[GRASS-SVN] r31870 - grass-web/trunk/download
svn_grass at osgeo.org
Sat Jun 28 07:18:11 EDT 2008
Author: neteler
Date: 2008-06-28 07:18:10 -0400 (Sat, 28 Jun 2008)
New Revision: 31870
grass-web/trunk/download/addons.inc
all this should go into the Wiki and be deleted here
Modified: grass-web/trunk/download/addons.inc
--- grass-web/trunk/download/addons.inc 2008-06-28 09:37:22 UTC (rev 31869)
+++ grass-web/trunk/download/addons.inc 2008-06-28 11:18:10 UTC (rev 31870)
@@ -49,8 +49,6 @@
<li>
<a href="http://www.jgrass.org">JAVAGRASS</a>:
JGrass, a Java based framework for the GRASS Geographic Information System</li>
-<li>
-<a href="http://gtkgrass.sourceforge.net/">GTK/GRASS</a></li>
</ul>
<h2>CLI (Command Line Interface)</h2>
@@ -87,23 +85,6 @@
href="http://www.hydrosciences.org/index.asp?frame=fuzzy_index">r.fuzzy: Fuzzy logic tools</a> (François Delclaux)</li>
<li>
-<a
-href="http://www.grass.fukengrueven.com/">r.mandelbrot</a>
-A Perl-script to compute the mandelbrot set within a XY-location (Peter
-Löwe, Germany)
-<li>
-<a
-href="http://www.unipg.it/~afrigeri/r.out.netcdf/">r.out.netcdf</a>
-Export of GRASS raster maps to netCDF format to support GMT, OpenDX etc.
-(Alessandro Frigeri, Italy)
-<li>
-<a href="http://geomatica.ing.unico.it/software/index.html">r.outldetect,
-r.outldetopt</a>: Outlier detection in DEM (Dr. D. Triglione, Prof. Dr.
-M. Brovelli, Milano, Italy)</li>
-<li>
<a href="http://www.ing.unitn.it/~grass/software.html">r.obstruction,
r.planning.static, r.planning.cinematic</a>: r.obstruction creates a polar
obstruction map from a DTM. r.planning.static performs a static planning
@@ -126,74 +107,8 @@
r.rifs generates a raster map and/or image of a fractal by means of the
specified random iterated function system. (Dr. M. Lake, London, U.K.)</li>
-<li>
-<a
-href="http://www.grass-gis.de/dassau/r_cross_pg/r.cross.to.pg.html">r.cross.to.pg</a>:
-r.cross exports category labels from a GRASS raster map created with r.cross
-into PostgreSQL table (O. Dassau, Germany).
</ul>
-<h2>
-Sites modules</h2>
-<ul>
-<li>
-<a href="http://www.tigers.ru/grass_docs/progs/DESCRIPTION.html">Parallelized
-s.surf.idw (MPI) for GRASS 5</a> (Alexei Popov, Russia)</li>
-</ul>
-<h2>Vector modules</h2>
-<ul>
-<li> <a href="http://www.grass-gis.de/dassau/edbs_import/edbs_vortrag/startseite.html">v.in.edbs</a>:
-Import module for EDBS vector data. EDBS (Einheitliche
-Datenbankschnittstelle) is the German vector data exchange standard
-(ATKIS/ALK) (O. Dassau, Hannover, Cl. Rinner, Germany)</li>
-</ul>
-<h2>
-XML</h2>
-<ul>
-<li>
-<a href="http://web.archive.org/web/20030201220232/http://pweb.jps.net/~egm2/grass/xml/index.html">GRASS
-5.0 XML Fun</a>: a couple of XSLT stylesheets for transforming the output
-of GRASS 5.0 commands that respond to the "--interface-description" flag
-(Eric G. Miller, U.S.A.)</li>
-</ul>
-<h2>
-Web modules</h2>
-<ul>
-<li>
-<a
-href="http://ippc2.orst.edu/glinks/">OSU IPPC GRASSlinks</a> (Len Coop,
-IPPC Oregon State University)</li>
-<li>
-<a href="http://gisws.media.osaka-cu.ac.jp/slidelinks/">GRASS,
-GRASSlinks and PHP3</a> (Prof. Dr. V. Raghavan, Osaka, Japan)</li>
-<li>
-<a
-href="http://motivation.ru/mv_webgrass.ru.html">webgrass</a>:
-based on grasslinks, <a href="http://motivation.ru/src/">download</a>
-(Felix Gershunov, Alex Shevlakov, Russia)</li>
-<li>
-<a href="http://www.ambientepi.arti.beniculturali.it:2020/demo/grules.html">Grules:
-GRASS and JAVA</a> (F. Ponchio, Pisa, Italy)</li>
-</ul>
-If you want to see your module(s) listed here or if you are aware of interesting
-tools, send your GRASS Add-Ons proposal to <a href="mailto:grass-web(at)lists.osgeo.org">Webteam</a>.
<div align="right">
<i>Last change: $Date$ </i><br>
<i>$Author$</i>
