_res();
+/*void where_is_point();
+void cube(int, int);
+void calculate(double xcoord, double ycoord, int buffer_e, int buffer_w, int buffer_s, int buffer_n);
+int     ip, jp,  ip100, jp100;
+int     n, m,  m100, n100;
+int degreeOutput=0;
+float     **z, **z100, **horizon_raster;
+double  stepx, stepy, stepxhalf, stepyhalf, stepxy, xp, yp, op, dp, xg0, xx0, yg0, yy0,deltx,delty;
+double  invstepx, invstepy, distxy;
+double offsetx, offsety;
+double single_direction;
+/*int arrayNumInt;*/
+double  xmin, xmax, ymin, ymax,zmax=0.;
+int     d, day, tien=0;
+double  length, maxlength=BIG, zmult=1.0, step=0.0,dist;
+double fixedMaxLength=BIG;
+char *tt,*lt;
+double z_orig,zp;
+double h0, tanh0, angle;
+double stepsinangle, stepcosangle, sinangle, cosangle, distsinangle, distcosangle;
+double TOLER;
+int mode;
+int isMode()
+	return mode;
+void setMode(int val)
+	mode = val;
+int ll_correction=0;
+double coslatsq;
+double distance(double x1, double x2, double y1, double y2)
+	if(ll_correction)
+		return DEGREEINMETERS*sqrt(coslatsq*(x1-x2)*(x1-x2)
+				+(y1-y2)*(y1-y2));
+	else
+		return sqrt((x1 - x2)*(x1 - x2) + (y1 - y2)*(y1 - y2));
+int main(int argc, char *argv[])
+	double xcoord, ycoord;
+	struct GModule *module;
+ 	struct
+		struct Option *elevin,*dist,*coord,*direction,*horizon,*step,*bufferzone,*e_buff,*w_buff,*n_buff,*s_buff, *maxdistance;
+	} parm;
+	struct
+		struct Flag   *degreeOutput;
+	flag;
+	  G_gisinit (argv[0]);
+          module = G_define_module();
+	module->keywords = _("raster");
+	module->label = _("Horizon angle computation from a digital elevation model.");
+	module->description =
+          _("Computes horizon angle height from a digital elevation model. The module has two"
+		  " different modes of operation:  "
+		  "1. Computes the entire horizon around a single point whose coordinates are"
+		  " given on withe the 'coord' option. The horizon height (in radians). "
+		  "2. Computes one or more raster maps of the horizon height in a single direction. "
+		  " The input for this is the angle (in degrees), which is measured "
+		  " counterclockwise with east=0, north=90 etc. The output is the horizon height in radians.");
+	if(G_get_set_window(&cellhd)==-1) G_fatal_error("G_get_set_window() failed");
+	stepx = cellhd.ew_res;
+	stepy = cellhd.ns_res;
+	stepxhalf = stepx/2.;
+	stepyhalf = stepy/2.;
+	invstepx = 1./stepx;
+	invstepy = 1./stepy;
+	offsetx = 2. *  invstepx;
+    	offsety = 2. * invstepy;
+	offsetx = 0.5*stepx;
+    	offsety = 0.5*stepy;
+	offsetx = 0.5;
+    	offsety = 0.5;
+	n/*n_cols*/ = cellhd.cols;
+	m/*n_rows*/ = cellhd.rows;
+	n100=ceil(n/100.);
+	m100=ceil(m/100.);
+	xmin = cellhd.west;
+	ymin = cellhd.south;
+	xmax = cellhd.east;
+	ymax = cellhd.north;
+        deltx = fabs(cellhd.east - cellhd.west);
+        delty = fabs(cellhd.north - cellhd.south);
+	  parm.elevin = G_define_option();
+	  parm.elevin->key = "elevin";
+	  parm.elevin->type = TYPE_STRING;
+	  parm.elevin->required = YES;
+	  parm.elevin->gisprompt = "old,cell,raster";
+	  parm.elevin->description = _("Name of the input elevation raster map [meters]");
+  	  parm.elevin->guisection  = _("Input_options");
+	  parm.direction = G_define_option();
+	  parm.direction->key = "direction";
+	  parm.direction->type = TYPE_DOUBLE;
+	  parm.direction->required = NO;
+	  parm.direction->description = _("Direction in which you want to know the horizon height");
+	  parm.direction->guisection = _("Input_options");
+	  parm.step = G_define_option();
+	  parm.step->key = "step";
+	  parm.step->type = TYPE_DOUBLE;
+	  parm.step->required = NO;
+	  parm.step->description = _("For multidirectional horizon: the step size in degrees");
+	  parm.step->guisection = _("Input_options");
+	  parm.bufferzone = G_define_option();
+	  parm.bufferzone->key = "bufferzone";
+	  parm.bufferzone->type = TYPE_DOUBLE;
+	  parm.bufferzone->required = NO;
+	  parm.bufferzone->description = _("For horizon rasters, read from the DEM an extra buffer around the present region");
+	  parm.bufferzone->guisection = _("Input_options");
+	  parm.e_buff = G_define_option();
+	  parm.e_buff->key = "e_buff";
+	  parm.e_buff->type = TYPE_DOUBLE;
+	  parm.e_buff->required = NO;
+	  parm.e_buff->description = _("For horizon rasters, read from the DEM an extra buffer eastward the present region");
+	  parm.e_buff->guisection = _("Input_options");
+	  parm.w_buff = G_define_option();
+	  parm.w_buff->key = "w_buff";
+	  parm.w_buff->type = TYPE_DOUBLE;
+	  parm.w_buff->required = NO;
+	  parm.w_buff->description = _("For horizon rasters, read from the DEM an extra buffer westward the present region");
+	  parm.w_buff->guisection = _("Input_options");
+	  parm.n_buff = G_define_option();
+	  parm.n_buff->key = "n_buff";
+	  parm.n_buff->type = TYPE_DOUBLE;
+	  parm.n_buff->required = NO;
+	  parm.n_buff->description = _("For horizon rasters, read from the DEM an extra buffer northward the present region");
+	  parm.n_buff->guisection = _("Input_options");
+	  parm.s_buff = G_define_option();
+	  parm.s_buff->key = "s_buff";
+	  parm.s_buff->type = TYPE_DOUBLE;
+	  parm.s_buff->required = NO;
+	  parm.s_buff->description = _("For horizon rasters, read from the DEM an extra buffer southward the present region");
+	  parm.s_buff->guisection = _("Input_options");
+	  parm.maxdistance = G_define_option();
+	  parm.maxdistance->key = "maxdistance";
+	  parm.maxdistance->type = TYPE_DOUBLE;
+	  parm.maxdistance->required = NO;
+	  parm.maxdistance->description = _("The maximum distance to consider when finding the horizon height");
+	  parm.maxdistance->guisection = _("Input_options");
+	  parm.horizon = G_define_option();
+	  parm.horizon->key = "horizon";
+	  parm.horizon->type = TYPE_STRING;
+	  parm.horizon->required = NO;
+	  parm.horizon->gisprompt = "old,cell,raster";
+	  parm.horizon->description = _("Name of the horizon raster output");
+	  parm.horizon->guisection = _("Output_options");
+          parm.coord = G_define_option();
+          parm.coord->key = "coord";
+          parm.coord->type = TYPE_STRING;
+          parm.coord->required = NO;
+          parm.coord->description = _("Coordinate for which you want to calculate the horizon");
+          parm.coord->guisection = _("Output_options");
+          parm.dist = G_define_option();
+          parm.dist->key = "dist";
+          parm.dist->type = TYPE_DOUBLE;
+          parm.dist->answer = DIST;
+          parm.dist->required = NO;
+          parm.dist->description = _("Sampling distance step coefficient (0.5-1.5)");
+          parm.dist->guisection = _("Output_options");
+	  flag.degreeOutput = G_define_flag();
+	  flag.degreeOutput->key = 'd';
+	  flag.degreeOutput->description =
+			  _("Write output in degrees (default is radians)");
+ 	if (G_parser(argc, argv))
+	   exit(EXIT_FAILURE);
+	degreeOutput = flag.degreeOutput->answer;
+	elevin = parm.elevin->answer;
+	if(parm.coord->answer==NULL)
+		setMode(WHOLE_RASTER);
+	else
+		setMode(SINGLE_POINT);
+		if(sscanf(parm.coord->answer,"%lf,%lf", &xcoord, &ycoord)!=2)
+		    G_fatal_error
+			("Can't read the coordinates from the \"coord\" option.");
+		/* Transform the coordinates to row/column */
+		xcoord = (int) ((xcoord-xmin)/stepx);
+		ycoord = (int) ((ycoord-ymin)/stepy);
+	if(parm.direction->answer!=NULL) sscanf(parm.direction->answer, "%lf", &single_direction);
+	if(isMode(WHOLE_RASTER))
+		if((parm.direction->answer==NULL) && (parm.step->answer==NULL))
+			G_fatal_error
+			(_("You didn't specify a direction value or step size. Aborting."));
+		if(parm.horizon->answer==NULL)
+			G_fatal_error
+			(_("You didn't specify a horizon raster name. Aborting."));
+		horizon = parm.horizon->answer;
+		if(parm.step->answer!=NULL) sscanf(parm.step->answer, "%lf", &step);
+	else
+		if(parm.step->answer==NULL)
+			G_fatal_error
+			(_("You didn't specify an angle step size. Aborting."));
+	        sscanf(parm.step->answer, "%lf", &step);
+	if(step==0.0)
+		step=360.;
+	if(parm.bufferzone->answer!=NULL)
+		if(sscanf(parm.bufferzone->answer, "%lf", &bufferZone)!=1)
+			G_fatal_error
+			(_("Could not read bufferzone size. Aborting."));
+	if(parm.e_buff->answer!=NULL)
+		if(sscanf(parm.e_buff->answer, "%lf", &ebufferZone)!=1)
+			G_fatal_error
+			(_("Could not read east bufferzone size. Aborting."));
+	if(parm.w_buff->answer!=NULL)
+		if(sscanf(parm.w_buff->answer, "%lf", &wbufferZone)!=1)
+			G_fatal_error
+			(_("Could not read west bufferzone size. Aborting."));
+	if(parm.s_buff->answer!=NULL)
+		if(sscanf(parm.s_buff->answer, "%lf", &sbufferZone)!=1)
+			G_fatal_error
+			(_("Could not read south bufferzone size. Aborting."));
+	if(parm.n_buff->answer!=NULL)
+		if(sscanf(parm.n_buff->answer, "%lf", &nbufferZone)!=1)
+			G_fatal_error
+			(_("Could not read north bufferzone size. Aborting."));
+	if(parm.maxdistance->answer!=NULL)
+		if(sscanf(parm.maxdistance->answer, "%lf", &fixedMaxLength)!=1)
+			G_fatal_error
+			(_("Could not read maximum distance. Aborting."));
+        sscanf(parm.dist->answer, "%lf", &dist);
+                stepxy = dist * 0.5 * (stepx + stepy);
+		distxy = dist;
+                TOLER = stepxy * EPS;
+	if(bufferZone>0. || ebufferZone>0. || wbufferZone>0. || sbufferZone>0. || nbufferZone>0.)
+		new_cellhd=cellhd;
+		if (ebufferZone==0.) ebufferZone=bufferZone;
+		if (wbufferZone==0.) wbufferZone=bufferZone;
+		if (sbufferZone==0.) sbufferZone=bufferZone;
+		if (nbufferZone==0.) nbufferZone=bufferZone;
+		new_cellhd.rows+=(int) ((nbufferZone+sbufferZone)/stepy);
+		new_cellhd.cols+=(int) ((ebufferZone+wbufferZone)/stepx);
+		new_cellhd.north+=nbufferZone;
+		new_cellhd.south-=sbufferZone;
+		new_cellhd.east+=ebufferZone;
+		new_cellhd.west-=wbufferZone;
+		xmin = new_cellhd.west;
+		ymin = new_cellhd.south;
+		xmax = new_cellhd.east;
+		ymax = new_cellhd.north;
+        	deltx = fabs(new_cellhd.east - new_cellhd.west);
+        	delty = fabs(new_cellhd.north - new_cellhd.south);
+		n/*n_cols*/ = new_cellhd.cols;
+		m/*n_rows*/ = new_cellhd.rows;
+/*printf("%lf %lf %lf %lf \n",ymax, ymin, xmin,xmax);
+		if(G_set_window(&new_cellhd)==-1) exit(EXIT_FAILURE);
+	struct Key_Value *in_proj_info, *in_unit_info;
+	if ((in_proj_info = G_get_projinfo()) == NULL)
+	    G_fatal_error
+		(_("Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"));
+	if ((in_unit_info = G_get_projunits()) == NULL)
+	    G_fatal_error(_("Can't get projection units of current location"));
+	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+	    G_fatal_error
+		(_("Can't get projection key values of current location"));
+	G_free_key_value(in_proj_info);
+	G_free_key_value(in_unit_info);
+	/* Set output projection to latlong w/ same ellipsoid */
+	oproj.zone = 0;
+	oproj.meters = 1.;
+	sprintf(oproj.proj, "ll");
+	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+	    G_fatal_error(_("Unable to set up lat/long projection parameters"));
+/**********end of parser - ******************************/
+	   INPUT();
+	   calculate(xcoord, ycoord, (int) (ebufferZone/stepx), (int) (wbufferZone/stepx),  (int) (sbufferZone/stepy), (int) (nbufferZone/stepy));
+	if(bufferZone>0.)
+		/* Set the region window back to the original */
+		if(G_set_window(&cellhd)==-1) exit(EXIT_FAILURE);
+/*sorry, I've moved OUTGR to calculate() - into the loop*/
+/*	if(isMode(WHOLE_RASTER))
+		OUTGR(cellhd.rows,cellhd.cols);
+	exit(EXIT_SUCCESS);
+/**********************end of main.c*****************/
+int INPUT(void)
+	FCELL    *cell1;
+	int     fd1, row, row_rev;
+	int     l,i,j,k;
+	int     lmax,kmax;
+	cell1=G_allocate_f_raster_buf();
+	z = (float **)malloc(sizeof(float *)*(m));
+	z100 = (float **)malloc(sizeof(float *)*(m100));
+  for(l=0;l<m;l++)
+	z[l]   = (float*)malloc(sizeof(float)*(n));
+  for(l=0;l<m100;l++)
+	z100[l]   = (float*)malloc(sizeof(float)*(n100));
+/*read Z raster*/
+  if((mapset=G_find_cell(elevin,""))==NULL)
+  	G_fatal_error(_("Elevation raster file not found"));
+  fd1 = G_open_cell_old(elevin,mapset);
+  for (row=0; row<m; row++)
+	  G_get_f_raster_row(fd1,cell1,row);
+	for (j=0; j<n; j++)
+	   row_rev = m - row - 1;
+	    if (!G_is_f_null_value(cell1 + j))
+                z[row_rev][j] = (float)cell1[j];
+            else
+                z[row_rev][j] = UNDEFZ;
+  G_close_cell(fd1);
+/*create low resolution array 100*/
+  for (i=0; i<m100; i++)
+	lmax=(i+1)*100;
+	if (lmax>m) lmax=m;
+	for (j=0; j<n100; j++)
+		zmax=SMALL;
+		kmax=(j+1)*100;
+		if (kmax>n) kmax=n;
+	 	for (l=(i*100); l<lmax; l++)
+		 	for (k=(j*100); k<kmax; k++)
+				zmax=amax1(zmax,z[l][k]);
+		z100[i][j]=zmax;
+//printf("%d %d %lf\n", i, j, z100[i][j]);
+/*find max Z*/
+  for (i = 0; i < m; i++)
+	  for (j = 0; j < n; j++)
+		zmax = amax1(zmax,z[i][j]);
+	return 1;
+	FCELL *cell1=NULL;
+   int 	 	fd1=0;
+   int      i,iarc,j;
+   if(G_set_window (&cellhd) < 0) exit(EXIT_FAILURE);
+    if (horizon != NULL) {
+	cell1 = G_allocate_f_raster_buf();
+	fd1 = G_open_fp_cell_new(shad_filename);
+	if (fd1 < 0)
+	    G_fatal_error(_("Unable to create raster map %s"), shad_filename);
+   if (numrows != G_window_rows())
+	  G_fatal_error(_("OOPS: rows changed from %d to %d"), numrows, G_window_rows());
+   if (numcols != G_window_cols())
+	  G_fatal_error(_("OOPS: cols changed from %d to %d"), numcols, G_window_cols());
+	  for(iarc=0;iarc<numrows;iarc++)
+	  i=numrows-iarc-1;
+		    for (j = 0; j < numcols; j++) {
+			if (horizon_raster[i][j] == UNDEFZ)
+			    G_set_f_null_value(cell1 + j, 1);
+			else
+			    cell1[j] = (FCELL) horizon_raster[i][j];
+		    G_put_f_raster_row(fd1, cell1);
+	  } /* End loop over rows. */
+	G_close_cell (fd1);
+		return 1;
+double amax1(arg1,arg2)
+ double arg1;
+ double arg2;
+	double res;
+	if (arg1>=arg2) {
+	res = arg1;
+	else  {
+	res = arg2;
+	return res;
+double amin1(arg1,arg2)
+ double arg1;
+ double arg2;
+	double res;
+	if (arg1<=arg2) {
+	res = arg1;
+	else  {
+	res = arg2;
+	return res;
+int min(arg1,arg2)
+ int arg1;
+ int arg2;
+	int res;
+	if (arg1 <= arg2)
+	res = arg1;
+	else
+	res = arg2;
+	return res;
+int max(arg1,arg2)
+ int arg1;
+ int arg2;
+	int res;
+	if (arg1>=arg2) {
+	res = arg1;
+	else  {
+	res = arg2;
+	return res;
+	sinangle=sin(angle);
+	if (fabs(sinangle)<0.0000001) {sinangle=0.;}
+	cosangle=cos(angle);
+	if (fabs(cosangle)<0.0000001) {cosangle=0.;}
+	distsinangle=32000;
+	distcosangle=32000;
+	if (sinangle != 0.)
+	{	distsinangle = 100./(distxy*sinangle);}
+	if (cosangle != 0.)
+	{	distcosangle = 100./(distxy*cosangle);}
+	stepsinangle = stepxy*sinangle;
+	stepcosangle = stepxy*cosangle;
+	double height;
+	tanh0 = 0.;
+	length = 0;
+	height = searching();
+        xx0 = xg0; yy0 = yg0;
+	return height;
+	shadow_angle = horizon_height();
+	return shadow_angle;
+	  double dfr_rad;
+	int i;
+	int printCount;
+	double shadow_angle;
+	double printangle;
+        double sx, sy;
+	double xp, yp;
+	double latitude, longitude;
+   	double delt_lat, delt_lon;
+   	double delt_east, delt_nor;
+	double delt_dist;
+	double angle;
+	printCount=360./fabs(step);
+	if(printCount<1)
+		printCount=1;
+	dfr_rad = step*deg2rad ;
+	xp = xmin + xx0;
+	yp = ymin + yy0;
+	angle = (single_direction*deg2rad)+pihalf;
+	maxlength=fixedMaxLength;
+	for(i=0;i<printCount;i++)
+		ip=jp=0;
+		sx = xx0 * invstepx;
+		sy = yy0 * invstepy;
+		ip100=floor(sx/100.); jp100=floor(sy/100.);
+		if ((G_projection() != PROJECTION_LL))
+            		longitude = xp;
+            		latitude = yp;
+		        if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) <0)
+                		G_fatal_error(_("Error in pj_do_proj"));
+		else
+			{ /* ll projection */
+			latitude = yp;
+			longitude=xp;
+		latitude *= deg2rad;
+		longitude *= deg2rad;
+		delt_lat = -0.0001*cos(angle);
+		delt_lon = 0.0001*sin(angle)/cos(latitude);
+		latitude = (latitude+delt_lat)*rad2deg;
+		longitude = (longitude+delt_lon)*rad2deg;
+		if (pj_do_proj(&longitude, &latitude, &oproj, &iproj) <0)
+		delt_east=longitude-xp;
+		delt_nor=latitude-yp;
+		delt_dist=sqrt(delt_east*delt_east+delt_nor*delt_nor);
+		stepsinangle = stepxy*delt_nor/delt_dist;
+		stepcosangle = stepxy*delt_east/delt_dist;
+		if(degreeOutput)
+			shadow_angle *= rad2deg;
+		printangle=angle*rad2deg-90.;
+		if(printangle<0.)
+			printangle+=360;
+		else if(printangle>=360.)
+			printangle-=360;
+		printf("%lf, %lf\n", printangle, shadow_angle);
+		angle += dfr_rad;
+		if(angle<0.)
+			angle+=twopi;
+		else if(angle>twopi)
+			angle-=twopi;
+		} /* end of for loop over angles */
+int new_point()
+	int iold, jold;
+        int succes = 1, succes2 = 1;
+        double sx, sy;
+        double dx, dy;
+	iold=ip; jold=jp;
+	while (succes)
+          yy0 += stepsinangle;
+          xx0 += stepcosangle;
+    /* offset 0.5 cell size to get the right cell i, j */
+	sx = xx0 * invstepx  + offsetx;
+	sy = yy0 * invstepy  + offsety;
+	ip = (int)sx; jp = (int)sy;
+    /* test outside of raster*/
+	if ((ip < 0) || (ip >= n) || (jp < 0) || (jp >= m)) return (3);
+	if ((ip!=iold) || (jp!=jold))
+		dx = (double)ip *stepx;
+		dy = (double)jp *stepy;
+		length = distance(xg0, dx, yg0, dy); /* dist from orig. grid point to the current grid point */
+		succes2=test_low_res();
+		if (succes2 ==1)
+			zp = z[jp][ip];
+			return(1);
+	return -1;
+int test_low_res()
+	int iold100, jold100;
+        double sx, sy;
+	int delx, dely, mindel;
+	double zp100, z2, curvature_diff;
+	iold100=ip100; jold100=jp100;
+	ip100 = floor(ip/100.); jp100 = floor(jp/100.);
+	/*test the new position with low resolution*/
+	if ((ip100!=iold100) || (jp100!=jold100))
+//printf("%d %d %d %d\n",ip,jp, iold100,jold100);
+/*  replace with approximate version
+			curvature_diff = EARTHRADIUS*(1.-cos(length/EARTHRADIUS));
+			curvature_diff = 0.5*length*length*invEarth;
+			z2 = z_orig + curvature_diff + length * tanh0;
+		zp100=z100[jp100][ip100];
+//printf("%d %d %lf %lf \n",ip,jp,z2,zp100);
+		if (zp100 <= z2)
+			/*skip to the next lowres cell*/
+			delx=32000;
+			dely=32000;
+			if (cosangle>0.) {
+				delx=floor(fabs((ceil(sx/100.) - (sx/100.))*distcosangle));
+			if (cosangle<0.) {
+				delx=floor(fabs((floor(sx/100.) - (sx/100.))*distcosangle));
+			if (sinangle>0.) {
+				dely=floor(fabs((ceil(sy/100.) - (sy/100.))*distsinangle));
+			else if (sinangle<0.) {
+				dely=floor(fabs((floor(jp/100.) - (sy/100.))*distsinangle));
+			mindel=min(delx,dely);
+//printf("%d %d %d %lf %lf\n",ip, jp, mindel,xg0, yg0);
+			yy0 = yy0 + (mindel*stepsinangle);
+			xx0 = xx0 + (mindel*stepcosangle);
+//printf("  %lf %lf\n",xx0,yy0);
+			return(3);
+			else
+			return(1); /*change of low res array - new cell is reaching limit for high resolution processing*/
+	else
+	return(1); /*no change of low res array*/
+double searching()
+	double z2;
+	double curvature_diff;
+        int succes = 1;
+	if(zp==UNDEFZ)
+		return 0;
+	while(1)
+		succes = new_point();
+		if(succes!=1)
+			break;
+		if (z2 < zp)
+			tanh0 = (zp-z_orig-curvature_diff)/length;
+        	if( z2 >= zmax)
+			break;
+        	if( length >= maxlength)
+			break;
+       return atan(tanh0);
+	int i, j, l, k=0;
+	int numDigits;
+	int xindex, yindex;
+	double coslat;
+	double latitude,longitude;
+	double xp, yp;
+	double inputAngle;
+	double delt_dist;
+	char formatString[10];
+	int hor_row_start=buffer_s;
+	int hor_row_end= m - buffer_n;
+	int hor_col_start= buffer_w;
+	int hor_col_end= n - buffer_e;
+	int hor_numrows = m - (buffer_s+buffer_n);
+	int hor_numcols = n - (buffer_e+buffer_w);
+/*	char shad_filename[256];*/
+	int arrayNumInt;
+	double dfr_rad;
+	fprintf(stderr,"\n\n");
+	xindex = (int) ((xcoord-xmin)/stepx);
+	yindex = (int) ((ycoord-ymin)/stepy);
+	if ((G_projection() == PROJECTION_LL))
+		ll_correction=1;
+	if(isMode()==SINGLE_POINT)
+		/* Calculate the horizon for one single point */
+		xg0 = xx0 = (double)xcoord * stepx;
+		yg0 = yy0 = (double)ycoord * stepy;
+		xg0 = xx0 = xcoord -0.5*stepx -xmin;
+		yg0 = yy0 = ycoord -0.5*stepy-ymin;
+			xg0 = xx0 = xindex*stepx -0.5*stepx;
+			yg0 = yy0 = yindex*stepy -0.5*stepy;
+		xg0 = xx0 = xindex*stepx;
+		yg0 = yy0 = yindex*stepy;
+		if(ll_correction)
+			coslat=cos(deg2rad*(ymin + yy0));
+			coslatsq = coslat*coslat;
+		z_orig= zp = z[yindex][xindex];
+		calculate_shadow();
+	else
+		/*  The loop over raster points starts here!                    */
+                        horizon_raster = (float **)malloc(sizeof(float *)*(hor_numrows));
+                        for( l=0; l<hor_numrows; l++)
+                          horizon_raster[l] = (float*)malloc(sizeof(float)*(hor_numcols));
+                        for (j = 0; j < hor_numrows; j++)
+                          for (i = 0; i < hor_numcols; i++)
+                          	horizon_raster[j][i] = 0.;
+definition of horizon angle in loop
+	if (step==0.0)  {
+		dfr_rad = 0;
+		arrayNumInt=1;
+		sprintf(shad_filename, "%s", horizon);
+	else {
+		dfr_rad = step*deg2rad;
+		arrayNumInt = (int)(360. / fabs(step));
+	numDigits = (int)(log10(1.*arrayNumInt))+1;
+	sprintf(formatString, "%%s_%%0%dd", numDigits);
+	for (k = 0; k < arrayNumInt; k++) {
+		if (step!=0.0)  sprintf(shad_filename, formatString, horizon,k);
+		angle = (single_direction*deg2rad)+(dfr_rad*k);
+		com_par(angle);
+		printf("%01d from %01d  angle %lf  %s\n", (k+1),arrayNumInt,angle*rad2deg,shad_filename);
+		for (j = hor_row_start; j < hor_row_end; j++) {
+			G_percent(j-hor_row_start,hor_numrows-1,2);
+			shadow_angle = 15*deg2rad;
+			for (i = hor_col_start; i < hor_col_end; i++) {
+				ip100=floor(i/100.); jp100=floor(j/100.);
+				ip=jp=0;
+				xg0 = xx0 = (double)i * stepx;
+				xp = xmin + xx0;
+				yg0 = yy0 = (double)j * stepy;
+				yp = ymin + yy0;
+				length=0;
+				if(ll_correction)
+					coslat=cos(deg2rad*yp);
+				longitude=xp;
+				latitude = yp;
+                				G_fatal_error("Error in pj_do_proj");
+				inputAngle=angle+pihalf;
+				inputAngle=(inputAngle>=twopi)?inputAngle-twopi:inputAngle;
+				delt_lat = -0.0001*cos(inputAngle); /* Arbitrary small distance in latitude */
+				delt_lon = 0.0001*sin(inputAngle)/cos(latitude);
+				sinangle=delt_nor/delt_dist;
+				cosangle=delt_east/delt_dist;
+				z_orig= zp = z[j][i];
+				maxlength=(zmax-z_orig)/TANMINANGLE;
+				maxlength=(maxlength<fixedMaxLength)?maxlength:fixedMaxLength;
+                          if (z_orig != UNDEFZ) {
+/*printf("**************new line %d %d\n", i, j);
+				if(degreeOutput)
+				if((j==1400)&&(i==1400))
+					printf("coordinates=%f,%f, raster no. %d, horizon=%f\n",
+					       xp, yp, k, shadow_angle);
+				horizon_raster[j-buffer_s][i-buffer_w] = shadow_angle;
+				} /* undefs*/
+		/* empty array*/
+  		/*return back the buffered region*/
+		if(bufferZone>0.)
+			if(G_set_window(&new_cellhd)==-1) exit(0);
