[GRASS-SVN] r31759 - in grass-addons/visualization/nviz2: . cmd lib
wxpython wxpython/nviz
svn_grass at osgeo.org
Thu Jun 19 10:58:52 EDT 2008
Author: martinl
Date: 2008-06-19 10:58:52 -0400 (Thu, 19 Jun 2008)
New Revision: 31759
Added:
grass-addons/visualization/nviz2/lib/
grass-addons/visualization/nviz2/lib/Makefile
grass-addons/visualization/nviz2/lib/nviz.h
grass-addons/visualization/nviz2/lib/render.c
grass-addons/visualization/nviz2/lib/render.h
Removed:
grass-addons/visualization/nviz2/cmd/nviz.h
grass-addons/visualization/nviz2/cmd/render.c
grass-addons/visualization/nviz2/cmd/render.h
grass-addons/visualization/nviz2/cmd/Makefile
grass-addons/visualization/nviz2/cmd/local_proto.h
grass-addons/visualization/nviz2/cmd/main.c
grass-addons/visualization/nviz2/wxpython/mapdisp.py
grass-addons/visualization/nviz2/wxpython/nviz.py
grass-addons/visualization/nviz2/wxpython/nviz/Makefile
grass-addons/visualization/nviz2/wxpython/nviz/init.cpp
grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
nviz2: various updates towards wxNVIZ extension (based on nviz_cmd functionality)
Modified: grass-addons/visualization/nviz2/cmd/Makefile
--- grass-addons/visualization/nviz2/cmd/Makefile 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/cmd/Makefile 2008-06-19 14:58:52 UTC (rev 31759)
@@ -24,17 +24,15 @@
XTRA_LDFLAGS = $(OGL_LIBS)
-LIBES = $(BITMAPLIB) $(LINKMLIB) $(VECTLIB) $(SITESLIB) $(FORMLIB) $(DBMILIB) \
- $(G3DLIB) $(GISLIB) $(XDRLIB) \
- $(DATETIMELIB) $(XTRA_LDFLAGS) $(TIFFLIBPATH) $(TIFFLIB) \
- $(MATHLIB)
-DEPENDENCIES = $(VECTDEP) $(BITMAPDEP) $(LINKMDEP) $(FORMDEP) $(DBMIDEP) $(GISDEP) $(OGSFDEP)
EXTRA_CFLAGS=$(XCFLAGS) $(XMINC)
-LIBES = $(GISLIB) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB)
-DEPENDENCIES = $(GISDEP)
+# TODO
+NVIZLIB= -lgrass_nviz $(GISLIB)
+NVIZDEP=$(ARCH_LIBDIR)/$(LIB_PREFIX)grass_nviz$(LIB_SUFFIX)
+LIBES = $(GISLIB) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB) $(NVIZLIB)
+DEPENDENCIES = $(GISDEP) $(NVIZDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
Modified: grass-addons/visualization/nviz2/cmd/local_proto.h
--- grass-addons/visualization/nviz2/cmd/local_proto.h 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/cmd/local_proto.h 2008-06-19 14:58:52 UTC (rev 31759)
@@ -1,8 +1,7 @@
#ifndef __LOCAL_PROTO_H__
#define __LOCAL_PROTO_H__
-#include "render.h"
-#include "nviz.h"
+#include <grass/nviz.h>
/* module flags and parameters */
struct GParams {
@@ -69,13 +68,6 @@
int focus_set_state(int);
int focus_set_map(int, int);
-/* render.c */
-void render_window_init(render_window *);
-int render_window_create(render_window *, int, int);
-int render_window_destroy(render_window *);
-int render_window_make_current(const render_window *);
-void swap_gl();
/* write_img.c */
int write_img(const char *, int);
Modified: grass-addons/visualization/nviz2/cmd/main.c
--- grass-addons/visualization/nviz2/cmd/main.c 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/cmd/main.c 2008-06-19 14:58:52 UTC (rev 31759)
@@ -20,11 +20,12 @@
#include <grass/gis.h>
#include <grass/glocale.h>
-#include <grass/gsurf.h>
-#include <grass/gstypes.h>
#include "local_proto.h"
+static void swap_gl();
int main (int argc, char *argv[])
struct GModule *module;
@@ -39,7 +40,7 @@
char *output_name;
nv_data data;
- render_window offscreen;
+ struct render_window *offscreen;
/* initialize GRASS */
G_gisinit(argv[0]);
@@ -63,9 +64,10 @@
GS_set_swap_func(swap_gl);
/* define render window */
- render_window_init(&offscreen);
- render_window_create(&offscreen, width, height); /* TOD0: option dim */
- render_window_make_current(&offscreen);
+ offscreen = Nviz_new_render_window();
+ Nviz_init_render_window(offscreen);
+ Nviz_create_render_window(offscreen, NULL, width, height); /* offscreen display */
+ Nviz_make_current_render_window(offscreen);
/* initialize nviz data */
nv_data_init(&data);
@@ -224,10 +226,15 @@
if (!ret)
G_fatal_error(_("Unsupported output format"));
- render_window_destroy(&offscreen);
+ Nviz_destroy_render_window(offscreen);
G_free ((void *) output_name);
G_free ((void *) params);
exit(EXIT_SUCCESS);
+void swap_gl()
+ return;
Deleted: grass-addons/visualization/nviz2/cmd/nviz.h
--- grass-addons/visualization/nviz2/cmd/nviz.h 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/cmd/nviz.h 2008-06-19 14:58:52 UTC (rev 31759)
@@ -1,75 +0,0 @@
-#ifndef __NVIZ_H__
-#define __NVIZ_H__
-#define MAP_OBJ_UNDEFINED 0
-#define MAP_OBJ_SURF 1
-#define MAP_OBJ_VOL 2
-#define MAP_OBJ_VECT 3
-#define RANGE (5 * GS_UNIT_SIZE)
-#define RANGE_OFFSET (2 * GS_UNIT_SIZE)
-#define ZRANGE (3 * GS_UNIT_SIZE)
-#define ZRANGE_OFFSET (1 * GS_UNIT_SIZE)
-#define DEFAULT_SURF_COLOR 0x33BBFF
-#define RED_MASK 0x000000FF
-#define GRN_MASK 0x0000FF00
-#define BLU_MASK 0x00FF0000
-#define FORMAT_PPM 1
-#define FORMAT_TIF 2
-/* data structures */
-typedef struct{
- int id;
- float brt;
- float r, g, b;
- float ar, ag, ab; /* ambient rgb */
- float x, y, z, w; /* position */
-} light_data;
-typedef struct {
- /* ranges */
- float zrange, xyrange;
- /* cplanes */
- int num_cplanes;
- int cur_cplane, cp_on[MAX_CPLANES];
- float cp_trans[MAX_CPLANES][3];
- float cp_rot[MAX_CPLANES][3];
- /* light */
- light_data light[MAX_LIGHTS];
- /* background color */
- int bgcolor;
-} nv_data;
-/* The following structure is used to associate client data with surfaces.
- * We do this so that we don't have to rely on the surface ID (which is libal to change
- * between subsequent executions of nviz) when saving set-up info to files.
-typedef struct {
- /* We use logical names to assign textual names to map objects.
- When Nviz needs to refer to a map object it uses the logical name
- rather than the map ID. By setting appropriate logical names, we
- can reuse names inbetween executions of Nviz. The Nviz library
- also provides a mechanism for aliasing between logical names.
- Thus several logical names may refer to the same map object.
- Aliases are meant to support the case in which two logical names
- happen to be the same. The Nviz library automatically assigns
- logical names uniquely if they are not specified in the creation
- of a map object. When loading a saved file containing several map
- objects, it is expected that the map 0bjects will be aliased to
- their previous names. This ensures that old scripts will work.
- char *logical_name;
-} nv_clientdata;
-#endif /* __NVIZ_H__ */
Deleted: grass-addons/visualization/nviz2/cmd/render.c
--- grass-addons/visualization/nviz2/cmd/render.c 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/cmd/render.c 2008-06-19 14:58:52 UTC (rev 31759)
@@ -1,154 +0,0 @@
- \file render.c
- \brief GLX context manipulation
- COPYRIGHT: (C) 2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
- Based on visualization/nviz/src/togl.c etc.
- \author Updated/modified by Martin Landa <landa.martin gmail.com>
- \date 2008
-#include <grass/gis.h>
-#include <grass/glocale.h>
- \brief Initialize render window
- \param win pointer to render_window struct
-void render_window_init(render_window * win)
- win->displayId = NULL;
- win->contextId = NULL;
- win->pixmap = 0;
- win->windowId = 0;
- \brief Create rendew window
- \param width window width
- \param height window height
- \return 1
-int render_window_create(render_window *win, int width, int height)
- XVisualInfo *v;
- int attributeList[] = { GLX_RGBA, GLX_RED_SIZE, 1,
- GLX_GREEN_SIZE, 1, GLX_BLUE_SIZE, 1,
- GLX_DEPTH_SIZE, 1, None };
- int attributeList[] = { GLX_USE_GL, GLX_RED_SIZE, 1,
- GLX_DEPTH_SIZE, 1, GLX_DOUBLEBUFFER,
- None };
- /* get the default display connection */
- win->displayId = XOpenDisplay((char *) NULL);
- if (!win->displayId) {
- G_fatal_error (_("Bad X server connection"));
- /* get visual info and set up pixmap buffer */
- v = glXChooseVisual(win->displayId,
- DefaultScreen(win->displayId),
- attributeList);
- win->contextId = glXCreateContext(win->displayId,
- v, NULL, GL_FALSE);
- if (!win->contextId) {
- G_fatal_error (_("Unable to create GLX rendering context"));
- /* create win pixmap to render to (same depth as RootWindow) */
- win->pixmap = XCreatePixmap(win->displayId,
- RootWindow(win->displayId, v->screen),
- width,
- height,
- v->depth);
- /* create an off-screen GLX rendering area */
- win->windowId = glXCreateGLXPixmap(win->displayId,
- v, win->pixmap);
- if (v) {
- XFree(v);
- this->MakeCurrent();
- glMatrixMode( GL_MODELVIEW );
- glDepthFunc( GL_LEQUAL );
- glEnable( GL_DEPTH_TEST );
- glTexEnvf( GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_MODULATE );
- glBlendFunc( GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA );
- glEnable(GL_BLEND);
- glEnable( GL_NORMALIZE );
- glAlphaFunc(GL_GREATER,0);
- this->Mapped = 0; // if its mapped, then it trys windowgetattributes which fails!
- this->SwapBuffers = 0;
- this->DoubleBuffer = 0;
- return 1;
- \brief Free render window
- \return 1
-int render_window_destroy(render_window *win)
- glXDestroyContext(win->displayId, win->contextId);
- XFreePixmap(win->displayId, win->pixmap);
- render_window_init(win);
- return 1;
- \brief Make window current for rendering
- \return 1
-int render_window_make_current(const render_window *win)
- if (!win->displayId || !win->contextId)
- return 0;
- if (win->contextId == glXGetCurrentContext())
- return 1;
- glXMakeCurrent(win->displayId, win->windowId,
- win->contextId);
- /* TODO: AQUA */
- return 1;
-void swap_gl()
- return;
Deleted: grass-addons/visualization/nviz2/cmd/render.h
--- grass-addons/visualization/nviz2/cmd/render.h 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/cmd/render.h 2008-06-19 14:58:52 UTC (rev 31759)
@@ -1,44 +0,0 @@
-#ifndef __RENDER_H__
-#define __RENDER_H__
-/*** Windows headers ***/
-#if defined(OPENGL_WINDOWS)
-# define WIN32_LEAN_AND_MEAN
-# include <windows.h>
-# undef WIN32_LEAN_AND_MEAN
-# include <winnt.h>
-/*** X Window System headers ***/
-#elif defined(OPENGL_X11)
-# include <X11/Xlib.h>
-# include <X11/Xutil.h>
-# include <X11/Xatom.h> /* for XA_RGB_DEFAULT_MAP atom */
-# if defined(__vms)
-# include <X11/StdCmap.h> /* for XmuLookupStandardColormap */
-# else
-# include <X11/Xmu/StdCmap.h> /* for XmuLookupStandardColormap */
-# endif
-# include <GL/glx.h>
-/*** Mac headers ***/
-#elif defined(OPENGL_AQUA)
-# define Cursor QDCursor
-# include <AGL/agl.h>
-# undef Cursor
-# include <ApplicationServices/ApplicationServices.h>
-#else /* make sure only one platform defined */
-# error Unsupported platform, or confused platform defines...
-#endif
-typedef struct {
- Display *displayId; /* display connection */
- GLXContext contextId; /* GLX rendering context */
- Pixmap pixmap;
- GLXPixmap windowId;
-} render_window;
-#endif /* __RENDER_H__ */
Added: grass-addons/visualization/nviz2/lib/Makefile
--- grass-addons/visualization/nviz2/lib/Makefile (rev 0)
+++ grass-addons/visualization/nviz2/lib/Makefile 2008-06-19 14:58:52 UTC (rev 31759)
@@ -0,0 +1,17 @@
+#MODULE_TOPDIR = ../../..
+MODULE_TOPDIR = $(HOME)/src/grass6_devel
+# LIB_NAME = $(NVIZ_LIBNAME)
+LIB_NAME = grass_nviz
+DEPENDENCIES = $(VECTDEP) $(BITMAPDEP) $(LINKMDEP) $(FORMDEP) $(DBMIDEP) $(GISDEP) $(OGSFDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(INC) \
+ $(TIFFINCPATH) $(DSPINC) \
+ $(VECT_CFLAGS) $(OPENGLINC)
+EXTRA_LIBS = $(GISLIB) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB)
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+default: lib
Copied: grass-addons/visualization/nviz2/lib/nviz.h (from rev 31709, grass-addons/visualization/nviz2/cmd/nviz.h)
--- grass-addons/visualization/nviz2/lib/nviz.h (rev 0)
+++ grass-addons/visualization/nviz2/lib/nviz.h 2008-06-19 14:58:52 UTC (rev 31759)
@@ -0,0 +1,122 @@
+#ifndef GRASS_NVIZ_H
+#define GRASS_NVIZ_H
+#include <grass/gsurf.h>
+#include <grass/gstypes.h>
+/*** Windows headers ***/
+#if defined(OPENGL_WINDOWS)
+# define WIN32_LEAN_AND_MEAN
+# include <windows.h>
+# undef WIN32_LEAN_AND_MEAN
+# include <winnt.h>
+/*** X Window System headers ***/
+#elif defined(OPENGL_X11)
+# include <X11/Xlib.h>
+# include <X11/Xutil.h>
+# include <X11/Xatom.h> /* for XA_RGB_DEFAULT_MAP atom */
+# if defined(__vms)
+# include <X11/StdCmap.h> /* for XmuLookupStandardColormap */
+# else
+# include <X11/Xmu/StdCmap.h> /* for XmuLookupStandardColormap */
+# endif
+# include <GL/glx.h>
+/*** Mac headers ***/
+#elif defined(OPENGL_AQUA)
+# define Cursor QDCursor
+# include <AGL/agl.h>
+# undef Cursor
+# include <ApplicationServices/ApplicationServices.h>
+#else /* make sure only one platform defined */
+# error Unsupported platform, or confused platform defines...
+#endif
+#define MAP_OBJ_UNDEFINED 0
+#define MAP_OBJ_SURF 1
+#define MAP_OBJ_VOL 2
+#define MAP_OBJ_VECT 3
+#define RANGE (5 * GS_UNIT_SIZE)
+#define RANGE_OFFSET (2 * GS_UNIT_SIZE)
+#define ZRANGE (3 * GS_UNIT_SIZE)
+#define ZRANGE_OFFSET (1 * GS_UNIT_SIZE)
+#define DEFAULT_SURF_COLOR 0x33BBFF
+#define RED_MASK 0x000000FF
+#define GRN_MASK 0x0000FF00
+#define BLU_MASK 0x00FF0000
+#define FORMAT_PPM 1
+#define FORMAT_TIF 2
+/* data structures */
+typedef struct{
+ int id;
+ float brt;
+ float r, g, b;
+ float ar, ag, ab; /* ambient rgb */
+ float x, y, z, w; /* position */
+} light_data;
+typedef struct {
+ /* ranges */
+ float zrange, xyrange;
+ /* cplanes */
+ int num_cplanes;
+ int cur_cplane, cp_on[MAX_CPLANES];
+ float cp_trans[MAX_CPLANES][3];
+ float cp_rot[MAX_CPLANES][3];
+ /* light */
+ light_data light[MAX_LIGHTS];
+ /* background color */
+ int bgcolor;
+} nv_data;
+/* The following structure is used to associate client data with surfaces.
+ * We do this so that we don't have to rely on the surface ID (which is libal to change
+ * between subsequent executions of nviz) when saving set-up info to files.
+typedef struct {
+ /* We use logical names to assign textual names to map objects.
+ When Nviz needs to refer to a map object it uses the logical name
+ rather than the map ID. By setting appropriate logical names, we
+ can reuse names inbetween executions of Nviz. The Nviz library
+ also provides a mechanism for aliasing between logical names.
+ Thus several logical names may refer to the same map object.
+ Aliases are meant to support the case in which two logical names
+ happen to be the same. The Nviz library automatically assigns
+ logical names uniquely if they are not specified in the creation
+ of a map object. When loading a saved file containing several map
+ objects, it is expected that the map 0bjects will be aliased to
+ their previous names. This ensures that old scripts will work.
+ char *logical_name;
+} nv_clientdata;
+struct render_window {
+ Display *displayId; /* display connection */
+ GLXContext contextId; /* GLX rendering context */
+ Pixmap pixmap;
+ GLXPixmap windowId;
+/* render.c */
+struct render_window* Nviz_new_render_window();
+void Nviz_init_render_window(struct render_window*);
+void Nviz_destroy_render_window(struct render_window *);
+int Nviz_create_render_window(struct render_window *, void *,
+ int, int);
+int Nviz_make_current_render_window(const struct render_window *);
+#endif /* GRASS_NVIZ_H */
Added: grass-addons/visualization/nviz2/lib/render.c
--- grass-addons/visualization/nviz2/lib/render.c (rev 0)
+++ grass-addons/visualization/nviz2/lib/render.c 2008-06-19 14:58:52 UTC (rev 31759)
@@ -0,0 +1,143 @@
+ \file render.c
+ \brief Nviz library -- GLX context manipulation
+ COPYRIGHT: (C) 2008 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ Based on visualization/nviz/src/togl.c etc.
+ \author Updated/modified by Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+ \date 2008
+#include <grass/glocale.h>
+ \brief Allocate memory for render window
+ \return pointer to render_window struct
+ \return NULL on failure
+struct render_window *Nviz_new_render_window()
+ struct render_window *rwin;
+ /* G_malloc() calls G_fatal_error() on failure */
+ rwin = (struct render_window *) G_malloc (sizeof (struct render_window));
+ return rwin;
+ \brief Initialize render window
+ \param win pointer to render_window struct
+void Nviz_init_render_window(struct render_window *rwin)
+ rwin->displayId = NULL;
+ rwin->contextId = NULL;
+ rwin->pixmap = 0;
+ rwin->windowId = 0;
+ return;
+ \brief Free render window
+void Nviz_destroy_render_window(struct render_window *rwin)
+ glXDestroyContext(rwin->displayId, rwin->contextId);
+ XFreePixmap(rwin->displayId, rwin->pixmap);
+ G_free ((void *) rwin);
+ return;
+ \brief Create render window
+ \param rwin pointer to render_window struct
+ \param display display instance (NULL for offscreen)
+ \param width window width
+ \param height window height
+ \return 1
+int Nviz_create_render_window(struct render_window *rwin, void *display,
+ int width, int height)
+ XVisualInfo *v;
+ int attributeList[] = { GLX_RGBA, GLX_RED_SIZE, 1,
+ GLX_GREEN_SIZE, 1, GLX_BLUE_SIZE, 1,
+ GLX_DEPTH_SIZE, 1, None };
+ /* get the default display connection */
+ rwin->displayId = XOpenDisplay((char *) display);
+ if (!rwin->displayId) {
+ G_fatal_error (_("Bad X server connection"));
+ /* get visual info and set up pixmap buffer */
+ v = glXChooseVisual(rwin->displayId,
+ DefaultScreen(rwin->displayId),
+ attributeList);
+ rwin->contextId = glXCreateContext(rwin->displayId,
+ v, NULL, GL_FALSE);
+ if (!rwin->contextId) {
+ G_fatal_error (_("Unable to create GLX rendering context"));
+ /* create win pixmap to render to (same depth as RootWindow) */
+ rwin->pixmap = XCreatePixmap(rwin->displayId,
+ RootWindow(rwin->displayId, v->screen),
+ width,
+ height,
+ v->depth);
+ /* create an off-screen GLX rendering area */
+ rwin->windowId = glXCreateGLXPixmap(rwin->displayId,
+ v, rwin->pixmap);
+ if (v) {
+ XFree(v);
+ return 1;
+ \brief Make window current for rendering
+ \return 1
+int Nviz_make_current_render_window(const struct render_window *rwin)
+ if (!rwin->displayId || !rwin->contextId)
+ return 0;
+ if (rwin->contextId == glXGetCurrentContext())
+ return 1;
+ glXMakeCurrent(rwin->displayId, rwin->windowId,
+ rwin->contextId);
+ /* TODO: AQUA */
+ return 1;
Copied: grass-addons/visualization/nviz2/lib/render.h (from rev 31709, grass-addons/visualization/nviz2/cmd/render.h)
--- grass-addons/visualization/nviz2/lib/render.h (rev 0)
+++ grass-addons/visualization/nviz2/lib/render.h 2008-06-19 14:58:52 UTC (rev 31759)
@@ -0,0 +1,44 @@
+#ifndef __RENDER_H__
+#define __RENDER_H__
+# else
+# endif
+# undef Cursor
+#endif
+typedef struct {
+ Pixmap pixmap;
+} render_window;
+#endif /* __RENDER_H__ */
Modified: grass-addons/visualization/nviz2/wxpython/mapdisp.py
--- grass-addons/visualization/nviz2/wxpython/mapdisp.py 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/wxpython/mapdisp.py 2008-06-19 14:58:52 UTC (rev 31759)
@@ -542,19 +542,7 @@
Updates the canvas anytime there is a change to the
underlaying images or to the geometry of the canvas.
- if self.parent.toolbars['nviz']:
- self.UpdateMap3D() # OpenGL
- else:
- self.UpdateMap2D(render, renderVector)
- def UpdateMap2D(self, render=True, renderVector=True):
- Updates the canvas anytime there is a change to the
- underlaying images or to the geometry of the canvas.
- This method works in 2D mode.
@param render re-render map composition
@param renderVector re-render vector map layer enabled for editing (used for digitizer)
@@ -674,49 +662,11 @@
### self.Map.SetRegion()
self.parent.StatusbarUpdate()
- Debug.msg (2, "BufferedWindow.UpdateMap2D(): render=%s, renderVector=%s -> time=%g" % \
+ Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
(render, renderVector, (stop-start)))
return True
- def UpdateMap3D(self):
- This method works in 3D mode.
- Instead PseudoDC is used GLCanvas
- if not self.parent.toolbars['nviz']:
- return False
- start = time.clock()
- self.resize = False
- # clear current canvas first
- self.pdc.Clear()
- self.pdc.RemoveAll()
- self.pdcTmp.Clear()
- self.pdcTmp.RemoveAll()
- self.Draw(self.pdc, pdctype='clear')
- stop = time.clock()
- # update statusbar
- ### self.Map.SetRegion()
- self.parent.StatusbarUpdate()
- Debug.msg (2, "BufferedWindow.UpdateMap3D(): time=%g" % \
- (stop-start))
- return True
def DrawCompRegionExtent(self):
"""Draw computational region extent in the display
@@ -2538,6 +2488,9 @@
if not nviz.haveOpenGL:
msg = _("Unable to start Nviz. The OpenGL package was not found. You can get it "
"at http://PyOpenGL.sourceforge.net. Switching back to 2D display mode.")
+ if not nviz.haveNviz:
+ msg = _("Unable to start Nviz. Python extension for Nviz was not found. "
+ "Switching back to 2D display mode.")
if msg:
wx.MessageBox(parent=self,
Modified: grass-addons/visualization/nviz2/wxpython/nviz/Makefile
--- grass-addons/visualization/nviz2/wxpython/nviz/Makefile 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/wxpython/nviz/Makefile 2008-06-19 14:58:52 UTC (rev 31759)
@@ -7,8 +7,8 @@
SOURCES := $(wildcard *.cpp) $(LIB_NAME)_wrap.cpp
SHLIB_OBJS := $(patsubst %.cpp, $(OBJDIR)/%.o, $(SOURCES))
-EXTRA_CFLAGS = $(SHLIB_CFLAGS) $(GDALCFLAGS) $(PYTHONCFLAGS) $(WXWIDGETSCXXFLAGS)
-EXTRA_LIBS = $(VECTLIB) $(GISLIB) $(GDALLIBS) $(VEDITLIB) $(WXWIDGETSLIB) $(PYTHONLDFLAGS)
+EXTRA_CFLAGS = $(SHLIB_CFLAGS) $(GDALCFLAGS) $(PYTHONCFLAGS) $(WXWIDGETSCXXFLAGS) $(XCFLAGS) $(XMINC)
+EXTRA_LIBS = $(GISLIB) $(WXWIDGETSLIB) $(PYTHONLDFLAGS) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB)
LOCAL_HEADERS = nviz.h
Modified: grass-addons/visualization/nviz2/wxpython/nviz/init.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/init.cpp 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/wxpython/nviz/init.cpp 2008-06-19 14:58:52 UTC (rev 31759)
@@ -18,21 +18,56 @@
#include "nviz.h"
- \brief Initialize Nviz class
+ \brief Initialize Nviz class instance
Nviz::Nviz()
+ G_gisinit(""); /* GRASS functions */
GS_libinit();
/* GVL_libinit(); TODO */
- //GS_set_swap_func(swap_gl);
+ GS_set_swap_func(swap_gl);
+ /* initialize render window */
+ rwind = Nviz_new_render_window();
+ Nviz_init_render_window(rwind);
+ \brief Destroy Nviz class instance
+Nviz::~Nviz()
+ Nviz_destroy_render_window(rwind);
+ G_free((void *) rwind);
\brief Swap GL buffers
-void Nviz::swap_gl()
+void swap_gl()
return;
+ \brief Associate display with render window
+ \return 1 on success
+ \return 0 on failure
+int Nviz::SetDisplay(void *display, int width, int height)
+ if (!rwind)
+ return 0;
+ Nviz_create_render_window(rwind, display, width, height);
+ Nviz_make_current_render_window(rwind);
+ return 1;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
--- grass-addons/visualization/nviz2/wxpython/nviz/nviz.h 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/wxpython/nviz/nviz.h 2008-06-19 14:58:52 UTC (rev 31759)
@@ -2,18 +2,27 @@
#define __NVIZ_H__
extern "C" {
+#include <grass/gis.h>
class Nviz
private:
- void swap_gl();
+ // struct render_window *rwind;
+ struct render_window *rwind;
public:
/* constructor */
Nviz();
+ /* destructor */
+ ~Nviz();
+ /* set */
+ int SetDisplay(void *, int, int);
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-19 14:14:48 UTC (rev 31758)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-19 14:58:52 UTC (rev 31759)
@@ -29,13 +29,28 @@
except ImportError:
haveOpenGL = False
+import globalvar
+#try:
+nvizPath = os.path.join(globalvar.ETCWXDIR, "nviz")
+sys.path.append(nvizPath)
+import grass6_wxnviz as wxnviz
+haveNviz = True
+#except ImportError:
+# haveNviz = False
class GLWindow(glcanvas.GLCanvas):
"""OpenGL canvas for Map Display Window"""
def __init__(self, parent):
self.parent = parent # MapWindow
glcanvas.GLCanvas.__init__(self, parent, wx.ID_ANY)
self.init = False
+ # create nviz instance
+ nvizClass = wxnviz.Nviz()
# initialize mouse position
self.lastx = self.x = 30
self.lasty = self.y = 30
