[GRASS-SVN] r31859 - grass-addons/visualization/nviz2/wxpython
Fri Jun 27 10:45:36 EDT 2008
Author: martinl
Date: 2008-06-27 10:45:35 -0400 (Fri, 27 Jun 2008)
New Revision: 31859
Added:
   grass-addons/visualization/nviz2/wxpython/preferences.py
   grass-addons/visualization/nviz2/wxpython/mapdisp.py
   grass-addons/visualization/nviz2/wxpython/nviz.py
   grass-addons/visualization/nviz2/wxpython/wxgui_utils.py
nviz2: wxGUI layout updated (surface settings)
Modified: grass-addons/visualization/nviz2/wxpython/mapdisp.py
--- grass-addons/visualization/nviz2/wxpython/mapdisp.py	2008-06-27 12:35:50 UTC (rev 31858)
+++ grass-addons/visualization/nviz2/wxpython/mapdisp.py	2008-06-27 14:45:35 UTC (rev 31859)
@@ -160,9 +160,11 @@
     def ZoomToMap(self, event):
         pass
-    def GetSelectedLayer(self):
+    def GetSelectedLayer(self, nviz=False):
         """Get selected layer from layer tree
+        @param nviz get nviz properties instead
         @return map layer instance
         @return None on failure
@@ -172,7 +174,10 @@
         item = self.tree.GetSelection()
         try:
-            layer = self.tree.GetPyData(item)[0]['maplayer']
+            if nviz:
+                layer = self.tree.GetPyData(item)[0]['nviz']
+            else:
+                layer = self.tree.GetPyData(item)[0]['maplayer']
         except:
             layer = None
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py	2008-06-27 12:35:50 UTC (rev 31858)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py	2008-06-27 14:45:35 UTC (rev 31859)
@@ -24,6 +24,7 @@
 from threading import Thread
 import wx
+import wx.lib.colourselect as csel
 try:
     from wx import glcanvas
     haveGLCanvas = True
@@ -42,13 +43,14 @@
 import gselect
 from debug import Debug as Debug
 from mapdisp import MapWindow as MapWindow
-#try:
-nvizPath = os.path.join(globalvar.ETCWXDIR, "nviz")
-sys.path.append(nvizPath)
-import grass6_wxnviz as wxnviz
-haveNviz = True
-#except ImportError:
-#    haveNviz = False
+from preferences import globalSettings as UserSettings
+try:
+    nvizPath = os.path.join(globalvar.ETCWXDIR, "nviz")
+    sys.path.append(nvizPath)
+    import grass6_wxnviz as wxnviz
+    haveNviz = True
+except ImportError:
+    haveNviz = False
 class GLWindow(MapWindow, glcanvas.GLCanvas):
     """OpenGL canvas for Map Display Window"""
@@ -102,34 +104,8 @@
         # default values
-        self.view = { 'persp' : { 'value' : 40,
-                                  'min' : 0,
-                                  'max' : 100,
-                                  'step' : 5,
-                                  'update' : False,
-                      'pos' : { 'value' : (0.85, 0.85),
-                                'update' : False,
-                      'height' : { 'value': -1,
-                                   'min' : -2245, # TODO: determine min/max height
-                                   'max' : 3695,
-                                   'step' : 100,
-                                   'update' : False,
-                      'twist' : { 'value' : 0,
-                                  'min' : -180,
-                                  'max' : 180,
-                                  'step' : 5,
-                                  'update' : False,
-                      'z-exag' : { 'value': 1.0,
-                                   'min' : 0.0,
-                                   'max' : 10,
-                                   'step' : 1,
-                                   'update' : False
+        self.view = UserSettings.Get(group='nviz', key='view') # reference
+        self.update = [] # update view/controls
         self.size = None
         self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
@@ -194,7 +170,7 @@
             if hasattr(self.parent, "nvizToolWin"):
                 self.parent.nvizToolWin.UpdateSettings()
-            self.nvizClass.SetView(self.view['pos']['value'][0], self.view['pos']['value'][1],
+            self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
                                    self.view['height']['value'],
                                    self.view['persp']['value'],
                                    self.view['twist']['value'])
@@ -252,20 +228,16 @@
                 self.parent.onRenderTimer.Start(100)
             self.parent.onRenderCounter = 0
-        if self.view['pos']['update'] or \
-                self.view['height']['update'] or \
-                self.view['persp']['update'] or \
-                self.view['twist']['update']:
+        if 'view' in self.update:
-            for control in ('pos', 'height', 'persp', 'twist'):
-                self.view[control]['update'] = False
+            self.update.remove('view')
-        if self.view['z-exag']['update']:
+        if 'z-exag' in self.update:
             self.nvizClass.SetZExag(self.view['z-exag']['value'])
-            self.view['z-exag']['update'] = False
+            self.update.remove('z-exag')
         if render is True:
             self.nvizClass.Draw(False)
@@ -333,16 +305,15 @@
     def ResetView(self):
         """Reset to default view"""
-        self.view['pos']['value'] = (wxnviz.VIEW_DEFAULT_POS_X,
-                                     wxnviz.VIEW_DEFAULT_POS_Y)
+        self.view['pos']['x'] = wxnviz.VIEW_DEFAULT_POS_X
+        self.view['pos']['y'] = wxnviz.VIEW_DEFAULT_POS_Y
         self.view['height']['value'] = self.nvizClass.SetViewDefault()
         self.view['persp']['value'] = wxnviz.VIEW_DEFAULT_PERSP
         self.view['twist']['value'] = wxnviz.VIEW_DEFAULT_TWIST
         self.view['z-exag']['value'] = wxnviz.VIEW_DEFAULT_ZEXAG
-                        'twist', 'z-exag'):
-            self.view[control]['update'] = True
+        self.update.append('view')
+        self.update.append('z-exag')
 class NvizToolWindow(wx.Frame):
     """Experimental window for Nviz tools
@@ -369,6 +340,7 @@
         self.__createViewPage()
         self.__createSurfacePage()
+        self.UpdatePage('surface')
         mainSizer.Add(item=self.notebook, proportion=1,
                       flag=wx.EXPAND | wx.ALL, border=5)
@@ -411,6 +383,8 @@
         pageSizer = wx.BoxSizer(wx.VERTICAL)
         gridSizer = wx.GridBagSizer(vgap=3, hgap=3)
+        self.win['view'] = {}
         # position
         posSizer = wx.GridBagSizer(vgap=3, hgap=3)
         posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("W")),
@@ -419,7 +393,7 @@
                      pos=(0, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_BOTTOM)
         viewPos = ViewPositionWindow(panel, id=wx.ID_ANY, size=(175, 175),
                                      settings=self.settings, mapwindow=self.mapWindow)
-        self.win['pos'] = viewPos.GetId()
+        self.win['view']['pos'] = viewPos.GetId()
         posSizer.Add(item=viewPos,
                      pos=(1, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_CENTER_VERTICAL)
         posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("S")),
@@ -432,16 +406,16 @@
         self.CreateControl(panel, 'persp')
         gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Perspective:")),
                       pos=(1, 0), flag=wx.ALIGN_CENTER)
-        gridSizer.Add(item=self.FindWindowById(self.win['persp']['slider']), pos=(2, 0))
-        gridSizer.Add(item=self.FindWindowById(self.win['persp']['spin']), pos=(3, 0),
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['slider']), pos=(2, 0))
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['persp']['spin']), pos=(3, 0),
         # twist
         self.CreateControl(panel, 'twist')
         gridSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Twist:")),
                       pos=(1, 1), flag=wx.ALIGN_CENTER)
-        gridSizer.Add(item=self.FindWindowById(self.win['twist']['slider']), pos=(2, 1))
-        gridSizer.Add(item=self.FindWindowById(self.win['twist']['spin']), pos=(3, 1),
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['slider']), pos=(2, 1))
+        gridSizer.Add(item=self.FindWindowById(self.win['view']['twist']['spin']), pos=(3, 1),
         # height + z-exag
@@ -450,16 +424,16 @@
         heightSizer = wx.GridBagSizer(vgap=3, hgap=3)
         heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Height:")),
                       pos=(0, 0), flag=wx.ALIGN_LEFT, span=(1, 2))
-        heightSizer.Add(item=self.FindWindowById(self.win['height']['slider']),
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['slider']),
                         flag=wx.ALIGN_RIGHT, pos=(1, 0))
-        heightSizer.Add(item=self.FindWindowById(self.win['height']['spin']),
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['height']['spin']),
                         flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT | wx.TOP |
                         wx.BOTTOM | wx.RIGHT, pos=(1, 1))
         heightSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("Z-exag:")),
                       pos=(0, 2), flag=wx.ALIGN_LEFT, span=(1, 2))
-        heightSizer.Add(item=self.FindWindowById(self.win['z-exag']['slider']),
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['slider']),
                         flag=wx.ALIGN_RIGHT, pos=(1, 2))
-        heightSizer.Add(item=self.FindWindowById(self.win['z-exag']['spin']),
+        heightSizer.Add(item=self.FindWindowById(self.win['view']['z-exag']['spin']),
                         wx.BOTTOM | wx.RIGHT, pos=(1, 3))
@@ -516,6 +490,7 @@
+        self.win['surface'] = {}
         # surface attributes
@@ -536,19 +511,22 @@
         #             col += 1
         # type
+        self.win['surface']['attr'] = {}
         row = 0
-        for attr in (_("Topography"),
-                     _("Color"),
-                     _("Mask"),
-                     _("Transparency"),
-                     _("Shininess"),
-                     _("Emission")):
+        for code, attr in (('topo', _("Topography")),
+                     ('color', _("Color")),
+                     ('mask', _("Mask")),
+                     ('transp', _("Transparency")),
+                     ('shine', _("Shininess")),
+                     ('emis', _("Emission"))):
+            self.win['surface'][code] = {}
             gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
                                              label=attr + ':'),
                           pos=(row, 0), flag=wx.ALIGN_CENTER_VERTICAL)
             use = wx.Choice (parent=panel, id=wx.ID_ANY, size=(100, -1),
                              choices = [_("map"),
                                         _("constant")])
+            self.win['surface'][code]['use'] = use.GetId()
             use.Bind(wx.EVT_CHOICE, self.OnSurfaceUse)
             gridSizer.Add(item=use, flag=wx.ALIGN_CENTER_VERTICAL,
                           pos=(row, 1))
@@ -557,20 +535,27 @@
                                  # size=globalvar.DIALOG_GSELECT_SIZE,
                                  size=(200, -1),
                                  type="raster")
+            self.win['surface'][code]['map'] = map.GetId()
+            map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
             gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
                           pos=(row, 2))
             value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
                                 initial=0,
                                 min=0,
                                 max=100)
+            self.win['surface'][code]['constant'] = value.GetId()
+            value.Enable(False)
             gridSizer.Add(item=value, flag=wx.ALIGN_CENTER_VERTICAL,
                           pos=(row, 3))
+            self.SetSurfaceUseMap(code) # -> enable map / disable constant
             row += 1
         boxSizer.Add(item=gridSizer, proportion=1,
                   flag=wx.ALL | wx.EXPAND, border=3)
-        pageSizer.Add(item=boxSizer, proportion=1,
+        pageSizer.Add(item=boxSizer, proportion=0,
                       border=5)
@@ -631,24 +616,101 @@
         gridSizer.Add(item=shade, flag=wx.ALIGN_CENTER_VERTICAL,
                       pos=(1, 3))
+        # color
+        gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                         label=_("Wire color:")),
+                      pos=(2, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+        color = csel.ColourSelect(panel, id=wx.ID_ANY,
+                                  colour="white")
+        gridSizer.Add(item=color, flag=wx.ALIGN_CENTER_VERTICAL,
+                      pos=(2, 1))
+        boxSizer.Add(item=gridSizer, proportion=1,
+                  flag=wx.ALL | wx.EXPAND, border=3)
+                      flag=wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM,
+                      border=5)
         all = wx.Button(panel, id=wx.ID_ANY, label=_("All"))
         all.SetToolTipString(_("Use for all loaded surfaces"))
         # self.win['reset'] = reset.GetId()
         # reset.Bind(wx.EVT_BUTTON, self.OnResetView)
         gridSizer.Add(item=all, flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND,
-                      pos=(1, 4))
+                      pos=(2, 4))
+        # mask
+        box = wx.StaticBox (parent=panel, id=wx.ID_ANY,
+                            label=" %s " % (_("Mask")))
+        boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
+                                         label=_("Mask zeros:")),
+                      pos=(0, 0), flag=wx.ALIGN_CENTER_VERTICAL)
+        elev = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                           label=_("by elevation"))
+        gridSizer.Add(item=elev, pos=(0, 1))
+        color = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                           label=_("by color"))
+        gridSizer.Add(item=color, pos=(0, 2))
-                      flag=wx.EXPAND | wx.ALL,
                       border=5)
+        # position
+                            label=" %s " % (_("Position")))
+        # position
+                                         label="X:"),
+        x = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                        initial=0,
+                        min=0,
+                        max=100)
+        gridSizer.Add(item=x, pos=(0, 1))
+                                         label="X:"),
+                      pos=(0, 2), flag=wx.ALIGN_CENTER_VERTICAL)
+        y = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                        initial=0,
+                        min=0,
+                        max=100)
+        gridSizer.Add(item=y, pos=(0, 3))
+                                         label="X:"),
+                      pos=(0, 4), flag=wx.ALIGN_CENTER_VERTICAL)
+        z = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(100, -1),
+                        initial=0,
+                        min=0,
+                        max=100)
+        gridSizer.Add(item=z, pos=(0, 5))
+                      border=5)
         panel.SetSizer(pageSizer)
     def CreateControl(self, parent, name, sliderHor=True):
         """Add control (Slider + SpinCtrl)"""
-        self.win[name] = {}
+        self.win['view'][name] = {}
         if sliderHor:
             style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
                 wx.SL_BOTTOM
@@ -665,7 +727,7 @@
                            size=size)
         slider.Bind(wx.EVT_SCROLL, self.OnChangeValue)
-        self.win[name]['slider'] = slider.GetId()
+        self.win['view'][name]['slider'] = slider.GetId()
         spin = wx.SpinCtrl(parent=parent, id=wx.ID_ANY, size=(65, -1),
                            initial=self.settings[name]['value'],
@@ -677,7 +739,7 @@
         #                      self.settings[name]['max'])
         spin.Bind(wx.EVT_SPINCTRL, self.OnChangeValue)
-        self.win[name]['spin'] = spin.GetId()
+        self.win['view'][name]['spin'] = spin.GetId()
     def UpdateSettings(self):
         """Update dialog settings"""
@@ -685,38 +747,41 @@
                         'persp',
                         'twist',
                         'z-exag'):
-            for win in self.win[control].itervalues():
+            for win in self.win['view'][control].itervalues():
                 self.FindWindowById(win).SetValue(self.settings[control]['value'])
-        self.FindWindowById(self.win['pos']).Draw()
-        self.FindWindowById(self.win['pos']).Refresh(False)
+        self.FindWindowById(self.win['view']['pos']).Draw()
+        self.FindWindowById(self.win['view']['pos']).Refresh(False)
         self.Refresh(False)
+    def __GetWindowName(self, dict, id):
+        for name in dict.iterkeys():
+            if type(dict[name]) is type({}):
+                for win in dict[name].itervalues():
+                    if win == id:
+                        return name
+            else:
+                if dict[name] == id:
+                    return name
+        return None
     def OnChangeValue(self, event):
         # find control
-        winName = ''
-        for name in self.win.iterkeys():
-            if type(self.win[name]) is type({}):
-                for win in self.win[name].itervalues():
-                    if win == event.GetId():
-                        winName = name
-                        break
-            else:
-                if self.win[name] == event.GetId():
-                    winName = name
-                    break
-        if winName == '':
+        winName = self.__GetWindowName(self.win['view'], event.GetId())
+        if not winName:
             return
         self.settings[winName]['value'] = event.GetInt()
-        for win in self.win[winName].itervalues():
+        for win in self.win['view'][winName].itervalues():
             self.FindWindowById(win).SetValue(self.settings[winName]['value'])
+        if winName in ('pos', 'height', 'twist', 'persp'):
+            self.mapWindow.update.append('view')
+        else:
+            self.mapWindow.update.append(winName)
-        self.settings[winName]['update'] = True
         self.mapWindow.Refresh(False)
     def OnResetView(self, event):
@@ -729,25 +794,34 @@
         """Look at (view page)"""
         sel = event.GetSelection()
         if sel == 0: # top
-            self.settings['pos']['value'] = (0.5, 0.5)
+            self.settings['pos']['x'] = 0.5
+            self.settings['pos']['y'] = 0.5
         elif sel == 1: # north
-            self.settings['pos']['value'] = (0.5, 0.0)
+            self.settings['pos']['y'] = 0.0
         elif sel == 2: # south
-            self.settings['pos']['value'] = (0.5, 1.0)
+            self.settings['pos']['y'] = 1.0
         elif sel == 3: # east
-            self.settings['pos']['value'] = (1.0, 0.5)
+            self.settings['pos']['x'] = 1.0
         elif sel == 4: # west
-            self.settings['pos']['value'] = (0.0, 0.5)
+            self.settings['pos']['x'] = 0.0
         elif sel == 5: # north-west
-            self.settings['pos']['value'] = (0.0, 0.0)
         elif sel == 6: # north-east
-            self.settings['pos']['value'] = (1.0, 0.0)
         elif sel == 7: # south-east
-            self.settings['pos']['value'] = (1.0, 1.0)
         elif sel == 8: # south-west
-            self.settings['pos']['value'] = (0.0, 1.0)
-        self.settings['pos']['update'] = True
         self.UpdateSettings()
@@ -774,8 +848,40 @@
     def OnSurfaceUse(self, event):
         """Surface attribute -- use -- map/constant"""
-        pass
+        # find attribute row
+        attrName = self.__GetWindowName(self.win['surface'], event.GetId())
+        if not attrName:
+            return
+        if event.GetSelection() == 0:
+            useMap = True
+        else:
+            useMap = False
+        self.SetSurfaceUseMap(attrName, useMap)
+    def SetSurfaceUseMap(self, attrName, map=True):
+        if map: # map
+            self.FindWindowById(self.win['surface'][attrName]['map']).Enable(True)
+            self.FindWindowById(self.win['surface'][attrName]['constant']).Enable(False)
+            self.FindWindowById(self.win['surface'][attrName]['use']).SetSelection(0)
+        else: # constant
+            self.FindWindowById(self.win['surface'][attrName]['map']).Enable(False)
+            self.FindWindowById(self.win['surface'][attrName]['constant']).Enable(True)
+            self.FindWindowById(self.win['surface'][attrName]['use']).SetSelection(1)
+    def OnSurfaceMap(self, event):
+        """Set surface attribute -- map"""
+        attrName = 'topo'
+        win = self.FindWindowById(self.win['surface'][attrName]['map'])
+        # print win.GetId(), win.tcp.seltree.GetId(), event.GetId()
+        if not attrName:
+            return
+        if attrName == 'topo':
+            print 'x'
     def OnSurfaceMode(self, event):
         pass
@@ -785,6 +891,22 @@
     def OnSurfaceShade(self, event):
         pass
+    def UpdatePage(self, pageId):
+        """Update dialog (selected page)"""
+        layer = self.mapWindow.GetSelectedLayer()
+        nvizLayer = self.mapWindow.GetSelectedLayer(nviz=True)
+        if pageId == 'surface':
+            if nvizLayer is None:
+                for attr in ('topo', 'color'):
+                    self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
+                if UserSettings.Get(group='nviz', key='surface', subkey=['shininess', 'map']) is False:
+                    self.SetSurfaceUseMap('shine', False)
+                    value = UserSettings.Get(group='nviz', key='surface', subkey=['shininess', 'value'])
+                    self.FindWindowById(self.win['surface']['shine']['constant']).SetValue(value)
+            else:
+                pass # TODO
 class ViewPositionWindow(wx.Window):
     """Position control window (for NvizToolWindow)"""
     def __init__(self, parent, id, mapwindow,
@@ -812,7 +934,8 @@
         w, h = self.GetClientSize()
         if pos is None:
-            x, y = self.settings['pos']['value']
+            x = self.settings['pos']['x']
+            y = self.settings['pos']['y']
             x = x * w
             y = y * h
         else:
@@ -840,8 +963,9 @@
             x = float(x) / w
             y = float(y) / h
-            self.settings['pos']['value'] = (x, y)
+            self.settings['pos']['x'] = x
+            self.settings['pos']['y'] = y
             self.mapWindow.Refresh(eraseBackground=False)
             # self.mapWindow.UpdateMap()
Added: grass-addons/visualization/nviz2/wxpython/preferences.py
--- grass-addons/visualization/nviz2/wxpython/preferences.py	                        (rev 0)
+++ grass-addons/visualization/nviz2/wxpython/preferences.py	2008-06-27 14:45:35 UTC (rev 31859)
@@ -0,0 +1,1427 @@
+ at package preferences
+ at brief User preferences dialog
+Sets default display font, etc.
+Classes:
+ - PreferencesDialog
+ - SetDefaultFont
+ - MapsetAccess
+(C) 2007-2008 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Michael Barton (Arizona State University)
+Martin Landa <landa.martin gmail.com>
+import os
+import sys
+import copy
+import stat
+if os.name in ('posix', 'mac'):
+    import pwd
+import wx
+import wx.lib.filebrowsebutton as filebrowse
+import wx.lib.mixins.listctrl as listmix
+from wx.lib.wordwrap import wordwrap
+import gcmd
+import grassenv
+import utils
+import globalvar
+from debug import Debug as Debug
+class Settings:
+    """Generic class where to store settings"""
+    def __init__(self):
+        # settings filename
+        self.fileName = ".grasswx"
+        self.filePath = None
+        # default settings
+        self.defaultSettings = {
+            # general
+            'general': {
+                # current mapset search path
+                'mapsetPath'  : { 'selection' : 0 },
+                # use default window layout (layer manager, displays, ...)
+                'defWindowPos' : { 'enabled' : False, 'dim' : '' },
+            'manager' : {
+                # show opacity level widget
+                'changeOpacityLevel' : { 'enabled' : False },
+                # ask when removing layer from layer tree
+                'askOnRemoveLayer' : { 'enabled' : True },
+            # display
+            'display': {
+                'displayFont' : { 'value' : '' },
+                'driver': { 'type': 'default' },
+                'compResolution' : { 'enabled' : False },
+                'autoRendering': { 'enabled' : False },
+                'statusbarMode': { 'selection' : 0 },
+            # advanced
+            'advanced' : {
+                'settingsFile'   : { 'type' : 'gisdbase' }, # gisdbase, location, mapset
+                'digitInterface' : { 'type' : 'vdigit' }, # vedit, vdigit
+                'iconTheme'      : { 'type' : 'silk' }, # grass, silk
+            # Attribute Table Manager
+            'atm' : {
+                'highlight' : { 'color' : (255, 255, 0, 255), 'width' : 2},
+                'leftDbClick' : { 'selection' : 0 },
+            # Command
+            'cmd': {
+                'overwrite' : { 'enabled' : False },
+                'closeDlg' : { 'enabled' : False },
+                'verbosity' : { 'selection' : 'grassenv' },
+                'rasterOverlay' : { 'enabled' : False },
+            # Workspace
+            'workspace' : {
+                'posDisplay' : { 'enabled' : False },
+                'posManager' : { 'enabled' : False },
+            # vdigit
+            'vdigit' : {
+                # symbology
+                'symbolHighlight'   : { 'enabled' : None,  'color' : (255, 255, 0, 255) }, # yellow
+                'symbolHighlightDupl' : { 'enabled' : None,  'color' : (255, 72, 0, 255) }, # red
+                'symbolPoint'       : { 'enabled' : True,  'color' : (0, 0, 0, 255) }, # black
+                'symbolLine'        : { 'enabled' : True,  'color' : (0, 0, 0, 255) }, # black
+                'symbolBoundaryNo'  : { 'enabled' : True,  'color' : (126, 126, 126, 255) }, # grey
+                'symbolBoundaryOne' : { 'enabled' : True,  'color' : (0, 255, 0, 255) }, # green
+                'symbolBoundaryTwo' : { 'enabled' : True,  'color' : (255, 135, 0, 255) }, # orange
+                'symbolCentroidIn'  : { 'enabled' : True,  'color' : (0, 0, 255, 255) }, # blue
+                'symbolCentroidOut' : { 'enabled' : True,  'color' : (165, 42, 42, 255) }, # brown
+                'symbolCentroidDup' : { 'enabled' : True,  'color' : (156, 62, 206, 255) }, # violet
+                'symbolNodeOne'     : { 'enabled' : True,  'color' : (255, 0, 0, 255) }, # red
+                'symbolNodeTwo'     : { 'enabled' : True,  'color' : (0, 86, 45, 255) }, # dark green
+                'symbolVertex'      : { 'enabled' : False, 'color' : (255, 20, 147, 255) }, # deep pink
+                # display
+                'lineWidth' : { 'value' : 2, 'units' : 'screen pixels' },
+                # snapping
+                'snapping' : { 'value' : 10, 'units' : 'screen pixels' },
+                'snapToVertex' : { 'enabled' : False },
+                'backgroundMap' : {'value' : ''},
+                # digitize new record
+                'addRecord' : { 'enabled' : True },
+                'layer' : {'value' : 1 },
+                'category' : {'value' : 1 },
+                'categoryMode' : {'selection' : 0 },
+                # delete existing feature(s)
+                'delRecord' : { 'enabled' : True },
+                # query tool
+                'query'       : { 'selection' : 0, 'box' : True },
+                'queryLength' : { 'than-selection' : 0, 'thresh' : 0 },
+                'queryDangle' : { 'than-selection' : 0, 'thresh' : 0 },
+                # select feature (point, line, centroid, boundary)
+                'selectFeaturePoint'    : { 'enabled' : True },
+                'selectFeatureLine'     : { 'enabled' : True },
+                'selectFeatureCentroid' : { 'enabled' : True },
+                'selectFeatureBoundary' : { 'enabled' : True },
+                'selectThresh'          : { 'value' : 10, 'units' : 'screen pixels'},
+                'checkForDupl'          : { 'enabled' : False },
+                # exit
+                'saveOnExit'            : { 'enabled' : False },
+            'profile': {
+                'raster0' : { 'pcolor' : (0, 0, 255, 255), # profile line color
+                              'pwidth' : 1, # profile line width
+                              'pstyle' : 'solid', # profile line pen style
+                'raster1' : { 'pcolor' : (255, 0, 0, 255),
+                              'pwidth' : 1,
+                'raster2' : { 'pcolor' : (0, 255, 0, 255),
+                              'pwidth' : 1,
+                'font' : { 'titleSize' : 12,
+                           'axisSize' : 11,
+                           'legendSize' : 10,
+                'marker' : { 'color' : wx.Colour(0, 0, 0),
+                             'fill' : 'transparent',
+                             'size' : 2,
+                             'type' : 'triangle',
+                             'legend' : _('Segment break'),
+                'grid' : { 'color' : wx.Colour(200,200,200) ,
+                           'enabled' : True,
+                'x-axis' : { 'type' : 'auto', # axis format
+                             'min' : 0, # axis min for custom axis range
+                             'max': 0, # axis max for custom axis range
+                             'log' : False,
+                'y-axis' : { 'type' : 'auto', # axis format
+                             'log' : False,
+                'legend' : { 'enabled' : True
+            'georect' : {
+                'symbol' : { 'color' : (0, 0, 255, 255),
+                             'width' : 2,
+            'nviz' : {
+                'view' : {'persp' : { 'value' : 40,
+                                      'min' : 0,
+                                      'max' : 100,
+                                      'step' : 5,
+                                      'update' : False,
+                          'pos' : { 'x' : 0.85,
+                                    'y' : 0.85,
+                                    'update' : False,
+                          'height' : { 'value': -1,
+                                       'min' : -2245, # TODO: determine min/max height
+                                       'max' : 3695,
+                                       'step' : 100,
+                                       'update' : False,
+                          'twist' : { 'value' : 0,
+                                      'min' : -180,
+                                      'max' : 180,
+                                      'step' : 5,
+                                      'update' : False,
+                          'z-exag' : { 'value': 1.0,
+                                       'min' : 0.0,
+                                       'max' : 10,
+                                       'step' : 1,
+                                       'update' : False
+                'surface' : {
+                    'shininess': { 'map' : False,
+                                   'value' : 60.0,
+                    'draw' : {
+                        'color' : (136, 136, 136, 255),
+                        'mode' : 1, # fine
+                        'style' : 1, # surface
+                        'shading' : 1, # gouraud
+                        'res-fine' : 1,
+                        'res-coarse' : 1,
+                    'position' : {
+                        'x' : 0,
+                        'y' : 0,
+                        'z' : 0,
+        # user settings
+        self.userSettings = copy.deepcopy(self.defaultSettings)
+        try:
+            self.ReadSettingsFile()
+        except gcmd.SettingsError, e:
+            print >> sys.stderr, e.message
+        # internal settings (based on user settings)
+        self.internalSettings = {}
+        for group in self.userSettings.keys():
+            if group == 'vdigit':
+                continue # skip digitization settings (separate window frame)
+            self.internalSettings[group] = {}
+            for key in self.userSettings[group].keys():
+                self.internalSettings[group][key] = {}
+        self.internalSettings['general']["mapsetPath"]['value'] = self.GetMapsetPath()
+        self.internalSettings['general']['mapsetPath']['choices'] = [_('Mapset search path'),
+        _('All available mapsets')]
+        self.internalSettings['atm']['leftDbClick']['choices'] = [_('Edit selected record'),
+        _('Display selected')]
+        self.internalSettings['advanced']['settingsFile']['choices'] = ['gisdbase',
+        'location',
+        'mapset']
+        self.internalSettings['advanced']['iconTheme']['choices'] = ['grass',
+        'silk']
+        self.internalSettings['advanced']['digitInterface']['choices'] = ['vedit',
+        'vdigit']
+        self.internalSettings['cmd']['verbosity']['choices'] = ['grassenv',
+        'verbose',
+        'quiet']
+        self.internalSettings['display']['driver']['choices'] = ['default']
+        self.internalSettings['display']['statusbarMode']['choices'] = globalvar.MAP_DISPLAY_STATUSBAR_MODE
+    def GetMapsetPath(self):
+        """Store mapset search path"""
+        all, access = utils.ListOfMapsets()
+        if self.Get(group='general', key='mapsetPath', subkey='selection') == 0:
+            return access
+        else:
+            return all
+    def ReadSettingsFile(self, settings=None):
+        """Reads settings file (mapset, location, gisdbase)"""
+        if settings is None:
+            settings = self.userSettings
+        # look for settings file
+        # -> mapser
+        #  -> location
+        #   -> gisdbase
+        gisdbase = grassenv.GetGRASSVariable("GISDBASE")
+        location_name = grassenv.GetGRASSVariable("LOCATION_NAME")
+        mapset_name = grassenv.GetGRASSVariable("MAPSET")
+        mapset_file = os.path.join(gisdbase, location_name, mapset_name, self.fileName)
+        location_file = os.path.join(gisdbase, location_name, self.fileName)
+        gisdbase_file = os.path.join(gisdbase, self.fileName)
+        if os.path.isfile(mapset_file):
+            self.filePath = mapset_file
+        elif os.path.isfile(location_file):
+            self.filePath = location_file
+        elif os.path.isfile(gisdbase_file):
+            self.filePath = gisdbase_file
+        if self.filePath:
+            self.__ReadFile(self.filePath, settings)
+    def __ReadFile(self, filename, settings=None):
+        """Read settings from file to dict"""
+        try:
+            file = open(filename, "r")
+            for line in file.readlines():
+                line = line.rstrip('%s' % os.linesep)
+                group, key = line.split(':')[0:2]
+                kv = line.split(':')[2:]
+                subkeyMaster = None
+                if len(kv) % 2 != 0: # multiple (e.g. nviz)
+                    subkeyMaster = kv[0]
+                    del kv[0]
+                idx = 0
+                while idx < len(kv):
+                    if subkeyMaster:
+                        subkey = [subkeyMaster, kv[idx]]
+                    else:
+                        subkey = kv[idx]
+                    value = kv[idx+1]
+                    if len(value) == 0:
+                        self.Append(settings, group, key, subkey, '')
+                    else:
+                        # casting
+                        if value == 'True':
+                            value = True
+                        elif value == 'False':
+                            value = False
+                        elif value == 'None':
+                            value = None
+                        elif value[0] == '(':
+                            tmp = value.replace('(','').replace(')', '').split(',')
+                            try:
+                                value = tuple(map(int, tmp))
+                            except ValueError:
+                                value = tuple(tmp)
+                        else:
+                            try:
+                                value = int(value)
+                                try:
+                                    value = float(value)
+                                    pass
+                        self.Append(settings, group, key, subkey, value)
+                    idx += 2
+        finally:
+            file.close()
+    def SaveToFile(self, settings=None):
+        """Save settings to the file"""
+        loc = self.Get(group='advanced', key='settingsFile', subkey='type')
+        filePath = None
+        if loc == 'gisdbase':
+            filePath = os.path.join(gisdbase, self.fileName)
+        elif loc == 'location':
+            filePath = os.path.join(gisdbase, location_name, self.fileName)
+        elif loc == 'mapset':
+            filePath = os.path.join(gisdbase, location_name, mapset_name, self.fileName)
+        if filePath is None:
+            raise gcmd.SettingsError(_('Uknown settings file location.'))
+        try:
+            file = open(filePath, "w")
+            for group in settings.keys():
+                for key in settings[group].keys():
+                    file.write('%s:%s:' % (group, key))
+                    subkeys = settings[group][key].keys()
+                    for idx in range(len(subkeys)):
+                        value = settings[group][key][subkeys[idx]]
+                        if type(value) == type({}):
+                            if idx > 0:
+                                file.write('%s%s:%s:' % (os.linesep, group, key))
+                            file.write('%s:' % subkeys[idx])
+                            kvalues = settings[group][key][subkeys[idx]].keys()
+                            srange = range(len(kvalues))
+                            for sidx in srange:
+                                file.write('%s:%s' % (kvalues[sidx],
+                                                      settings[group][key][subkeys[idx]][kvalues[sidx]]))
+                                if sidx < len(kvalues) - 1:
+                                    file.write(':')
+                        else:
+                            file.write('%s:%s' % (subkeys[idx], value))
+                            if idx < len(subkeys) - 1:
+                                file.write(':')
+                    file.write('%s' % os.linesep)
+        except IOError, e:
+            raise gcmd.SettingsError(e)
+        except:
+            raise gcmd.SettingsError('Writing settings to file <%s> failed.' % filePath)
+        file.close()
+        return filePath
+    def Get(self, group, key=None, subkey=None, internal=False):
+        """Get value by key/subkey
+        Raise KeyError if key is not found
+        @param group settings group
+        @param key
+        @param subkey if not given return dict of key
+        @param subkey1
+        @param internal use internal settings instead
+        @return value
+        if internal is True:
+            settings = self.internalSettings
+        else:
+        try:
+            if subkey is None:
+                if key is None:
+                    return settings[group]
+                else:
+                    return settings[group][key]
+            else:
+                if type(subkey) == type([]):
+                    return settings[group][key][subkey[0]][subkey[1]]
+                else:
+                    return settings[group][key][subkey]
+        except KeyError:
+            raise gcmd.SettingsError("%s %s:%s:%s." % (_("Unable to get value"),
+                                                       group, key, subkey))
+    def Set(self, group, key, subkey, value, internal=False):
+        """Set value of key/subkey
+        Raise KeyError if group/key is not found
+        @param key key
+        @param subkey subkey (value or list)
+        @param value value
+        else:
+        try:
+                settings[group][key][subkey[0]][subkey[1]] = value
+            else:
+                settings[group][key][subkey] = value
+        except KeyError:
+            raise gcmd.SettingsError("%s '%s:%s:%s'" % (_("Unable to set "), group, key, subkey))
+    def Append(self, dict, group, key, subkey, value):
+        Create group/key/subkey if not exists
+        @param dict settings dictionary to use
+        @param key key
+        if not dict.has_key(group):
+            dict[group] = {}
+        if not dict[group].has_key(key):
+            dict[group][key] = {}
+            # TODO: len(subkey) > 2
+            if not dict[group][key].has_key(subkey[0]):
+                dict[group][key][subkey[0]] = {}
+            dict[group][key][subkey[0]][subkey[1]] = value
+        else:
+            dict[group][key][subkey] = value
+    def GetDefaultSettings(self):
+        """Get default user settings"""
+        return self.defaultSettings
+globalSettings = Settings()
+class PreferencesDialog(wx.Dialog):
+    """User preferences dialog"""
+    def __init__(self, parent, title=_("User GUI settings"),
+                 settings=globalSettings,
+                 style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+        self.parent = parent # GMFrame
+        self.title = title
+        wx.Dialog.__init__(self, parent=parent, id=wx.ID_ANY, title=title,
+                           style=style, size=(-1, -1))
+        self.settings = settings
+        # notebook
+        notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+        # dict for window ids
+        self.winId = {}
+        # create notebook pages
+        self.__CreateGeneralPage(notebook)
+        self.__CreateDisplayPage(notebook)
+        self.__CreateCmdPage(notebook)
+        self.__CreateAttributeManagerPage(notebook)
+        self.__CreateWorkspacePage(notebook)
+        self.__CreateAdvancedPage(notebook)
+        # buttons
+        btnDefault = wx.Button(self, wx.ID_ANY, _("Set to default"))
+        btnSave = wx.Button(self, wx.ID_SAVE)
+        btnApply = wx.Button(self, wx.ID_APPLY)
+        btnCancel = wx.Button(self, wx.ID_CANCEL)
+        btnSave.SetDefault()
+        # bindigs
+        btnDefault.Bind(wx.EVT_BUTTON, self.OnDefault)
+        btnDefault.SetToolTipString(_("Revert settings to default and apply changes"))
+        btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+        btnApply.SetToolTipString(_("Apply changes for the current session"))
+        btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+        btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
+        btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+        btnCancel.SetToolTipString(_("Close dialog and ignore changes"))
+        # sizers
+        btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+        btnSizer.Add(item=btnDefault, proportion=1,
+                     flag=wx.ALL, border=5)
+        btnStdSizer = wx.StdDialogButtonSizer()
+        btnStdSizer.AddButton(btnCancel)
+        btnStdSizer.AddButton(btnSave)
+        btnStdSizer.AddButton(btnApply)
+        btnStdSizer.Realize()
+        mainSizer = wx.BoxSizer(wx.VERTICAL)
+        mainSizer.Add(item=notebook, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+        mainSizer.Add(item=btnSizer, proportion=0,
+                      flag=wx.EXPAND, border=0)
+        mainSizer.Add(item=btnStdSizer, proportion=0,
+                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_RIGHT, border=5)
+        self.SetSizer(mainSizer)
+        mainSizer.Fit(self)
+        self.SetMinSize(self.GetBestSize())
+        self.SetSize((500, 375))
+    def __CreateGeneralPage(self, notebook):
+        """Create notebook page for general settings"""
+        panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
+        notebook.AddPage(page=panel, text=_("General"))
+        border = wx.BoxSizer(wx.VERTICAL)
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("General settings"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
+        gridSizer.AddGrowableCol(0)
+        # mapsets path
+        row = 0
+                                         label=_("Mapsets path:")),
+                       flag=wx.ALIGN_LEFT |
+                       wx.ALIGN_CENTER_VERTICAL,
+                       pos=(row, 0))
+        mapsetPath = wx.Choice(parent=panel, id=wx.ID_ANY, size=(200, -1),
+                                    choices=self.settings.Get(group='general', key='mapsetPath',
+                                                              subkey='choices', internal=True),
+                                    name="GetSelection")
+        mapsetPath.SetSelection(self.settings.Get(group='general', key='mapsetPath', subkey='selection'))
+        self.winId['general:mapsetPath:selection'] = mapsetPath.GetId()
+        gridSizer.Add(item=mapsetPath,
+                      flag=wx.ALIGN_RIGHT |
+                      pos=(row, 1))
+        # default window layout
+        row += 1
+        defaultPos = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                 label=_("Save current window layout as default"),
+                                 name='IsChecked')
+        defaultPos.SetValue(self.settings.Get(group='general', key='defWindowPos', subkey='enabled'))
+        defaultPos.SetToolTip(wx.ToolTip (_("Save current position and size of Layer Manager window and opened "
+                                            "Map Display window(s) and use as default for next sessions.")))
+        self.winId['general:defWindowPos:enabled'] = defaultPos.GetId()
+        gridSizer.Add(item=defaultPos,
+                      pos=(row, 0), span=(1, 2))
+        sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+        border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+        # Layer Manager settings
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Layer Manager settings"))
+        # show opacily level
+        row = 0
+        changeOpacityLevel = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                       label=_("Opacity level editable"),
+                                       name='IsChecked')
+        changeOpacityLevel.SetValue(self.settings.Get(group='manager', key='changeOpacityLevel', subkey='enabled'))
+        self.winId['manager:changeOpacityLevel:enabled'] = changeOpacityLevel.GetId()
+        gridSizer.Add(item=changeOpacityLevel,
+        # ask when removing map layer from layer tree
+        row += 1
+        askOnRemoveLayer = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                       label=_("Ask when removing map layer from layer tree"),
+                                       name='IsChecked')
+        askOnRemoveLayer.SetValue(self.settings.Get(group='manager', key='askOnRemoveLayer', subkey='enabled'))
+        self.winId['manager:askOnRemoveLayer:enabled'] = askOnRemoveLayer.GetId()
+        gridSizer.Add(item=askOnRemoveLayer,
+        border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
+        panel.SetSizer(border)
+        return panel
+    def __CreateDisplayPage(self, notebook):
+        """Create notebook page for display settings"""
+        notebook.AddPage(page=panel, text=_("Display"))
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Font settings"))
+        # font settings
+        row = 0
+                                         label=_("Default font for GRASS displays:")),
+                      pos=(row, 0))
+        fontButton = wx.Button(parent=panel, id=wx.ID_ANY,
+                               label=_("Set font"), size=(100, -1))
+        gridSizer.Add(item=fontButton,
+                      pos=(row, 1))
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Default display settings"))
+        # display driver
+        row = 0
+                                         label=_("Display driver:")),
+                      pos=(row, 0))
+        listOfDrivers = self.settings.Get(group='display', key='driver', subkey='choices', internal=True)
+        # check if cairo is available
+        if 'cairo' not in listOfDrivers:
+            for line in gcmd.Command(['d.mon', '-l']).ReadStdOutput():
+                if 'cairo' in line:
+                    listOfDrivers.append('cairo')
+                    break
+        driver = wx.Choice(parent=panel, id=wx.ID_ANY, size=(150, -1),
+                           choices=listOfDrivers,
+                           name="GetStringSelection")
+        driver.SetStringSelection(self.settings.Get(group='display', key='driver', subkey='type'))
+        self.winId['display:driver:type'] = driver.GetId()
+        gridSizer.Add(item=driver,
+                      flag=wx.ALIGN_RIGHT,
+                      pos=(row, 1))
+        # Statusbar mode
+        row += 1
+                                         label=_("Statusbar mode:")),
+                      pos=(row, 0))
+        listOfModes = self.settings.Get(group='display', key='statusbarMode', subkey='choices', internal=True)
+        statusbarMode = wx.Choice(parent=panel, id=wx.ID_ANY, size=(150, -1),
+                                  choices=listOfModes,
+        statusbarMode.SetSelection(self.settings.Get(group='display', key='statusbarMode', subkey='selection'))
+        self.winId['display:statusbarMode:selection'] = statusbarMode.GetId()
+        gridSizer.Add(item=statusbarMode,
+                      pos=(row, 1))
+        # Use computation resolution
+        row += 1
+        compResolution = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                    label=_("Constrain display resolution to computational settings"),
+                                    name="IsChecked")
+        compResolution.SetValue(self.settings.Get(group='display', key='compResolution', subkey='enabled'))
+        self.winId['display:compResolution:enabled'] = compResolution.GetId()
+        gridSizer.Add(item=compResolution,
+        # auto-rendering
+        row += 1
+        autoRendering = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                    label=_("Enable auto-rendering"),
+                                    name="IsChecked")
+        autoRendering.SetValue(self.settings.Get(group='display', key='autoRendering', subkey='enabled'))
+        self.winId['display:autoRendering:enabled'] = autoRendering.GetId()
+        gridSizer.Add(item=autoRendering,
+        # bindings
+        fontButton.Bind(wx.EVT_BUTTON, self.OnSetFont)
+        return panel
+    def __CreateCmdPage(self, notebook):
+        """Create notebook page for commad dialog settings"""
+        notebook.AddPage(page=panel, text=_("Command"))
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Command dialog settings"))
+        # command dialog settings
+        row = 0
+        # overwrite
+        overwrite = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                label=_("Allow output files to overwrite existing files"),
+                                name="IsChecked")
+        overwrite.SetValue(self.settings.Get(group='cmd', key='overwrite', subkey='enabled'))
+        self.winId['cmd:overwrite:enabled'] = overwrite.GetId()
+        gridSizer.Add(item=overwrite,
+        row += 1
+        # close
+        close = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                            label=_("Close dialog on finish"),
+                            name="IsChecked")
+        close.SetValue(self.settings.Get(group='cmd', key='closeDlg', subkey='enabled'))
+        self.winId['cmd:closeDlg:enabled'] = close.GetId()
+        gridSizer.Add(item=close,
+        row += 1
+        # verbosity
+                                         label=_("Verbosity level:")),
+                      pos=(row, 0))
+        verbosity = wx.Choice(parent=panel, id=wx.ID_ANY, size=(200, -1),
+                              choices=self.settings.Get(group='cmd', key='verbosity', subkey='choices', internal=True),
+        verbosity.SetStringSelection(self.settings.Get(group='cmd', key='verbosity', subkey='selection'))
+        self.winId['cmd:verbosity:selection'] = verbosity.GetId()
+        gridSizer.Add(item=verbosity,
+                      pos=(row, 1))
+        # raster settings
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Raster settings"))
+        # raster overlay
+        row = 0
+        rasterOverlay = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                    label=_("Overlay raster maps"),
+                                    name='IsChecked')
+        rasterOverlay.SetValue(self.settings.Get(group='cmd', key='rasterOverlay', subkey='enabled'))
+        self.winId['cmd:rasterOverlay:enabled'] = rasterOverlay.GetId()
+        gridSizer.Add(item=rasterOverlay,
+        return panel
+    def __CreateAttributeManagerPage(self, notebook):
+        """Create notebook page for 'Attribute Table Manager' settings"""
+        notebook.AddPage(page=panel, text=_("Attributes"))
+        pageSizer = wx.BoxSizer(wx.VERTICAL)
+        # highlighting
+        highlightBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
+                                    label=" %s " % _("Highlighting"))
+        highlightSizer = wx.StaticBoxSizer(highlightBox, wx.VERTICAL)
+        flexSizer = wx.FlexGridSizer (cols=2, hgap=5, vgap=5)
+        flexSizer.AddGrowableCol(0)
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label="Color")
+        hlColor = csel.ColourSelect(parent=panel, id=wx.ID_ANY,
+                                    colour=self.settings.Get(group='atm', key='highlight', subkey='color'),
+                                    size=(25, 25))
+        self.winId['atm:highlight:color'] = hlColor.GetId()
+        flexSizer.Add(label, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(hlColor, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Line width (in pixels)"))
+        hlWidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(50, -1),
+                              initial=self.settings.Get(group='atm', key='highlight',subkey='width'),
+                              min=1, max=1e6)
+        self.winId['atm:highlight:width'] = hlWidth.GetId()
+        flexSizer.Add(hlWidth, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        highlightSizer.Add(item=flexSizer,
+                           proportion=0,
+                           border=5)
+        pageSizer.Add(item=highlightSizer,
+                      proportion=0,
+                      border=5)
+        # data browser related settings
+        dataBrowserBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
+                                    label=" %s " % _("Data browser"))
+        dataBrowserSizer = wx.StaticBoxSizer(dataBrowserBox, wx.VERTICAL)
+        label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Left mouse double click"))
+        leftDbClick = wx.Choice(parent=panel, id=wx.ID_ANY,
+                                choices=self.settings.Get(group='atm', key='leftDbClick', subkey='choices', internal=True),
+        leftDbClick.SetSelection(self.settings.Get(group='atm', key='leftDbClick', subkey='selection'))
+        self.winId['atm:leftDbClick:selection'] = leftDbClick.GetId()
+        flexSizer.Add(leftDbClick, proportion=0, flag=wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+        dataBrowserSizer.Add(item=flexSizer,
+                           proportion=0,
+                           border=5)
+        pageSizer.Add(item=dataBrowserSizer,
+                      proportion=0,
+                      flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
+                      border=3)
+        panel.SetSizer(pageSizer)
+        return panel
+    def __CreateWorkspacePage(self, notebook):
+        """Create notebook page for workspace settings"""
+        notebook.AddPage(page=panel, text=_("Workspace"))
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Loading workspace"))
+        row = 0
+        # positioning
+        posDisplay = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                 label=_("Suppress positioning Map Display Window(s)"),
+                                 name='IsChecked')
+        posDisplay.SetValue(self.settings.Get(group='workspace', key='posDisplay', subkey='enabled'))
+        self.winId['workspace:posDisplay:enabled'] = posDisplay.GetId()
+        gridSizer.Add(item=posDisplay,
+        row +=1
+        posManager = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+                                 label=_("Suppress positioning Layer Manager window"),
+                                 name='IsChecked')
+        posManager.SetValue(self.settings.Get(group='workspace', key='posManager', subkey='enabled'))
+        self.winId['workspace:posManager:enabled'] = posManager.GetId()
+        gridSizer.Add(item=posManager,
+        return panel
+    def __CreateAdvancedPage(self, notebook):
+        """Create notebook page for advanced settings"""
+        notebook.AddPage(page=panel, text=_("Advanced"))
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Advanced settings"))
+        row = 0
+        # place where to store settings
+                                         label=_("Place where to store settings:")),
+                       pos=(row, 0))
+        settingsFile = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+                                 choices=self.settings.Get(group='advanced', key='settingsFile',
+                                 name='GetStringSelection')
+        settingsFile.SetStringSelection(self.settings.Get(group='advanced', key='settingsFile', subkey='type'))
+        self.winId['advanced:settingsFile:type'] = settingsFile.GetId()
+        gridSizer.Add(item=settingsFile,
+                      pos=(row, 1))
+        row += 1
+        # icon theme
+                                         label=_("Icon theme:")),
+                       pos=(row, 0))
+        iconTheme = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+                              choices=self.settings.Get(group='advanced', key='iconTheme',
+        iconTheme.SetStringSelection(self.settings.Get(group='advanced', key='iconTheme', subkey='type'))
+        self.winId['advanced:iconTheme:type'] = iconTheme.GetId()
+        gridSizer.Add(item=iconTheme,
+                      pos=(row, 1))
+        row += 1
+        iconNote = wordwrap(_("Note: Requires GUI restart."),
+                            self.GetSize()[0]-50, wx.ClientDC(self))
+                                         label=iconNote),
+        row += 1
+        # digitization interface
+                                         label=_("Digitization interface:")),
+                       pos=(row, 0))
+        digitInterface = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
+                                   choices=self.settings.Get(group='advanced', key='digitInterface',
+        digitInterface.SetStringSelection(self.settings.Get(group='advanced', key='digitInterface',
+                                                            subkey='type'))
+        self.winId['advanced:digitInterface:type'] = digitInterface.GetId()
+        gridSizer.Add(item=digitInterface,
+                      pos=(row, 1))
+        row += 1
+        digitNote = wordwrap(_("Note: User can choose from two interfaces for digitization. "
+                               "The simple one uses v.edit command on the background. "
+                               "Map topology is rebuild on each operation which can "
+                               "significantly slow-down response. The vdigit is a native "
+                               "interface which uses v.edit functionality, but doesn't "
+                               "call the module itself."),
+                                         label=digitNote),
+        border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=3)
+        return panel
+    def OnSetFont(self, event):
+        """'Set font' button pressed"""
+        dlg = SetDefaultFont(parent=self, id=wx.ID_ANY,
+                             title=_('Select default display font'),
+                             pos=wx.DefaultPosition, size=wx.DefaultSize,
+                             style=wx.DEFAULT_DIALOG_STYLE,
+                             encoding=self.parent.encoding)
+        if dlg.ShowModal() == wx.ID_CANCEL:
+            dlg.Destroy()
+            return
+        # set default font type, font, and encoding to whatever selected in dialog
+        if dlg.font != None:
+            self.font = dlg.font
+        if dlg.encoding != None:
+            self.encoding = dlg.encoding
+        dlg.Destroy()
+        # set default font and encoding environmental variables
+        os.environ["GRASS_FONT"] = self.font
+        if self.encoding != None and self.encoding != "ISO-8859-1":
+            os.environ["GRASS_ENCODING"] = self.encoding
+        event.Skip()
+    def OnSave(self, event):
+        """Button 'Save' pressed"""
+        self.__UpdateSettings()
+        file = self.settings.SaveToFile()
+        self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % file)
+        self.Close()
+    def OnApply(self, event):
+        """Button 'Apply' pressed"""
+        self.Close()
+    def OnCancel(self, event):
+        """Button 'Cancel' pressed"""
+        self.Close()
+    def OnDefault(self, event):
+        """Button 'Set to default' pressed"""
+        self.settings.userSettings = copy.deepcopy(self.settings.defaultSettings)
+        # update widgets
+        for gks in self.winId.keys():
+            group, key, subkey = gks.split(':')
+            value = self.settings.Get(group, key, subkey)
+            win = self.FindWindowById(self.winId[gks])
+            if win.GetName() in ('GetValue', 'IsChecked'):
+                value = win.SetValue(value)
+            elif win.GetName() == 'GetSelection':
+                value = win.SetSelection(value)
+            elif win.GetName() == 'GetStringSelection':
+                value = win.SetStringSelection(value)
+            else:
+    def __UpdateSettings(self):
+        """Update user settings"""
+        for item in self.winId.keys():
+            group, key, subkey = item.split(':')
+            id = self.winId[item]
+            win = self.FindWindowById(id)
+            if win.GetName() == 'GetValue':
+                value = win.GetValue()
+                value = win.GetSelection()
+            elif win.GetName() == 'IsChecked':
+                value = win.IsChecked()
+                value = win.GetStringSelection()
+            else:
+            self.settings.Set(group, key, subkey, value)
+        # update default window dimension
+        if self.settings.Get(group='general', key='defWindowPos', subkey='enabled') is True:
+            dim = ''
+            # layer manager
+            pos = self.parent.GetPosition()
+            size = self.parent.GetSize()
+            dim = '%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
+            # opened displays
+            for page in range(0, self.parent.gm_cb.GetPageCount()):
+                pos = self.parent.gm_cb.GetPage(page).maptree.mapdisplay.GetPosition()
+                size = self.parent.gm_cb.GetPage(page).maptree.mapdisplay.GetSize()
+                dim += ',%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
+            self.settings.Set(group='general', key='defWindowPos', subkey='dim', value=dim)
+        else:
+            self.settings.Set(group='general', key='defWindowPos', subkey='dim', value='')
+class SetDefaultFont(wx.Dialog):
+    Opens a file selection dialog to select default font
+    to use in all GRASS displays
+    def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
+            style=wx.DEFAULT_DIALOG_STYLE, encoding='ISO-8859-1'):
+        wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+        if "GRASS_FONT" in os.environ:
+            self.font = os.environ["GRASS_FONT"]
+        else:
+            self.font = None
+        self.fontlist = self.GetFonts()
+        self.encoding = encoding
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        box = wx.BoxSizer(wx.HORIZONTAL)
+        label = wx.StaticText(self, -1, "Select Font:", (15, 50))
+        box.Add(label, 0, wx.EXPAND|wx.GROW|wx.ALIGN_TOP|wx.RIGHT, 5)
+        self.fontlb = wx.ListBox(self, wx.ID_ANY, pos=wx.DefaultPosition,
+                                 size=(280,150), choices=self.fontlist,
+                                 style=wx.LB_SINGLE|wx.LB_SORT)
+        self.Bind(wx.EVT_LISTBOX, self.EvtListBox, self.fontlb)
+        self.Bind(wx.EVT_LISTBOX_DCLICK, self.EvtListBoxDClick, self.fontlb)
+        if self.font:
+            self.fontlb.SetStringSelection(self.font, True)
+        box.Add(self.fontlb, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT)
+        sizer.Add(box, 0, wx.EXPAND|wx.GROW|wx.ALIGN_RIGHT|wx.ALL, 8)
+        label = wx.StaticText(self, -1, "Character encoding:")
+        box.Add(label, 0, wx.ALIGN_RIGHT|wx.RIGHT, 5)
+        self.textentry = wx.TextCtrl(self, -1, "", size=(200,-1))
+        self.textentry.SetValue(self.encoding)
+        box.Add(self.textentry, 0, wx.ALIGN_LEFT)
+        self.textentry.Bind(wx.EVT_TEXT, self.OnEncoding)
+        sizer.Add(box, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 8)
+        line = wx.StaticLine(self, -1, size=(20,-1), style=wx.LI_HORIZONTAL)
+        sizer.Add(line, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.ALL, 10)
+        btnsizer = wx.StdDialogButtonSizer()
+        btn = wx.Button(self, wx.ID_OK)
+        btn.SetDefault()
+        btnsizer.AddButton(btn)
+        btn = wx.Button(self, wx.ID_CANCEL)
+        btnsizer.Realize()
+        sizer.Add(btnsizer, 0, wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+        self.SetSizer(sizer)
+        sizer.Fit(self)
+    def EvtRadioBox(self, event):
+        if event.GetInt() == 0:
+            self.fonttype = 'grassfont'
+        elif event.GetInt() == 1:
+            self.fonttype = 'truetype'
+        self.fontlist = self.GetFonts(self.fonttype)
+        self.fontlb.SetItems(self.fontlist)
+    def OnEncoding(self, event):
+        self.encoding = event.GetString()
+    def EvtListBox(self, event):
+        self.font = event.GetString()
+        event.Skip()
+    def EvtListBoxDClick(self, event):
+        event.Skip()
+    def GetFonts(self):
+        parses fonts directory or fretypecap file to get a list of fonts for the listbox
+        fontlist = []
+        cmd = ["d.font", "-l"]
+        p = gcmd.Command(cmd, stderr=None)
+        dfonts = p.ReadStdOutput()
+        dfonts.sort(lambda x,y: cmp(x.lower(), y.lower()))
+        for item in range(len(dfonts)):
+           # ignore duplicate fonts and those starting with #
+           if not dfonts[item].startswith('#') and \
+                  dfonts[item] != dfonts[item-1]:
+              fontlist.append(dfonts[item])
+        return fontlist
+class MapsetAccess(wx.Dialog):
+    Controls setting options and displaying/hiding map overlay decorations
+    def __init__(self, parent, id, title=_('Set/unset access to mapsets in current location'),
+                 pos=wx.DefaultPosition, size=(350, 400),
+                 style=wx.DEFAULT_DIALOG_STYLE|wx.RESIZE_BORDER):
+        self.all_mapsets, self.accessible_mapsets = utils.ListOfMapsets()
+        self.curr_mapset = grassenv.GetGRASSVariable('MAPSET')
+        # make a checklistbox from available mapsets and check those that are active
+        label = wx.StaticText(parent=self, id=wx.ID_ANY,
+                              label=_("Check mapset to make it accessible, uncheck it to hide it.%s"
+                                      "Note: PERMANENT and current mapset are always accessible.") % os.linesep)
+        sizer.Add(item=label, proportion=0,
+        self.mapsetlb = CheckListMapset(parent=self)
+        self.mapsetlb.LoadData(self.all_mapsets)
+        sizer.Add(item=self.mapsetlb, proportion=1,
+                  flag=wx.ALL | wx.EXPAND, border=5)
+        # check all accessible mapsets
+        if globalSettings.Get(group='general', key='mapsetPath', subkey='selection') == 1:
+            for mset in self.all_mapsets:
+                self.mapsetlb.CheckItem(self.all_mapsets.index(mset), True)
+        else:
+            for mset in self.accessible_mapsets:
+                pass
+        # dialog buttons
+        line = wx.StaticLine(parent=self, id=wx.ID_ANY,
+                             style=wx.LI_HORIZONTAL)
+        sizer.Add(item=line, proportion=0,
+                  flag=wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border=5)
+        okbtn = wx.Button(self, wx.ID_OK)
+        okbtn.SetDefault()
+        btnsizer.AddButton(okbtn)
+        cancelbtn = wx.Button(self, wx.ID_CANCEL)
+        btnsizer.AddButton(cancelbtn)
+        sizer.Add(item=btnsizer, proportion=0,
+                  flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border=5)
+        # do layout
+        self.Layout()
+        sizer.Fit(self)
+        self.SetMinSize(size)
+    def GetMapsets(self):
+        """Get list of checked mapsets"""
+        ms = []
+        i = 0
+            if self.mapsetlb.IsChecked(i):
+                ms.append(mset)
+            i += 1
+        return ms
+class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
+    """List of mapset/owner/group"""
+    def __init__(self, parent, pos=wx.DefaultPosition,
+                 log=None):
+        wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
+                             style=wx.LC_REPORT)
+        listmix.CheckListCtrlMixin.__init__(self)
+        self.log = log
+        # setup mixins
+        listmix.ListCtrlAutoWidthMixin.__init__(self)
+    def LoadData(self, mapsets):
+        """Load data into list"""
+        self.InsertColumn(0, _('Mapset'))
+        self.InsertColumn(1, _('Owner'))
+        self.InsertColumn(2, _('Group'))
+        locationPath = os.path.join(grassenv.GetGRASSVariable('GISDBASE'),
+                                    grassenv.GetGRASSVariable('LOCATION_NAME'))
+        for mapset in mapsets:
+            index = self.InsertStringItem(sys.maxint, mapset)
+            mapsetPath = os.path.join(locationPath,
+                                      mapset)
+            stat_info = os.stat(mapsetPath)
+	    if os.name in ('posix', 'mac'):
+                self.SetStringItem(index, 1, "%s" % pwd.getpwuid(stat_info.st_uid)[0])
+                # FIXME: get group name
+                self.SetStringItem(index, 2, "%-8s" % stat_info.st_gid)
+	    else:
+                # FIXME: no pwd under MS Windows (owner: 0, group: 0)
+                self.SetStringItem(index, 1, "%-8s" % stat_info.st_uid)
+        self.SetColumnWidth(col=0, width=wx.LIST_AUTOSIZE)
+        self.SetColumnWidth(col=1, width=wx.LIST_AUTOSIZE)
+    def OnCheckItem(self, index, flag):
+        """Mapset checked/unchecked"""
+        mapset = self.parent.all_mapsets[index]
+        if mapset == 'PERMANENT' or mapset == self.parent.curr_mapset:
+            self.CheckItem(index, True)
Modified: grass-addons/visualization/nviz2/wxpython/wxgui_utils.py
--- grass-addons/visualization/nviz2/wxpython/wxgui_utils.py	2008-06-27 12:35:50 UTC (rev 31858)
+++ grass-addons/visualization/nviz2/wxpython/wxgui_utils.py	2008-06-27 14:45:35 UTC (rev 31859)
@@ -619,6 +619,7 @@
                                     'type' : ltype,
                                     'ctrl' : ctrlId,
                                     'maplayer' : None,
+                                    'nviz' : None,
                                     'prowin' : None},
                                    None))
@@ -874,6 +875,10 @@
         except:
             pass
+        # update nviz tools
+        if self.mapdisplay.toolbars['nviz']:
+            self.mapdisplay.nvizToolWin.UpdatePage('surface')
     def OnCollapseNode(self, event):
         Collapse node
