[GRASS-SVN] r31905 - in grass/branches/develbranch_6/scripts:
v.db.addcol v.db.addtable
svn_grass at osgeo.org
Mon Jun 30 16:27:16 EDT 2008
Author: neteler
Date: 2008-06-30 16:27:15 -0400 (Mon, 30 Jun 2008)
New Revision: 31905
grass/branches/develbranch_6/scripts/v.db.addcol/description.html
grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
grass/branches/develbranch_6/scripts/v.db.addtable/description.html
grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
Changed help messages to adapt the SQL2003 specification (DOUBLE => DOUBLE PRECISION) (merge from trunk)
Modified: grass/branches/develbranch_6/scripts/v.db.addcol/description.html
--- grass/branches/develbranch_6/scripts/v.db.addcol/description.html 2008-06-30 18:43:10 UTC (rev 31904)
+++ grass/branches/develbranch_6/scripts/v.db.addcol/description.html 2008-06-30 20:27:15 UTC (rev 31905)
@@ -1,16 +1,16 @@
<h2>DESCRIPTION</h2>
-<em>v.db.addcol</em> adds one or more column(s) to the attribute table connected
-to a given vector map. It automatically checks the connection for the specified
-layer.
+<em>v.db.addcol</em> adds one or more column(s) to the attribute table
+connected to a given vector map. It automatically checks the connection for the
+specified layer.
<h2>NOTES</h2>
v.db.addcol is a front-end to <em>db.execute</em> to allow easier usage.
-The supported types of columns depend on the database backend. However,
-all backends should support VARCHAR, INT, DOUBLE/REAL and DATE. The default dbf backend
-supports only these types.
+The supported types of columns depend on the database backend. However, all
+backends should support VARCHAR, INT, DOUBLE PRECISION and DATE. The default
+dbf backend supports only these types.
The existing database connection(s) can be verified with <em>v.db.connect</em>.
Modified: grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol
--- grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2008-06-30 18:43:10 UTC (rev 31904)
+++ grass/branches/develbranch_6/scripts/v.db.addcol/v.db.addcol 2008-06-30 20:27:15 UTC (rev 31905)
@@ -40,7 +40,7 @@
#%option
#% key: columns
#% type: string
-#% description: Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE and DATE)
+#% description: Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)
#% required : yes
#%end
Modified: grass/branches/develbranch_6/scripts/v.db.addtable/description.html
--- grass/branches/develbranch_6/scripts/v.db.addtable/description.html 2008-06-30 18:43:10 UTC (rev 31904)
+++ grass/branches/develbranch_6/scripts/v.db.addtable/description.html 2008-06-30 20:27:15 UTC (rev 31905)
@@ -1,17 +1,18 @@
-<em>v.db.addtable</em> creates and adds a new attribute table to a given vector map. It
-links the table to the specified layer of the vector map. If the vector map
-is not yet linked to any table, new a database link is established based
-on the MAPSET database settings (see <em>db.connect</em>).
+<em>v.db.addtable</em> creates and adds a new attribute table to a given vector
+map. It links the table to the specified layer of the vector map. If the vector
+map is not yet linked to any table, new a database link is established based on
+the MAPSET database settings (see <em>db.connect</em>).
<h2>NOTES</h2>
-<em>v.db.addtable</em> is a front-end to <em>db.execute</em> to allow easier usage.
+<em>v.db.addtable</em> is a front-end to <em>db.execute</em> to allow easier
+usage.
-all backends should support VARCHAR, INT, DOUBLE and DATE. The default dbf backend
@@ -19,7 +20,7 @@
Adding a new attribute table with a single column to default layer 1:<br>
<div class="code"><pre>
-v.db.addtable sentiero_brenta_points columns="slope double"
+v.db.addtable sentiero_brenta_points columns="slope double precision"
v.db.connect -p sentiero_brenta_points
v.info -c sentiero_brenta_points
</pre></div>
@@ -27,7 +28,7 @@
<p>
Adding a new attribute table with two columns to layer 2:<br>
-v.db.addtable sentiero_brenta_points columns="slope double,myname varchar(15)" layer=2
+v.db.addtable sentiero_brenta_points columns="slope double precision,myname varchar(15)" layer=2
</pre></div>
Modified: grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable
--- grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable 2008-06-30 18:43:10 UTC (rev 31904)
+++ grass/branches/develbranch_6/scripts/v.db.addtable/v.db.addtable 2008-06-30 20:27:15 UTC (rev 31905)
@@ -41,7 +41,7 @@
#%option
#% key: columns
#% type: string
#% answer: cat integer
#% required : no
#% multiple : yes
