[GRASS-SVN] r31902 - grass-addons/vector/v.parallel2
svn_grass at osgeo.org
Mon Jun 30 14:15:40 EDT 2008
Author: rmatev
Date: 2008-06-30 14:15:40 -0400 (Mon, 30 Jun 2008)
New Revision: 31902
grass-addons/vector/v.parallel2/main.c
grass-addons/vector/v.parallel2/vlib_buffer.c
Added feature: parallel lines on both sides; fixed minor bug;
Modified: grass-addons/vector/v.parallel2/main.c
--- grass-addons/vector/v.parallel2/main.c 2008-06-30 15:27:31 UTC (rev 31901)
+++ grass-addons/vector/v.parallel2/main.c 2008-06-30 18:15:40 UTC (rev 31902)
@@ -76,8 +76,8 @@
side_opt->required = YES;
side_opt->answer = "right";
side_opt->multiple = NO;
- side_opt->options = "left,right";
- side_opt->description = _("left;Parallel line is on the left;right;Parallel line is on the right;");
+ side_opt->options = "left,right,both";
+ side_opt->description = _("left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides");
tol_opt = G_define_option();
tol_opt->key = "tolerance";
@@ -120,6 +120,8 @@
side = 1;
else if (strcmp(side_opt->answer, "left") == 0)
side = -1;
+ else
+ side = 0;
Vect_set_open_level (2);
Vect_open_old (&In, in_opt->answer, "");
@@ -143,8 +145,16 @@
if ( ltype & GV_LINES ) {
if (!(buf_flag->answer)) {
- Vect_line_parallel2(Points, da, db, dalpha, side, round_flag->answer, tolerance, Points2);
- Vect_write_line(&Out, ltype, Points2, Cats);
+ if (side != 0) {
+ Vect_line_parallel2(Points, da, db, dalpha, side, round_flag->answer, tolerance, Points2);
+ Vect_write_line(&Out, ltype, Points2, Cats);
+ else {
+ Vect_line_parallel2(Points, da, db, dalpha, 1, round_flag->answer, tolerance, Points2);
+ Vect_line_parallel2(Points, da, db, dalpha, -1, round_flag->answer, tolerance, Points2);
else {
parallel_line_b(Points, da, db, dalpha, round_flag->answer, 1, tolerance, &oPoints, &iPoints, &inner_count);
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c 2008-06-30 15:27:31 UTC (rev 31901)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c 2008-06-30 18:15:40 UTC (rev 31902)
@@ -493,8 +493,11 @@
wx = vx;
wy = vy;
- i = nPoints->n_points - 1;
- Vect_line_insert_point(nPoints, 0, nPoints->x[i], nPoints->y[i], 0);
+ if (looped) {
+ i = nPoints->n_points - 1;
+ Vect_line_insert_point(nPoints, 0, nPoints->x[i], nPoints->y[i], 0);
Vect_line_prune ( nPoints );
