[GRASS-SVN] r31861 - grass/trunk
svn_grass at osgeo.org
Fri Jun 27 12:48:12 EDT 2008
Author: glynn
Date: 2008-06-27 12:48:11 -0400 (Fri, 27 Jun 2008)
New Revision: 31861
grass/trunk/aclocal.m4
grass/trunk/configure
grass/trunk/configure.in
Add LOC_CHECK_LINK to allow checking Windows (stdcall) libraries
Change GDAL ODBC checks to handle stdcall
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2008-06-27 16:35:43 UTC (rev 31860)
+++ grass/trunk/aclocal.m4 2008-06-27 16:48:11 UTC (rev 31861)
@@ -77,6 +77,34 @@
CPPFLAGS=$ac_save_cppflags
+dnl $1 = library
+dnl $2 = header
+dnl $3 = function call
+dnl $4 = descriptive name
+dnl $5 = LDFLAGS initialiser
+dnl $6 = result variable
+dnl $7 = mandatory dependencies (not added to $5)
+dnl $8 = mandatory dependencies (added to $5)
+dnl $9 = ACTION-IF-NOT-FOUND
+define(LOC_CHECK_LINK,[
+ac_save_ldflags="$LDFLAGS"
+ac_save_libs="$LIBS"
+AC_MSG_CHECKING(for $4 library)
+LDFLAGS="$5 $LDFLAGS"
+LIBS="-l$1 $7 $8"
+AC_TRY_LINK([$2],[$3],[
+AC_MSG_RESULT(found)
+$6="$$6 -l$1 $8"
+ifelse($9,[],[
+ AC_MSG_ERROR([*** Unable to locate $4 library.])
+],$9)
+LIBS=${ac_save_libs}
+LDFLAGS=${ac_save_ldflags}
dnl autoconf undefines "shift", so use "builtin([shift], ...)"
define(LOC_SHIFT1,[builtin([shift],$*)])
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-06-27 16:35:43 UTC (rev 31860)
+++ grass/trunk/configure 2008-06-27 16:48:11 UTC (rev 31861)
@@ -7665,102 +7665,45 @@
GDAL=
LIBS="$LIBS $GDAL_LIBS"
- echo $ac_n "checking for GDALOpen""... $ac_c" 1>&6
-echo "configure:7670: checking for GDALOpen" >&5
-cat > conftest.$ac_ext <<EOF
-#line 7673 "configure"
+ cat > conftest.$ac_ext <<EOF
+#line 7670 "configure"
#include "confdefs.h"
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char GDALOpen(); below. */
-#include <assert.h>
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char GDALOpen();
+#include <gdal.h>
int main() {
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined (__stub_GDALOpen) || defined (__stub___GDALOpen)
-choke me
-#else
-GDALOpen();
-#endif
+GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_func_GDALOpen=yes"
+if { (eval echo configure:7677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
cat conftest.$ac_ext >&5
rm -rf conftest*
- eval "ac_cv_func_GDALOpen=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_func_'GDALOpen`\" = yes"; then
- echo "$ac_t""yes" 1>&6
-else
- echo "$ac_t""no" 1>&6
LIBS="$LIBS $GDAL_DEP_LIBS"
-echo "configure:7715: checking for GDALOpen" >&5
-#line 7718 "configure"
+#line 7686 "configure"
-char GDALOpen();
+#include <gdal.h>
int main() {
-choke me
-#else
-GDALOpen();
-#endif
; return 0; }
EOF
-if { (eval echo configure:7741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
+ GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
rm -rf conftest*
+ { echo "configure: error: *** Unable to locate GDAL library." 1>&2; exit 1; }
fi
rm -f conftest*
- GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
-else
- { echo "configure: error: *** couldn't find GDAL" 1>&2; exit 1; }
fi
-fi
+rm -f conftest*
@@ -7773,7 +7716,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7777: checking whether to use TIFF" >&5
+echo "configure:7720: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7793,7 +7736,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7797: checking for location of TIFF includes" >&5
+echo "configure:7740: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7819,15 +7762,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7823: checking for $ac_hdr" >&5
+echo "configure:7766: checking for $ac_hdr" >&5
-#line 7826 "configure"
+#line 7769 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7831: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7774: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7861,7 +7804,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7865: checking for location of TIFF library" >&5
+echo "configure:7808: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7892,13 +7835,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7896: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7839: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltiff $LIBS"
-#line 7902 "configure"
+#line 7845 "configure"
@@ -7909,7 +7852,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7928,13 +7871,13 @@
-echo "configure:7932: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7875: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7938 "configure"
+#line 7881 "configure"
@@ -7945,7 +7888,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7964,13 +7907,13 @@
-echo "configure:7968: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7911: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7974 "configure"
+#line 7917 "configure"
@@ -7981,7 +7924,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8000,13 +7943,13 @@
-echo "configure:8004: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7947: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8010 "configure"
+#line 7953 "configure"
@@ -8017,7 +7960,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8036,13 +7979,13 @@
-echo "configure:8040: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7983: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8046 "configure"
+#line 7989 "configure"
@@ -8053,7 +7996,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8072,13 +8015,13 @@
-echo "configure:8076: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8019: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8082 "configure"
+#line 8025 "configure"
@@ -8089,7 +8032,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8108,13 +8051,13 @@
-echo "configure:8112: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8055: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8118 "configure"
+#line 8061 "configure"
@@ -8125,7 +8068,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8144,13 +8087,13 @@
-echo "configure:8148: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8091: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8154 "configure"
+#line 8097 "configure"
@@ -8161,7 +8104,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8259,7 +8202,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8263: checking whether to use PNG" >&5
+echo "configure:8206: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8278,7 +8221,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8282: checking for location of PNG includes" >&5
+echo "configure:8225: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8304,15 +8247,15 @@
do
-echo "configure:8308: checking for $ac_hdr" >&5
+echo "configure:8251: checking for $ac_hdr" >&5
-#line 8311 "configure"
+#line 8254 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8259: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8346,7 +8289,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8350: checking for location of PNG library" >&5
+echo "configure:8293: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8371,13 +8314,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8375: checking for png_read_image in -lpng" >&5
+echo "configure:8318: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8381 "configure"
+#line 8324 "configure"
@@ -8388,7 +8331,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8430,7 +8373,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8434: checking whether to use Tcl/Tk" >&5
+echo "configure:8377: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8450,7 +8393,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8454: checking for location of Tcl/Tk includes" >&5
+echo "configure:8397: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8476,15 +8419,15 @@
do
-echo "configure:8480: checking for $ac_hdr" >&5
+echo "configure:8423: checking for $ac_hdr" >&5
-#line 8483 "configure"
+#line 8426 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8521,15 +8464,15 @@
do
-echo "configure:8525: checking for $ac_hdr" >&5
+echo "configure:8468: checking for $ac_hdr" >&5
-#line 8528 "configure"
+#line 8471 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8563,7 +8506,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8567: checking Tcl version" >&5
+echo "configure:8510: checking Tcl version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8571,7 +8514,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8575 "configure"
+#line 8518 "configure"
#include <stdio.h>
@@ -8583,7 +8526,7 @@
EOF
-if { (eval echo configure:8587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8601,7 +8544,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8605: checking Tk version" >&5
+echo "configure:8548: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8609,7 +8552,7 @@
else
-#line 8613 "configure"
+#line 8556 "configure"
#include <stdio.h>
@@ -8621,7 +8564,7 @@
EOF
-if { (eval echo configure:8625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8650,7 +8593,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8654: checking for location of Tcl/Tk library" >&5
+echo "configure:8597: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8680,13 +8623,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8684: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8627: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8690 "configure"
+#line 8633 "configure"
@@ -8697,7 +8640,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8716,13 +8659,13 @@
-echo "configure:8720: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8663: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8726 "configure"
+#line 8669 "configure"
@@ -8733,7 +8676,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8760,13 +8703,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8764: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8707: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8770 "configure"
+#line 8713 "configure"
@@ -8777,7 +8720,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8796,13 +8739,13 @@
-echo "configure:8800: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8743: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8806 "configure"
+#line 8749 "configure"
@@ -8813,7 +8756,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8840,13 +8783,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8844: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8787: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8850 "configure"
+#line 8793 "configure"
@@ -8857,7 +8800,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8876,13 +8819,13 @@
-echo "configure:8880: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8823: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8886 "configure"
+#line 8829 "configure"
@@ -8893,7 +8836,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8971,13 +8914,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8975: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8918: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8981 "configure"
+#line 8924 "configure"
@@ -8988,7 +8931,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9007,13 +8950,13 @@
-echo "configure:9011: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8954: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9017 "configure"
+#line 8960 "configure"
@@ -9024,7 +8967,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9051,13 +8994,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9055: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:8998: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9061 "configure"
+#line 9004 "configure"
@@ -9068,7 +9011,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9087,13 +9030,13 @@
-echo "configure:9091: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9034: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9097 "configure"
+#line 9040 "configure"
@@ -9104,7 +9047,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9131,13 +9074,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9135: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9078: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9141 "configure"
+#line 9084 "configure"
@@ -9148,7 +9091,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9167,13 +9110,13 @@
-echo "configure:9171: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9114: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9177 "configure"
+#line 9120 "configure"
@@ -9184,7 +9127,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9276,7 +9219,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9280: checking whether to use PostgreSQL" >&5
+echo "configure:9223: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9303,7 +9246,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9307: checking for location of PostgreSQL includes" >&5
+echo "configure:9250: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9329,15 +9272,15 @@
do
-echo "configure:9333: checking for $ac_hdr" >&5
+echo "configure:9276: checking for $ac_hdr" >&5
-#line 9336 "configure"
+#line 9279 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9375,7 +9318,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9379: checking for location of PostgreSQL library" >&5
+echo "configure:9322: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9404,13 +9347,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9408: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9351: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9414 "configure"
+#line 9357 "configure"
@@ -9421,7 +9364,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9440,13 +9383,13 @@
-echo "configure:9444: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9387: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9450 "configure"
+#line 9393 "configure"
@@ -9457,7 +9400,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9476,13 +9419,13 @@
-echo "configure:9480: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9423: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9486 "configure"
+#line 9429 "configure"
@@ -9493,7 +9436,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9512,13 +9455,13 @@
-echo "configure:9516: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9459: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9522 "configure"
+#line 9465 "configure"
@@ -9529,7 +9472,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9586,13 +9529,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9590: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9533: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9596 "configure"
+#line 9539 "configure"
@@ -9603,7 +9546,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9625,13 +9568,13 @@
-echo "configure:9629: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9572: checking for PQcmdTuples in -lpq" >&5
-#line 9635 "configure"
+#line 9578 "configure"
@@ -9642,7 +9585,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9685,7 +9628,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9689: checking whether to use MySQL" >&5
+echo "configure:9632: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9705,7 +9648,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9709: checking for location of MySQL includes" >&5
+echo "configure:9652: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9731,15 +9674,15 @@
do
-echo "configure:9735: checking for $ac_hdr" >&5
+echo "configure:9678: checking for $ac_hdr" >&5
-#line 9738 "configure"
+#line 9681 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9776,7 +9719,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9780: checking for location of MySQL library" >&5
+echo "configure:9723: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9807,13 +9750,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9811: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9754: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9817 "configure"
+#line 9760 "configure"
@@ -9824,7 +9767,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9843,13 +9786,13 @@
-echo "configure:9847: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9790: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9853 "configure"
+#line 9796 "configure"
@@ -9860,7 +9803,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9879,13 +9822,13 @@
-echo "configure:9883: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9826: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9889 "configure"
+#line 9832 "configure"
@@ -9896,7 +9839,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9915,13 +9858,13 @@
-echo "configure:9919: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9862: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9925 "configure"
+#line 9868 "configure"
@@ -9932,7 +9875,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9951,13 +9894,13 @@
-echo "configure:9955: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9898: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9961 "configure"
+#line 9904 "configure"
@@ -9968,7 +9911,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9987,13 +9930,13 @@
-echo "configure:9991: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9934: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9997 "configure"
+#line 9940 "configure"
@@ -10004,7 +9947,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10023,13 +9966,13 @@
-echo "configure:10027: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9970: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10033 "configure"
+#line 9976 "configure"
@@ -10040,7 +9983,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10059,13 +10002,13 @@
-echo "configure:10063: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10006: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10069 "configure"
+#line 10012 "configure"
@@ -10076,7 +10019,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10166,7 +10109,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:10170: checking for $ac_word" >&5
+echo "configure:10113: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10207,10 +10150,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10211: checking for mysql_server_init" >&5
+echo "configure:10154: checking for mysql_server_init" >&5
-#line 10214 "configure"
+#line 10157 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -10233,7 +10176,7 @@
; return 0; }
EOF
-if { (eval echo configure:10237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10271,7 +10214,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10275: checking whether to use SQLite" >&5
+echo "configure:10218: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10291,7 +10234,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10295: checking for location of SQLite includes" >&5
+echo "configure:10238: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10317,15 +10260,15 @@
do
-echo "configure:10321: checking for $ac_hdr" >&5
+echo "configure:10264: checking for $ac_hdr" >&5
-#line 10324 "configure"
+#line 10267 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10368,7 +10311,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10372: checking for location of SQLite library" >&5
+echo "configure:10315: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10395,13 +10338,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10399: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10342: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10405 "configure"
+#line 10348 "configure"
@@ -10412,7 +10355,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10431,13 +10374,13 @@
-echo "configure:10435: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10378: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10441 "configure"
+#line 10384 "configure"
@@ -10448,7 +10391,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10501,7 +10444,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10505: checking whether to use FFMPEG" >&5
+echo "configure:10448: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10521,7 +10464,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10525: checking for location of FFMPEG includes" >&5
+echo "configure:10468: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10547,15 +10490,15 @@
do
-echo "configure:10551: checking for $ac_hdr" >&5
+echo "configure:10494: checking for $ac_hdr" >&5
-#line 10554 "configure"
+#line 10497 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10559: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10591,15 +10534,15 @@
do
-echo "configure:10595: checking for $ac_hdr" >&5
+echo "configure:10538: checking for $ac_hdr" >&5
-#line 10598 "configure"
+#line 10541 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10603: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10546: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10635,15 +10578,15 @@
do
-echo "configure:10639: checking for $ac_hdr" >&5
+echo "configure:10582: checking for $ac_hdr" >&5
-#line 10642 "configure"
+#line 10585 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10590: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10686,7 +10629,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10690: checking for location of FFMPEG library" >&5
+echo "configure:10633: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10713,13 +10656,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10717: checking for av_free in -lavutil" >&5
+echo "configure:10660: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10723 "configure"
+#line 10666 "configure"
@@ -10730,7 +10673,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10749,13 +10692,13 @@
-echo "configure:10753: checking for av_free in -lavutil" >&5
+echo "configure:10696: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10759 "configure"
+#line 10702 "configure"
@@ -10766,7 +10709,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10811,13 +10754,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10815: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10758: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10821 "configure"
+#line 10764 "configure"
@@ -10828,7 +10771,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10847,13 +10790,13 @@
-echo "configure:10851: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10794: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10857 "configure"
+#line 10800 "configure"
@@ -10864,7 +10807,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10909,13 +10852,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10913: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10856: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10919 "configure"
+#line 10862 "configure"
@@ -10926,7 +10869,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10945,13 +10888,13 @@
-echo "configure:10949: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10892: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10955 "configure"
+#line 10898 "configure"
@@ -10962,7 +10905,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11022,7 +10965,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:11026: checking whether to use OpenGL" >&5
+echo "configure:10969: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -11056,7 +10999,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11060: checking for location of OpenGL includes" >&5
+echo "configure:11003: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11082,15 +11025,15 @@
do
-echo "configure:11086: checking for $ac_hdr" >&5
+echo "configure:11029: checking for $ac_hdr" >&5
-#line 11089 "configure"
+#line 11032 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11037: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11124,7 +11067,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11128: checking for location of OpenGL library" >&5
+echo "configure:11071: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11153,13 +11096,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11157: checking for glBegin in -lGL" >&5
+echo "configure:11100: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11163 "configure"
+#line 11106 "configure"
@@ -11170,7 +11113,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11189,13 +11132,13 @@
-echo "configure:11193: checking for glBegin in -lGL" >&5
+echo "configure:11136: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11199 "configure"
+#line 11142 "configure"
@@ -11206,7 +11149,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11225,13 +11168,13 @@
-echo "configure:11229: checking for glBegin in -lGL" >&5
+echo "configure:11172: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11235 "configure"
+#line 11178 "configure"
@@ -11242,7 +11185,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11261,13 +11204,13 @@
-echo "configure:11265: checking for glBegin in -lGL" >&5
+echo "configure:11208: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11271 "configure"
+#line 11214 "configure"
@@ -11278,7 +11221,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11340,13 +11283,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11344: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11287: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11350 "configure"
+#line 11293 "configure"
@@ -11357,7 +11300,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11376,13 +11319,13 @@
-echo "configure:11380: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11323: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11386 "configure"
+#line 11329 "configure"
@@ -11393,7 +11336,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11437,10 +11380,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11441: checking for glXCreatePbuffer" >&5
+echo "configure:11384: checking for glXCreatePbuffer" >&5
-#line 11444 "configure"
+#line 11387 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11463,7 +11406,7 @@
; return 0; }
EOF
-if { (eval echo configure:11467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11485,10 +11428,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11489: checking for glXCreateGLXPixmap" >&5
+echo "configure:11432: checking for glXCreateGLXPixmap" >&5
-#line 11492 "configure"
+#line 11435 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11511,7 +11454,7 @@
; return 0; }
EOF
-if { (eval echo configure:11515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11550,7 +11493,7 @@
-echo "configure:11554: checking for location of OpenGL includes" >&5
+echo "configure:11497: checking for location of OpenGL includes" >&5
@@ -11576,15 +11519,15 @@
do
-echo "configure:11580: checking for $ac_hdr" >&5
+echo "configure:11523: checking for $ac_hdr" >&5
-#line 11583 "configure"
+#line 11526 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11619,10 +11562,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11623: checking for glBegin" >&5
+echo "configure:11566: checking for glBegin" >&5
-#line 11626 "configure"
+#line 11569 "configure"
which can conflict with char glBegin(); below. */
@@ -11645,7 +11588,7 @@
; return 0; }
EOF
-if { (eval echo configure:11649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11660,10 +11603,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11664: checking for gluBeginCurve" >&5
+echo "configure:11607: checking for gluBeginCurve" >&5
-#line 11667 "configure"
+#line 11610 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11686,7 +11629,7 @@
; return 0; }
EOF
-if { (eval echo configure:11690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11732,7 +11675,7 @@
-echo "configure:11736: checking for location of OpenGL includes" >&5
+echo "configure:11679: checking for location of OpenGL includes" >&5
@@ -11758,15 +11701,15 @@
do
-echo "configure:11762: checking for $ac_hdr" >&5
+echo "configure:11705: checking for $ac_hdr" >&5
-#line 11765 "configure"
+#line 11708 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11713: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11800,7 +11743,7 @@
-echo "configure:11804: checking for location of OpenGL library" >&5
+echo "configure:11747: checking for location of OpenGL library" >&5
@@ -11819,60 +11762,77 @@
fi
-LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11827: checking for OpenGL library" >&5
-LIBS="-lopengl32"
+echo "configure:11770: checking for OpenGL library" >&5
+LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
+LIBS="-lopengl32 "
-#line 11830 "configure"
+#line 11774 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
-OPENGLLIB=-lopengl32
+OPENGLLIB="$OPENGLLIB -lopengl32 "
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ { echo "configure: error: *** Unable to locate OpenGL library." 1>&2; exit 1; }
+fi
+rm -f conftest*
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11843: checking for GLU library" >&5
-LIBS="-lglu32 $OPENGLLIB"
+echo "configure:11805: checking for GLU library" >&5
+LIBS="-lglu32 $OPENGLLIB "
-#line 11846 "configure"
+#line 11809 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
-OPENGLULIB=-lglu32
+OPENGLULIB="$OPENGLULIB -lglu32 "
else
rm -rf conftest*
- { echo "configure: error: *** Unable to locate GLU library." 1>&2; exit 1; }
-fi
-rm -f conftest*
-else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- { echo "configure: error: *** Unable to locate OpenGL library." 1>&2; exit 1; }
+ { echo "configure: error: *** Unable to locate GLU library." 1>&2; exit 1; }
fi
rm -f conftest*
OPENGLLIB="$OPENGL_LIB_PATH $OPENGLLIB"
OPENGLULIB="$OPENGL_LIB_PATH $OPENGLULIB"
@@ -11900,7 +11860,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11904: checking whether to use ODBC" >&5
+echo "configure:11864: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11919,7 +11879,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11923: checking for location of ODBC includes" >&5
+echo "configure:11883: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11945,15 +11905,15 @@
do
-echo "configure:11949: checking for $ac_hdr" >&5
+echo "configure:11909: checking for $ac_hdr" >&5
-#line 11952 "configure"
+#line 11912 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11987,7 +11947,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11991: checking for location of ODBC library" >&5
+echo "configure:11951: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12012,13 +11972,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12016: checking for SQLConnect in -lodbc" >&5
+echo "configure:11976: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12022 "configure"
+#line 11982 "configure"
@@ -12029,7 +11989,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12054,13 +12014,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12058: checking for SQLConnect in -liodbc" >&5
+echo "configure:12018: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12064 "configure"
+#line 12024 "configure"
@@ -12071,7 +12031,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12091,13 +12051,47 @@
+echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
+echo "configure:12058: checking for ODBC library" >&5
+LDFLAGS="$ODBCLIB $LDFLAGS"
+LIBS="-lodbc32 "
+cat > conftest.$ac_ext <<EOF
+#line 12062 "configure"
+#include "confdefs.h"
+#include <windows.h>
+#include <sql.h>
+int main() {
+SQLAllocEnv((SQLHENV *)0);
+; return 0; }
+EOF
+if { (eval echo configure:12070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+echo "$ac_t""found" 1>&6
+ODBCLIB="$ODBCLIB -lodbc32 "
+else
+ rm -rf conftest*
{ echo "configure: error: *** Unable to locate ODBC library." 1>&2; exit 1; }
fi
+rm -f conftest*
+fi
@@ -12120,7 +12114,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12124: checking whether to use FFTW" >&5
+echo "configure:12118: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12139,7 +12133,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12143: checking for location of FFTW includes" >&5
+echo "configure:12137: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12165,15 +12159,15 @@
do
-echo "configure:12169: checking for $ac_hdr" >&5
+echo "configure:12163: checking for $ac_hdr" >&5
-#line 12172 "configure"
+#line 12166 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12177: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12201,15 +12195,15 @@
do
-echo "configure:12205: checking for $ac_hdr" >&5
+echo "configure:12199: checking for $ac_hdr" >&5
-#line 12208 "configure"
+#line 12202 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12207: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12237,15 +12231,15 @@
do
-echo "configure:12241: checking for $ac_hdr" >&5
+echo "configure:12235: checking for $ac_hdr" >&5
-#line 12244 "configure"
+#line 12238 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12291,7 +12285,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12295: checking for location of FFTW library" >&5
+echo "configure:12289: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12316,13 +12310,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12320: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12314: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12326 "configure"
+#line 12320 "configure"
@@ -12333,7 +12327,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12358,13 +12352,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12362: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12356: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12368 "configure"
+#line 12362 "configure"
@@ -12375,7 +12369,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12400,13 +12394,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12404: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12398: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12410 "configure"
+#line 12404 "configure"
@@ -12417,7 +12411,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12474,7 +12468,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12478: checking whether to use BLAS" >&5
+echo "configure:12472: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12495,7 +12489,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12499: checking for location of BLAS includes" >&5
+echo "configure:12493: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12515,7 +12509,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12519: checking for location of BLAS library" >&5
+echo "configure:12513: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12541,15 +12535,15 @@
do
-echo "configure:12545: checking for $ac_hdr" >&5
+echo "configure:12539: checking for $ac_hdr" >&5
-#line 12548 "configure"
+#line 12542 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12553: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12547: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12584,13 +12578,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12588: checking for dnrm2_ in -lblas" >&5
+echo "configure:12582: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12594 "configure"
+#line 12588 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12601,7 +12595,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12620,13 +12614,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:12624: checking for dnrm2_ in -lblas" >&5
+echo "configure:12618: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12630 "configure"
+#line 12624 "configure"
@@ -12637,7 +12631,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12681,13 +12675,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12685: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12679: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12691 "configure"
+#line 12685 "configure"
@@ -12698,7 +12692,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12713,13 +12707,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12717: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12711: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12723 "configure"
+#line 12717 "configure"
@@ -12730,7 +12724,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12745,13 +12739,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12749: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12743: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12755 "configure"
+#line 12749 "configure"
@@ -12762,7 +12756,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12807,16 +12801,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12811: checking for sgemm in $vlib_flags" >&5
+echo "configure:12805: checking for sgemm in $vlib_flags" >&5
-#line 12813 "configure"
+#line 12807 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12814: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12834,13 +12828,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12838: checking for sgemm_ in -lblas" >&5
+echo "configure:12832: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $LIBS"
-#line 12844 "configure"
+#line 12838 "configure"
@@ -12851,7 +12845,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12866,13 +12860,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12870: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12864: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12876 "configure"
+#line 12870 "configure"
@@ -12883,7 +12877,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12898,13 +12892,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12902: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12896: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12908 "configure"
+#line 12902 "configure"
@@ -12915,7 +12909,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12949,13 +12943,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12953: checking for acosp in -lsunmath" >&5
+echo "configure:12947: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12959 "configure"
+#line 12953 "configure"
@@ -12966,7 +12960,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12981,13 +12975,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12985: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12979: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12991 "configure"
+#line 12985 "configure"
@@ -12998,7 +12992,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13028,13 +13022,13 @@
# Generic BLAS library
-echo "configure:13032: checking for sgemm_ in -lblas" >&5
+echo "configure:13026: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13038 "configure"
+#line 13032 "configure"
@@ -13045,7 +13039,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13084,7 +13078,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13088: checking whether to use LAPACK" >&5
+echo "configure:13082: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13109,7 +13103,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13113: checking for location of LAPACK includes" >&5
+echo "configure:13107: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13129,7 +13123,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13133: checking for location of LAPACK library" >&5
+echo "configure:13127: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13155,15 +13149,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13159: checking for $ac_hdr" >&5
+echo "configure:13153: checking for $ac_hdr" >&5
-#line 13162 "configure"
+#line 13156 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13167: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13161: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13195,10 +13189,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13199: checking for dsegv_" >&5
+echo "configure:13193: checking for dsegv_" >&5
-#line 13202 "configure"
+#line 13196 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char dsegv_(); below. */
@@ -13221,7 +13215,7 @@
; return 0; }
EOF
-if { (eval echo configure:13225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13248,13 +13242,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13252: checking for desgv_ in -llapack" >&5
+echo "configure:13246: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13258 "configure"
+#line 13252 "configure"
@@ -13265,7 +13259,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13297,13 +13291,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13301: checking for dgesv_ in -llapack" >&5
+echo "configure:13295: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13307 "configure"
+#line 13301 "configure"
@@ -13314,7 +13308,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13333,13 +13327,13 @@
-echo "configure:13337: checking for dgesv_ in -llapack" >&5
+echo "configure:13331: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13343 "configure"
+#line 13337 "configure"
@@ -13350,7 +13344,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13406,7 +13400,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13410: checking whether to use Motif" >&5
+echo "configure:13404: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13425,7 +13419,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13429: checking for location of Motif includes" >&5
+echo "configure:13423: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13451,15 +13445,15 @@
do
-echo "configure:13455: checking for $ac_hdr" >&5
+echo "configure:13449: checking for $ac_hdr" >&5
-#line 13458 "configure"
+#line 13452 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13493,7 +13487,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13497: checking for location of Motif library" >&5
+echo "configure:13491: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13518,13 +13512,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13522: checking for XmStringCreate in -lXm" >&5
+echo "configure:13516: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13528 "configure"
+#line 13522 "configure"
@@ -13535,7 +13529,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13576,7 +13570,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:13580: checking whether to use Cairo" >&5
+echo "configure:13574: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -13602,15 +13596,15 @@
do
-echo "configure:13606: checking for $ac_hdr" >&5
+echo "configure:13600: checking for $ac_hdr" >&5
-#line 13609 "configure"
+#line 13603 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13614: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13647,10 +13641,10 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $CAIROLIB"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13651: checking for cairo_create" >&5
+echo "configure:13645: checking for cairo_create" >&5
-#line 13654 "configure"
+#line 13648 "configure"
which can conflict with char cairo_create(); below. */
@@ -13673,7 +13667,7 @@
; return 0; }
EOF
-if { (eval echo configure:13677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13708,7 +13702,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13712: checking whether to use GLw" >&5
+echo "configure:13706: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13727,7 +13721,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13731: checking for location of GLw includes" >&5
+echo "configure:13725: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13753,15 +13747,15 @@
do
-echo "configure:13757: checking for $ac_hdr" >&5
+echo "configure:13751: checking for $ac_hdr" >&5
-#line 13760 "configure"
+#line 13754 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13789,15 +13783,15 @@
do
-echo "configure:13793: checking for $ac_hdr" >&5
+echo "configure:13787: checking for $ac_hdr" >&5
-#line 13796 "configure"
+#line 13790 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13795: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13837,7 +13831,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13841: checking for location of GLw library" >&5
+echo "configure:13835: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13862,13 +13856,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13866: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13860: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13872 "configure"
+#line 13866 "configure"
@@ -13879,7 +13873,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13904,13 +13898,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13908: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13902: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13914 "configure"
+#line 13908 "configure"
@@ -13921,7 +13915,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13946,13 +13940,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13950: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13944: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13956 "configure"
+#line 13950 "configure"
@@ -13963,7 +13957,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13988,13 +13982,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13992: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13986: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13998 "configure"
+#line 13992 "configure"
@@ -14005,7 +13999,7 @@
; return 0; }
EOF
-if { (eval echo configure:14009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14030,13 +14024,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14034: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14028: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14040 "configure"
+#line 14034 "configure"
@@ -14047,7 +14041,7 @@
; return 0; }
EOF
-if { (eval echo configure:14051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14072,13 +14066,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14076: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14070: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14082 "configure"
+#line 14076 "configure"
@@ -14089,7 +14083,7 @@
; return 0; }
EOF
-if { (eval echo configure:14093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14116,13 +14110,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14120: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14114: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14126 "configure"
+#line 14120 "configure"
@@ -14133,7 +14127,7 @@
; return 0; }
EOF
-if { (eval echo configure:14137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14152,13 +14146,13 @@
-echo "configure:14156: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14150: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14162 "configure"
+#line 14156 "configure"
@@ -14169,7 +14163,7 @@
; return 0; }
EOF
-if { (eval echo configure:14173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14196,13 +14190,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14200: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14194: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14206 "configure"
+#line 14200 "configure"
@@ -14213,7 +14207,7 @@
; return 0; }
EOF
-if { (eval echo configure:14217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14232,13 +14226,13 @@
-echo "configure:14236: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14230: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14242 "configure"
+#line 14236 "configure"
@@ -14249,7 +14243,7 @@
; return 0; }
EOF
-if { (eval echo configure:14253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14362,7 +14356,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14366: checking whether to use FreeType" >&5
+echo "configure:14360: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14381,7 +14375,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14385: checking for location of FreeType includes" >&5
+echo "configure:14379: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14407,15 +14401,15 @@
do
-echo "configure:14411: checking for $ac_hdr" >&5
+echo "configure:14405: checking for $ac_hdr" >&5
-#line 14414 "configure"
+#line 14408 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14419: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14449,7 +14443,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14453: checking for location of FreeType library" >&5
+echo "configure:14447: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14474,13 +14468,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14478: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14472: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14484 "configure"
+#line 14478 "configure"
@@ -14491,7 +14485,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14532,7 +14526,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14536: checking whether to use NLS" >&5
+echo "configure:14530: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14552,10 +14546,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14556: checking for gettext" >&5
+echo "configure:14550: checking for gettext" >&5
-#line 14559 "configure"
+#line 14553 "configure"
which can conflict with char gettext(); below. */
@@ -14578,7 +14572,7 @@
; return 0; }
EOF
-if { (eval echo configure:14582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14596,13 +14590,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14600: checking for gettext in -lintl" >&5
+echo "configure:14594: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14606 "configure"
+#line 14600 "configure"
@@ -14613,7 +14607,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14648,7 +14642,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14652: checking whether to use C++" >&5
+echo "configure:14646: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14664,7 +14658,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:14668: checking for $ac_word" >&5
+echo "configure:14662: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14693,7 +14687,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14697: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14691: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14704,12 +14698,12 @@
cat > conftest.$ac_ext << EOF
-#line 14708 "configure"
+#line 14702 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14735,19 +14729,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14739: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14733: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14744: checking whether we are using GNU C++" >&5
+echo "configure:14738: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14751: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14745: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14765,7 +14759,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14769: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14763: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14806,7 +14800,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14810: checking whether to use openDWG" >&5
+echo "configure:14804: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14826,7 +14820,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14830: checking for location of openDGW includes" >&5
+echo "configure:14824: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14852,15 +14846,15 @@
do
-echo "configure:14856: checking for $ac_hdr" >&5
+echo "configure:14850: checking for $ac_hdr" >&5
-#line 14859 "configure"
+#line 14853 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14864: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14858: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14894,7 +14888,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14898: checking for location of openDWG library" >&5
+echo "configure:14892: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14941,7 +14935,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14945: checking for special C compiler options needed for large files" >&5
+echo "configure:14939: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14949,7 +14943,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14953 "configure"
+#line 14947 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14965,7 +14959,7 @@
; return 0; }
EOF
-if { (eval echo configure:14969: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -14974,7 +14968,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14978 "configure"
+#line 14972 "configure"
@@ -14990,7 +14984,7 @@
; return 0; }
EOF
-if { (eval echo configure:14994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14988: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15010,11 +15004,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15014: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15008: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15018 "configure"
+#line 15012 "configure"
@@ -15030,14 +15024,14 @@
; return 0; }
EOF
-if { (eval echo configure:15034: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15028: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15041 "configure"
+#line 15035 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15055,7 +15049,7 @@
; return 0; }
EOF
-if { (eval echo configure:15059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15074,11 +15068,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15078: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15072: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15082 "configure"
+#line 15076 "configure"
@@ -15094,14 +15088,14 @@
; return 0; }
EOF
-if { (eval echo configure:15098: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15092: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15105 "configure"
+#line 15099 "configure"
#define _LARGE_FILES 1
@@ -15119,7 +15113,7 @@
; return 0; }
EOF
-if { (eval echo configure:15123: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15117: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15138,25 +15132,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15142: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15136: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15146 "configure"
+#line 15140 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15153: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15147: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15160 "configure"
+#line 15154 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15165,7 +15159,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15169: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15163: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -15186,10 +15180,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15190: checking if system supports Large Files at all" >&5
+echo "configure:15184: checking if system supports Large Files at all" >&5
-#line 15193 "configure"
+#line 15187 "configure"
#include <stdio.h>
@@ -15221,7 +15215,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:15225: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15219: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -15250,7 +15244,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15254: checking whether to use Python" >&5
+echo "configure:15248: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -15270,7 +15264,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15274: checking for $ac_word" >&5
+echo "configure:15268: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -15315,15 +15309,15 @@
do
-echo "configure:15319: checking for $ac_hdr" >&5
+echo "configure:15313: checking for $ac_hdr" >&5
-#line 15322 "configure"
+#line 15316 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15321: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15363,7 +15357,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:15367: checking for $ac_word" >&5
+echo "configure:15361: checking for $ac_word" >&5
case "$SWIG" in
@@ -15409,7 +15403,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15413: checking whether to use wxWidgets" >&5
+echo "configure:15407: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -15429,7 +15423,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:15433: checking for $ac_word" >&5
+echo "configure:15427: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -15477,7 +15471,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15481: checking wxWidgets version" >&5
+echo "configure:15475: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -15500,15 +15494,15 @@
do
-echo "configure:15504: checking for $ac_hdr" >&5
+echo "configure:15498: checking for $ac_hdr" >&5
-#line 15507 "configure"
+#line 15501 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15506: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15544,15 +15538,15 @@
do
-echo "configure:15548: checking for $ac_hdr" >&5
+echo "configure:15542: checking for $ac_hdr" >&5
-#line 15551 "configure"
+#line 15545 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15550: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-06-27 16:35:43 UTC (rev 31860)
+++ grass/trunk/configure.in 2008-06-27 16:48:11 UTC (rev 31861)
@@ -708,10 +708,10 @@
GDAL=
ac_save_libs="$LIBS"
LIBS="$LIBS $GDAL_LIBS"
- AC_CHECK_FUNC(GDALOpen, , [
+ AC_TRY_LINK([#include <gdal.h>],[GDALOpen("foo", GA_ReadOnly);],,[
LIBS="$LIBS $GDAL_DEP_LIBS"
- AC_CHECK_FUNC(GDALOpen, GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS", [
- AC_MSG_ERROR([*** couldn't find GDAL])
+ AC_TRY_LINK([#include <gdal.h>],[GDALOpen("foo", GA_ReadOnly);],GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS",[
+ AC_MSG_ERROR([*** Unable to locate GDAL library.])
LIBS=${ac_save_libs}
@@ -1142,23 +1142,8 @@
LOC_CHECK_LIB_PATH(opengl,OpenGL,OPENGL_LIB_PATH)
-ac_save_ldflags="$LDFLAGS"
-ac_save_libs="$LIBS"
-AC_MSG_CHECKING(for OpenGL library)
-LIBS="-lopengl32"
-AC_TRY_LINK([#include <GL/gl.h>],[glEnd();],[
-AC_MSG_RESULT(found)
-AC_MSG_CHECKING(for GLU library)
-AC_TRY_LINK([#include <GL/glu.h>],[gluNewQuadric();],[
-OPENGLULIB=-lglu32
-],[AC_MSG_ERROR([*** Unable to locate GLU library.])])
-],[AC_MSG_ERROR([*** Unable to locate OpenGL library.])])
-LIBS=${ac_save_libs}
-LDFLAGS=${ac_save_ldflags}
+LOC_CHECK_LINK(opengl32,[#include <GL/gl.h>],[glEnd();],OpenGL,$OPENGL_LIB_PATH,OPENGLLIB)
+LOC_CHECK_LINK(glu32,[#include <GL/glu.h>],[gluNewQuadric();],GLU,$OPENGL_LIB_PATH,OPENGLULIB,$OPENGLLIB)
@@ -1200,8 +1185,11 @@
LOC_CHECK_LIB_PATH(odbc,ODBC,ODBCLIB)
LOC_CHECK_LIBS(odbc,SQLConnect,ODBC,$ODBCLIB,ODBCLIB,$ICONVLIB,,[
-LOC_CHECK_LIBS(iodbc,SQLConnect,ODBC,$ODBCLIB,ODBCLIB,,,)
+LOC_CHECK_LIBS(iodbc,SQLConnect,ODBC,$ODBCLIB,ODBCLIB,,,[
+LOC_CHECK_LINK(odbc32,[#include <windows.h>
+#include <sql.h>],[SQLAllocEnv((SQLHENV *)0);],ODBC,$ODBCLIB,ODBCLIB)
fi # $USE_ODBC
