[GRASS-SVN] r31827 - grass-addons/general/g.region.point
svn_grass at osgeo.org
Mon Jun 23 09:38:31 EDT 2008
Author: hamish
Date: 2008-06-23 09:38:31 -0400 (Mon, 23 Jun 2008)
New Revision: 31827
grass-addons/general/g.region.point/description.html
improve example script
Modified: grass-addons/general/g.region.point/description.html
--- grass-addons/general/g.region.point/description.html 2008-06-23 13:21:50 UTC (rev 31826)
+++ grass-addons/general/g.region.point/description.html 2008-06-23 13:38:31 UTC (rev 31827)
@@ -23,13 +23,22 @@
<h2>EXAMPLE</H2>
-Evaluate the mean value in a 100m wide raster buffer around a series of
-vector points.
+The following is a shell script utilizing <em>g.region.point</em> which
+will evaluate the mean value in a 100m wide raster buffer around a series
+of vector points. Using <em>g.region.point</em> speeds up this script about
+700% while producing identical output.
-<!-- it is unclear to me if the "clone current region" step is actually needed -->
<div class="code"><pre>
+ #!/bin/sh
# Spearfish dataset
+ # maps to use in query
+ VECT_MAP=archsites
+ RAST_MAP=elevation.10m
+ # set region from target raster
+ g.region rast="$RAST_MAP"
# clone current region
g.region save="tmp_region.$$"
@@ -37,24 +46,33 @@
WIND_OVERRIDE="tmp_region.$$"
export WIND_OVERRIDE
- # create list of starting coordinates
- POINTS=`v.out.ascii archsites | cut -f1,2 -d'|' | tr '|' ','`
+ # output column headings line
+ echo "cat|mean_elev|n"
# run the processing loop
- for POINT in $POINTS ; do
+ v.out.ascii "$VECT_MAP" | ( while read LINE ; do
+ POINT=`echo $LINE | cut -f1,2 -d'|' | tr '|' ','`
+ CATEGORY=`echo $LINE | cut -f3 -d'|'`
g.region.point coord="$POINT" diam=150 res=10
- r.circle -b coord=$POINT max=100 out=MASK --quiet
- eval `r.univar -g elevation.10m`
+ r.circle -b coord="$POINT" max=100 out=MASK --quiet
+ eval `r.univar -g "$RAST_MAP"`
g.remove MASK --quiet
- echo "coord=$POINT mean=$mean (n=$n)"
- done
+ echo "$CATEGORY|$mean|$n"
+ done )
# remove the temporary region
unset WIND_OVERRIDE
g.remove region="tmp_region.$$" --quiet
</pre></div>
+The <em>v.db.update</em> module may be used in place of "echo" in the above
+example to load the results into the vector map's attribute table instead of
+sending them to <tt>stdout</tt>. If required a new column to hold these values
+may be added to the database table with <em>v.db.addcol</em> prior to running
+the update script.
<H2>SEE ALSO</H2>
<EM>
<A HREF="g.region.html">g.region</A>,
