[GRASS-SVN] r30411 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sat Mar 1 04:13:29 EST 2008
Author: martinl
Date: 2008-03-01 04:13:28 -0500 (Sat, 01 Mar 2008)
New Revision: 30411
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: User settings dialog reorganized, new tab for 'display', item for 'Overlay rasters'
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-01 03:38:38 UTC (rev 30410)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-03-01 09:13:28 UTC (rev 30411)
@@ -45,67 +45,73 @@
# general
'general': {
- 'displayFont' : { 'value' : '' },
- 'mapsetPath' : { 'value' : 'p' }, # current mapset search path
+ 'mapsetPath' : { 'value' : 'p' }, # current mapset search path
+ # display
+ 'display': {
+ 'displayFont' : { 'value' : '' },
+ 'rasterOverlay' : { 'enabled' : False },
# advanced
'advanced' : {
- 'settingsFile' : { 'value' : 'gisdbase' }, # gisdbase, location, mapset
- 'digitInterface' : { 'value' : 'vdigit' }, # vedit, vdigit
- 'iconTheme' : { 'value' : 'silk' }, # grass, silk
+ 'settingsFile' : { 'value' : 'gisdbase' }, # gisdbase, location, mapset
+ 'digitInterface' : { 'value' : 'vdigit' }, # vedit, vdigit
+ 'iconTheme' : { 'value' : 'silk' }, # grass, silk
# vdigit
'vdigit' : {
- # symbology
- 'symbolHighlight' : { 'enabled' : None, 'color' : (255, 255, 0, 255) }, #yellow
- 'symbolPoint' : { 'enabled' : True, 'color' : (0, 0, 0, 255) }, # black
- 'symbolLine' : { 'enabled' : True, 'color' : (0, 0, 0, 255) }, # black
- 'symbolBoundaryNo' : { 'enabled' : True, 'color' : (126, 126, 126, 255) }, # grey
- 'symbolBoundaryOne' : { 'enabled' : True, 'color' : (0, 255, 0, 255) }, # green
- 'symbolBoundaryTwo' : { 'enabled' : True, 'color' : (255, 135, 0, 255) }, # orange
- 'symbolCentroidIn' : { 'enabled' : True, 'color' : (0, 0, 255, 255) }, # blue
- 'symbolCentroidOut' : { 'enabled' : True, 'color' : (165, 42, 42, 255) }, # brown
- 'symbolCentroidDup' : { 'enabled' : True, 'color' : (156, 62, 206, 255) }, # violet
- 'symbolNodeOne' : { 'enabled' : True, 'color' : (255, 0, 0, 255) }, # red
- 'symbolNodeTwo' : { 'enabled' : True, 'color' : (0, 86, 45, 255) }, # dark green
- 'symbolVertex' : { 'enabled' : False, 'color' : (255, 20, 147, 255) }, # deep pink
- # display
- 'lineWidth' : { 'value' : 2, 'units' : 'screen pixels' },
- # snapping
- 'snapping' : { 'value' : 10, 'units' : 'screen pixels' },
- 'snapToVertex' : { 'enabled' : False },
- 'backgroundMap' : {'value' : ''},
- # digitize new record
- 'addRecord' : { 'enabled' : True },
- 'layer' : {'value' : 1 },
- 'category' : {'value' : 1 },
- 'categoryMode' : {'value' : 'Next to use' },
- # delete existing feature(s)
- 'delRecord' : { 'enabled' : True },
- # query tool
- 'query' : { 'type' : 'length', 'box' : True },
- 'queryLength' : { 'than' : 'shorter than', 'thresh' : 0 },
- 'queryDangle' : { 'than' : 'shorter than', 'thresh' : 0 },
- # select feature (point, line, centroid, boundary)
- 'selectFeaturePoint' : { 'enabled' : True },
- 'selectFeatureLine' : { 'enabled' : True },
- 'selectFeatureCentroid' : { 'enabled' : True },
- 'selectFeatureBoundary' : { 'enabled' : True },
- 'selectThresh' : { 'value' : 10, 'units' : 'screen pixels'},
+ # symbology
+ 'symbolHighlight' : { 'enabled' : None, 'color' : (255, 255, 0, 255) }, #yellow
+ 'symbolPoint' : { 'enabled' : True, 'color' : (0, 0, 0, 255) }, # black
+ 'symbolLine' : { 'enabled' : True, 'color' : (0, 0, 0, 255) }, # black
+ 'symbolBoundaryNo' : { 'enabled' : True, 'color' : (126, 126, 126, 255) }, # grey
+ 'symbolBoundaryOne' : { 'enabled' : True, 'color' : (0, 255, 0, 255) }, # green
+ 'symbolBoundaryTwo' : { 'enabled' : True, 'color' : (255, 135, 0, 255) }, # orange
+ 'symbolCentroidIn' : { 'enabled' : True, 'color' : (0, 0, 255, 255) }, # blue
+ 'symbolCentroidOut' : { 'enabled' : True, 'color' : (165, 42, 42, 255) }, # brown
+ 'symbolCentroidDup' : { 'enabled' : True, 'color' : (156, 62, 206, 255) }, # violet
+ 'symbolNodeOne' : { 'enabled' : True, 'color' : (255, 0, 0, 255) }, # red
+ 'symbolNodeTwo' : { 'enabled' : True, 'color' : (0, 86, 45, 255) }, # dark green
+ 'symbolVertex' : { 'enabled' : False, 'color' : (255, 20, 147, 255) }, # deep pink
+ # display
+ 'lineWidth' : { 'value' : 2, 'units' : 'screen pixels' },
+ # snapping
+ 'snapping' : { 'value' : 10, 'units' : 'screen pixels' },
+ 'snapToVertex' : { 'enabled' : False },
+ 'backgroundMap' : {'value' : ''},
+ # digitize new record
+ 'addRecord' : { 'enabled' : True },
+ 'layer' : {'value' : 1 },
+ 'category' : {'value' : 1 },
+ 'categoryMode' : {'value' : 'Next to use' },
+ # delete existing feature(s)
+ 'delRecord' : { 'enabled' : True },
+ # query tool
+ 'query' : { 'type' : 'length', 'box' : True },
+ 'queryLength' : { 'than' : 'shorter than', 'thresh' : 0 },
+ 'queryDangle' : { 'than' : 'shorter than', 'thresh' : 0 },
+ # select feature (point, line, centroid, boundary)
+ 'selectFeaturePoint' : { 'enabled' : True },
+ 'selectFeatureLine' : { 'enabled' : True },
+ 'selectFeatureCentroid' : { 'enabled' : True },
+ 'selectFeatureBoundary' : { 'enabled' : True },
+ 'selectThresh' : { 'value' : 10, 'units' : 'screen pixels'},
# user settings
self.userSettings = copy.deepcopy(self.defaultSettings)
try:
self.ReadSettingsFile()
- except gcmd.GException, e:
- raise gcmd.SettingsError(_('Reading settings failed\n\n%s.'), e)
+ except gcmd.SettingsError, e:
+ print >> sys.stderr, e.message
# internal settings (based on user settings)
self.internalSettings = {}
self.internalSettings['general'] = {}
@@ -248,19 +254,15 @@
else:
settings = self.userSettings
- if settings.has_key(group) and settings[group].has_key(key):
+ try:
if subkey is None:
return settings[group][key]
else:
- if settings[group][key].has_key(subkey):
- return settings[group][key][subkey]
- else:
- raise KeyError
- else:
- raise KeyError
+ return settings[group][key][subkey]
+ except KeyError:
+ raise gcmd.SettingsError(_("Unable to get value of '%s:%s:%s'.") %
+ (group, key, subkey))
- return None
def Set(self, group, key, subkey, value, internal=False):
"""Set value by key/subkey
@@ -275,18 +277,17 @@
settings = self.internalSettings
else:
- if settings.has_key(group) and settings[group].has_key(key) and \
- settings[group][key].has_key(subkey):
+ try:
settings[group][key][subkey] = value
- else:
- raise KeyError
+ except KeyError:
+ raise gcmd.SettingsError(_("Unable to set '%s:%s:%s'") % (group, key, subkey))
globalSettings = Settings()
class PreferencesDialog(wx.Dialog):
"""User preferences dialog"""
- def __init__(self, parent, title,
+ def __init__(self, parent, title=_("User settings"),
settings=globalSettings,
style=wx.DEFAULT_DIALOG_STYLE):
self.parent = parent # GMFrame
@@ -300,26 +301,29 @@
# create notebook pages
self.__CreateGeneralPage(notebook)
+ self.__CreateDisplayPage(notebook)
self.__CreateAdvancedPage(notebook)
# buttons
btnSave = wx.Button(self, wx.ID_SAVE)
btnApply = wx.Button(self, wx.ID_APPLY)
btnCancel = wx.Button(self, wx.ID_CANCEL)
- # btnOk = wx.Button(self, wx.ID_OK)
btnSave.SetDefault()
# bindigs
btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+ btnApply.SetToolTipString(_("Apply changes for this session"))
btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+ btnSave.SetToolTipString(_("Close window and save changes to user settings file"))
+ btnSave.SetDefault()
btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
+ btnCancel.SetToolTipString(_("Close window and ignore changes"))
# sizers
btnSizer = wx.StdDialogButtonSizer()
btnSizer.AddButton(btnCancel)
btnSizer.AddButton(btnSave)
btnSizer.AddButton(btnApply)
- # btnSizer.AddButton(btnOk)
btnSizer.Realize()
mainSizer = wx.BoxSizer(wx.VERTICAL)
@@ -343,33 +347,14 @@
gridSizer.AddGrowableCol(0)
- # display font
+ # mapsets path
+ row = 0
gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Default font for GRASS displays:")),
- flag=wx.ALIGN_LEFT |
- wx.ALIGN_CENTER_VERTICAL,
- pos=(0, 0))
- fontButton = wx.Button(parent=panel, id=wx.ID_ANY,
- label=_("Set font"), size=(100, -1))
- gridSizer.Add(item=fontButton,
- flag=wx.ALIGN_RIGHT |
- pos=(0, 1))
- gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Currently selected font:")),
- pos=(1, 0), span=(1, 2))
- # mapsets path
label=_("Mapsets path:")),
- pos=(2, 0))
+ pos=(row, 0))
self.mapsetPath = wx.Choice(parent=panel, id=wx.ID_ANY, size=(200, -1),
choices=['mapset search path', 'all available mapsets'])
if self.settings.Get(group='general', key='mapsetPath', subkey='value') == 'p':
@@ -379,7 +364,7 @@
gridSizer.Add(item=self.mapsetPath,
- pos=(2, 1))
+ pos=(row, 1))
sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=3)
@@ -387,11 +372,70 @@
panel.SetSizer(border)
# bindings
- fontButton.Bind(wx.EVT_BUTTON, self.OnSetFont)
self.mapsetPath.Bind(wx.EVT_CHOICE, self.OnChangeMapsetPath)
return panel
+ def __CreateDisplayPage(self, notebook):
+ """Create notebook page concerning with symbology settings"""
+ panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
+ notebook.AddPage(page=panel, text=_("Display"))
+ border = wx.BoxSizer(wx.VERTICAL)
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Font settings"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
+ gridSizer.AddGrowableCol(0)
+ # font settings
+ row = 0
+ gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
+ label=_("Default font for GRASS displays:")),
+ flag=wx.ALIGN_LEFT |
+ wx.ALIGN_CENTER_VERTICAL,
+ pos=(row, 0))
+ fontButton = wx.Button(parent=panel, id=wx.ID_ANY,
+ label=_("Set font"), size=(100, -1))
+ gridSizer.Add(item=fontButton,
+ flag=wx.ALIGN_RIGHT |
+ pos=(row, 1))
+ sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+ border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
+ # raster settings
+ box = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Raster settings"))
+ # raster overlay
+ row = 0
+ self.rasterOverlay = wx.CheckBox(parent=panel, id=wx.ID_ANY,
+ label=_("Overlay raster map layers"))
+ self.rasterOverlay.SetValue(self.settings.Get(group='display', key='rasterOverlay', subkey='enabled'))
+ gridSizer.Add(item=self.rasterOverlay,
+ pos=(row, 0), span=(1, 2))
+ border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
+ panel.SetSizer(border)
+ # bindings
+ fontButton.Bind(wx.EVT_BUTTON, self.OnSetFont)
+ return panel
def __CreateAdvancedPage(self, notebook):
@@ -541,17 +585,24 @@
def __UpdateSettings(self):
"""Update user settings"""
- # font
- # TODO
+ # display
# location
- self.settings.Set(group='advanced', key='settingsFile', subkey='value', value=self.settingsFile.GetStringSelection())
+ self.settings.Set(group='display', key='rasterOverlay', subkey='enabled',
+ value=self.rasterOverlay.IsChecked())
+ # advanced
+ # location
+ self.settings.Set(group='advanced', key='settingsFile', subkey='value',
+ value=self.settingsFile.GetStringSelection())
# icon theme
- self.settings.Set(group='advanced', key='iconTheme', subkey='value', value=self.iconTheme.GetStringSelection())
+ self.settings.Set(group='advanced', key='iconTheme', subkey='value',
+ value=self.iconTheme.GetStringSelection())
# digitization interface
- self.settings.Set(group='advanced', key='digitInterface', subkey='value', value=self.digitInterface.GetStringSelection())
+ self.settings.Set(group='advanced', key='digitInterface', subkey='value',
+ value=self.digitInterface.GetStringSelection())
class SetDefaultFont(wx.Dialog):
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-01 03:38:38 UTC (rev 30410)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-03-01 09:13:28 UTC (rev 30411)
@@ -558,7 +558,10 @@
parentframe=self, show=show)
self.GetPyData(layer)[0]['cmd'] = cmdValidated
elif ltype == 'raster':
- menuform.GUI().ParseCommand(['d.rast'], completed=(self.GetOptData,layer,params),
+ cmd = ['d.rast']
+ if UserSettings.Get(group='display', key='rasterOverlay', subkey='enabled'):
+ cmd.append('-o')
+ menuform.GUI().ParseCommand(cmd, completed=(self.GetOptData,layer,params),
parentframe=self)
elif ltype == 'rgb':
menuform.GUI().ParseCommand(['d.rgb'], completed=(self.GetOptData,layer,params),
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-03-01 03:38:38 UTC (rev 30410)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-03-01 09:13:28 UTC (rev 30411)
@@ -856,7 +856,7 @@
def OnPreferences(self, event):
"""General GUI preferences/settings"""
- preferences.PreferencesDialog(parent=self, title=_("User preferences")).ShowModal()
+ preferences.PreferencesDialog(parent=self).ShowModal()
def DispHistogram(self, event):
