[GRASS-SVN] r31743 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jun 18 09:05:58 EDT 2008
Author: neteler
Date: 2008-06-18 09:05:57 -0400 (Wed, 18 Jun 2008)
New Revision: 31743
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
WKT dialog added
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2008-06-18 11:04:03 UTC (rev 31742)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2008-06-18 13:05:57 UTC (rev 31743)
@@ -251,9 +251,12 @@
label=_("Use coordinate system of selected "
"georeferenced file"))
self.radio4 = wx.RadioButton(parent=self, id=wx.ID_ANY,
+ label=_("Use coordinate system of selected "
+ "WKT file"))
+ self.radio5 = wx.RadioButton(parent=self, id=wx.ID_ANY,
label=_("Create custom PROJ.4 parameters "
"string for coordinate system"))
- self.radio5 = wx.RadioButton(parent=self, id=wx.ID_ANY,
+ self.radio6 = wx.RadioButton(parent=self, id=wx.ID_ANY,
label=_("Use arbitrary non-earth "
"coordinate system (XY)"))
# layout
@@ -268,6 +271,8 @@
flag=wx.ALIGN_LEFT, pos=(4, 1))
self.sizer.Add(item=self.radio5,
flag=wx.ALIGN_LEFT, pos=(5, 1))
+ self.sizer.Add(item=self.radio6,
+ flag=wx.ALIGN_LEFT, pos=(6, 1))
# bindings
self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio1.GetId())
@@ -275,6 +280,7 @@
self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio3.GetId())
self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio4.GetId())
self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio5.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id=self.radio6.GetId())
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
# do page layout
@@ -306,10 +312,14 @@
self.SetNext(self.parent.filepage)
self.parent.sumpage.SetPrev(self.parent.filepage)
elif event.GetId() == self.radio4.GetId():
+ coordsys = "wkt"
+ self.SetNext(self.parent.wktpage)
+ self.parent.sumpage.SetPrev(self.parent.wktpage)
+ elif event.GetId() == self.radio5.GetId():
coordsys = "custom"
self.SetNext(self.parent.custompage)
self.parent.sumpage.SetPrev(self.parent.custompage)
- elif event.GetId() == self.radio5.GetId():
+ elif event.GetId() == self.radio6.GetId():
coordsys = "xy"
self.SetNext(self.parent.sumpage)
self.parent.sumpage.SetPrev(self.parent.csystemspage)
@@ -1127,6 +1137,84 @@
def OnCreate(self, event):
pass
+class WKTPage(TitledPage):
+ Wizard page for selecting WKT file to use
+ for setting coordinate system parameters
+ def __init__(self, wizard, parent):
+ TitledPage.__init__(self, wizard, _("Select WKT file"))
+ self.wktfile = ''
+ # create controls
+ self.lfile= self.MakeLabel(_("WKT file:"))
+ self.tfile = self.MakeTextCtrl(size=(300,-1))
+ self.bbrowse = self.MakeButton(_("Browse"))
+ # do layout
+ self.sizer.AddGrowableCol(3)
+ self.sizer.Add(item=self.lfile, flag=wx.ALIGN_LEFT |
+ wx.ALIGN_CENTRE_VERTICAL |
+ wx.ALL, border=5, pos=(1, 1))
+ self.sizer.Add(item=self.tfile, flag=wx.ALIGN_LEFT |
+ wx.ALL, border=5, pos=(1, 2))
+ self.sizer.Add(item=self.bbrowse, flag=wx.ALIGN_LEFT |
+ wx.ALL, border=5, pos=(1, 3))
+ self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
+ self.tfile.Bind(wx.EVT_TEXT, self.OnText)
+ self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnPageChanging)
+ self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+ # do page layout
+ # self.DoLayout()
+ def OnEnterPage(self, event):
+ if len(self.wktfile) == 0:
+ # disable 'next' button by default
+ wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+ else:
+ wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+ event.Skip()
+ def OnPageChanging(self, event):
+ if event.GetDirection() and self.wktfile == '':
+ event.Veto()
+ self.GetNext().SetPrev(self)
+ event.Skip()
+ def OnText(self, event):
+ self.wktfile = event.GetString()
+ nextButton = wx.FindWindowById(wx.ID_FORWARD)
+ if len(self.wktfile) > 0 and os.path.isfile(self.wktfile):
+ if not nextButton.IsEnabled():
+ nextButton.Enable(True)
+ else:
+ if nextButton.IsEnabled():
+ nextButton.Enable(False)
+ event.Skip()
+ def OnBrowse(self, event):
+ """Choose file"""
+ dlg = wx.FileDialog(self,
+ _("Select WKT file"),
+ os.getcwd(), "", "*.*", wx.OPEN)
+ if dlg.ShowModal() == wx.ID_OK:
+ path = dlg.GetPath()
+ self.tfile.SetValue(path)
+ dlg.Destroy()
+ event.Skip()
+ def OnCreate(self, event):
+ pass
class EPSGPage(TitledPage):
Wizard page for selecting EPSG code for
@@ -1502,6 +1590,9 @@
elif coordsys == 'file':
label = 'matches file %s' % self.parent.filepage.georeffile
self.lprojection.SetLabel(label)
+ elif coordsys == 'wkt':
+ label = 'matches file %s' % self.parent.wktpage.wktfile
+ self.lprojection.SetLabel(label)
elif coordsys == 'proj':
label = ('%s, %s%s' % (projdesc, datumdesc, ellipsedesc))
@@ -1560,6 +1651,7 @@
self.projtypepage = ProjTypePage(self.wizard,self)
self.epsgpage = EPSGPage(self.wizard, self)
self.filepage = GeoreferencedFilePage(self.wizard, self)
+ self.wktpage = WKTPage(self.wizard, self)
self.ellipsepage = EllipsePage(self.wizard, self)
self.custompage = CustomPage(self.wizard, self)
self.sumpage = SummaryPage(self.wizard, self)
@@ -1591,6 +1683,9 @@
self.filepage.SetPrev(self.csystemspage)
self.filepage.SetNext(self.sumpage)
+ self.wktpage.SetPrev(self.csystemspage)
+ self.wktpage.SetNext(self.sumpage)
self.custompage.SetPrev(self.csystemspage)
self.custompage.SetNext(self.sumpage)
@@ -1606,6 +1701,7 @@
self.projtypepage.DoLayout()
self.epsgpage.DoLayout()
self.filepage.DoLayout()
+ self.wktpage.DoLayout()
self.ellipsepage.DoLayout()
self.custompage.DoLayout()
self.sumpage.DoLayout()
@@ -1763,6 +1859,8 @@
success = self.EPSGCreate()
elif coordsys == "file":
success = self.FileCreate()
+ elif coordsys == "wkt":
+ success = self.WKTCreate()
return success
@@ -2009,6 +2107,35 @@
return False
+ def WKTCreate(self):
+ Create a new location from a WKT file
+ wktfile = self.wktpage.wktfile
+ location = self.startpage.location
+ cmdlist = []
+ # this should not happen
+ if not wktfile or not os.path.isfile(wktfile):
+ dlg = wx.MessageBox(parent=self.wizard,
+ message="%s: %s ('%s')" % \
+ (_("Unable to create new location"),
+ _("file not found"),
+ wktfile),
+ caption=("Error"), style=wx.OK | wx.ICON_ERROR)
+ return False
+ # creating location
+ cmdlist = ['g.proj', '-c',
+ 'wkt=%s' % wktfile,
+ 'location=%s' % location]
+ p = gcmd.Command(cmdlist)
+ if p.returncode == 0:
+ return True
+ return False
class RegionDef(BaseClass, wx.Frame):
Page for setting default region extents and resolution
