[GRASS-SVN] r31753 - grass/branches/develbranch_6
svn_grass at osgeo.org
Thu Jun 19 03:02:04 EDT 2008
Author: hamish
Date: 2008-06-19 03:02:03 -0400 (Thu, 19 Jun 2008)
New Revision: 31753
grass/branches/develbranch_6/SUBMITTING
minor clean, spelling
Modified: grass/branches/develbranch_6/SUBMITTING
--- grass/branches/develbranch_6/SUBMITTING 2008-06-19 06:33:20 UTC (rev 31752)
+++ grass/branches/develbranch_6/SUBMITTING 2008-06-19 07:02:03 UTC (rev 31753)
@@ -54,7 +54,7 @@
* be used. Note that most linked list functionality (add,
* remove, get) is supported, but their is no sorting
* functionality.
- * COPYRIGHT: (C) 2005 by the GRASS Development Team
+ * COPYRIGHT: (C) 2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -67,7 +67,7 @@
4. - deleted.
- We don't want the $ ID $ in source code any more as it causes problems
+ We don't want the $ID$ in source code any more as it causes problems
for the SVN branches.
@@ -148,7 +148,7 @@
Always use the gettext macros with _("") for user messages,
example:
- G_fatal_error (_("Vector map <%s> not found"), name);
+ G_fatal_error(_("Vector map <%s> not found"), name);
Pipe/file data output:
@@ -191,12 +191,13 @@
G_setenv() instead of setenv()
G_unsetenv() instead of unsetenv()
G_sleep() instead of sleep()
+ G_system() instead of system()
Could somebody please add others (please verify that they are
useful and safe first)
-12. Use function names which fulfil the official GNU naming convention.
+12. Use function names which fulfill the official GNU naming convention.
http://www.gnu.org/prep/standards/html_node/Names.html#Names
Instead of naming a function like: MyNewFunction() use underscores
@@ -263,7 +264,8 @@
MS-Windows: [to be suggested]
-18. Make sure a new line is at the end of each file.
+18. Make sure a new line is at the end of each file and UNIX style newlines
+ are used (\n).
19. When writing Makefiles, use the current standard.
@@ -278,7 +280,8 @@
cp (normal file) | $(INSTALL) -m 644 file target
ar | $(AR)
- rm: be VERY careful with recursive remove.
+ rm: be VERY careful with recursive remove. Also beware of
+ removing $(FOO)* if $(FOO) has any chance of being empty.
Examples: see below examples or others
raster/r.info/Makefile
@@ -305,6 +308,7 @@
23. Add/update, if required the related GUI menus:
gui/tcltk/gis.m/gmmenu.tcl
+ gui/wxpython/gui_modules/menudata.py
24. For consistency, use README rather than README.txt for any README files.
@@ -316,8 +320,8 @@
lib/init/variables.html
-26. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
- You can re-check before submission with 'svn diff':
+26. Be sure to develop on top of the LATEST GRASS code (which is in our SVN
+ repository). You can re-check before submission with 'svn diff':
Be sure to create unified ("diff -u") format. "Plain" diffs (the default
format) are risky, because they will apply without warning to code which
@@ -325,7 +329,7 @@
Such diffs should be made from the top-level directory, e.g.
"svn diff display/d.vect/main.c"; that way, the diff will
- include the pathname rather than just "main.c".
+ include the pathname rather than just an ambiguous "main.c".
27. Try to use module names which describe shortly the intended purpose of the module.
@@ -342,7 +346,7 @@
v. - vector commands
Some additional naming conventions
- * export modules: (type).out.(format) eg: r.out.arc, v.out.ascii
+ * export modules: (type).out.(format) eg: r.out.arc, v.out.ascii
* import module: (type).in.(format) eg: r.in.arc, v.in.ascii
* conversion modules: (type).to.(type) eg: r.to.vect, v.to.rast, r3.to.rast
