[GRASS-SVN] r31723 - grass-addons/visualization/nviz2/wxpython
svn_grass at osgeo.org
Mon Jun 16 12:43:13 EDT 2008
Author: martinl
Date: 2008-06-16 12:43:13 -0400 (Mon, 16 Jun 2008)
New Revision: 31723
Added:
grass-addons/visualization/nviz2/wxpython/nviz.py
grass-addons/visualization/nviz2/wxpython/mapdisp.py
grass-addons/visualization/nviz2/wxpython/toolbars.py
nviz2/wx: initial modifications towards 3D map display
Modified: grass-addons/visualization/nviz2/wxpython/mapdisp.py
--- grass-addons/visualization/nviz2/wxpython/mapdisp.py 2008-06-16 14:30:44 UTC (rev 31722)
+++ grass-addons/visualization/nviz2/wxpython/mapdisp.py 2008-06-16 16:43:13 UTC (rev 31723)
@@ -60,6 +60,7 @@
import globalvar
import utils
import gdialogs
+import nviz
from vdigit import VDigitCategoryDialog as VDigitCategoryDialog
from vdigit import VDigitZBulkDialog as VDigitZBulkDialog
from vdigit import VDigitDuplicatesDialog as VDigitDuplicatesDialog
@@ -539,9 +540,21 @@
def UpdateMap(self, render=True, renderVector=True):
- Updates the canvas anytime there is a change to the underlaying images
- or to the geometry of the canvas.
+ Updates the canvas anytime there is a change to the
+ underlaying images or to the geometry of the canvas.
+ if self.parent.toolbars['nviz']:
+ self.UpdateMap3D() # OpenGL
+ else:
+ self.UpdateMap2D(render, renderVector)
+ def UpdateMap2D(self, render=True, renderVector=True):
+ This method works in 2D mode.
@param render re-render map composition
@param renderVector re-render vector map layer enabled for editing (used for digitizer)
@@ -661,11 +674,49 @@
### self.Map.SetRegion()
self.parent.StatusbarUpdate()
- Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+ Debug.msg (2, "BufferedWindow.UpdateMap2D(): render=%s, renderVector=%s -> time=%g" % \
(render, renderVector, (stop-start)))
return True
+ def UpdateMap3D(self):
+ This method works in 3D mode.
+ Instead PseudoDC is used GLCanvas
+ if not self.parent.toolbars['nviz']:
+ return False
+ start = time.clock()
+ self.resize = False
+ # clear current canvas first
+ self.pdc.Clear()
+ self.pdc.RemoveAll()
+ self.pdcTmp.Clear()
+ self.pdcTmp.RemoveAll()
+ self.Draw(self.pdc, pdctype='clear')
+ stop = time.clock()
+ # update statusbar
+ ### self.Map.SetRegion()
+ self.parent.StatusbarUpdate()
+ Debug.msg (2, "BufferedWindow.UpdateMap3D(): time=%g" % \
+ (stop-start))
+ return True
def DrawCompRegionExtent(self):
"""Draw computational region extent in the display
@@ -2308,7 +2359,8 @@
self.toolbars = { 'map' : None,
'vdigit' : None,
- 'georect' : None }
+ 'georect' : None,
+ 'nviz' : None }
for toolb in toolbars:
self.AddToolbar(toolb)
@@ -2371,6 +2423,7 @@
self.MapWindow = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map, tree=self.tree, gismgr=self.gismanager)
self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
self.MapWindow.SetCursor(self.cursors["default"])
+ self.MapWindowGL = None # used by Nviz (default is 2D display mode)
# initialize region values
@@ -2434,7 +2487,8 @@
- map basic map toolbar
- digit vector digitizer
- georect georectifier
+ # default toolbar
if name == "map":
self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
@@ -2445,8 +2499,8 @@
LeftDockable(False).RightDockable(False).
BottomDockable(False).TopDockable(True).
CloseButton(False).Layer(2))
- if name == "digit":
+ # vector digitizer
+ elif name == "vdigit":
self.toolbars['vdigit'] = toolbars.VDigitToolbar(self, self.Map, self.tree)
for toolRow in range(0, self.toolbars['vdigit'].numOfRows):
@@ -2463,18 +2517,58 @@
self.MapWindow.zoomtype = 0
self.MapWindow.pen = wx.Pen(colour='red', width=2, style=wx.SOLID)
self.MapWindow.polypen = wx.Pen(colour='green', width=2, style=wx.SOLID)
- if name == "georect":
+ # georectifier
+ elif name == "georect":
self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
self._mgr.AddPane(self.toolbars['georect'].toolbar,
wx.aui.AuiPaneInfo().
- Name("georecttoolbar").Caption(_("Georectification Toolbar")).
+ Name("georecttoolbar").Caption(_("Georectification toolbar")).
ToolbarPane().Top().
+ # nviz
+ elif name == "nviz":
+ # check for GLCanvas and OpenGL
+ msg = None
+ if not nviz.haveGLCanvas:
+ msg = _("Unable to start Nviz. The GLCanvas class has not been included with this build "
+ "of wxPython! Switching back to 2D display mode.")
+ if not nviz.haveOpenGL:
+ msg = _("Unable to start Nviz. The OpenGL package was not found. You can get it "
+ "at http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.")
+ if msg:
+ wx.MessageBox(parent=self,
+ message=msg,
+ caption=_("Error"))
+ return
+ # create GL window & NVIZ toolbar
+ self.MapWindowGL = nviz.GLWindow(self)
+ self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
+ # switch from MapWindow to MapWindowGL
+ # add nviz toolbar
+ self._mgr.DetachPane(self.MapWindow)
+ self.MapWindow.Hide()
+ self._mgr.AddPane(self.MapWindowGL, wx.aui.AuiPaneInfo().CentrePane().
+ Dockable(False).BestSize((-1,-1)).
+ CloseButton(False).DestroyOnClose(True).
+ Layer(0))
+ self._mgr.AddPane(self.toolbars['nviz'].toolbar,
+ wx.aui.AuiPaneInfo().
+ Name("nviztoolbar").Caption(_("Nviz toolbar")).
+ ToolbarPane().Top().Row(1).
+ LeftDockable(False).RightDockable(False).
+ BottomDockable(False).TopDockable(True).
+ CloseButton(False).Layer(2))
self._mgr.Update()
def RemoveToolbar (self, name):
@@ -2487,14 +2581,29 @@
# cannot hide main toolbar
if name == "map":
return
- elif name == "digit":
# TODO: not destroy only hide
self._mgr.DetachPane (self.toolbars['vdigit'].toolbar[toolRow])
self.toolbars['vdigit'].toolbar[toolRow].Destroy()
- self.toolbars['vdigit'] = None
+ else:
+ self._mgr.DetachPane (self.toolbars[name].toolbar)
+ self.toolbars[name].toolbar.Destroy()
- self.toolbars['map'].combo.SetValue ("Tools");
+ self.toolbars[name] = None
+ if name == 'nviz':
+ # switch from MapWindowGL to MapWindow
+ self._mgr.DetachPane(self.MapWindowGL)
+ self.MapWindowGL.Hide()
+ self.MapWindow.Show()
+ self._mgr.AddPane(self.MapWindow, wx.aui.AuiPaneInfo().CentrePane().
+ Layer(0))
+ self.toolbars['map'].combo.SetValue ("Tools")
self._mgr.Update()
def __InitDisplay(self):
Added: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py (rev 0)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-16 16:43:13 UTC (rev 31723)
@@ -0,0 +1,140 @@
+ at package nviz.py
+ at brief 2.5/3D visialization mode for Map Display Window
+List of classes:
+ - GLCanvas
+(C) 2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Martin Landa <landa.martin gmail.com>
+import wx
+try:
+ from wx import glcanvas
+ haveGLCanvas = True
+except ImportError:
+ haveGLCanvas = False
+try:
+ from OpenGL.GL import *
+ from OpenGL.GLUT import *
+ haveOpenGL = True
+ haveOpenGL = False
+class GLWindow(glcanvas.GLCanvas):
+ """OpenGL canvas for Map Display Window"""
+ def __init__(self, parent):
+ self.parent = parent # MapWindow
+ glcanvas.GLCanvas.__init__(self, parent, wx.ID_ANY)
+ self.init = False
+ # initialize mouse position
+ self.lastx = self.x = 30
+ self.lasty = self.y = 30
+ self.size = None
+ self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ # self.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
+ # self.Bind(wx.EVT_LEFT_UP, self.OnLeftUp)
+ # self.Bind(wx.EVT_MOTION, self.OnMouseMotion)
+ def OnEraseBackground(self, event):
+ pass # do nothing, to avoid flashing on MSW
+ def OnSize(self, event):
+ size = self.size = self.parent.GetClientSize()
+ if self.GetContext():
+ self.SetCurrent()
+ glViewport(0, 0, size.width, size.height)
+ event.Skip()
+ def OnPaint(self, event):
+ dc = wx.PaintDC(self)
+ self.SetCurrent()
+ if not self.init:
+ self.InitGL()
+ self.init = True
+ self.OnDraw()
+ def InitGL(self):
+ # set viewing projection
+ glMatrixMode(GL_PROJECTION)
+ glFrustum(-0.5, 0.5, -0.5, 0.5, 1.0, 3.0)
+ # position viewer
+ glMatrixMode(GL_MODELVIEW)
+ glTranslatef(0.0, 0.0, -2.0)
+ # position object
+ glRotatef(self.y, 1.0, 0.0, 0.0)
+ glRotatef(self.x, 0.0, 1.0, 0.0)
+ glEnable(GL_DEPTH_TEST)
+ glEnable(GL_LIGHTING)
+ glEnable(GL_LIGHT0)
+ def OnDraw(self):
+ # clear color and depth buffers
+ glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT)
+ # draw six faces of a cube
+ glBegin(GL_QUADS)
+ glNormal3f( 0.0, 0.0, 1.0)
+ glVertex3f( 0.5, 0.5, 0.5)
+ glVertex3f(-0.5, 0.5, 0.5)
+ glVertex3f(-0.5,-0.5, 0.5)
+ glVertex3f( 0.5,-0.5, 0.5)
+ glNormal3f( 0.0, 0.0,-1.0)
+ glVertex3f(-0.5,-0.5,-0.5)
+ glVertex3f(-0.5, 0.5,-0.5)
+ glVertex3f( 0.5, 0.5,-0.5)
+ glVertex3f( 0.5,-0.5,-0.5)
+ glNormal3f( 0.0, 1.0, 0.0)
+ glNormal3f( 0.0,-1.0, 0.0)
+ glNormal3f( 1.0, 0.0, 0.0)
+ glNormal3f(-1.0, 0.0, 0.0)
+ glEnd()
+ if self.size is None:
+ self.size = self.GetClientSize()
+ w, h = self.size
+ w = max(w, 1.0)
+ h = max(h, 1.0)
+ xScale = 180.0 / w
+ yScale = 180.0 / h
+ glRotatef((self.y - self.lasty) * yScale, 1.0, 0.0, 0.0);
+ glRotatef((self.x - self.lastx) * xScale, 0.0, 1.0, 0.0);
+ self.SwapBuffers()
Modified: grass-addons/visualization/nviz2/wxpython/toolbars.py
--- grass-addons/visualization/nviz2/wxpython/toolbars.py 2008-06-16 14:30:44 UTC (rev 31722)
+++ grass-addons/visualization/nviz2/wxpython/toolbars.py 2008-06-16 16:43:13 UTC (rev 31723)
@@ -8,7 +8,8 @@
* GCPToolbar
* VDigitToolbar
* ProfileToolbar
+ * NvizToolbar
PURPOSE: Toolbars for Map Display window
AUTHORS: The GRASS Development Team
@@ -111,10 +112,10 @@
# optional tools
self.combo = wx.ComboBox(parent=self.toolbar, id=wx.ID_ANY, value='Tools',
- choices=['Digitize'], style=wx.CB_READONLY, size=(90, -1))
+ choices=['Digitize', 'Nviz'], style=wx.CB_READONLY, size=(90, -1))
self.comboid = self.toolbar.AddControl(self.combo)
- self.mapdisplay.Bind(wx.EVT_COMBOBOX, self.OnSelect, self.comboid)
+ self.mapdisplay.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
# realize the toolbar
self.toolbar.Realize()
@@ -188,15 +189,18 @@
- def OnSelect(self, event):
+ def OnSelectTool(self, event):
Select / enable tool available in tools list
tool = event.GetString()
if tool == "Digitize" and not self.mapdisplay.toolbars['vdigit']:
- self.mapdisplay.AddToolbar("digit")
+ self.mapdisplay.AddToolbar("vdigit")
+ elif tool == "Nviz" and not self.mapdisplay.toolbars['nviz']:
+ self.mapdisplay.AddToolbar("nviz")
class GRToolbar(AbstractToolbar):
Georectify Display toolbar
@@ -525,7 +529,7 @@
self.parent.dialogs['attributes'].OnCancel(None)
# disable the toolbar
- self.parent.RemoveToolbar ("digit")
+ self.parent.RemoveToolbar ("vdigit")
def OnMoveVertex(self, event):
"""Move line vertex"""
@@ -987,3 +991,40 @@
wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
self.parent.OnQuit),
+class NvizToolbar(AbstractToolbar):
+ Nviz toolbar
+ def __init__(self, parent, map):
+ self.mapcontent = map
+ self.toolbar = wx.ToolBar(parent=self.parent, id=wx.ID_ANY)
+ # self.SetToolBar(self.toolbar)
+ self.toolbar.SetToolBitmapSize(globalvar.toolbarSize)
+ self.InitToolbar(self.parent, self.toolbar, self.ToolbarData())
+ # realize the toolbar
+ self.toolbar.Realize()
+ def ToolbarData(self):
+ """Toolbar data"""
+ self.quit = wx.NewId()
+ # tool, label, bitmap, kind, shortHelp, longHelp, handler
+ return (
+ (self.quit, 'quit', Icons["quit"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["quit"].GetLabel(), Icons["quit"].GetDesc(),
+ self.OnExit),
+ def OnExit (self, event=None):
+ """Quit nviz tool (swith to 2D mode)"""
+ # disable the toolbar
+ self.parent.RemoveToolbar ("nviz")
