[GRASS-SVN] r31876 - in grass-addons/visualization/nviz2: lib
wxpython wxpython/nviz
svn_grass at osgeo.org
Sat Jun 28 18:19:55 EDT 2008
Author: martinl
Date: 2008-06-28 18:19:55 -0400 (Sat, 28 Jun 2008)
New Revision: 31876
grass-addons/visualization/nviz2/lib/map_obj.c
grass-addons/visualization/nviz2/wxpython/nviz.py
grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
nviz2/wxGUI: surface color fix (map/constant)
OnApply -> update map + render
auto-rendering -> surface attribute changed -> OnApply
Modified: grass-addons/visualization/nviz2/lib/map_obj.c
--- grass-addons/visualization/nviz2/lib/map_obj.c 2008-06-28 17:56:20 UTC (rev 31875)
+++ grass-addons/visualization/nviz2/lib/map_obj.c 2008-06-28 22:19:55 UTC (rev 31876)
@@ -28,22 +28,18 @@
\brief Create a new map object which can be one of surf, vect, vol or site.
- This routine creates the object
- internally in the gsf library and links a new tcl/tk
- command to the general object command parser below.
- Optionally, a logical name may be specified for the new map
- object. If no name is specified, a logical name is assigned to
- the new object automatically. Note that maintaining unique
- logical names is not the responsibility of the library (currently).
+ This routine creates the object internally in the gsf libraryb.
+ Optionally, a logical name may be specified for the new map object.
+ If no name is specified, a logical name is assigned to the new
+ object automatically. Note that maintaining unique logical names is
+ not the responsibility of the library (currently).
- Initially map objects contain no data, use the
- attribute commands to set attributes such as topology,
- color, etc.
+ Initially map objects contain no data, use the attribute commands to
+ set attributes such as topology, color, etc.
- \param data
- \param interp
- \param argc
- \param argv
+ \param type map object type
+ \param name map name
+ \param data nviz data
\return map object id
\return -1 on error
@@ -56,16 +52,13 @@
nv_clientdata *client_data;
- * For each type of map obj do the following --
- * 1) Verify we havn't maxed out the number of
- * allowed objects.
- * 2) Call the internal library to generate a new
- * map object of the specified type.
- * 3) Create a new tcl/tk command with the new object
- * id number and link it to the Nmap_obj_cmd routine
- * below.
+ * For each type of map obj do the following --
+ * 1) Verify we havn't maxed out the number of
+ * allowed objects.
+ * 2) Call the internal library to generate a new
+ * map object of the specified type.
/* raster -> surface */
if (type == MAP_OBJ_SURF) {
if (GS_num_surfs() >= MAX_SURFS) {
Modified: grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp 2008-06-28 17:56:20 UTC (rev 31875)
+++ grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp 2008-06-28 22:19:55 UTC (rev 31876)
@@ -27,7 +27,7 @@
else {
float val;
- val = atof(value);
+ val = Nviz_color_from_str(value);
Nviz_set_attr(id, MAP_OBJ_SURF, ATT_COLOR, CONST_ATT,
NULL, val,
data);
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-28 17:56:20 UTC (rev 31875)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py 2008-06-28 22:19:55 UTC (rev 31876)
@@ -105,7 +105,7 @@
# default values
self.view = UserSettings.Get(group='nviz', key='view') # reference
- self.update = [] # update view/controls
+ self.update = {} # update view/controls
self.object = {} # loaded data objects (layer index / gsurf id)
self.size = None
@@ -229,16 +229,16 @@
self.parent.onRenderTimer.Start(100)
self.parent.onRenderCounter = 0
- if 'view' in self.update:
+ if 'view' in self.update.keys():
self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
self.view['height']['value'],
self.view['persp']['value'],
self.view['twist']['value'])
- self.update.remove('view')
+ del self.update['view']
- if 'z-exag' in self.update:
+ if 'z-exag' in self.update.keys():
self.nvizClass.SetZExag(self.view['z-exag']['value'])
- self.update.remove('z-exag')
+ del self.update['z-exag']
if render is True:
self.nvizClass.Draw(False)
@@ -314,8 +314,8 @@
self.view['twist']['value'] = wxnviz.VIEW_DEFAULT_TWIST
self.view['z-exag']['value'] = wxnviz.VIEW_DEFAULT_ZEXAG
- self.update.append('view')
- self.update.append('z-exag')
+ self.update['view'] = None
+ self.update['z-exag'] = None
def GetMapObjId(self, layer):
"""Get map object id of given map layer (2D)
@@ -557,7 +557,7 @@
if code == 'color':
value = csel.ColourSelect(panel, id=wx.ID_ANY)
- value.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+ value.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceMap)
else:
value = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
initial=0,
@@ -799,9 +799,9 @@
self.FindWindowById(win).SetValue(self.settings[winName]['value'])
if winName in ('pos', 'height', 'twist', 'persp'):
- self.mapWindow.update.append('view')
+ self.mapWindow.update['view'] = None
else:
- self.mapWindow.update.append(winName)
+ self.mapWindow.update[winName] = None
self.mapWindow.Refresh(False)
@@ -842,7 +842,7 @@
self.settings['pos']['x'] = 0.0
self.settings['pos']['y'] = 1.0
self.UpdateSettings()
@@ -858,8 +858,16 @@
Update map (don't save settings)
- pass
+ layer = self.mapWindow.GetSelectedLayer()
+ id = self.mapWindow.GetMapObjId(layer)
+ if self.mapWindow.update.has_key('color'):
+ map, value = self.mapWindow.update['color']
+ self.mapWindow.nvizClass.SetSurfaceColor(id, map, str(value))
+ del self.mapWindow.update['color']
+ self.mapWindow.Refresh(False)
def OnClose(self, event):
"""Close button pressed
@@ -876,11 +884,15 @@
if event.GetSelection() == 0:
useMap = True
+ value = self.win['surface'][attrName]['map']
else:
useMap = False
+ value = self.win['surface'][attrName]['constant']
self.SetSurfaceUseMap(attrName, useMap)
+ self.mapWindow.update[attrName] = (useMap, str(value))
def SetSurfaceUseMap(self, attrName, map=True):
if map: # map
self.FindWindowById(self.win['surface'][attrName]['map']).Enable(True)
@@ -892,7 +904,7 @@
self.FindWindowById(self.win['surface'][attrName]['use']).SetSelection(1)
def OnSurfaceMap(self, event):
- """Set surface attribute -- map"""
+ """Set surface attribute"""
if not self.mapWindow.init:
return
@@ -905,15 +917,14 @@
map = True
else:
value = self.FindWindowById(self.win['surface'][attrName]['constant']).GetValue()
- print value
+ value = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
map = False
- layer = self.mapWindow.GetSelectedLayer()
- id = self.mapWindow.GetMapObjId(layer)
+ self.mapWindow.update[attrName] = (map, str(value))
- if attrName == 'color':
- self.mapWindow.nvizClass.SetSurfaceColor(id, map, str(value))
+ if self.parent.autoRender.IsChecked():
+ self.OnApply(None)
def OnSurfaceMode(self, event):
pass
@@ -997,7 +1008,7 @@
y = float(y) / h
self.settings['pos']['x'] = x
self.settings['pos']['y'] = y
self.mapWindow.Refresh(eraseBackground=False)
# self.mapWindow.UpdateMap()
