[GRASS-SVN] r31864 - grass-addons/visualization/nviz2/wxpython
svn_grass at osgeo.org
Fri Jun 27 17:33:17 EDT 2008
Author: martinl
Date: 2008-06-27 17:33:16 -0400 (Fri, 27 Jun 2008)
New Revision: 31864
grass-addons/visualization/nviz2/wxpython/mapdisp.py
grass-addons/visualization/nviz2/wxpython/nviz.py
nviz2: wxGUI-related fixes (r31863)
Modified: grass-addons/visualization/nviz2/wxpython/mapdisp.py
--- grass-addons/visualization/nviz2/wxpython/mapdisp.py 2008-06-27 21:31:43 UTC (rev 31863)
+++ grass-addons/visualization/nviz2/wxpython/mapdisp.py 2008-06-27 21:33:16 UTC (rev 31864)
@@ -160,7 +160,7 @@
def ZoomToMap(self, event):
pass
- def GetSelectedLayer(self, nviz=False):
+ def GetSelectedLayer(self, nviz=False, index=False):
"""Get selected layer from layer tree
@param nviz get nviz properties instead
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-27 21:31:43 UTC (rev 31863)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-27 21:33:16 UTC (rev 31864)
@@ -106,6 +106,7 @@
self.view = UserSettings.Get(group='nviz', key='view') # reference
self.update = [] # update view/controls
+ self.object = {} # loaded data objects (layer index / gsurf id)
self.size = None
self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
@@ -279,7 +280,8 @@
@todo volumes
for raster in self.Map.GetListOfLayers(l_type='raster', l_active=True):
- self.nvizClass.LoadRaster(str(raster.name), None, None)
+ id = self.nvizClass.LoadRaster(str(raster.name), None, None)
+ self.object[self.Map.GetLayerIndex(raster)] = id
def Reset(self):
"""Reset (unload data)"""
@@ -315,6 +317,19 @@
self.update.append('view')
self.update.append('z-exag')
+ def GetMapObjId(self, layer):
+ """Get map object id of given map layer (2D)
+ @param layer MapLayer instance
+ index = self.Map.GetLayerIndex(layer)
+ try:
+ return self.object[index]
+ except:
+ return -1
class NvizToolWindow(wx.Frame):
"""Experimental window for Nviz tools
@@ -535,17 +550,23 @@
# size=globalvar.DIALOG_GSELECT_SIZE,
size=(200, -1),
type="raster")
- self.win['surface'][code]['map'] = map.GetId()
+ self.win['surface'][code]['map'] = map.GetId() - 1 # FIXME !
map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
pos=(row, 2))
- value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=0,
- min=0,
- max=100)
+ if code == 'color':
+ value = csel.ColourSelect(panel, id=wx.ID_ANY)
+ value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+ else:
+ value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
+ initial=0,
+ min=0,
+ max=100)
self.win['surface'][code]['constant'] = value.GetId()
value.Enable(False)
gridSizer.Add(item=value, flag=wx.ALIGN_CENTER_VERTICAL,
pos=(row, 3))
@@ -872,15 +893,26 @@
def OnSurfaceMap(self, event):
"""Set surface attribute -- map"""
- attrName = 'topo'
- win = self.FindWindowById(self.win['surface'][attrName]['map'])
- # print win.GetId(), win.tcp.seltree.GetId(), event.GetId()
+ if not self.mapWindow.init:
+ return
+ attrName = self.__GetWindowName(self.win['surface'], event.GetId())
if not attrName:
return
- if attrName == 'topo':
- print 'x'
+ if self.FindWindowById(self.win['surface'][attrName]['use']).GetSelection() == 0:
+ value = self.FindWindowById(self.win['surface'][attrName]['map']).GetValue()
+ map = True
+ else:
+ value = self.FindWindowById(self.win['surface'][attrName]['constant']).GetValue()
+ print value
+ map = False
+ layer = self.mapWindow.GetSelectedLayer()
+ id = self.mapWindow.GetMapObjId(layer)
+ if attrName == 'color':
+ self.mapWindow.nvizClass.SetSurfaceColor(id, map, str(value))
def OnSurfaceMode(self, event):
pass
