[GRASS-SVN] r31779 - grass/trunk
Sat Jun 21 08:08:39 EDT 2008
Author: neteler
Date: 2008-06-21 08:08:39 -0400 (Sat, 21 Jun 2008)
New Revision: 31779
   grass/trunk/SUBMITTING
indent rules updated (from Glynn)
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING	2008-06-21 11:51:28 UTC (rev 31778)
+++ grass/trunk/SUBMITTING	2008-06-21 12:08:39 UTC (rev 31779)
@@ -229,9 +229,9 @@
 15. To promote a consistent coding style, please use the "indent" program
     on all new C modules using the following switches:
-     $ indent -nbad -bap -bbb -nbbo -nbc -br -bli1 -bls -cbi0 -ncdb -nce \
-        -ci4 -cli0 -ncs -d0 -di0 -fc1 -nfca -hnl -i4 -ip4 -l80 -lc80 -lp \
-	-npcs -pi4 -nprs -npsl -sbi0 -sc -nsob -ss -ts8  main.c
+     $ indent -bad -bap -bbb -br -bli0 -bls -cli0 -ncs -fc1 -hnl -i4 \
+      -nbbo -nbc -nbfda -nbfde -ncdb -ncdw -nce -nfca -npcs -nprs \
+      -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut main.c
     Existing code should not be re-indented except in extreme cases, as this
     will make "diff" comparisons with older versions impossible. If indent is
