[GRASS-SVN] r31762 - in grass-addons/visualization/nviz2: cmd lib
wxpython wxpython/nviz
svn_grass at osgeo.org
Thu Jun 19 14:50:41 EDT 2008
Author: martinl
Date: 2008-06-19 14:50:41 -0400 (Thu, 19 Jun 2008)
New Revision: 31762
Added:
grass-addons/visualization/nviz2/lib/change_view.c
grass-addons/visualization/nviz2/lib/cplanes_obj.c
grass-addons/visualization/nviz2/lib/lights.c
grass-addons/visualization/nviz2/lib/nviz.c
grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp
Removed:
grass-addons/visualization/nviz2/cmd/cplanes_obj.c
grass-addons/visualization/nviz2/cmd/lights.c
grass-addons/visualization/nviz2/cmd/nviz.c
grass-addons/visualization/nviz2/cmd/change_view.c
grass-addons/visualization/nviz2/cmd/local_proto.h
grass-addons/visualization/nviz2/cmd/main.c
grass-addons/visualization/nviz2/lib/nviz.h
grass-addons/visualization/nviz2/wxpython/nviz.py
grass-addons/visualization/nviz2/wxpython/nviz/Makefile
grass-addons/visualization/nviz2/wxpython/nviz/init.cpp
grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
nviz2: wxGUI integration in progress
Modified: grass-addons/visualization/nviz2/cmd/change_view.c
--- grass-addons/visualization/nviz2/cmd/change_view.c 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/cmd/change_view.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -163,23 +163,6 @@
- \brief Map canvas resized
- \param width window width
- \param height window height
-void resize_window(int width, int height)
- GS_set_viewport(0, width, 0, height);
-/* GS_clear(0x0000FF); causes red flash - debug only */
- GS_set_draw(GSD_BACK);
- GS_ready_draw();
- GS_alldraw_wire();
- GS_done_draw();
\brief Change z-exag value
\param data nviz data
Deleted: grass-addons/visualization/nviz2/cmd/cplanes_obj.c
--- grass-addons/visualization/nviz2/cmd/cplanes_obj.c 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/cmd/cplanes_obj.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -1,123 +0,0 @@
- \file cplanes_obj.c
- \brief Clip planes manipulation
- COPYRIGHT: (C) 2008 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
- Based on visualization/nviz/src/cutplanes_obj.c
- \author Updated/modified by Martin Landa <landa.martin gmail.com>
- \date 2008
-#include "local_proto.h"
-static void cp_draw(nv_data *, int, int, int);
- \brief Creates a clip plane object
- The number of clip planes is fixed (MAX_CPLANES) and
- we'll create them all ahead of time anyway we just let
- the user decide on the id for each.
-int cplane_new(nv_data *data, int id)
- data->num_cplanes++;
- /* Initialize internal attributes for this cutplane */
- data->cp_rot[id][X] = data->cp_rot[id][Y] = data->cp_rot[id][Z] = 0.0;
- data->cp_trans[id][X] = data->cp_trans[id][Y] = data->cp_trans[id][Z] = 0.0;
- data->cp_on[id] = 0;
- return 1;
- \brief Turn off (make inactive) the given clip plane
- \param data nviz data
- \param cplane id
-int cplane_off(nv_data *data, int id)
- GS_unset_cplane(id);
- return 1;
- \brief Draw the clip plane
- \param bound1
- \param bound2
-int cplane_draw(nv_data *data, int bound1, int bound2)
- cp_draw(data, data->cur_cplane, bound1, bound2);
- return 1;
- \brief Draw current clip plane
- \param current id of current clip plane
- \param surf1 first surface id
- \param surf2 second surface id
-void cp_draw(nv_data *data, int current, int surf1, int surf2)
- int i, nsurfs;
- int surf_min=0, surf_max=0, temp;
- int *surf_list;
- GS_clear(data->bgcolor);
- GS_ready_draw();
- /* If surf boundaries present then find them */
- surf_list = GS_get_surf_list(&nsurfs);
- if ((surf1 != -1) && (surf2 != -1)) {
- for (i = 0; i < nsurfs; i++) {
- if (surf_list[i] == surf1)
- surf_min = i;
- if (surf_list[i] == surf2)
- surf_max = i;
- if (surf_max < surf_min) {
- temp = surf_min;
- surf_min = surf_max;
- surf_max = temp;
- surf_max++;
- else {
- surf_min = 0;
- surf_max = nsurfs;
- if (nsurfs > 1) {
- for (i = 0; i < MAX_CPLANES; i++) {
- if (data->cp_on[i])
- GS_draw_cplane_fence(surf_list[0], surf_list[1], i);
- for (i = surf_min; i < surf_max; i++) {
- GS_draw_wire(surf_list[i]);
- GS_done_draw();
- return;
Deleted: grass-addons/visualization/nviz2/cmd/lights.c
--- grass-addons/visualization/nviz2/cmd/lights.c 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/cmd/lights.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -1,154 +0,0 @@
- \file lights.c
- \brief Change view settings
- for details.
- Based on visualization/nviz/src/lights.c
- \date 2008
-#include <grass/gsurf.h>
-#include <grass/gstypes.h>
-#include <grass/glocale.h>
- \brief Set light position
- \param num light num (starts with 0)
- \param x,y,z,w position, model coordinates
-int light_set_position(nv_data *data, int num,
- float x, float y, float z, float w)
- data->light[num].id = num + 1;
- data->light[num].x = x;
- data->light[num].y = y;
- data->light[num].z = z;
- data->light[num].w = w;
- GS_setlight_position(num + 1, x, y, z, w);
- return 1;
- \brief Set light brightness
- \param value brightness value
-int light_set_bright(nv_data * data, int num, float value)
- float r, g, b;
- data->light[num].brt = value;
- r = data->light[num].r * data->light[num].brt;
- g = data->light[num].g * data->light[num].brt;
- b = data->light[num].b * data->light[num].brt;
- GS_setlight_color(num + 1, r, g, b);
- return 1;
- \brief Set light color
- \param red,green,blue rGB values (0-1)
-int light_set_color(nv_data * data, int num,
- float red, float green, float blue)
- float r, g, b;
- data->light[num].r = red;
- data->light[num].g = green;
- data->light[num].b = blue;
- return 1;
- \brief Set light ambient
-int light_set_ambient(nv_data *data, int num,
- data->light[num].ar = red;
- data->light[num].ag = green;
- data->light[num].ab = blue;
- GS_setlight_ambient(num + 1, red, green, blue);
- return 1;
- \brief Init new light
-int light_init(nv_data *data, int num)
- if (num >= MAX_LIGHTS) {
- return 0;
- data->light[num].id = 0;
- data->light[num].brt = 0.8;
- data->light[num].ar = 0.3;
- data->light[num].ag = 0.3;
- data->light[num].ab = 0.3;
- data->light[num].r = 1.0;
- data->light[num].b = 1.0;
- data->light[num].g = 1.0;
- data->light[num].x = 1.0;
- data->light[num].y = 1.0;
- data->light[num].z = 1.0;
- data->light[num].w = 1.0;
- return 1;
-int light_new(nv_data *data)
- int num;
- num = GS_new_light();
- if (num < 1) {
- G_warning(_("Unable to define new light"));
- return 0;
- light_init(data, num - 1);
- return 1;
Modified: grass-addons/visualization/nviz2/cmd/local_proto.h
--- grass-addons/visualization/nviz2/cmd/local_proto.h 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/cmd/local_proto.h 2008-06-19 18:50:41 UTC (rev 31762)
@@ -16,11 +16,6 @@
void parse_command(int, char**, struct GParams *);
int color_from_cmd(const char *);
-/* cplanes_obj.c */
-int cplane_new(nv_data *, int);
-int cplane_off(nv_data *, int);
-int cplane_draw(nv_data *, int, int);
/* change_view.c */
int update_ranges(nv_data *);
int viewpoint_set_position(nv_data *,
@@ -48,21 +43,6 @@
nv_data *);
void set_att_default();
-/* nviz.c */
-void nv_data_init(nv_data *);
-void nv_data_set_bgcolor(nv_data *, int);
-/* lights.c */
-int light_set_position(nv_data *, int,
- float, float, float, float);
-int light_set_bright(nv_data *, int, float);
-int light_set_color(nv_data *, int,
- float, float, float);
-int light_set_ambient(nv_data *, int,
-int light_init(nv_data *, int);
-int light_new(nv_data *);
/* position.c */
void init_view();
int focus_set_state(int);
Modified: grass-addons/visualization/nviz2/cmd/main.c
--- grass-addons/visualization/nviz2/cmd/main.c 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/cmd/main.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -70,11 +70,11 @@
Nviz_make_current_render_window(offscreen);
/* initialize nviz data */
- nv_data_init(&data);
+ Nviz_init_data(&data);
/* define default attributes for map objects */
set_att_default();
/* set background color */
- nv_data_set_bgcolor(&data, color_from_cmd(params->bgcolor->answer));
+ Nviz_set_bgcolor(&data, color_from_cmd(params->bgcolor->answer));
/* load data */
nelev = ncolor_map = ncolor_const = 0;
@@ -160,14 +160,14 @@
/* set lights */
/* TODO: add options */
- light_set_position(&data, 0,
- 0.68, -0.68, 0.80, 0.0);
- light_set_bright(&data, 0,
- 0.8);
- light_set_color(&data, 0,
- 1.0, 1.0, 1.0);
- light_set_ambient(&data, 0,
- 0.2, 0.2, 0.2);
+ Nviz_set_light_position(&data, 0,
+ 0.68, -0.68, 0.80, 0.0);
+ Nviz_set_light_bright(&data, 0,
+ 0.8);
+ Nviz_set_light_color(&data, 0,
+ 1.0, 1.0, 1.0);
+ Nviz_set_light_ambient(&data, 0,
+ 0.2, 0.2, 0.2);
light_set_position(&data, 1,
@@ -180,14 +180,14 @@
0.2, 0.2, 0.2);
- light_set_position(&data, 1,
- 0.0, 0.0, 1.0, 0.0);
- light_set_bright(&data, 1,
- 0.5);
- light_set_color(&data, 1,
- 1.0, 1.0, 1.0);
- light_set_ambient(&data, 1,
- 0.3, 0.3, 0.3);
+ Nviz_set_light_position(&data, 1,
+ 0.0, 0.0, 1.0, 0.0);
+ Nviz_set_light_bright(&data, 1,
+ 0.5);
+ Nviz_set_light_color(&data, 1,
+ 1.0, 1.0, 1.0);
+ Nviz_set_light_ambient(&data, 1,
+ 0.3, 0.3, 0.3);
/* define view point */
if (params->height->answer) {
@@ -208,13 +208,10 @@
viewpoint_set_persp(&data,
atoi(params->persp->answer));
- // resize_window(600, 480);
GS_clear(data.bgcolor);
/* draw */
- cplane_draw(&data, -1, -1);
+ Nviz_draw_cplane(&data, -1, -1);
draw_all (&data);
ret = 0;
Deleted: grass-addons/visualization/nviz2/cmd/nviz.c
--- grass-addons/visualization/nviz2/cmd/nviz.c 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/cmd/nviz.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -1,58 +0,0 @@
- \file nviz.c
- \brief Nviz subroutines
- for details.
- \date 2008
-void nv_data_init(nv_data *data)
- unsigned int i;
- /* data range */
- data->zrange = 0;
- data->xyrange = 0;
- /* clip planes, turn off by default*/
- data->num_cplanes = 0;
- data->cur_cplane = 0;
- cplane_new(data, i);
- cplane_off(data, i);
- /* lights */
- for (i = 0; i < MAX_LIGHTS; i++) {
- light_new(data);
- return;
- \brief Set background color
- \param color color value
-void nv_data_set_bgcolor(nv_data *data, int color)
- data->bgcolor = color;
- return;
Added: grass-addons/visualization/nviz2/lib/change_view.c
--- grass-addons/visualization/nviz2/lib/change_view.c (rev 0)
+++ grass-addons/visualization/nviz2/lib/change_view.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -0,0 +1,51 @@
+ \file change_view.c
+ \brief Change view settings
+ COPYRIGHT: (C) 2008 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ Based on visualization/nviz/src/change_view.c
+ \author Updated/modified by Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+ \date 2008
+#include <grass/nviz.h>
+ \brief GL canvas resized
+ \param width window width
+ \param height window height
+ \return 1 on success
+ \return 0 on failure (window resized by dafault to 20x20 px)
+int Nviz_resize_window(int width, int height)
+ int ret;
+ ret = 1;
+ if (width < 1 || height < 1) {
+ width = 20;
+ height = 20;
+ ret = 0;
+ GS_set_viewport(0, width, 0, height);
+ /* GS_clear(0x0000FF); causes red flash - debug only */
+ GS_set_draw(GSD_BACK);
+ GS_ready_draw();
+ GS_alldraw_wire();
+ GS_done_draw();
+ return ret;
Copied: grass-addons/visualization/nviz2/lib/cplanes_obj.c (from rev 31709, grass-addons/visualization/nviz2/cmd/cplanes_obj.c)
--- grass-addons/visualization/nviz2/lib/cplanes_obj.c (rev 0)
+++ grass-addons/visualization/nviz2/lib/cplanes_obj.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -0,0 +1,123 @@
+ \file cplanes_obj.c
+ \brief Nviz library -- Clip planes manipulation
+ for details.
+ Based on visualization/nviz/src/cutplanes_obj.c
+ \date 2008
+static void cp_draw(nv_data *, int, int, int);
+ \brief Creates a clip plane object
+ The number of clip planes is fixed (MAX_CPLANES) and
+ we'll create them all ahead of time anyway we just let
+ the user decide on the id for each.
+int Nviz_new_cplane(nv_data *data, int id)
+ data->num_cplanes++;
+ /* Initialize internal attributes for this cutplane */
+ data->cp_rot[id][X] = data->cp_rot[id][Y] = data->cp_rot[id][Z] = 0.0;
+ data->cp_trans[id][X] = data->cp_trans[id][Y] = data->cp_trans[id][Z] = 0.0;
+ data->cp_on[id] = 0;
+ return 1;
+ \brief Turn off (make inactive) the given clip plane
+ \param data nviz data
+ \param cplane id
+int Nviz_off_cplane(nv_data *data, int id)
+ GS_unset_cplane(id);
+ return 1;
+ \brief Draw the clip plane
+ \param bound1
+ \param bound2
+int Nviz_draw_cplane(nv_data *data, int bound1, int bound2)
+ cp_draw(data, data->cur_cplane, bound1, bound2);
+ return 1;
+ \brief Draw current clip plane
+ \param current id of current clip plane
+ \param surf1 first surface id
+ \param surf2 second surface id
+void cp_draw(nv_data *data, int current, int surf1, int surf2)
+ int i, nsurfs;
+ int surf_min=0, surf_max=0, temp;
+ int *surf_list;
+ GS_clear(data->bgcolor);
+ GS_ready_draw();
+ /* If surf boundaries present then find them */
+ surf_list = GS_get_surf_list(&nsurfs);
+ if ((surf1 != -1) && (surf2 != -1)) {
+ for (i = 0; i < nsurfs; i++) {
+ if (surf_list[i] == surf1)
+ surf_min = i;
+ if (surf_list[i] == surf2)
+ surf_max = i;
+ if (surf_max < surf_min) {
+ temp = surf_min;
+ surf_min = surf_max;
+ surf_max = temp;
+ surf_max++;
+ else {
+ surf_min = 0;
+ surf_max = nsurfs;
+ if (nsurfs > 1) {
+ for (i = 0; i < MAX_CPLANES; i++) {
+ if (data->cp_on[i])
+ GS_draw_cplane_fence(surf_list[0], surf_list[1], i);
+ for (i = surf_min; i < surf_max; i++) {
+ GS_draw_wire(surf_list[i]);
+ GS_done_draw();
+ return;
Copied: grass-addons/visualization/nviz2/lib/lights.c (from rev 31709, grass-addons/visualization/nviz2/cmd/lights.c)
--- grass-addons/visualization/nviz2/lib/lights.c (rev 0)
+++ grass-addons/visualization/nviz2/lib/lights.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -0,0 +1,151 @@
+ \file lights.c
+ \brief Nviz library -- Change view settings
+ for details.
+ Based on visualization/nviz/src/lights.c
+ \date 2008
+#include <grass/glocale.h>
+ \brief Set light position
+ \param num light num (starts with 0)
+ \param x,y,z,w position, model coordinates
+int Nviz_set_light_position(nv_data *data, int num,
+ float x, float y, float z, float w)
+ data->light[num].id = num + 1;
+ data->light[num].x = x;
+ data->light[num].y = y;
+ data->light[num].z = z;
+ data->light[num].w = w;
+ GS_setlight_position(num + 1, x, y, z, w);
+ return 1;
+ \brief Set light brightness
+ \param value brightness value
+int Nviz_set_light_bright(nv_data * data, int num, float value)
+ float r, g, b;
+ data->light[num].brt = value;
+ r = data->light[num].r * data->light[num].brt;
+ g = data->light[num].g * data->light[num].brt;
+ b = data->light[num].b * data->light[num].brt;
+ GS_setlight_color(num + 1, r, g, b);
+ return 1;
+ \brief Set light color
+ \param red,green,blue rGB values (0-1)
+int Nviz_set_light_color(nv_data * data, int num,
+ float red, float green, float blue)
+ float r, g, b;
+ data->light[num].r = red;
+ data->light[num].g = green;
+ data->light[num].b = blue;
+ return 1;
+ \brief Set light ambient
+int Nviz_set_light_ambient(nv_data *data, int num,
+ data->light[num].ar = red;
+ data->light[num].ag = green;
+ data->light[num].ab = blue;
+ GS_setlight_ambient(num + 1, red, green, blue);
+ return 1;
+ \brief Init new light
+int Nviz_init_light(nv_data *data, int num)
+ if (num >= MAX_LIGHTS) {
+ return 0;
+ data->light[num].id = 0;
+ data->light[num].brt = 0.8;
+ data->light[num].ar = 0.3;
+ data->light[num].ag = 0.3;
+ data->light[num].ab = 0.3;
+ data->light[num].r = 1.0;
+ data->light[num].b = 1.0;
+ data->light[num].g = 1.0;
+ data->light[num].x = 1.0;
+ data->light[num].y = 1.0;
+ data->light[num].z = 1.0;
+ data->light[num].w = 1.0;
+ return 1;
+int Nviz_new_light(nv_data *data)
+ int num;
+ num = GS_new_light();
+ if (num < 1) {
+ G_warning(_("Unable to define new light"));
+ return 0;
+ Nviz_init_light(data, num - 1);
+ return 1;
Copied: grass-addons/visualization/nviz2/lib/nviz.c (from rev 31709, grass-addons/visualization/nviz2/cmd/nviz.c)
--- grass-addons/visualization/nviz2/lib/nviz.c (rev 0)
+++ grass-addons/visualization/nviz2/lib/nviz.c 2008-06-19 18:50:41 UTC (rev 31762)
@@ -0,0 +1,61 @@
+ \file nviz.c
+ \brief Nviz library -- Data management
+ for details.
+ \date 2008
+ \brief Initialize Nviz data
+void Nviz_init_data(nv_data *data)
+ unsigned int i;
+ /* data range */
+ data->zrange = 0;
+ data->xyrange = 0;
+ /* clip planes, turn off by default*/
+ data->num_cplanes = 0;
+ data->cur_cplane = 0;
+ Nviz_new_cplane(data, i);
+ Nviz_off_cplane(data, i);
+ /* lights */
+ for (i = 0; i < MAX_LIGHTS; i++) {
+ Nviz_new_light(data);
+ return;
+ \brief Set background color
+ \param color color value
+void Nviz_set_bgcolor(nv_data *data, int color)
+ data->bgcolor = color;
+ return;
Modified: grass-addons/visualization/nviz2/lib/nviz.h
--- grass-addons/visualization/nviz2/lib/nviz.h 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/lib/nviz.h 2008-06-19 18:50:41 UTC (rev 31762)
@@ -110,13 +110,35 @@
GLXPixmap windowId;
+/* change_view.c */
+int Nviz_resize_window(int, int);
+/* cplanes_obj.c */
+int Nviz_new_cplane(nv_data *, int);
+int Nviz_off_cplane(nv_data *, int);
+int Nviz_draw_cplane(nv_data *, int, int);
+/* lights.c */
+int Nviz_set_light_position(nv_data *, int,
+ float, float, float, float);
+int Nviz_set_light_bright(nv_data *, int, float);
+int Nviz_set_light_color(nv_data *, int,
+ float, float, float);
+int Nviz_set_light_ambient(nv_data *, int,
+int Nviz_init_light(nv_data *, int);
+int Nviz_new_light(nv_data *);
+/* nviz.c */
+void Nviz_init_data(nv_data *);
+void Nviz_set_bgcolor(nv_data *, int);
/* render.c */
struct render_window* Nviz_new_render_window();
void Nviz_init_render_window(struct render_window*);
void Nviz_destroy_render_window(struct render_window *);
int Nviz_create_render_window(struct render_window *, void *,
int, int);
int Nviz_make_current_render_window(const struct render_window *);
#endif /* GRASS_NVIZ_H */
Modified: grass-addons/visualization/nviz2/wxpython/nviz/Makefile
--- grass-addons/visualization/nviz2/wxpython/nviz/Makefile 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/wxpython/nviz/Makefile 2008-06-19 18:50:41 UTC (rev 31762)
@@ -3,12 +3,16 @@
include $(MODULE_TOPDIR)/include/Make/Lib.make
+# TODO
+NVIZLIB= -lgrass_nviz $(GISLIB)
+# NVIZDEP=$(ARCH_LIBDIR)/$(LIB_PREFIX)grass_nviz$(LIB_SUFFIX)
LIB_NAME = grass6_wxnviz
SOURCES := $(wildcard *.cpp) $(LIB_NAME)_wrap.cpp
SHLIB_OBJS := $(patsubst %.cpp, $(OBJDIR)/%.o, $(SOURCES))
EXTRA_CFLAGS = $(SHLIB_CFLAGS) $(GDALCFLAGS) $(PYTHONCFLAGS) $(WXWIDGETSCXXFLAGS) $(XCFLAGS) $(XMINC)
-EXTRA_LIBS = $(GISLIB) $(WXWIDGETSLIB) $(PYTHONLDFLAGS) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB)
+EXTRA_LIBS = $(GISLIB) $(WXWIDGETSLIB) $(PYTHONLDFLAGS) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB) $(NVIZLIB)
LOCAL_HEADERS = nviz.h
Added: grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp (rev 0)
+++ grass-addons/visualization/nviz2/wxpython/nviz/change_view.cpp 2008-06-19 18:50:41 UTC (rev 31762)
@@ -0,0 +1,33 @@
+ \file change_view.cpp
+ \brief Experimental C++ wxWidgets Nviz prototype -- Change viewport
+ Used by wxGUI Nviz extension.
+ Copyright: (C) by the GRASS Development Team
+ for details.
+ \author Martin Landa <landa.martin gmail.com> (Google SoC 2008)
+ \date 2008
+#include "nviz.h"
+int Nviz::ResizeWindow(int width, int height)
+ return Nviz_resize_window(width, height);
Modified: grass-addons/visualization/nviz2/wxpython/nviz/init.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/init.cpp 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/wxpython/nviz/init.cpp 2008-06-19 18:50:41 UTC (rev 31762)
@@ -48,26 +48,26 @@
- \brief Swap GL buffers
-void swap_gl()
- return;
\brief Associate display with render window
-int Nviz::SetDisplay(void *display, int width, int height)
+int Nviz::SetDisplay(void *display)
if (!rwind)
return 0;
- Nviz_create_render_window(rwind, display, width, height);
- Nviz_make_current_render_window(rwind);
+ glCanvas = (wxGLCanvas *) display;
+ //Nviz_create_render_window(rwind, display, width, height);
+ //Nviz_make_current_render_window(rwind);
return 1;
+void swap_gl()
+ return;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
--- grass-addons/visualization/nviz2/wxpython/nviz/nviz.h 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/wxpython/nviz/nviz.h 2008-06-19 18:50:41 UTC (rev 31762)
@@ -8,11 +8,25 @@
+// For compilers that support precompilation, includes "wx.h".
+#include <wx/wxprec.h>
+#ifdef __BORLANDC__
+#pragma hdrstop
+#endif
+#ifndef WX_PRECOMP
+// Include your minimal set of headers here, or wx.h
+#include <wx/wx.h>
+#endif
+#include <wx/glcanvas.h>
class Nviz
private:
- // struct render_window *rwind;
+ wxGLCanvas *glCanvas;
public:
/* constructor */
@@ -22,7 +36,8 @@
~Nviz();
/* set */
- int SetDisplay(void *, int, int);
+ int SetDisplay(void *);
+ int ResizeWindow(int, int);
#endif /* __NVIZ_H__ */
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-19 18:25:31 UTC (rev 31761)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-19 18:50:41 UTC (rev 31762)
@@ -49,8 +49,13 @@
# create nviz instance
- nvizClass = wxnviz.Nviz()
+ self.nvizClass = wxnviz.Nviz()
+ # set current display
+ self.nvizClass.SetDisplay(self)
# initialize mouse position
self.lastx = self.x = 30
self.lasty = self.y = 30
@@ -70,7 +75,8 @@
size = self.size = self.parent.GetClientSize()
if self.GetContext():
self.SetCurrent()
- glViewport(0, 0, size.width, size.height)
+ # glViewport(0, 0, size.width, size.height)
+ self.nvizClass.ResizeWindow(size.width, size.height)
event.Skip()
@@ -78,11 +84,13 @@
dc = wx.PaintDC(self)
self.SetCurrent()
if not self.init:
- self.InitGL()
+ # self.InitGL()
+ nvizClass.InitView()
self.init = True
self.OnDraw()
def InitGL(self):
# set viewing projection
glMatrixMode(GL_PROJECTION)
glFrustum(-0.5, 0.5, -0.5, 0.5, 1.0, 3.0)
